after months of perfect use, my alfresco server seems to misfire…
in apache log I start to see a lot of errors like those below.
alfresce is used as repository and browsed from a typo3 CMS via cmis and everything seems ok, but I have those errors and I would not something terrible was going to happen….
error log
2014-04-11 10:45:17,686  ERROR [extensions.webscripts.AbstractRuntime] [http-bio-8080-exec-1] Exception from executeScript - redirecting to status template error: 03110008 Wrapped Exception (with status template): 03110205 Errore durante l'elaborazione del modello 'get(properties) failed on instance of org.alfresco.repo.template.TemplateNode'.$
 org.springframework.extensions.webscripts.WebScriptException: 03110008 Wrapped Exception (with status template): 03110205 Errore durante l'elaborazione del modello 'get(properties) failed on instance of org.alfresco.repo.template.TemplateNode'. Contattare l'amministratore di sistema.
        at org.springframework.extensions.webscripts.AbstractWebScript.createStatusException(AbstractWebScript.java:1067)
        at org.alfresco.repo.web.scripts.RepositoryContainer$3.execute(RepositoryContainer.java:439)
        at org.alfresco.repo.transaction.RetryingTransactionHelper.doInTransaction(RetryingTransactionHelper.java:447)
        at org.alfresco.repo.web.scripts.RepositoryContainer.transactionedExecute(RepositoryContainer.java:508)
        at org.alfresco.repo.web.scripts.RepositoryContainer.transactionedExecuteAs(RepositoryContainer.java:546)
        at org.alfresco.repo.web.scripts.RepositoryContainer.executeScript(RepositoryContainer.java:358)
        at org.springframework.extensions.webscripts.AbstractRuntime.executeScript(AbstractRuntime.java:376)
        at org.springframework.extensions.webscripts.servlet.WebScriptServlet.service(WebScriptServlet.java:132)
        at javax.servlet.http.HttpServlet.service(HttpServlet.java:722)
        at org.apache.catalina.authenticator.AuthenticatorBase.invoke(AuthenticatorBase.java:472)
        at org.apache.catalina.core.StandardHostValve.invoke(StandardHostValve.java:168)
        at org.apache.catalina.valves.ErrorReportValve.invoke(ErrorReportValve.java:99)
        at org.apache.catalina.valves.AccessLogValve.invoke(AccessLogValve.java:929)
        at org.apache.catalina.connector.CoyoteAdapter.service(CoyoteAdapter.java:407)
        at org.apache.coyote.http11.AbstractHttp11Processor.process(AbstractHttp11Processor.java:1002)
        at org.apache.coyote.AbstractProtocol$AbstractConnectionHandler.process(AbstractProtocol.java:585)
        at org.apache.tomcat.util.net.JIoEndpoint$SocketProcessor.run(JIoEndpoint.java:310)
        at java.util.concurrent.ThreadPoolExecutor.runWorker(ThreadPoolExecutor.java:1145)
        at java.lang.Thread.run(Thread.java:724)
Caused by: org.alfresco.service.cmr.repository.TemplateException: 03110205 Errore durante l'elaborazione del modello 'get(properties) failed on instance of org.alfresco.repo.template.TemplateNode'. Contattare l'amministratore di sistema.
