help webscripts and portlets
kocoubb
Any tell me how incorporate an alfresco webscript as portlet, i create a portlet.xml archive in alfresco WEB-INF/, but no work,
Thx
kocoubb
I incoporate alfresco webscript as jboss portlet using portlet Bridge, but i have a problem with the alfresco authentication, any idea to fix this problem.
the message in the portlet.
State HTTP 401 -
message
Description this requeriment requires HTTP () authentication.
thanks
openpj
Elite Collaborator
Elite Collaborator
You don't need to use a portlet bridge to expose an Alfresco WebScript as a portlet, here you can find one of my posts about this integration:
http://forums.alfresco.com/en/viewtopic.php?f=36&t=15117
You must define only authentication rules (portlet parameters) and settings in Alfresco portlet.xml.
Hope this helps.
