Document preview problem was fixed by changing libreoffice's ctl.sh to libreoffice_ctl.sh
billydekid
I just want to share how to fix the problem of document preview which sometimes not fully functional on loading some of certain files.
I use Alfresco 5.0.a on Ubuntu 14.04.
One of the problem occurred when opening .docx files.
Document preview just showing a thumbnail image instead of full frame of document viewer.
The problem can be solved by changing libreoffice's ctl script in alfresco.sh; from ctl.sh to libreoffice_ctl.sh (since ctl.sh is not exist on libreoffice's script dir).
OLD:
LIBREOFFICE_SCRIPT=$INSTALLDIR/libreoffice/scripts/ctl.sh
NEW
LIBREOFFICE_SCRIPT=$INSTALLDIR/libreoffice/scripts/libreoffice_ctl.sh
Next I restarted Alfresco and problem is solved! Smiley Happy
Document viewer frame is appear instead of document thumbnail image…
Regards,
[bayu]
luceros
Hi, I resolve this problem changing the path of libreoffice installation on alfresco-global.properties.
ooo.exe=/opt/alfresco-community/libreoffice/program/soffice.bin
to
ooo.exe=/usr/bin/soffice
then I restart alfresco service et voilà.
You must find soffice file on your sistem (this works on linux).
Bye, bye.
21 REPLIES 21
danyfortier
PKnight, have you resolve the problem ?
I have exactly the same problem here. I am running with Alfreso 5.0.d
ok i got it working by restarting tomcat service for now. But still investigating
voula_11
I have the same problem on 5.0.d.
I changed alfresco.sh to point to the correct script, I changed libreoffice_ctl.sh to have the correct paths. Still not working.
When I test for missing libraries as suggested by caolem, I get this:
error while loading shared libraries: libdbus-glib-1.so.2: cannot open shared object file: No such file or directory
So I did a "yum install libdbus-glib-1.so.2" and I got this:
Package dbus-glib-0.86-6.10.amzn1.i686 already installed and latest version
So I guess this means that the package is installed in the wrong directory?
I tried removing it and re-installing it, but it still can't be located.
I really don't know what to do to fix this.
Can anyone help please?
yoyo46
how about in windows? same also?
wags
Thanks for that.  Where is alfresco.sh located under ubuntu 14.04?  I installed using
https://github.com/loftuxab/alfresco-ubuntu-install
anon26949
Thank you for sharing your experience!.. The same problem in Alfresco 5.1 CE.
Hi ‌,
Frankly speaking, this problem is never appear again in 5.1 and 5.2 CE so far, on my environment.
Hi, Bayu Widyasanyata!
It seems that this script is not needed at all... LibreOffice managed by JODConverter.
Hi ‌,
Thank you for issue's link! Then we can "close" this issue for 4.2+ version 🙂
douglascrp
World-Class Innovator
Out of the box, LibreOffice managed by JODConverter is an Enterprise only feature.
If you need it for Community edition, then you will have to use an addon, in this case, this is what you are looking for xenit / alfresco-remote-jodconverter — Bitbucket
