04-15-2009 10:57 AM
06-16-2009 11:36 AM
<!– DAO that rejects changes - LDAP is read only at the moment. It does allow users to be deleted with out warnings from the UI. –>
<bean name="authenticationDaoLDAP" class="org.alfresco.repo.security.authentication.DefaultMutableAuthenticationDao" >
<property name="allowDeleteUser">
<value>true</value>
</property>
</bean>
<bean id="authenticationComponentLDAP"
class="org.alfresco.repo.security.authentication.ldap.LDAPAuthenticationComponentImpl"
parent="authenticationComponentBase">
<property name="LDAPInitialDirContextFactory">
<ref bean="ldapInitialDirContextFactory"/>
</property>
<property name="userNameFormat">
This maps between what the user types in and what is passed through to the underlying LDAP authentication.
"%s" - the user id is passed through without modification.
Used for LDAP authentication such as DIGEST-MD5, anything that is not "simple".
"cn=%s,ou=London,dc=company,dc=com" - If the user types in "Joe Bloggs" the authenticate as "cn=Joe Bloggs,ou=London,dc=company,dc=com"
Usually for simple authentication. Simple authentication always uses the DN for the user.
<value>${ldap.authentication.userNameFormat}</value>
</property>
<property name="nodeService">
<ref bean="nodeService" />
</property>
<property name="personService">
<ref bean="personService" />
</property>
<property name="transactionService">
<ref bean="transactionService" />
</property>
<property name="escapeCommasInBind">
<value>${ldap.authentication.escapeCommasInBind}</value>
</property>
<property name="escapeCommasInUid">
<value>${ldap.authentication.escapeCommasInUid}</value>
</property>
</bean>
<!– LDAP –>
<bean id="authenticationServiceLDAP" class="org.alfresco.repo.security.authentication.AuthenticationServiceImpl">
<property name="authenticationDao">
<ref bean="authenticationDaoLDAP"/>
</property>
<property name="ticketComponent">
<ref bean="ticketComponent"/>
</property>
<property name="authenticationComponent">
<ref bean="authenticationComponentLDAP"/>
</property>
</bean>
<bean id="authenticationComponent"
class="org.alfresco.repo.security.authentication.ChainingAuthenticationComponentImpl">
<property name="authenticationComponents">
<list>
<ref bean="authenticationComponentImplSecureToken" />
</list>
</property>
<property name="mutableAuthenticationComponent">
<ref bean="authenticationComponentImplAlfresco" />
</property>
</bean>
<bean id="authenticationService"
class="org.alfresco.repo.security.authentication.ChainingAuthenticationServiceImpl">
<property name="authenticationServices">
<list>
<ref bean="authenticationServiceImplSecureToken" />
<ref bean ="authenticationServiceLDAP"/>
</list>
</property>
<property name="mutableAuthenticationService">
<ref bean="authenticationServiceImplAlfresco" />
</property>
<property name="sysAdminCache">
<ref bean="sysAdminCache" />
</property>
</bean>
06-16-2009 08:35 PM
06-17-2009 05:52 AM
A few ways to debug if your chaining is working or not is listed below.
1) Check if you can login to alfresco directly using a ldap username and password
2) With the above configuration see if you can login as "admin" user when ldap is not accessible or turned off.
3) AWPr should display appropriate contents using STAr authentication.
Step 1:
Edit you ldap-authentication-context.xml to change bean authenticationDao to authenticationDaoLDAP.
Step 2:
Change the bean id authenticationComponent to authenticationComponentLDAP in the same file (ldap-authentication-context.xml).
Step 3:
Add a new bean to chaining-authentication-context.xml
Step 4:
Add additional authentication component to the bean authenticationComponent in chaining-authentication-context.xml as show below.
<ref bean="authenticationComponentImplSecureToken" />Step 5:
Add LDAP authentication service to existing list in the bean authenticationService in chaining-authentication-service.xml as shown below.
<ref bean="authenticationServiceImplSecureToken" />10:18:47,553 WARN [HttpMethodBase:682] Going to buffer response body of large or unknown size. Using getResponseBodyAsStream instead is recommended.
10:18:48,698 WARN [HttpMethodBase:682] Going to buffer response body of large or unknown size. Using getResponseBodyAsStream instead is recommended.
10:18:49,634 WARN [HttpMethodBase:682] Going to buffer response body of large or unknown size. Using getResponseBodyAsStream instead is recommended.
10:18:49,742 WARN [HttpMethodBase:682] Going to buffer response body of large or unknown size. Using getResponseBodyAsStream instead is recommended.
06-17-2009 10:40 AM
Hi all,
I want to use rivet logic awpr portlet and so I'm trying to understand how it works and how secure it is.
