Enterprise 3.0 with ldap + cifs(passthru) problem
tgck
HI all,
while the ldap configuration is working, the cifs server does not accept the passthru authenticator.
In file-server.xml  for cifs I changed the enterprise authenticator to passthru
     <!– CIFS authentication –>
       <authenticator type="passthru">
          <Server>sambaServer</Server>
      </authenticator>
log4j says:
16:01:46,209 DEBUG [org.alfresco.fileserver] [SMB] CIFS Server gollumA starting
16:01:46,211 DEBUG [org.alfresco.fileserver] [SMB] Version 5.0.0 [beta], Java VM 11.0-b15, OS SunOS, version 5.10
16:01:46,211 DEBUG [org.alfresco.fileserver] [SMB] Using authenticator org.alfresco.filesys.auth.cifs.PassthruCifsAuthenticator, mode=USER
16:01:46,211 DEBUG [org.alfresco.fileserver] [SMB] Server timezone offset = 0hrs
16:01:46,211 DEBUG [org.alfresco.fileserver] [SMB] Dialects enabled = [Core,CorePlus,DOS LANMAN 1.0,LANMAN1.0,DOS LANMAN 2.1,LM1.2X002,LANMAN2.1,NT LM 0.12]
16:01:46,211 DEBUG [org.alfresco.fileserver] [SMB] Shares:
16:01:46,215 DEBUG [org.alfresco.fileserver] [SMB]  [Alfresco,DISK,,[Alfresco]] [Alfresco]
16:01:46,215 DEBUG [org.alfresco.fileserver] [SMB]  [AVM,DISK,,[AVM]] [AVM]
16:01:46,217 DEBUG [org.alfresco.fileserver] [SMB] Added NTServer flag to host announcement
16:01:46,223 DEBUG [org.alfresco.fileserver] [SMB] Server error : org.alfresco.jlan.server.config.InvalidConfigurationException: Error initializing TCP-IP SMB session handler, Permission denied
I did not change anything else for the cifs server.
Maybe anyone has a hint  for a proper configuration?
Thank you.
Torsten
tgck
As everyone has expected the problem was an access to privileged ports by a normal user.
I granted access to these ports and now I get the following information:
DEBUG [org.alfresco.smb.protocol.auth]   No PassthruDetails for T1
Also there is no activity on the net to the server given to the passthru authenticator.
What are these passthru details needed?
I am running alfresco Enterprise 3.0 on Solaris 10u5 x86
Torsten
steve
If you are running the Enterprise version you should contact Alfresco Support to help resolve your issues.
Steve
