can't find scripting engine for 'text/javascript' error help
mrmike
Hello everyone, I created a very simple workflow that has a start -> runs a javascript -> end
The java script simply writes "hello" to a file at hte location C:\test\test.txt.
Right when attempting to start the process i get the error "can't find scripting engine for 'text/javascript'
Does anyone have a solution for this? I don't see any information surfing the web.
MIke
rasmi
I get the same error. Where you able to solve?
frederikherema1
What JDK are you running? DO you have a scripting-implementation on your class path that support javascript? Try adding rhino…
jbarrez
scriptFormat="Javascript" instead of text/javascript. This is the name according the  JSR 223 spec.
