Exception while initializing process engine
luisalves00
I'm creating the ProcessEngine like this:
ProcessEngine processEngine = ProcessEngineConfiguration
                    .createStandaloneProcessEngineConfiguration()
                    .setJdbcUrl(…..
                    .setHistory("audit")
                    .setProcessEngineName(ACTIVITI_ENGINE_NAME)
                    .buildProcessEngine();
then when I issue this:
ProcessEngines.getProcessEngine(ACTIVITI_ENGINE_NAME);
I get this exception:
11:05:08,137 ERROR ProcessEngines:157 - Exception while initializing process engine :No bean named 'processEngineConfiguration' is defined
why? do I still need the activiti.cfg.xml?!?!
jbarrez
The ProcessEngines class is usable when you have (one or more) activiti.cfg.xml files on the classpath.
Just put your ProcessEngine you create programmatically in a static member, the end result is the same.
