difference between alfresco sdk and alfresco svn
cherifalfresco
Hello dear predecessors, I debuted on alfresco maintanant, I was looking for the source code to customize alfresco and saw I could get a tutorial that showed me how to download it from subversion and I fait.Mais I want to understand the difference between the SDK and source code download by svn. thank you to you
mrogers
The SDK are some resources provided to allow you to code extensions to alfresco without needing to build alfresco.
Subversion is a resource control system that allows you to obtain the source code for alfresco (including the SDK).