I would like to know if someone can confirm that:
1)
The Util.java class uses
usernName = liferayUser.getLogin()
as the alfresco user. When Liferay uses email address for user credentials, liferayUser.getLogin() is the user email that can hardly be used as a username on Alfresco. It seems not possible to use the screenName.
2)
AWPR is able to access Alfresco webscript using the Liferay user, but it does not authenticate the user on Alfresco: for example, if I configure awpr to use a webscript that requires authentication but just returns a link to an Alfresco document, the portlet works well, but I cannot access the document because I'm not authenticated on Alfresco. I have to use a portlet like MySpaces that makes an Ajax call and creates the ticket on Alfresco and than I'm authenticated and I can navigate inside the Alfresco web client.
3) The MySpaces portlet uses a call like this one:
Can somene sniffs the http traffic, reads the ticket and uses it to get access on Alfresco?
Mar...
'>http://localhost:8080/alfresco/wcservice/ui/awprmyspacespanel?p=/Company%20Home/User%20Homes/liferayuser&f=0&h=workspace://SpacesStore/ed23f702-b4b4-4b45-a30d-5f6106367ef3&pid=undefined&puri=undefined&alfUrl=http://localhost:8080/alfresco&ticket=TICKET_4fb7a221e79d7be25880b1df05cdd3f6b66e9f2f
Mar...
Hi Marco,
1)
Liferay supports 3 different ways to login (userId, screenName, and email).
liferayUser.getLogin() will return the appropriate login based on the login mechanism set. This was intentional. If the requirement is, that the screenName be always used then you should be able to get the screenName using liferayUser.getScreenName().
2)
Currently AWPr does not support downloads. If you have a link in the ftl file that is a direct link, Alfresco will not be aware of the user.
Proxying the download is under consideration.
AWPr portlet does keep a ticket in the session for the current user and uses the same ticket for all further requests that are proxied through AWPr.
3)
MySpaces is used as an example and AWPr is not limited to any particular Web Script.
Myspaces is not a simple Web Script. It has a lot of ajax calls and supporting beans. The inner panel is populated via an AJAX call and this call will not be aware of the ticket in AWPr session.
AWPr is intended to proxy all requests and not expose alfresco directly to the end user. It is still evolving. Once all the urls can be proxied through AWPr, this should not be an issue.
Best Regards,
Shagul
06-17-2009 11:37 AM
06-18-2009 04:20 PM
06-24-2009 03:23 PM
GET /alfresco/service/api/node/content/{store_type}/{store_id}/{id}/{file-name}?a={attach?}06-26-2009 06:00 AM
08:04:35,505 ERROR [PortletServlet:104] javax.portlet.PortletException: org.apache.jasper.JasperException: An exception occurred processing JSP page /html/edit.jsp at line 24
21: String scriptUrl = prefs.getValue(Constants.PORTLET_PREF_WEBSCRIPT_URL, "");
22: String scriptParams = prefs.getValue(Constants.PORTLET_PREF_WEBSCRIPT_PARAMS, "");
23: String proxyUrls = prefs.getValue(Constants.PORTLET_PREF_PROXY_URLS, "");
24: boolean proxyAllUrls = (prefs.getValue(Constants.PORTLET_PREF_PROXY_ALL_URLS, "true").equalsIgnoreCase("true"));
25: String charEncodingType = prefs.getValue(Constants.PORTLET_PREF_CHAR_ENCODING_TYPE, Constants.CHAR_ENCODING_UTF8);
26: String methodType = prefs.getValue(Constants.PORTLET_PREF_HTTP_METHOD, Constants.HTTP_METHOD_GET);
27: String jsVariable = prefs.getValue(Constants.PORTLET_PREF_JS_VARIABLE, "");
Stacktrace:
Stacktrace:
at com.liferay.portlet.PortletRequestDispatcherImpl.dispatch(PortletRequestDispatcherImpl.java:318)
at com.liferay.portlet.PortletRequestDispatcherImpl.include(PortletRequestDispatcherImpl.java:122)
at org.rivetlogic.rivet.portlet.awpr.JSPPortlet.include(JSPPortlet.java:362)
at org.rivetlogic.rivet.portlet.awpr.JSPPortlet.doEdit(JSPPortlet.java:139)
at javax.portlet.GenericPortlet.doDispatch(GenericPortlet.java:330)
at org.rivetlogic.rivet.portlet.awpr.JSPPortlet.doDispatch(JSPPortlet.java:131)
at javax.portlet.GenericPortlet.render(GenericPortlet.java:233)
