Hi, i´m using JBoss to deploy alfresco, and a SQL Server 2005 database..
1) i have already a database with name alfresco in SQL Server
2) i have copy the sqljdbc.jar to /Jboss/server/default/lib
3) i change my repository.properties to:
# Database configuration
db.schema.update=true
db.driver=com.microsoft.sqlserver.jdbc.SQLServerDriver
db.name=alfresco
db.url=jdbc:sqlserver://localhost:1433;databaseName=${db.name}
db.username=alfresco
db.password=alfresco
db.pool.initial=10
db.pool.max=20
4) i change file hibernate-cfg.properties to:
hibernate.dialect=org.hibernate.dialect.SQLServerDialect
but when i try to deploy the war…i get this error….
ERROR [JDBCExceptionReporter] Cannot create PoolableConnectionFactory (The TCP/IP connection to host has failed. java.net.ConnectException: Connection refused: connect)
what is wrong? can you help me? its really urgent….
thanks
