Chinese Trad LangPack - problem(solved with 2.1)
shawnhy
Hi there,
I almost finish a Chinese Trad. translation work. I find a prolem that some characters cannot show rightly.
[img]http://shawnnpano.googlepages.com/error0003.png[/img]
The words in the hint box should be the same with the white box. What should i do to correct it?
Thanks a lot. Shawn
4 REPLIES 4
kevinr
I think this is a bug in 2.0 - the tooltip gets encoding twice for the UIPanel component - it will be fixed for 2.1.
http://issues.alfresco.com/browse/AWC-1260
Kevin
shawnhy
hi Kevin,
Many thanks. I have one more question here. Do you have any suggestion editing .ftl with Chinese words? I tried saving a .ftl file with UTF8 but failed.
cheers, Shawn
kevinr
The issue with .ftl files and loading with the correct encoding has been fixed for 2.1 final.
Kevin
rommie
where I can find the chinese traditional language pack?
rommie