at com.sun.portal.portletcontainer.appengine.filter.FilterChainImpl.doFilter(FilterChainImpl.java:126)
at com.liferay.portal.kernel.portlet.PortletFilterUtil.doFilter(PortletFilterUtil.java:69)
at com.liferay.portal.kernel.servlet.PortletServlet.service(PortletServlet.java:100)
at org.apache.catalina.core.ApplicationDispatcher.invoke(ApplicationDispatcher.java:630)
at org.apache.catalina.core.ApplicationDispatcher.doInclude(ApplicationDispatcher.java:535)
at org.apache.catalina.core.ApplicationDispatcher.include(ApplicationDispatcher.java:472)
at com.liferay.portlet.InvokerPortletImpl.invoke(InvokerPortletImpl.java:618)
at com.liferay.portlet.InvokerPortletImpl.invokeRender(InvokerPortletImpl.java:700)
at com.liferay.portlet.InvokerPortletImpl.render(InvokerPortletImpl.java:419)
at org.apache.jsp.html.portal.render_005fportlet_jsp._jspService(Unknown Source)
at org.apache.jasper.runtime.HttpJspBase.service(HttpJspBase.java:70)
at org.apache.jasper.servlet.JspServletWrapper.service(JspServletWrapper.java:374)
at org.apache.jasper.servlet.JspServlet.serviceJspFile(JspServlet.java:342)
at org.apache.jasper.servlet.JspServlet.service(JspServlet.java:267)
at com.liferay.portal.util.PortalImpl.renderPortlet(PortalImpl.java:2884)
at com.liferay.portal.util.PortalUtil.renderPortlet(PortalUtil.java:897)
at com.liferay.portlet.layoutconfiguration.util.RuntimePortletUtil.processPortlet(RuntimePortletUtil.java:170)
at com.liferay.portlet.layoutconfiguration.util.RuntimePortletUtil.processPortlet(RuntimePortletUtil.java:90)
at com.liferay.portlet.layoutconfiguration.util.RuntimePortletUtil.processPortlet(RuntimePortletUtil.java:77)
at com.liferay.portlet.layoutconfiguration.util.velocity.PortletLogic.processContent(PortletLogic.java:85)
at com.liferay.portlet.layoutconfiguration.util.velocity.TemplateProcessor.processMax(TemplateProcessor.java:85)
at sun.reflect.GeneratedMethodAccessor391.invoke(Unknown Source)
at org.apache.velocity.util.introspection.UberspectImpl$VelMethodImpl.doInvoke(UberspectImpl.java:389)
at org.apache.velocity.util.introspection.UberspectImpl$VelMethodImpl.invoke(UberspectImpl.java:378)
at org.apache.velocity.runtime.parser.node.ASTMethod.execute(ASTMethod.java:270)
at org.apache.velocity.runtime.parser.node.ASTReference.execute(ASTReference.java:252)
at org.apache.velocity.runtime.parser.node.ASTReference.render(ASTReference.java:332)
at org.apache.velocity.runtime.parser.node.SimpleNode.render(SimpleNode.java:336)
at org.apache.velocity.Template.merge(Template.java:328)
at org.apache.velocity.Template.merge(Template.java:235)
at org.apache.velocity.app.VelocityEngine.mergeTemplate(VelocityEngine.java:381)
at com.liferay.portal.velocity.VelocityEngineImpl.mergeTemplate(VelocityEngineImpl.java:179)
at com.liferay.portal.kernel.velocity.VelocityEngineUtil.mergeTemplate(VelocityEngineUtil.java:84)
at com.liferay.portlet.layoutconfiguration.util.RuntimePortletUtil.processTemplate(RuntimePortletUtil.java:237)
at org.apache.jsp.html.portal.layout.view.portlet_jsp._jspService(Unknown Source)
at com.liferay.portal.action.LayoutAction.includeLayoutContent(LayoutAction.java:294)
at com.liferay.portal.action.LayoutAction.processLayout(LayoutAction.java:471)
at com.liferay.portal.action.LayoutAction.execute(LayoutAction.java:195)
at org.apache.struts.action.RequestProcessor.processActionPerform(RequestProcessor.java:431)
at org.apache.struts.action.RequestProcessor.process(RequestProcessor.java:236)
at com.liferay.portal.struts.PortalRequestProcessor.process(PortalRequestProcessor.java:157)
at org.apache.struts.action.ActionServlet.process(ActionServlet.java:1196)
at org.apache.struts.action.ActionServlet.doGet(ActionServlet.java:414)
at javax.servlet.http.HttpServlet.service(HttpServlet.java:617)
at com.liferay.portal.servlet.MainServlet.callParentService(MainServlet.java:608)
at com.liferay.portal.servlet.MainServlet.service(MainServlet.java:846)
at org.apache.catalina.core.ApplicationDispatcher.processRequest(ApplicationDispatcher.java:436)
