06-21-2007 11:59 AM
21 juin 2007 17:42:00 org.apache.catalina.core.AprLifecycleListener lifecycleEvent
INFO: The Apache Tomcat Native library which allows optimal performance in production environments was not found on the java.library.path: C:Program FilesJavajdk1.5.0_11bin;.;C:WINDOWSsystem32;C:WINDOWS;C:Program FilesJavajdk1.5.0_11/bin;C:alfrescobin;C:Program FilesJavajdk1.5.0_11bin;C:alfrescobin;C:WINDOWSsystem32;C:WINDOWS;C:WINDOWSsystem32WBEM;C:alfrescojavabin;C:PROGRA~1ULTRAE~1;C:Program FilesPostgreSQL8.0bin;C:Program FilesMySQLMySQL Server 5.0bin;D:Workey-J2EEjboss-4.0.0bin
21 juin 2007 17:42:00 org.apache.coyote.http11.Http11BaseProtocol init
INFO: Initialisation de Coyote HTTP/1.1 sur http-8180
21 juin 2007 17:42:00 org.apache.catalina.startup.Catalina load
INFO: Initialization processed in 1265 ms
21 juin 2007 17:42:00 org.apache.catalina.core.StandardService start
INFO: Démarrage du service Catalina
21 juin 2007 17:42:00 org.apache.catalina.core.StandardEngine start
INFO: Starting Servlet Engine: Apache Tomcat/5.5.20
21 juin 2007 17:42:00 org.springframework.beans.factory.xml.XmlBeanDefinitionReader loadBeanDefinitions
INFO: Loading XML bean definitions from URL [file:C:/alfresco/virtual-tomcat/conf/alfresco-virtserver-context.xml]
21 juin 2007 17:42:00 org.springframework.core.CollectionFactory <clinit>
INFO: JDK 1.4+ collections available
21 juin 2007 17:42:00 org.springframework.context.support.AbstractRefreshableApplicationContext refreshBeanFactory
INFO: Bean factory for application context [org.springframework.context.support.FileSystemXmlApplicationContext;hashCode=14732323]: org.springframework.beans.factory.support.DefaultListableBeanFactory defining beans [virtserver-properties,authenticationService,reauthenticatingAdvice,avmReauthenticatingAdvisor,avmRemoteTransport,avmRemote,avmRemoteTransportRaw,jndiInfoBean,virtServerInfo,virtServerMBeanServer,virtServerRegistry,serverConnector,virtServerExporter,virtWebappRegistry,cacheControlInfo]; root of BeanFactory hierarchy
21 juin 2007 17:42:00 org.springframework.context.support.AbstractApplicationContext refresh
INFO: 15 beans defined in application context [org.springframework.context.support.FileSystemXmlApplicationContext;hashCode=14732323]
21 juin 2007 17:42:00 org.springframework.core.io.support.PropertiesLoaderSupport loadProperties
INFO: Loading properties file from URL [file:C:/alfresco/virtual-tomcat/conf/alfresco-shared.properties]
INFO: Loading properties file from URL [file:C:/alfresco/virtual-tomcat/conf/alfresco-virtserver.properties]
21 juin 2007 17:42:00 org.springframework.context.support.AbstractApplicationContext initMessageSource
INFO: Unable to locate MessageSource with name 'messageSource': using default [org.springframework.context.support.DelegatingMessageSource@11bed71]
21 juin 2007 17:42:00 org.springframework.context.support.AbstractApplicationContext initApplicationEventMulticaster
INFO: Unable to locate ApplicationEventMulticaster with name 'applicationEventMulticaster': using default [org.springframework.context.event.SimpleApplicationEventMulticaster@1e1dadb]
21 juin 2007 17:42:00 org.springframework.beans.factory.support.DefaultListableBeanFactory preInstantiateSingletons
