Exception while initializing process engine Can't debug
Options
02-15-2011 06:43 AM
I am trying to initialize the activiti engine through a jsp scriptlet and I keep receiving this error from the console :
INFO: Exception while initializing process engine
rg/springframework/beans/factory/support/BeanDefinitionRegistry
when I try to debug I manage to dig until the following call inside the file : ProcessEngines.class :
private static ProcessEngine buildProcessEngine(URL resource) {
InputStream inputStream = null;
try {
inputStream = resource.openStream();
ProcessEngineConfiguration processEngineConfiguration = ProcessEngineConfiguration.createProcessEngineConfigurationFromInputStream(inputStream);
return processEngineConfiguration.buildProcessEngine();
} catch (IOException e) {
throw new ActivitiException("couldn't open resource stream: "+e.getMessage(), e);
} finally {
IoUtil.closeSilently(inputStream);
The problem is that I can't step into .createProcessEngineConfigurationFromInputStream(inputStream);
to find out what is going on, because when hitting "step into" the debugger jumps to the finally section.
( I have already tried to enable breakpoints inside the function createProcessEngineConfigurationFromInputStream ) it just keeps moving on to the finally section.
Apparently another exception is being fired…other than IOException. I can't see clearly what the exception is because this call : createProcessEngineConfigurationFromInputStream does not throws any exception
Thank you for your time!
try {
} finally {
Labels:
Archive
11 REPLIES 11
Options
10-30-2014 01:59 PM
I'm getting this same error. I am new to JAVA and programming. I am looking for help, please.
<code>
java.lang.NoClassDefFoundError: org/springframework/core/io/Resource
at org.activiti.engine.ProcessEngineConfiguration.createProcessEngineConfigurationFromResource(ProcessEngineConfiguration.java:212)
at org.activiti.engine.ProcessEngineConfiguration.createProcessEngineConfigurationFromResource(ProcessEngineConfiguration.java:208)
at org.activiti.engine.impl.test.TestHelper.getProcessEngine(TestHelper.java:232)
at org.activiti.engine.test.ActivitiRule.initializeProcessEngine(ActivitiRule.java:237)
at org.activiti.engine.test.ActivitiRule.starting(ActivitiRule.java:205)
at org.activiti.engine.test.ActivitiRule.startingQuietly(ActivitiRule.java:171)
at org.activiti.engine.test.ActivitiRule.access$000(ActivitiRule.java:86)
at org.activiti.engine.test.ActivitiRule$1.evaluate(ActivitiRule.java:124)
at org.junit.rules.RunRules.evaluate(RunRules.java:20)
at org.junit.runners.ParentRunner.runLeaf(ParentRunner.java:271)
at org.junit.runners.BlockJUnit4ClassRunner.runChild(BlockJUnit4ClassRunner.java:70)
at org.junit.runners.BlockJUnit4ClassRunner.runChild(BlockJUnit4ClassRunner.java:50)
at org.junit.runners.ParentRunner$3.run(ParentRunner.java:238)
at org.junit.runners.ParentRunner$1.schedule(ParentRunner.java:63)
at org.junit.runners.ParentRunner.runChildren(ParentRunner.java:236)
at org.junit.runners.ParentRunner.access$000(ParentRunner.java:53)
at org.junit.runners.ParentRunner$2.evaluate(ParentRunner.java:229)
at org.junit.runners.ParentRunner.run(ParentRunner.java:309)
at org.eclipse.jdt.internal.junit4.runner.JUnit4TestReference.run(JUnit4TestReference.java:50)
at org.eclipse.jdt.internal.junit.runner.TestExecution.run(TestExecution.java:38)
at org.eclipse.jdt.internal.junit.runner.RemoteTestRunner.runTests(RemoteTestRunner.java:459)
at org.eclipse.jdt.internal.junit.runner.RemoteTestRunner.runTests(RemoteTestRunner.java:675)
at org.eclipse.jdt.internal.junit.runner.RemoteTestRunner.run(RemoteTestRunner.java:382)
at org.eclipse.jdt.internal.junit.runner.RemoteTestRunner.main(RemoteTestRunner.java:192)
Caused by: java.lang.ClassNotFoundException: org.springframework.core.io.Resource
at java.net.URLClassLoader$1.run(Unknown Source)
at java.net.URLClassLoader.findClass(Unknown Source)
at java.lang.ClassLoader.loadClass(Unknown Source)
at sun.misc.Launcher$AppClassLoader.loadClass(Unknown Source)
… 24 more
at org.activiti.designer.test.ProcessTestMyProcess.startProcess(ProcessTestMyProcess.java:27)
at org.junit.runners.model.FrameworkMethod$1.runReflectiveCall(FrameworkMethod.java:47)
at org.junit.internal.runners.model.ReflectiveCallable.run(ReflectiveCallable.java:12)
at org.junit.runners.model.FrameworkMethod.invokeExplosively(FrameworkMethod.java:44)
at org.junit.internal.runners.statements.InvokeMethod.evaluate(InvokeMethod.java:17)
at org.activiti.engine.test.ActivitiRule$1.evaluate(ActivitiRule.java:126)
at org.activiti.engine.test.ActivitiRule.finished(ActivitiRule.java:273)
at org.activiti.engine.test.ActivitiRule.finishedQuietly(ActivitiRule.java:179)
at org.activiti.engine.test.ActivitiRule.access$400(ActivitiRule.java:86)
at org.activiti.engine.test.ActivitiRule$1.evaluate(ActivitiRule.java:135)
<code>
<code>
… 24 more
<code>
Options
11-18-2014 02:11 PM
Are you using Maven? If so, the class should be automatically on your classpath.
If you are not using a dependency mgmt system like Maven, you need to make sure the jar with the class is on your classpath. The error tells you that 'org/springframework/core/io/Resource' is *not* on the classpath.
