Document preview problem was fixed by changing libreoffice's ctl.sh to libreoffice_ctl.sh
billydekid
I just want to share how to fix the problem of document preview which sometimes not fully functional on loading some of certain files.
I use Alfresco 5.0.a on Ubuntu 14.04.
One of the problem occurred when opening .docx files.
Document preview just showing a thumbnail image instead of full frame of document viewer.
The problem can be solved by changing libreoffice's ctl script in alfresco.sh; from ctl.sh to libreoffice_ctl.sh (since ctl.sh is not exist on libreoffice's script dir).
OLD:
LIBREOFFICE_SCRIPT=$INSTALLDIR/libreoffice/scripts/ctl.sh
NEW
LIBREOFFICE_SCRIPT=$INSTALLDIR/libreoffice/scripts/libreoffice_ctl.sh
Next I restarted Alfresco and problem is solved! Smiley Happy
Document viewer frame is appear instead of document thumbnail image…
Regards,
[bayu]
luceros
Hi, I resolve this problem changing the path of libreoffice installation on alfresco-global.properties.
ooo.exe=/opt/alfresco-community/libreoffice/program/soffice.bin
to
ooo.exe=/usr/bin/soffice
then I restart alfresco service et voilà.
You must find soffice file on your sistem (this works on linux).
Bye, bye.
21 REPLIES 21
caolem
I'm using alfresco 5.0.a with debian, in order to fix the office documents preview I did several steps.
1. check if libreoffice is running
/opt/alfresco-5.0.a/libreoffice/scripts/libreoffice_ctl.sh status
2. edit the file /opt/alfresco-5.0.a/alfresco.sh
modify the line LIBREOFFICE_SCRIPT with the correct script path
3. test for missing libraries
/opt/alfresco-5.0.a/libreoffice/program/soffice.bin –nofirststartwizard –nologo –headless –accept=socket,host=localhost,port=8100
4. install missing libraries (I had missing libxinerama1 and libdbus-glib-1-2)
apt-get install libxinerama1
apt-get install libdbus-glib-1-2
5. try to start opeoffice using the script
/opt/alfresco-5.0.a/libreoffice/scripts/libreoffice_ctl.sh start
6. restart alfresco
/etc/init.d/alfresco restart
7. you must see the line
/opt/alfresco-5.0.a/libreoffice/scripts/libreoffice_ctl.sh : libreoffice started at port 8100
Now previews work perfectly 😉
d_hoang
Thank You caolem. It was exactly my problem. Prevviews work fine now.
fwegener
i'm got the problem that libreoffice isent't running, too. The Problem occurs both with Debian 8 and Ubuntu 14.04. Also i tested with 5.0d and 5.1.
In Share i got only thumbnails with doc-files and a option for downloading file and no preview with docx-files.
i try to test based on your instructions with following result:
–> libreoffice dont run and can't be started
–> i fixed the file but if i restart alfresco, libreoffice can't be started
–> libGl.so1 is missing. Unfortunately it isn't possible to install manually
root@ubuntu:/opt/alfresco-community/libreoffice/scripts# apt-get install  libGl.so.1
Reading package lists… Done
Building dependency tree
Reading state information… Done
E: Unable to locate package libGl.so.1
E: Couldn't find any package by regex 'libGl.so.1'
furthermore the linux-version has no gui.
–>not possible. look at 3
–> libreoffice wont start because i am not able to fix 3 & 4
6. restart alfresco
Sry for my bad english guys Smiley Wink Hope anyone can help me.
Thanks a lot
Florian
boiss007
just fyi, instead of blindly using ,
#apt-get install libGl.so.1
first use a sudo enabled user, not root (best practice), then do :
sudo apt-get update
apt-cache search libgl
and you will find the necessary libraries to install.
mkpelletier
Hello all!  Thanks for the info here. It has helped me some.