INFO: Pre-instantiating singletons in factory [org.springframework.beans.factory.support.DefaultListableBeanFactory defining beans [virtserver-properties,authenticationService,reauthenticatingAdvice,avmReauthenticatingAdvisor,avmRemoteTransport,avmRemote,avmRemoteTransportRaw,jndiInfoBean,virtServerInfo,virtServerMBeanServer,virtServerRegistry,serverConnector,virtServerExporter,virtWebappRegistry,cacheControlInfo]; root of BeanFactory hierarchy]
21 juin 2007 17:42:02 org.springframework.beans.factory.support.AbstractBeanFactory destroySingletons
INFO: Destroying singletons in factory {org.springframework.beans.factory.support.DefaultListableBeanFactory defining beans [virtserver-properties,authenticationService,reauthenticatingAdvice,avmReauthenticatingAdvisor,avmRemoteTransport,avmRemote,avmRemoteTransportRaw,jndiInfoBean,virtServerInfo,virtServerMBeanServer,virtServerRegistry,serverConnector,virtServerExporter,virtWebappRegistry,cacheControlInfo]; root of BeanFactory hierarchy}
21 juin 2007 17:42:02 org.alfresco.jndi.AVMFileDirContext InitAVMRemote
ATTENTION: Retrying JNDI connection….
21 juin 2007 17:42:07 org.springframework.beans.factory.xml.XmlBeanDefinitionReader loadBeanDefinitions
21 juin 2007 17:42:07 org.springframework.context.support.AbstractRefreshableApplicationContext refreshBeanFactory
INFO: Bean factory for application context [org.springframework.context.support.FileSystemXmlApplicationContext;hashCode=32386092]: org.springframework.beans.factory.support.DefaultListableBeanFactory defining beans [virtserver-properties,authenticationService,reauthenticatingAdvice,avmReauthenticatingAdvisor,avmRemoteTransport,avmRemote,avmRemoteTransportRaw,jndiInfoBean,virtServerInfo,virtServerMBeanServer,virtServerRegistry,serverConnector,virtServerExporter,virtWebappRegistry,cacheControlInfo]; root of BeanFactory hierarchy
21 juin 2007 17:42:07 org.springframework.context.support.AbstractApplicationContext refresh
INFO: 15 beans defined in application context [org.springframework.context.support.FileSystemXmlApplicationContext;hashCode=32386092]
21 juin 2007 17:42:07 org.springframework.core.io.support.PropertiesLoaderSupport loadProperties
21 juin 2007 17:42:07 org.springframework.context.support.AbstractApplicationContext initMessageSource
INFO: Unable to locate MessageSource with name 'messageSource': using default [org.springframework.context.support.DelegatingMessageSource@1e7c5cb]
21 juin 2007 17:42:07 org.springframework.context.support.AbstractApplicationContext initApplicationEventMulticaster
INFO: Unable to locate ApplicationEventMulticaster with name 'applicationEventMulticaster': using default [org.springframework.context.event.SimpleApplicationEventMulticaster@16a9b9c]
21 juin 2007 17:42:07 org.springframework.beans.factory.support.DefaultListableBeanFactory preInstantiateSingletons
21 juin 2007 17:42:08 org.springframework.beans.factory.support.AbstractBeanFactory destroySingletons
21 juin 2007 17:42:08 org.alfresco.jndi.AVMFileDirContext InitAVMRemote
21 juin 2007 17:42:13 org.springframework.beans.factory.xml.XmlBeanDefinitionReader loadBeanDefinitions
21 juin 2007 17:42:13 org.springframework.context.support.AbstractRefreshableApplicationContext refreshBeanFactory
INFO: Bean factory for application context [org.springframework.context.support.FileSystemXmlApplicationContext;hashCode=926353]: org.springframework.beans.factory.support.DefaultListableBeanFactory defining beans [virtserver-properties,authenticationService,reauthenticatingAdvice,avmReauthenticatingAdvisor,avmRemoteTransport,avmRemote,avmRemoteTransportRaw,jndiInfoBean,virtServerInfo,virtServerMBeanServer,virtServerRegistry,serverConnector,virtServerExporter,virtWebappRegistry,cacheControlInfo]; root of BeanFactory hierarchy
