Hi Tob,
I had similar requirement in one of my projects earlier. In Alfresco, there is no generic font defined that would reflect in the entire application. There are many files depending on the components and regions where fonts are defined.
IF you want to change it, you will have to look into those different css files.
I can help you with few files where fonts are defined and they are reflected in majority of the application. Those files are:-
1. presentation.css
2. base.css
3. skin.css
Do share any other files which you may think should be counted in the majority.
