Call activity delete problem
mlisiewicz
If I delete "Call activity" (by clicking basket icon on object) in given example, activiti file becomes corrupted and cannot be repaired manually.
SequenceFlows pointing to and from "Call activity" become invisible on graph but are still in a file *.activiti
Below i attached working *.activiti, after import please delete "Call activity" and save file - errors will appear in xml.
<?xml version="1.0" encoding="ASCII"?>
<xmi:XMI xmi:version="2.0" xmlns:xmi="http://www.omg.org/XMI" xmlns:xsi="http://www.w3.org/2001/XMLSchema-instance" xmlns:al="http://eclipse.org/graphiti/mm/algorithms" xmlns:bpmn2="http://www.omg.org/spec/BPMN/20100524/MODEL-XMI" xmlnsSmiley Tonguei="http://eclipse.org/graphiti/mm/pictograms">
  <piSmiley Very Happyiagram visible="true" gridUnit="10" diagramTypeId="BPMNdiagram" name="example" snapToGrid="true" showGuides="true" pictogramLinks="/0/@children.0/@link /0/@children.0/@children.0/@link /0/@children.1/@link /0/@connections.0/@link /0/@children.2/@link /0/@children.2/@children.0/@link /0/@connections.1/@link /0/@children.3/@link /0/@children.3/@children.0/@link /0/@connections.2/@link">
    <graphicsAlgorithm xsi:type="al:Rectangle" background="/0/@colors.1" foreground="/0/@colors.0" width="1000" height="1000"/>
    <children xsi:type="pi:ContainerShape" visible="true" active="true">
      <graphicsAlgorithm xsi:type="al:Ellipse" filled="false" lineVisible="false" width="55" height="55" x="490" y="110">
        <graphicsAlgorithmChildren xsi:type="al:Ellipse" width="55" height="55" style="/0/@styles.0"/>
      </graphicsAlgorithm>
      <link businessObjects="startevent1"/>
      <anchors xsi:type="pi:ChopboxAnchor" outgoingConnections="/0/@connections.0"/>
      <anchors xsi:type="pi:BoxRelativeAnchor" visible="true" active="true" referencedGraphicsAlgorithm="/0/@children.0/@graphicsAlgorithm/@graphicsAlgorithmChildren.0" relativeWidth="1.0" relativeHeight="0.51">
        <graphicsAlgorithm xsi:type="al:Ellipse" filled="false" lineVisible="false"/>
      </anchors>
      <children visible="true">
        <graphicsAlgorithm xsi:type="al:Text" width="55" height="55" style="/0/@styles.1" horizontalAlignment="ALIGNMENT_CENTER" value="Start">
          <font name="Arial" size="8" bold="true"/>
      </children>
    </children>
      <graphicsAlgorithm xsi:type="alSmiley Tongueolygon" filled="false" lineVisible="false" width="60" height="60" x="484" y="240">
        <graphicsAlgorithmChildren xsi:type="alSmiley Tongueolygon" width="60" height="60" style="/0/@styles.0">
          <points y="30"/>
          <points x="30"/>
          <points x="60" y="30"/>
          <points x="30" y="60"/>
          <points y="30"/>
        </graphicsAlgorithmChildren>
        <points y="30"/>
        <points x="30"/>
        <points y="30"/>
      <link businessObjects="exclusivegateway2"/>
      <anchors xsi:type="pi:ChopboxAnchor" outgoingConnections="/0/@connections.1" incomingConnections="/0/@connections.0"/>
      <anchors xsi:type="pi:BoxRelativeAnchor" visible="true" active="true" referencedGraphicsAlgorithm="/0/@children.1/@graphicsAlgorithm/@graphicsAlgorithmChildren.0" relativeWidth="0.51" relativeHeight="0.1">
      </anchors>
      <anchors xsi:type="pi:ChopboxAnchor"/>
      <anchors xsi:type="pi:BoxRelativeAnchor" visible="true" active="true" referencedGraphicsAlgorithm="/0/@children.1/@graphicsAlgorithm/@graphicsAlgorithmChildren.0" relativeWidth="0.51" relativeHeight="0.93">
      </anchors>
        <graphicsAlgorithm xsi:type="alSmiley Tongueolyline" lineWidth="7" filled="false" style="/0/@styles.0">
          <points x="45" y="15"/>
          <points x="15" y="45"/>
      </children>
          <points x="15" y="15"/>
          <points x="45" y="45"/>
      </children>
    </children>
      <graphicsAlgorithm xsi:type="al:Rectangle" filled="false" lineVisible="false" width="105" height="55" x="290" y="290">
        <graphicsAlgorithmChildren xsi:type="al:RoundedRectangle" lineWidth="3" width="105" height="55" style="/0/@styles.4" cornerHeight="5" cornerWidth="5"/>
      <link businessObjects="callactivity1"/>
      <anchors xsi:type="pi:ChopboxAnchor" outgoingConnections="/0/@connections.2" incomingConnections="/0/@connections.1"/>
      <anchors xsi:type="pi:BoxRelativeAnchor" visible="true" active="true" referencedGraphicsAlgorithm="/0/@children.2/@graphicsAlgorithm/@graphicsAlgorithmChildren.0" relativeWidth="1.0" relativeHeight="0.51">
      </anchors>
        <graphicsAlgorithm xsi:type="al:Text" width="105" height="20" y="20" style="/0/@styles.5" horizontalAlignment="ALIGNMENT_CENTER" value="Call activity">
      </children>
        <graphicsAlgorithm xsi:type="al:Image" width="10" height="10" x="47" y="40" id="org.activiti.designer.subprocess.collapsed" stretchH="false" stretchV="false" proportional="false"/>
      </children>