21 juin 2007 17:42:13 org.springframework.context.support.AbstractApplicationContext refresh
INFO: 15 beans defined in application context [org.springframework.context.support.FileSystemXmlApplicationContext;hashCode=926353]
21 juin 2007 17:42:13 org.springframework.core.io.support.PropertiesLoaderSupport loadProperties
21 juin 2007 17:42:13 org.springframework.context.support.AbstractApplicationContext initMessageSource
INFO: Unable to locate MessageSource with name 'messageSource': using default [org.springframework.context.support.DelegatingMessageSource@4865ce]
21 juin 2007 17:42:13 org.springframework.context.support.AbstractApplicationContext initApplicationEventMulticaster
INFO: Unable to locate ApplicationEventMulticaster with name 'applicationEventMulticaster': using default [org.springframework.context.event.SimpleApplicationEventMulticaster@113beb5]
21 juin 2007 17:42:13 org.springframework.beans.factory.support.DefaultListableBeanFactory preInstantiateSingletons
21 juin 2007 17:42:14 org.springframework.beans.factory.support.AbstractBeanFactory destroySingletons
21 juin 2007 17:42:14 org.alfresco.jndi.AVMFileDirContext InitAVMRemote
21 juin 2007 17:42:19 org.springframework.beans.factory.xml.XmlBeanDefinitionReader loadBeanDefinitions
21 juin 2007 17:42:19 org.springframework.context.support.AbstractRefreshableApplicationContext refreshBeanFactory
INFO: Bean factory for application context [org.springframework.context.support.FileSystemXmlApplicationContext;hashCode=21854021]: org.springframework.beans.factory.support.DefaultListableBeanFactory defining beans [virtserver-properties,authenticationService,reauthenticatingAdvice,avmReauthenticatingAdvisor,avmRemoteTransport,avmRemote,avmRemoteTransportRaw,jndiInfoBean,virtServerInfo,virtServerMBeanServer,virtServerRegistry,serverConnector,virtServerExporter,virtWebappRegistry,cacheControlInfo]; root of BeanFactory hierarchy
21 juin 2007 17:42:19 org.springframework.context.support.AbstractApplicationContext refresh
INFO: 15 beans defined in application context [org.springframework.context.support.FileSystemXmlApplicationContext;hashCode=21854021]
21 juin 2007 17:42:19 org.springframework.core.io.support.PropertiesLoaderSupport loadProperties
21 juin 2007 17:42:19 org.springframework.context.support.AbstractApplicationContext initMessageSource
INFO: Unable to locate MessageSource with name 'messageSource': using default [org.springframework.context.support.DelegatingMessageSource@18c3679]
21 juin 2007 17:42:19 org.springframework.context.support.AbstractApplicationContext initApplicationEventMulticaster
INFO: Unable to locate ApplicationEventMulticaster with name 'applicationEventMulticaster': using default [org.springframework.context.event.SimpleApplicationEventMulticaster@4c47db]
21 juin 2007 17:42:19 org.springframework.beans.factory.support.DefaultListableBeanFactory preInstantiateSingletons
21 juin 2007 17:42:20 org.springframework.beans.factory.support.AbstractBeanFactory destroySingletons
21 juin 2007 17:42:20 org.alfresco.jndi.AVMFileDirContext InitAVMRemote
21 juin 2007 17:42:25 org.springframework.beans.factory.xml.XmlBeanDefinitionReader loadBeanDefinitions