I followed your instructions, @caolem, and made some progress from the default install, however I now get:
12:28:45,009 ERROR [org.springframework.extensions.webscripts.AbstractRuntime] [http-bio-8443-exec-4] Exception from executeScript - redirecting to status template error: connection failed: socket,host=127.0.0.1,port=8100,tcpNoDelay=1; com.sun.star.lang.IllegalArgumentException
net.sf.jooreports.openoffice.connection.OpenOfficeException: connection failed: socket,host=127.0.0.1,port=8100,tcpNoDelay=1; com.sun.star.lang.IllegalArgumentException
   at net.sf.jooreports.openoffice.connection.AbstractOpenOfficeConnection.connect(AbstractOpenOfficeConnection.java:77)
   at org.alfresco.util.OpenOfficeConnectionTester.testAndConnect(OpenOfficeConnectionTester.java:183)
   at org.alfresco.util.OpenOfficeConnectionTester.checkConnection(OpenOfficeConnectionTester.java:129)
   at org.alfresco.util.OpenOfficeConnectionTester.onBootstrap(OpenOfficeConnectionTester.java:101)
   at org.springframework.context.event.SimpleApplicationEventMulticaster.multicastEvent(SimpleApplicationEventMulticaster.java:96)
   at org.alfresco.repo.management.subsystems.ChildApplicationContextFactory$ChildApplicationContext.publishEvent(ChildApplicationContextFactory.java:554)
   at org.springframework.context.support.AbstractApplicationContext.finishRefresh(AbstractApplicationContext.java:948)
   at org.springframework.context.support.AbstractApplicationContext.refresh(AbstractApplicationContext.java:482)
   at org.alfresco.repo.management.subsystems.ChildApplicationContextFactory$ApplicationContextState.start(ChildApplicationContextFactory.java:809)
   at org.alfresco.repo.management.subsystems.AbstractPropertyBackedBean.start(AbstractPropertyBackedBean.java:991)
   at org.alfresco.repo.management.subsystems.AbstractPropertyBackedBean.onApplicationEvent(AbstractPropertyBackedBean.java:530)
   at org.alfresco.repo.management.SafeApplicationEventMulticaster.multicastEventInternal(SafeApplicationEventMulticaster.java:209)
   at org.alfresco.repo.management.SafeApplicationEventMulticaster.multicastEvent(SafeApplicationEventMulticaster.java:180)
   at org.springframework.context.support.AbstractApplicationContext.publishEvent(AbstractApplicationContext.java:334)
   at org.springframework.web.context.ContextLoader.configureAndRefreshWebApplicationContext(ContextLoader.java:410)
   at org.springframework.web.context.ContextLoader.initWebApplicationContext(ContextLoader.java:306)
   at org.springframework.web.context.ContextLoaderListener.contextInitialized(ContextLoaderListener.java:112)
   at org.apache.catalina.core.StandardContext.listenerStart(StandardContext.java:4973)
   at org.apache.catalina.core.StandardContext.startInternal(StandardContext.java:5467)
   at org.apache.catalina.core.ContainerBase.addChildInternal(ContainerBase.java:901)
   at org.apache.catalina.core.ContainerBase.addChild(ContainerBase.java:877)
   at org.apache.catalina.core.StandardHost.addChild(StandardHost.java:632)
   at org.apache.catalina.startup.HostConfig.deployWAR(HostConfig.java:1073)
   at org.apache.catalina.startup.HostConfig$DeployWar.run(HostConfig.java:1857)
   at java.util.concurrent.Executors$RunnableAdapter.call(Unknown Source)
   at java.util.concurrent.FutureTask.run(Unknown Source)
This seems to only happen when using MySQL rather than the default postgresql.
loruam
Great Billythekid!!! It´s a week that i can't resolv this issue. Your solition work fine! Tks
arannasousa
In alfresco 5.0.c, was having connection problems between the alfresco and libreoffice.
In the file:
<alfresco> /libreoffice/scripts/libreoffice_ctl.sh
before:
Soffice="$SOFFICEWRAPPER –nofirststartwizard –nologo –headless –accept=socket,host=localhost,port=$
SOFFICE_PORT\;urp\;StarOffice.ServiceManager"
After (remove "\"):
Soffice="$SOFFICEWRAPPER –nofirststartwizard –nologo –headless –accept=socket,host=localhost,port=$SOFFICE_PORT;urp;StarOffice.ServiceManager"
This solve the problem for me. Kudos.
pknight
Does anyone know how to resolve this problem with Alfresco running on Windows server?
I can preview pdf's without issue but office docs won't display