    </children>
      <graphicsAlgorithm xsi:type="al:Ellipse" filled="false" lineVisible="false" width="55" height="55" x="332" y="392">
      <link businessObjects="endevent29"/>
      <anchors xsi:type="pi:ChopboxAnchor" incomingConnections="/0/@connections.2"/>
        <graphicsAlgorithm xsi:type="al:Text" width="55" height="55" style="/0/@styles.7" horizontalAlignment="ALIGNMENT_CENTER" value="End">
      </children>
    </children>
    <styles foreground="/0/@colors.2" lineWidth="2" id="BPMN-CLASS">
      <renderingStyle>
        <adaptedGradientColoredAreas definedStyleId="blue-white-gloss" gradientType="0">
          <adaptedGradientColoredAreas styleAdaption="0">
            <gradientColor>
              <start locationType="LOCATION_TYPE_ABSOLUTE_START" locationValue="0">
                <color red="248" green="251" blue="254"/>
              </start>
              <end locationType="LOCATION_TYPE_ABSOLUTE_START" locationValue="1">
              </end>
            </gradientColor>
            <gradientColor>
              <start locationType="LOCATION_TYPE_ABSOLUTE_START" locationValue="1">
                <color red="237" green="245" blue="252"/>
              </start>
              <end locationType="LOCATION_TYPE_ABSOLUTE_START" locationValue="2">
              </end>
            </gradientColor>
            <gradientColor>
              <start locationType="LOCATION_TYPE_ABSOLUTE_START" locationValue="2">
                <color red="222" green="237" blue="250"/>
              </start>
              <end locationType="LOCATION_TYPE_ABSOLUTE_START" locationValue="3">
              </end>
            </gradientColor>
            <gradientColor>
              <start locationType="LOCATION_TYPE_ABSOLUTE_START" locationValue="3">
                <color red="212" green="231" blue="248"/>
              </start>
              <end locationType="LOCATION_TYPE_ABSOLUTE_END" locationValue="2">
                <color red="250" green="251" blue="252"/>
              </end>
            </gradientColor>
            <gradientColor>
              <start locationType="LOCATION_TYPE_ABSOLUTE_END" locationValue="2">
                <color red="226" green="229" blue="233"/>
              </start>
              <end locationType="LOCATION_TYPE_ABSOLUTE_END" locationValue="0">
              </end>
            </gradientColor>
          </adaptedGradientColoredAreas>
          <adaptedGradientColoredAreas styleAdaption="1">
            <gradientColor>
                <color red="238" green="246" blue="253"/>
              </start>
              </end>
            </gradientColor>
            <gradientColor>
                <color red="208" green="230" blue="249"/>
              </start>
              </end>
            </gradientColor>
            <gradientColor>
                <color red="172" green="210" blue="244"/>
              </start>
              </end>
            </gradientColor>
            <gradientColor>
                <color red="129" green="185" blue="234"/>
              </start>
                <color red="170" green="208" blue="242"/>
              </end>
            </gradientColor>
            <gradientColor>
                <color red="154" green="191" blue="224"/>
              </start>
              </end>
            </gradientColor>
          <adaptedGradientColoredAreas styleAdaption="2">
            <gradientColor>
                <color red="245" green="249" blue="254"/>
              </start>
              </end>
            </gradientColor>
            <gradientColor>
                <color red="226" green="239" blue="252"/>
              </start>
              </end>
            </gradientColor>
            <gradientColor>
                <color red="203" green="227" blue="249"/>
              </start>
              </end>
            </gradientColor>
            <gradientColor>
                <color red="187" green="218" blue="247"/>
              </start>
                <color red="197" green="224" blue="247"/>
              </end>
            </gradientColor>
            <gradientColor>
                <color red="178" green="205" blue="229"/>
              </start>
              </end>
            </gradientColor>
          <adaptedGradientColoredAreas styleAdaption="3">
            <gradientColor>
                <color red="153" green="204"/>
              </start>
                <color red="51" green="153" blue="102"/>
              </end>
            </gradientColor>
          <adaptedGradientColoredAreas styleAdaption="4">
            <gradientColor>
                <color red="255" green="204"/>
              </start>
                <color red="255" green="102"/>
              </end>
            </gradientColor>
      </renderingStyle>
    </styles>
    <styles foreground="/0/@colors.3" id="BPMNCLASS-TEXT"/>
    <styles background="/0/@colors.4" foreground="/0/@colors.4" id="BPMN-POLYGON-ARROW"/>
