difference beetwen Current and Installed Versione
nicola_raglia
i made a porting of 2.1.3 repository (alf_data and database) to 3.0 lab. All is go fine.
At the end of my startup log i can read this row :
UserSmiley Frustratedystem INFO  [service.descriptor.DescriptorService] Alfresco started (Labs): Current version 3.0.0 (e dev 1606) schema 2000 - Installed version 2.1.3 (e dev xxx) schema xxx.
Why , did i have as Current Version the 3.0.0 and as Installed Version 2.1.3 , and not for someone 3.0.0 as value ?
Tanks at all.
Nicola
mikeh
Just read it as "You are currently running 3.0.0 and you originally installed 2.1.3". It's just for information and matches exactly what you've upgraded from/to.
Mike
nicola_raglia
thank, thanks a lot.
Nicola.
