Alfresco startup issue when it points to MySQL DB
hani
I have successfully installed Alfresco 2.1 Community edition in my Windows-XP machine and it works fine HSQL-DB. When I changed the files "custom-repository.properties" and  "custom-hibernate-dialect.properties" inorder to use my local MySQL DB the alfresco DB and users are created in my local DB . Now when I started Alfresco. It is showing the following error msg.
Please can any one look on this and let me know wht is wrong
alfresco.log======
10:09:14,515 WARN  [org.springframework.remoting.rmi.RmiRegistryFactoryBean] Could not detect RMI registry - creating new one
10:09:28,703 WARN  [org.alfresco.util.OpenOfficeConnectionTester] A connection to OpenOffice could not be established.
10:09:43,015 INFO  [org.alfresco.repo.domain.schema.SchemaBootstrap] Schema managed by database dialect org.hibernate.dialect.HSQLDialect.
10:09:43,015 INFO  [org.alfresco.repo.domain.schema.SchemaBootstrap] Alfresco is using the HSQL default database. Please only use this while evaluating Alfresco, it is NOT recommended for production or deployment!
10:09:43,578 INFO  [org.alfresco.repo.domain.schema.SchemaBootstrap] Executing database script C:\Alfresco\tomcat\temp\Alfresco\AlfrescoSchemaCreate-org.hibernate.dialect.HSQLDialect-13923.sql (Generated).
10:09:44,750 INFO  [org.alfresco.repo.domain.schema.SchemaBootstrap] Executing database script C:\Alfresco\tomcat\temp\Alfresco\AlfrescoSchemaUpdate-org.hibernate.dialect.HSQLDialect-13924.sql (Copied from classpath:alfresco/dbscripts/create/2.1/org.hibernate.dialect.HSQLDialect/AlfrescoPostCreate-2.1-FKIndexes.sql).
10:09:44,875 INFO  [org.alfresco.repo.domain.schema.SchemaBootstrap] All executed statements written to file C:\Alfresco\tomcat\temp\Alfresco\AlfrescoSchemaUpdate-All_Statements-13925.sql.
10:15:33,062 WARN  [org.alfresco.repo.admin.ConfigurationChecker] The Alfresco 'dir.root' property is set to a relative path './alf_data'.  'dir.root' should be overridden to point to a specific folder.
10:15:33,062 INFO  [org.alfresco.repo.admin.ConfigurationChecker] The Alfresco root data directory ('dir.root') is: .\alf_data
10:15:33,156 INFO  [org.alfresco.repo.admin.patch.PatchExecuter] Checking for patches to apply …
10:15:33,593 INFO  [org.alfresco.repo.module.ModuleServiceImpl] Found 0 module(s).
10:15:34,312 INFO  [org.alfresco.service.descriptor.DescriptorService] Alfresco JVM - v1.5.0_04-b05; maximum heap size 506.313MB
10:15:34,312 INFO  [org.alfresco.service.descriptor.DescriptorService] Alfresco started (Community Network): Current version 2.1.0 (482) schema 64 - Installed version 2.1.0 (482) schema 64
13:26:02,609 WARN  [org.springframework.remoting.rmi.RmiRegistryFactoryBean] Could not detect RMI registry - creating new one
13:26:12,656 WARN  [org.alfresco.util.OpenOfficeConnectionTester] A connection to OpenOffice could not be established.
13:26:26,125 INFO  [org.alfresco.repo.domain.schema.SchemaBootstrap] Schema managed by database dialect org.hibernate.dialect.MySQLInnoDBDialect.
13:26:36,953 INFO  [org.alfresco.repo.domain.schema.SchemaBootstrap] Executing database script C:\Alfresco\tomcat\temp\Alfresco\AlfrescoSchemaUpdate-org.hibernate.dialect.MySQLInnoDBDialect-23630.sql (Generated).
13:26:37,046 INFO  [org.alfresco.repo.domain.schema.SchemaBootstrap] All executed statements written to file C:\Alfresco\tomcat\temp\Alfresco\AlfrescoSchemaUpdate-All_Statements-23631.sql.
13:27:06,359 ERROR [org.springframework.web.context.ContextLoader] Context initialization failed
org.alfresco.error.AlfrescoRuntimeException: Bootstrap failed
   at org.alfresco.repo.importer.ImporterBootstrap.bootstrap(ImporterBootstrap.java:444)
   at org.alfresco.repo.importer.ImporterBootstrap.onBootstrap(ImporterBootstrap.java:666)
Caused by: org.alfresco.repo.search.SearcherException: More than one root node in index: 2
   at org.alfresco.repo.search.impl.lucene.query.LeafScorer.initialise(LeafScorer.java:252)
   at org.alfresco.repo.search.impl.lucene.query.LeafScorer.<init>(LeafScorer.java:164)
   at org.alfresco.repo.search.impl.lucene.query.PathScorer.createPathScorer(PathScorer.java:167)
   at org.alfresco.repo.search.impl.lucene.query.PathQuery$StructuredFieldWeight.scorer(PathQuery.java:258)
   at org.apache.lucene.search.IndexSearcher.search(IndexSearcher.java:130)
   at org.apache.lucene.search.IndexSearcher.search(IndexSearcher.java:100)
   at org.apache.lucene.search.Hits.getMoreDocs(Hits.java:66)
   at org.apache.lucene.search.Hits.<init>(Hits.java:45)
   at org.apache.lucene.search.Searcher.search(Searcher.java:45)
   at org.apache.lucene.search.Searcher.search(Searcher.java:37)
   at org.alfresco.repo.search.impl.lucene.ADMLuceneSearcherImpl.query(ADMLuceneSearcherImpl.java:272)
   at org.alfresco.repo.search.SearcherComponent.query(SearcherComponent.java:85)
   at org.alfresco.repo.importer.ImporterComponent$NodeImporter.resolveImportedNodeRef(ImporterComponent.java:1026)
   at org.alfresco.repo.importer.ImporterComponent$NodeImporter.end(ImporterComponent.java:746)
   at org.alfresco.repo.importer.ImporterComponent.parserImport(ImporterComponent.java:361)
   at org.alfresco.repo.importer.ImporterComponent.importView(ImporterComponent.java:224)
   at org.alfresco.repo.importer.ImporterBootstrap.bootstrap(ImporterBootstrap.java:426)
   … 35 more
13:27:06,390 ERROR [org.apache.catalina.core.ContainerBase.[Catalina].[localhost].[/alfresco]] Exception sending context initialized event to listener instance of class org.springframework.web.context.ContextLoaderListener
   … 35 more
13:27:06,406 ERROR [org.apache.catalina.core.ContainerBase.[Catalina].[localhost].[/alfresco]] Exception sending context initialized event to listener instance of class org.alfresco.web.app.ContextListener
   … 35 more
10 REPLIES 10
davidc
Correct.
Personally, I think the filename should remain system-overview.html and the reference in software_engineering_project.xml should be hard-coded to that name and not use the locale indirection.