    <styles foreground="/0/@colors.2" lineWidth="20" id="CALL-ACTIVITY">
      <renderingStyle>
            <gradientColor>
              </start>
              </end>
            </gradientColor>
            <gradientColor>
              </start>
              </end>
            </gradientColor>
            <gradientColor>
              </start>
              </end>
            </gradientColor>
            <gradientColor>
              </start>
              </end>
            </gradientColor>
            <gradientColor>
              </start>
              </end>
            </gradientColor>
            <gradientColor>
              </start>
              </end>
            </gradientColor>
            <gradientColor>
              </start>
              </end>
            </gradientColor>
            <gradientColor>
              </start>
              </end>
            </gradientColor>
            <gradientColor>
              </start>
              </end>
            </gradientColor>
            <gradientColor>
              </start>
              </end>
            </gradientColor>
            <gradientColor>
              </start>
              </end>
            </gradientColor>
            <gradientColor>
              </start>
              </end>
            </gradientColor>
            <gradientColor>
              </start>
              </end>
            </gradientColor>
            <gradientColor>
              </start>
              </end>
            </gradientColor>
            <gradientColor>
              </start>
              </end>
            </gradientColor>
            <gradientColor>
              </start>
              </end>
            </gradientColor>
            <gradientColor>
              </start>
              </end>
            </gradientColor>
      </renderingStyle>
    </styles>
    <connections xsi:type="pi:FreeFormConnection" visible="true" active="true" start="/0/@children.0/@anchors.0" end="/0/@children.1/@anchors.0">
      <graphicsAlgorithm xsi:type="alSmiley Tongueolyline" foreground="/0/@colors.4" filled="false"/>
      <link businessObjects="flow234"/>
      <connectionDecorators visible="true" active="true" locationRelative="true" location="0.5">
        <graphicsAlgorithm xsi:type="al:Text" x="10" style="/0/@styles.2" value="">
          <font name="Arial" size="8"/>
      </connectionDecorators>
      <connectionDecorators visible="true" locationRelative="true" location="1.0">
        <graphicsAlgorithm xsi:type="alSmiley Tongueolygon" style="/0/@styles.3">
          <points x="-10" y="-5" before="3" after="3"/>
          <points/>
          <points x="-10" y="5" before="3" after="3"/>
          <points x="-8" before="3" after="3"/>
    </connections>
    <connections xsi:type="pi:FreeFormConnection" visible="true" active="true" start="/0/@children.1/@anchors.0" end="/0/@children.2/@anchors.0">
      <link businessObjects="flow235"/>
        <graphicsAlgorithm xsi:type="al:Text" x="10" style="/0/@styles.6" value="">
          <points/>
    </connections>
    <connections xsi:type="pi:FreeFormConnection" visible="true" active="true" start="/0/@children.2/@anchors.0" end="/0/@children.3/@anchors.0">
      <link businessObjects="flow236"/>
        <graphicsAlgorithm xsi:type="al:Text" x="10" style="/0/@styles.8" value="">
          <points/>
    </connections>
    <colors red="227" green="238" blue="249"/>
    <colors red="255" green="255" blue="255"/>
    <colors red="25" green="25" blue="112"/>
    <colors red="51" green="51" blue="153"/>
    <colors/>
  </piSmiley Very Happyiagram>
  <bpmn2Smiley Tonguerocess id="helloworld" name="helloworld">
    <documentation id="documentation_process" text=""/>
  </bpmn2Smiley Tonguerocess>
  <bpmn2Smiley FrustratedtartEvent id="startevent1" name="Start" outgoing="flow234"/>
  <bpmn2:ExclusiveGateway id="exclusivegateway2" name="Exclusive Gateway" incoming="flow234" outgoing="flow235"/>
  <bpmn2Smiley FrustratedequenceFlow id="flow234" name="" sourceRef="startevent1" targetRef="exclusivegateway2"/>
  <bpmn2:CallActivity id="callactivity1" name="Call activity" incoming="flow235" outgoing="flow236"/>
  <bpmn2Smiley FrustratedequenceFlow id="flow235" name="" sourceRef="exclusivegateway2" targetRef="callactivity1">
    <conditionExpression id="flow235_condition" body="${true}"/>
  </bpmn2Smiley FrustratedequenceFlow>
  <bpmn2:EndEvent id="endevent29" name="End" incoming="flow236"/>
  <bpmn2Smiley FrustratedequenceFlow id="flow236" name="" sourceRef="callactivity1" targetRef="endevent29"/>
</xmi:XMI>
mlisiewicz
Workaround: before deleting "Call activity" move all incoming and outgoing connections (SequenceFlows) to other objects and delete just empty object.
trademak
This is certainly a bug. I'll look into it and think it will be solved in the coming release April 1.
