CIFS conf problem (KrbException: Identifier doesn't match...
nyugi
Hi everyone!
I have a little but very annoying problem with configuring CIFS on Alfresco Labs.
About the environment:
I have one computer to test this function with Windows XP on it (Computer name: va; Domain: mydom). I've decided to create a virtual PC and to install a Windows 2003 Server on it. This server (Computer name: va-virtserver; Domain: test2003.nyugi) is the AD server that I would like to configure to do the Kerbeos authentication for Alfresco CIFS. Unfortunately my PC and my new virtual server are in different domain, but if I understood right this should not be a problem. (But maybe this is the cause of my problems. … I hope not.)
About my installation and configuration process:
I have installed Alfresco Labs version 3.0.0 (b 1164) schema 131 (Alfresco-Labs-3b-OOo-Setup.exe) on my WinXP (d:\Alfresco). After that I followed the instructions of the Configuring the CIFS and web servers for Kerberos/AD integration wiki page. Since I belive I did everything by the 'manual' I will tell my every move step by step:
  1. On my virtual server (va-virtserver.test2003.nyugi) I've created the two user accounts (alfrescocifs, alfrescohttp) with password same as the account names, and with the desired settings: 'Password never expires' enabled, 'User must change password at next logon' disabled, 'Use DES encryption types for this account' and 'Do not require Kerberos preauthentication' options enabled.
  2. I used the ktpass utility om va-virtserver to generate key tables for the CIFS and web servers. I used these lines:
  3. ktpass -princ cifs/[email protected] -pass alfcifs -mapuser TEST2003\alfrescocifs -crypto DES-CBC-MD5 -ptype KRB5_NT_PRINCIPAL -mapop set +desonly -out c:\temp\alfrescocifs.keytab
    ktpass -princ HTTP/[email protected] -pass alfhttp -mapuser TEST2003\alfrescohttp -crypto DES-CBC-MD5 -ptype KRB5_NT_PRINCIPAL -mapop set +desonly -out c:\temp\alfrescohttp.keytab
    I am not really familiar with the Kerberos protocol, so I first tried different passwords from the ones set for the accounts, just to find out if it should be the same or not.
  4. I've created the Service Principal Names (SPN) for the Alfresco CIFS and web server using the setspn utility:
  5. setspn -a cifs/va alfrescocifs
    setspn -a cifs/va.mydom alfrescocifs
    setspn -a http/va alfrescohttp
    setspn -a http/va.mydom alfrescohttp
  6. I've copied the key table files to the installed Alfresco's etc subdir:
  7.   \\va-virtserver\c$\temp\alfrescocifs.keytab -> d$\Alfresco\etc\alfrescocifs.keytab
      \\va-virtserver\c$\temp\alfrescohttp.keytab -> d$\Alfresco\etc\alfrescohttp.keytab
  8. I've created the Kerberos ini file in c:\WINDOWS\krb5.ini (later I've made a copy of it in a newly created C:\WINNT folder because an exception somewhere missed it from that path):
  9. [libdefaults]
    default_realm = ALFTEST.NYUGI
    [realms]
    ALFTEST.NYUGI = {
      kdc = va-virtserver
      admin_server = va-virtserver
    [domain_realm]
    va-virtserver = ALFTEST.NYUGI
    .va-virtserver = ALFTEST.NYUGI
  10. I've created a Java login configuration file (c:\java\jdk1.5.0_07\jre\lib\security\java.login.config😞
  11. AlfrescoCIFS {
       com.sun.security.auth.module.Krb5LoginModule required
       storeKey=true
       useKeyTab=true
       keyTab="d:/Alfresco/etc/alfrescocifs.keytab"
       principal="cifs/va.mydom";
    AlfrescoHTTP {
       storeKey=true
       useKeyTab=true
       keyTab="d:/Alfresco/etc/alfrescohttp.keytab"
       principal="HTTP/va.mydom";
  12. I've put this line into the Java security configuration file (c:\java\jdk1.5.0_07\jre\lib\security\java.security😞
  13. login.config.url.1=file:${java.home}/lib/security/java.login.config
  14. I've added this to d:\Alfresco\tomcat\webapps\alfresco\WEB-INF\classes\alfresco\file-servers.xml file:
  15. <config evaluator="string-compare" condition="Filesystem Security">
      <authenticator type="enterprise">
        <KDC>va-virtserver</KDC>
        <Realm>ALFTEST.NYUGI</Realm>
        <Password>alfrescocifs</Password>
        <Principal>cifs/[email protected]</Principal>
      </authenticator>
    </config>
  16. I've changed the default values to these in d:\Alfresco\tomcat\webapps\alfresco\WEB-INF\web.xml file:
  17.   <filter>
         <filter-name>Authentication Filter</filter-name>
         <filter-class>org.alfresco.web.app.servlet.KerberosAuthenticationFilter</filter-class>