at org.apache.catalina.core.ApplicationDispatcher.doForward(ApplicationDispatcher.java:374)
at org.apache.catalina.core.ApplicationDispatcher.forward(ApplicationDispatcher.java:302)
at com.liferay.portal.servlet.FriendlyURLServlet.service(FriendlyURLServlet.java:143)
at com.liferay.portal.kernel.servlet.BaseFilter.processFilter(BaseFilter.java:154)
at com.liferay.portal.servlet.filters.strip.StripFilter.processFilter(StripFilter.java:142)
at com.liferay.portal.kernel.servlet.BaseFilter.doFilter(BaseFilter.java:91)
at com.liferay.portal.kernel.servlet.BaseFilter.doFilter(BaseFilter.java:94)
at com.liferay.portal.servlet.filters.gzip.GZipFilter.processFilter(GZipFilter.java:140)
at com.liferay.portal.servlet.filters.secure.SecureFilter.processFilter(SecureFilter.java:282)
at com.liferay.portal.servlet.filters.cache.CacheFilter.processFilter(CacheFilter.java:425)
at com.liferay.portal.servlet.filters.autologin.AutoLoginFilter.processFilter(AutoLoginFilter.java:257)
at com.liferay.portal.servlet.filters.sso.opensso.OpenSSOFilter.processFilter(OpenSSOFilter.java:73)
at com.liferay.portal.sharepoint.SharepointFilter.processFilter(SharepointFilter.java:193)
at com.liferay.portal.servlet.filters.virtualhost.VirtualHostFilter.doFilter(VirtualHostFilter.java:191)
at com.liferay.portal.servlet.filters.threadlocalcache.ThreadLocalCacheFilter.processFilter(ThreadLocalCacheFilter.java:55)
at org.tuckey.web.filters.urlrewrite.UrlRewriteFilter.doFilter(UrlRewriteFilter.java:738)
at org.apache.catalina.authenticator.AuthenticatorBase.invoke(AuthenticatorBase.java:433)
at org.apache.catalina.core.StandardHostValve.invoke(StandardHostValve.java:128)
at org.apache.catalina.connector.CoyoteAdapter.service(CoyoteAdapter.java:286)
at org.apache.coyote.http11.Http11Processor.process(Http11Processor.java:845)
at org.apache.tomcat.util.net.JIoEndpoint$Worker.run(JIoEndpoint.java:447)
Caused by: org.apache.jasper.JasperException: An exception occurred processing JSP page /html/edit.jsp at line 24
Stacktrace:
at org.apache.jasper.servlet.JspServletWrapper.handleJspException(JspServletWrapper.java:505)
at org.apache.jasper.servlet.JspServletWrapper.service(JspServletWrapper.java:416)
at com.liferay.portlet.PortletRequestDispatcherImpl.dispatch(PortletRequestDispatcherImpl.java:307)
… 156 more
at org.apache.jsp.html.edit_jsp._jspService(edit_jsp.java:221)
… 165 moreAWPr is temporarily unavailable.
06-26-2009 08:39 AM
06-30-2009 05:44 AM
Caused by: org.springframework.beans.factory.NoSuchBeanDefinitionException: No bean named 'userNameMatcher' is defined
at org.springframework.beans.factory.support.DefaultListableBeanFactory.getBeanDefinition(DefaultListableBeanFactory.java:356)
at org.springframework.beans.factory.support.AbstractBeanFactory.getMergedBeanDefinition(AbstractBeanFactory.java:916)
at org.springframework.beans.factory.support.AbstractBeanFactory.getBean(AbstractBeanFactory.java:243)
at org.springframework.beans.factory.support.AbstractBeanFactory.getBean(AbstractBeanFactory.java:160)
at org.springframework.beans.factory.support.BeanDefinitionValueResolver.resolveReference(BeanDefinitionValueResolver.java:261)
at org.springframework.beans.factory.support.BeanDefinitionValueResolver.resolveValueIfNecessary(BeanDefinitionValueResolver.java:109)
at org.springframework.beans.factory.support.AbstractAutowireCapableBeanFactory.applyPropertyValues(AbstractAutowireCapableBeanFactory.java:1099)
at org.springframework.beans.factory.support.AbstractAutowireCapableBeanFactory.populateBean(AbstractAutowireCapableBeanFactory.java:861)
at org.springframework.beans.factory.support.AbstractAutowireCapableBeanFactory.createBean(AbstractAutowireCapableBeanFactory.java:421)
at org.springframework.beans.factory.support.AbstractBeanFactory$1.getObject(AbstractBeanFactory.java:251)
at org.springframework.beans.factory.support.DefaultSingletonBeanRegistry.getSingleton(DefaultSingletonBeanRegistry.java:156)
at org.springframework.beans.factory.support.AbstractBeanFactory.getBean(AbstractBeanFactory.java:248)