21 juin 2007 17:42:25 org.springframework.context.support.AbstractRefreshableApplicationContext refreshBeanFactory
INFO: Bean factory for application context [org.springframework.context.support.FileSystemXmlApplicationContext;hashCode=101492]: org.springframework.beans.factory.support.DefaultListableBeanFactory defining beans [virtserver-properties,authenticationService,reauthenticatingAdvice,avmReauthenticatingAdvisor,avmRemoteTransport,avmRemote,avmRemoteTransportRaw,jndiInfoBean,virtServerInfo,virtServerMBeanServer,virtServerRegistry,serverConnector,virtServerExporter,virtWebappRegistry,cacheControlInfo]; root of BeanFactory hierarchy
21 juin 2007 17:42:25 org.springframework.context.support.AbstractApplicationContext refresh
INFO: 15 beans defined in application context [org.springframework.context.support.FileSystemXmlApplicationContext;hashCode=101492]
21 juin 2007 17:42:25 org.springframework.core.io.support.PropertiesLoaderSupport loadProperties
21 juin 2007 17:42:25 org.springframework.context.support.AbstractApplicationContext initMessageSource
INFO: Unable to locate MessageSource with name 'messageSource': using default [org.springframework.context.support.DelegatingMessageSource@1d3cdaa]
21 juin 2007 17:42:25 org.springframework.context.support.AbstractApplicationContext initApplicationEventMulticaster
INFO: Unable to locate ApplicationEventMulticaster with name 'applicationEventMulticaster': using default [org.springframework.context.event.SimpleApplicationEventMulticaster@6355dc]
21 juin 2007 17:42:25 org.springframework.beans.factory.support.DefaultListableBeanFactory preInstantiateSingletons
21 juin 2007 17:42:25 org.springframework.remoting.rmi.RmiClientInterceptor prepare
INFO: RMI stub [rmi://localhost:50500/authentication] is an RMI invoker
21 juin 2007 17:42:25 org.springframework.aop.framework.DefaultAopProxyFactory <clinit>
INFO: CGLIB2 not available: proxyTargetClass feature disabled
21 juin 2007 17:42:26 org.springframework.remoting.rmi.RmiClientInterceptor prepare
INFO: RMI stub [rmi://localhost:50500/avm] is an RMI invoker
21 juin 2007 17:42:26 org.springframework.remoting.rmi.RmiRegistryFactoryBean getRegistry
INFO: Looking for RMI registry at port '50501'
21 juin 2007 17:42:27 org.springframework.remoting.rmi.RmiRegistryFactoryBean getRegistry
ATTENTION: Could not detect RMI registry - creating new one
21 juin 2007 17:42:27 org.springframework.jmx.support.ConnectorServerFactoryBean afterPropertiesSet
INFO: JMX connector server started: javax.management.remote.rmi.RMIConnectorServer@4a9a7d
21 juin 2007 17:42:29 org.alfresco.mbeans.VirtServerRegistrationThread registerVirtServer
INFO: Connected to remote Alfresco JMX Server
21 juin 2007 17:42:29 org.alfresco.catalina.host.AVMHost start
INFO: XML validation disabled
21 juin 2007 17:42:29 org.apache.catalina.core.StandardHost start
21 juin 2007 17:42:30 org.apache.catalina.core.StandardHost start
21 juin 2007 17:42:31 org.apache.coyote.http11.Http11BaseProtocol start
INFO: Démarrage de Coyote HTTP/1.1 sur http-8180
21 juin 2007 17:42:32 org.apache.jk.common.ChannelSocket init
INFO: JK: ajp13 listening on /0.0.0.0:8109
21 juin 2007 17:42:32 org.apache.jk.server.JkMain start
INFO: Jk running ID=0 time=0/31 config=null
21 juin 2007 17:42:32 org.apache.catalina.storeconfig.StoreLoader load
21 juin 2007 17:42:32 org.apache.catalina.startup.Catalina start