         <init-param>
           <param-name>KDC</param-name>
           <param-value>va-virtserver</param-value>
         </init-param>
         <init-param>
           <param-name>Realm</param-name>
           <param-value>ALFTEST.NYUGI</param-value>
         </init-param>
         <init-param>
           <param-name>Password</param-name>
           <param-value>alfrescocifs</param-value>
         </init-param>
         <init-param>
           <param-name>Principal</param-name>
           <param-value>cifs/[email protected]</param-value>
         </init-param>
      </filter>
      <filter>
         <filter-name>WebDAV Authentication Filter</filter-name>
         <filter-class>org.alfresco.repo.webdav.auth.KerberosAuthenticationFilter</filter-class>
         <init-param>
         </init-param>
         <init-param>
         </init-param>
         <init-param>
           <param-value>alfrescohttp</param-value>
         </init-param>
         <init-param>
           <param-value>HTTP/[email protected]</param-value>
         </init-param>
      </filter>
And the result was:
[size=85]
09:01:07,139  ERROR [webdav.auth.KerberosAuthenticationFilter] HTTP Kerberos web filter error
javax.security.auth.login.LoginException: null (68)
        at com.sun.security.auth.module.Krb5LoginModule.attemptAuthentication(Krb5LoginModule.java:652)
        at com.sun.security.auth.module.Krb5LoginModule.login(Krb5LoginModule.java:512)
        at javax.security.auth.login.LoginContext.invoke(LoginContext.java:769)
        at javax.security.auth.login.LoginContext.access$000(LoginContext.java:186)
        at javax.security.auth.login.LoginContext$4.run(LoginContext.java:683)
        at javax.security.auth.login.LoginContext.invokePriv(LoginContext.java:680)
        at javax.security.auth.login.LoginContext.login(LoginContext.java:579)
        at org.alfresco.repo.webdav.auth.KerberosAuthenticationFilter.init(KerberosAuthenticationFilter.java:340)
        at org.apache.catalina.core.ApplicationFilterConfig.getFilter(ApplicationFilterConfig.java:221)
        at org.apache.catalina.core.ApplicationFilterConfig.setFilterDef(ApplicationFilterConfig.java:302)
        at org.apache.catalina.core.ApplicationFilterConfig.<init>(ApplicationFilterConfig.java:78)
        at org.apache.catalina.core.StandardContext.filterStart(StandardContext.java:3635)
        at org.apache.catalina.core.StandardContext.start(StandardContext.java:4222)
Caused by: KrbException: null (68)
        at sun.security.krb5.KrbAsRep.<init>(KrbAsRep.java:64)
        at sun.security.krb5.KrbAsReq.getReply(KrbAsReq.java:345)
        at sun.security.krb5.Credentials.acquireTGT(Credentials.java:370)
        at com.sun.security.auth.module.Krb5LoginModule.attemptAuthentication(Krb5LoginModule.java:642)
        … 39 more
Caused by: KrbException: Identifier doesn't match expected value (906)
        at sun.security.krb5.internal.KDCRep.init(KDCRep.java:133)
        at sun.security.krb5.internal.ASRep.init(ASRep.java:58)
        at sun.security.krb5.internal.ASRep.<init>(ASRep.java:53)
        at sun.security.krb5.KrbAsRep.<init>(KrbAsRep.java:50)
        … 42 more
09:01:07,686  ERROR [[Catalina].[localhost].[/alfresco]] Exception starting filter WebDAV Authentication Filter
javax.servlet.ServletException: Failed to login HTTP server service
        at org.alfresco.repo.webdav.auth.KerberosAuthenticationFilter.init(KerberosAuthenticationFilter.java:354)
09:01:07,748  ERROR [app.servlet.KerberosAuthenticationFilter] HTTP Kerberos web filter error
        at org.alfresco.web.app.servlet.KerberosAuthenticationFilter.init(KerberosAuthenticationFilter.java:366)
        … 39 more
        … 42 more
09:01:07,748  ERROR [[Catalina].[localhost].[/alfresco]] Exception starting filter Authentication Filter
        at org.alfresco.web.app.servlet.KerberosAuthenticationFilter.init(KerberosAuthenticationFilter.java:380)
2008.09.19. 9:01:07 org.apache.catalina.core.StandardContext start
SEVERE: Error filterStart
[/size]
Later I tried to change the passwords:
ktpass -princ cifs/[email protected] -pass alfrescocifs -mapuser TEST2003\alfrescocifs -crypto DES-CBC-MD5 -ptype KRB5_NT_PRINCIPAL -mapop set +desonly -out c:\temp\alfrescocifs.keytab
ktpass -princ HTTP/[email protected] -pass alfrescohttp -mapuser TEST2003\alfrescohttp -crypto DES-CBC-MD5 -ptype KRB5_NT_PRINCIPAL -mapop set +desonly -out c:\temp\alfrescohttp.keytab
but it didn't help.