        at org.alfresco.repo.template.FreeMarkerProcessor.process(FreeMarkerProcessor.java:222)
        at org.springframework.extensions.webscripts.AbstractWebScript.renderTemplate(AbstractWebScript.java:896)
        at org.springframework.extensions.webscripts.DeclarativeWebScript.renderFormatTemplate(DeclarativeWebScript.java:267)
        at org.springframework.extensions.webscripts.DeclarativeWebScript.execute(DeclarativeWebScript.java:147)
        … 28 more
Caused by: freemarker.template.TemplateModelException: get(properties) failed on instance of org.alfresco.repo.template.TemplateNode
        at freemarker.ext.beans.BeanModel.get(BeanModel.java:224)
        at freemarker.core.Dot._getAsTemplateModel(Dot.java:76)
      at freemarker.core.Dot._getAsTemplateModel(Dot.java:74)
        at freemarker.core.Expression.getAsTemplateModel(Expression.java:89)
        at freemarker.core.DefaultToExpression._getAsTemplateModel(DefaultToExpression.java:100)
        at freemarker.core.Expression.getStringValue(Expression.java:93)
        at freemarker.core.DollarVariable.accept(DollarVariable.java:76)
        at freemarker.core.Environment.visit(Environment.java:221)
        at freemarker.core.MixedContent.accept(MixedContent.java:92)
        at freemarker.core.Environment.visit(Environment.java:406)
        at freemarker.core.BodyInstruction.accept(BodyInstruction.java:93)
        at freemarker.core.Macro$Context.runMacro(Macro.java:172)
        at freemarker.core.Environment.visit(Environment.java:614)
        at freemarker.core.UnifiedCall.accept(UnifiedCall.java:106)
        at freemarker.core.IfBlock.accept(IfBlock.java:82)
        at freemarker.core.Environment.visit(Environment.java:310)
        at freemarker.core.CompressedBlock.accept(CompressedBlock.java:73)
        at freemarker.core.Environment.process(Environment.java:199)
        at org.alfresco.repo.template.FreeMarkerProcessor.process(FreeMarkerProcessor.java:218)
        … 31 more
Caused by: java.lang.reflect.InvocationTargetException
        at sun.reflect.GeneratedMethodAccessor545.invoke(Unknown Source)
        at java.lang.reflect.Method.invoke(Method.java:606)
        at freemarker.ext.beans.BeansWrapper.invokeMethod(BeansWrapper.java:870)
        at freemarker.ext.beans.BeanModel.invokeThroughDescriptor(BeanModel.java:277)
        at freemarker.ext.beans.BeanModel.get(BeanModel.java:184)
        … 66 more
Caused by: org.alfresco.repo.security.permissions.AccessDeniedException: 03110204 Accesso Negato.  Non si dispone di permessi appropriati per eseguire questa operazione.
        at org.alfresco.repo.security.permissions.impl.ExceptionTranslatorMethodInterceptor.invoke(ExceptionTranslatorMethodInterceptor.java:50)
        at org.alfresco.repo.transaction.RetryingTransactionInterceptor$1.execute(RetryingTransactionInterceptor.java:79)
        at org.alfresco.repo.transaction.RetryingTransactionInterceptor.invoke(RetryingTransactionInterceptor.java:69)
        at com.sun.proxy.$Proxy11.getProperties(Unknown Source)
        at org.alfresco.repo.template.TemplateNode.getProperties(TemplateNode.java:262)
        … 72 more
Caused by: net.sf.acegisecurity.AccessDeniedException: Access is denied.
        at net.sf.acegisecurity.vote.AffirmativeBased.decide(AffirmativeBased.java:86)
        at net.sf.acegisecurity.intercept.AbstractSecurityInterceptor.beforeInvocation(AbstractSecurityInterceptor.java:398)
        … 82 more
2014-04-11 10:46:39,530  INFO  [web.site.EditionInterceptor] [http-bio-8080-exec-8] Successfully retrieved license information from Alfresco.
 2014-04-11 10:46:46,751  INFO  [web.scripts.ImapServerStatus] [http-bio-8080-exec-8] Successfully retrieved IMAP server status from Alfresco: disabled
 2014-04-11 10:54:41,210  ERROR [freemarker.runtime] [http-bio-8080-exec-13] Template processing error: "get(properties) failed on instance of org.alfresco.repo.template.TemplateNode"
The problematic instruction:
==> ${node.properties.creator!""} [on line 49, column 15 in org/alfresco/cmis/lib/atomentry.lib.atom.ftl]
 in user-directive entry [on line 48, column 1 in org/alfresco/cmis/lib/atomentry.lib.atom.ftl]
 in user-directive entryLib.document [on line 13, column 3 in org/alfresco/cmis/item.get.atomentry.ftl]
Java backtrace for programmers:
        … 66 more
Caused by: org.alfresco.repo.security.permissions.AccessDeniedException: 03110368 Accesso Negato.  Non si dispone di permessi appropriati per eseguire questa operazione.
        at org.alfresco.repo.audit.AuditMethodInterceptor.invoke(AuditMethodInterceptor.java:161)
        … 72 more
        … 82 more