INFO: Server startup in 32254 ms
alfrescotomcatlogscatalina.2007-06-21.log21 juin 2007 17:42:00 org.apache.catalina.core.AprLifecycleListener lifecycleEvent
INFO: The Apache Tomcat Native library which allows optimal performance in production environments was not found on the java.library.path: C:Program FilesJavajdk1.5.0_11bin;.;C:WINDOWSsystem32;C:WINDOWS;C:Program FilesJavajdk1.5.0_11bin;C:alfrescobin;C:WINDOWSsystem32;C:WINDOWS;C:WINDOWSsystem32WBEM;C:alfrescojavabin;C:PROGRA~1ULTRAE~1;C:Program FilesPostgreSQL8.0bin;C:Program FilesMySQLMySQL Server 5.0bin;D:Workey-J2EEjboss-4.0.0bin
INFO: Initialisation de Coyote HTTP/1.1 sur http-8080
INFO: Initialization processed in 1468 ms
21 juin 2007 17:42:00 org.apache.catalina.core.StandardHost start
21 juin 2007 17:42:01 org.apache.catalina.startup.HostConfig deployWAR
INFO: Déploiement de l'archive alfresco.war de l'application web
21 juin 2007 17:42:35 org.apache.coyote.http11.Http11BaseProtocol start
INFO: Démarrage de Coyote HTTP/1.1 sur http-8080
21 juin 2007 17:42:36 org.apache.jk.common.ChannelSocket init
INFO: JK: ajp13 listening on /0.0.0.0:8009
21 juin 2007 17:42:36 org.apache.jk.server.JkMain start
INFO: Jk running ID=0 time=0/62 config=null
21 juin 2007 17:42:36 org.apache.catalina.storeconfig.StoreLoader load
21 juin 2007 17:42:36 org.apache.catalina.startup.Catalina start
INFO: Server startup in 35831 ms
alfrescoalfresco.log17:42:22,682 WARN [org.springframework.remoting.rmi.RmiRegistryFactoryBean] Could not detect RMI registry - creating new one
17:42:32,631 WARN [org.alfresco.repo.admin.ConfigurationChecker] The Alfresco 'dir.root' property is set to a relative path './alf_data'. 'dir.root' should be overridden to point to a specific folder.
17:42:32,631 INFO [org.alfresco.repo.admin.ConfigurationChecker] The Alfresco root data directory ('dir.root') is: .alf_data
17:42:32,819 INFO [org.alfresco.repo.admin.patch.PatchExecuter] Vérification des correctifs à appliquer …
17:42:32,850 INFO [org.alfresco.repo.admin.patch.PatchExecuter] Aucun correctif requis.
17:42:32,865 INFO [org.alfresco.repo.module.ModuleServiceImpl] Found 0 module(s).
17:42:33,084 INFO [org.alfresco.service.descriptor.DescriptorService] Alfresco JVM - v1.5.0_11-b03; maximum heap size 493,063MB
17:42:33,084 WARN [org.alfresco.service.descriptor.DescriptorService] Alfresco JVM - WARNING - maximum heap size 493,063MB is less than recommended 512MB
17:42:33,084 INFO [org.alfresco.service.descriptor.DescriptorService] Alfresco started (Community Network): Current version 2.0.0 (build-185) schema 38 - Installed version 2.0.0 (build-185) schema 38
Pourquoi la création de ces espaces ne s'est pas faite ?06-22-2007 04:11 AM
=== Correctif Appliqué ===
RESULTAT :
The Web Projects folder was successfully created: workspace://SpacesStore/a677d1b8-090c-11dc-89d7-95d7782f3ab8
The Web Forms folder was successfully created: workspace://SpacesStore/a677d1b8-090c-11dc-89d7-95d7782f3ab8
Remettez éventuellement à plat la base de données d'Alfresco et effacez le dossier alf_data afin de démarrer avec une instance neuve d'Alfresco. Refaite la manipulation consistant à dézipper l'archive WCM "alfresco-community-wcm-2.0.0.zip" et placez les fichiers dans le répertoire principal de l'installation d'Alfresco (créer éventuellement, pour séparer les fichiers WCM du reste, un dossier « WCM »).06-22-2007 04:19 AM