[size=85]
2008.09.19. 23:19:47 org.apache.coyote.http11.Http11BaseProtocol init
2008.09.19. 23:19:48 org.apache.catalina.startup.Catalina load
INFO: Initialization processed in 5187 ms
2008.09.19. 23:19:48 org.apache.catalina.core.StandardService start
2008.09.19. 23:19:48 org.apache.catalina.core.StandardEngine start
INFO: Starting Servlet Engine: Apache Tomcat/5.5.23
2008.09.19. 23:19:48 org.apache.catalina.core.StandardHost start
INFO: XML validation disabled
2008.09.19. 23:19:57 org.apache.catalina.startup.HostConfig deployWAR
23:22:16,837  INFO  [config.xml.XMLConfigService$PropertyConfigurer] Loading properties file from class path resource [alfresco/file-servers
.properties]
23:23:22,974  INFO  [domain.schema.SchemaBootstrap] Schema managed by database dialect org.hibernate.dialect.DerbyDialect.
23:23:23,005  INFO  [domain.schema.SchemaBootstrap] Alfresco is using the Apache Derby default database. Please only use this while evaluati
ng Alfresco, it is NOT recommended for production or deployment!
23:23:40,333  INFO  [domain.schema.SchemaBootstrap] No changes were made to the schema.
23:24:04,363 User:System INFO  [repo.admin.ConfigurationChecker] The Alfresco root data directory ('dir.root') is: D:\Alfresco\alf_data
23:24:04,941 User:System INFO  [admin.patch.PatchExecuter] Checking for patches to apply …
23:24:06,472 User:System INFO  [admin.patch.PatchExecuter] No patches were required.
23:24:06,519 User:System INFO  [repo.module.ModuleServiceImpl] Found 0 module(s).
23:24:22,393 User:System INFO  [service.descriptor.DescriptorService] Alfresco JVM - v1.5.0_07-b03; maximum heap size 506,313MB
23:24:22,393 User:System INFO  [service.descriptor.DescriptorService] Alfresco started (Labs): Current version 3.0.0 (b 1164) schema 131 - I
nstalled version 3.0.0 (b 1164) schema 131
23:24:24,284 User:System WARN  [alfresco.linkvalidation.LinkValidationServiceImpl] LinkValidationService Update is not running (virtualizati
on server not registered or started)
23:25:11,484  ERROR [webdav.auth.KerberosAuthenticationFilter] HTTP Kerberos web filter error
        … 39 more
        … 42 more
23:25:11,516  ERROR [[Catalina].[localhost].[/alfresco]] Exception starting filter WebDAV Authentication Filter
23:25:11,703  ERROR [app.servlet.KerberosAuthenticationFilter] HTTP Kerberos web filter error
        … 39 more
        … 42 more
23:25:11,953  ERROR [[Catalina].[localhost].[/alfresco]] Exception starting filter Authentication Filter
2008.09.19. 23:25:12 org.apache.catalina.core.StandardContext start
[/size]
Please somebody help me finding out the solution!
14 REPLIES 14
kaklaman
Is there any news for this problem? I am receiving the same stacktrace when I try to login…
meansartin14
Not at all. I've been fighting with this issue for 2 weeks and gave up. Now I'm waiting for somebody from Alfresco to come in and to suggest a solution. Obviously they are not so eager to help. Which makes me draw conclusions about the product and the support.
Has your issue been resolved? If so, how? What configurations were necessary?
Are you now able to login to the Alfresco Web Interface via single sign-on AND map a network drive to the Alfresco CIFS server?
jitse
Well, SSO/Kerberos is not a fairytale, it can work, and the supportguys/girls from alfresco where assistive enough though in the end it boils down to providing the right data.
We used Alf 2.2.1E, a win2k3 server with AD and a RHEL5 server with alfresco (not part of an AD domain), and XP domain-clients with FF and IE and windows explorer.
Actually followed the manual (the wiki page http://wiki.alfresco.com/wiki/Configuring_the_CIFS_and_web_servers_for_Kerberos/AD_integration) to the letter.
We ended up using the CIFS\principal (without domainname) in the file-server configuration file (the only difference to the wikipage).
We did use wireshark en kerberos utilities to figure out frequently were we where heading and what was working and what not, what kerberos handshakes were being made.
Depending on the type of networklease / static ip of the linuxserver , we also had issues using FQDN or short names, which of course influenced SSO/Kerberos working or not.
wuff
could you please post the config?
You're talking about the fiel file-servers.xml, the "Filesystem Security"-part, right?
meansartin14
I have started a thread that I hope to eventually turn into a AlfrescoWiki page for how to configure Active Directory authentication for both CIFS and the Web Interface in Alfresco Labs 3c.
Please see my thread:
[ERROR]Alfresco Engineers: CIFS auth does not work. Sugg?
Please come join in the discussion, or at least subscribe to the thread. I want to try to get everyone having these types of issues into the thread so that we can get a large collection of experiences and configurations.
We WILL find the answer for how to enable Active Directory authentication with CIFS in Alfresco!!
