Alfresco 2.1 AND PostgreSQL 9 problems with Startup
giuseppe
Hi all,
I’ve tried to install Alfresco 2.1 because i have to use it with Cmdbuild but I can not to start it .
Versions:
postgres 9.0
Cmdbuild 1.3.1.0
jdk1.6.0_16
Tomcat 6.0
I unpacked alfresco-tomcat-2.1.0.zip in the path C:/alfresco
Configurations :
C:/Alfresco/tomcat/conf/server.xml
<Server port="8006" shutdown="SHUTDOWN">
  <Listener className="org.apache.catalina.mbeans.ServerLifecycleListener" />
  <Listener className="org.apache.catalina.mbeans.GlobalResourcesLifecycleListener" />
  <Listener className="org.apache.catalina.storeconfig.StoreConfigLifecycleListener"/>
  <GlobalNamingResources>
    <Environment name="simpleValue" type="java.lang.Integer" value="30"/>
   <Resource name="UserDatabase" auth="Container"
              type="org.apache.catalina.UserDatabase"
       description="User database that can be updated and saved"
           factory="org.apache.catalina.users.MemoryUserDatabaseFactory"
          pathname="conf/tomcat-users.xml" />
  </GlobalNamingResources>
  <Service name="Catalina">
    <!– Define a non-SSL HTTP/1.1 Connector on port 8080 –>
    <Connector port="8080" URIEncoding="UTF-8" maxHttpHeaderSize="8192"
               maxThreads="150" minSpareThreads="25" maxSpareThreads="75"
               enableLookups="false" redirectPort="8443" acceptCount="100"
               connectionTimeout="20000" disableUploadTimeout="true" />
    <Engine name="Catalina" defaultHost="localhost">
      <Realm className="org.apache.catalina.realm.UserDatabaseRealm"
             resourceName="UserDatabase"/>
      <Host name="localhost" appBase="webapps"
       unpackWARs="true" autoDeploy="true"
       xmlValidation="false" xmlNamespaceAware="false">
      </Host>
</Engine>
</Service>
</Server>
C:/Alfresco/tomcat/shared/classes/alfresco/extension/custom-repository.properties
## Common Alfresco Properties #
# Sample custom content and index data location
dir.root=C:/alfresco/data
dir.indexes=C:/alfresco/data
# Sample database connection properties
db.username=mydbusername
db.password=mydbpwd
#db.pool.initial=10
#db.pool.max=100
# Property to control whether schema updates are performed automatically.
# Updates must be enabled during upgrades as, apart from the static upgrade scripts,
# there are also auto-generated update scripts that will need to be executed.  After
# upgrading to a new version, this can be disabled.
db.schema.update=true
# HSQL connection
#db.driver=org.hsqldb.jdbcDriver
#db.url=jdbc:hsqldb:file:alf_data/hsql_data/alfresco;ifexists=true;shutdown=true;
# MySQL connection (This is default and requires mysql-connector-java-5.0.3-bin.jar, which ships with the Alfresco server)
#db.driver=org.gjt.mm.mysql.Driver
#db.url=jdbc:mysql://localhost/alfresco
# Oracle connection (requires ojdbc14_g.jar or equivalent jar in shared libraries location)
#db.driver=oracle.jdbc.OracleDriver
#db.url=jdbcSmiley Surprisedracle:thin:@localhost:1521:alfresco
# Sybase connection (requires jconn2d.jar or equivalent jar in shared libraries location)
#db.driver=com.sybase.jdbc2.jdbc.SybDriver
#db.url=jdbc:sybase:Tds:localhost:2638/alfresco
# SQLServer connection (requires jdts-1.2.jar or equivalent - http://jtds.sourceforge.net/)
#db.driver=net.sourceforge.jtds.jdbc.Driver
#db.url=jdbc:jtds:sqlserver://localhost/alfresco
# SQLServer connection using Microsoft JDDB driver
#db.driver=com.microsoft.sqlserver.jdbc.SQLServerDriver
#db.url=jdbc:sqlserver://localhost;DatabaseName=alfresco
# PostgreSQL connection (requires postgresql-8.2-504.jdbc3.jar or equivalent)
db.driver=org.postgresql.Driver
db.url=jdbcSmiley Tongueostgresql://localhost:5432/alfresco
C:/alfresco/tomcat/shared/classes/alfresco/extension/custom-hibernate-dialect.properties
# Sample Hibernate configuration for changing Database dialect
# For a full list: http://www.hibernate.org/hib_docs/v3/reference/en/html_single/#configuration-optional-dialects
# HSQL dialect
#hibernate.dialect=org.hibernate.dialect.HSQLDialect
# MySQL dialect (default)
#hibernate.dialect=org.hibernate.dialect.MySQLInnoDBDialect
# Oracle dialect
#hibernate.dialect=org.hibernate.dialect.Oracle9Dialect
# Sybase dialect
#hibernate.dialect=org.alfresco.repo.domain.hibernate.dialect.AlfrescoSybaseAnywhereDialect
# SQLServer dialect
#hibernate.dialect=org.alfresco.repo.domain.hibernate.dialect.AlfrescoSQLServerDialect
# PostgreSQL dialect
hibernate.dialect=org.hibernate.dialect.PostgreSQLDialect
hibernate.query.substitutions=true TRUE, false FALSE
C:/alfresco/tomcat/shared/classes/alfresco/extension/file-server-custom.xml (I add the definition in bold)
<alfresco-config area="file-servers">
   <!– abilitazione server FTP –>
   <serverEnable enabled="true"/>
   <port>1121</port>
   </config>
   <config evaluator="string-compare" condition="Filesystems" replace="true">
      <filesystems>
        <filesystem name="Alfresco">
            <store>workspace://SpacesStore</store>
            <rootPath>/app:company_home</rootPath>
            <!– Add a URL file to each folder that links back to the web client –>
            <urlFile>
               <filename>__Alfresco.url</filename>
               <webpath>http://${localname}:8080/alfresco/</webpath>
            </urlFile>
            <!– Mark locked files as offline –>
            <offlineFiles/>
            <!– Desktop actions –>
            <desktopActions>
               <global>
                  <path>alfresco/desktop/Alfresco.exe</path>
               </global>
               <action>
                  <class>org.alfresco.filesys.smb.server.repo.desk.CheckInOutDesktopAction</class>
                  <name>CheckInOut</name>
                  <filename>__CheckInOut.exe</filename>
               </action>
               <action>
                  <class>org.alfresco.filesys.smb.server.repo.desk.JavaScriptDesktopAction</class>
                  <name>JavaScriptURL</name>
                  <filename>__ShowDetails.exe</filename>
                  <script>alfresco/desktop/showDetails.js</script>
                  <attributes>anyFiles</attributes>
                  <preprocess>copyToTarget</preprocess>
               </action>
            </desktopActions>
         </filesystem>
         <!– AVM virtualization view of all stores/versions for WCM –>
         <avmfilesystem name="AVM">
            <virtualView/>
         </avmfilesystem>
      </filesystems>
   </config>
</alfresco-config>
in postgres , I created the db with name “alfresco“ using PgAdminIII
CREATE DATABASE alfresco
  WITH OWNER = postgres
       ENCODING = 'UTF8'
       TABLESPACE = pg_default
       LC_COLLATE = 'Italian, Italy'
       LC_CTYPE = 'Italian, Italy'
       CONNECTION LIMIT = -1;
I pasted the driver postgresql-8.2-504.jdbc3.jar  in the  directory C:\alfresco\tomcat\common\lib
(I also tried with postgresql-8.3-603.jdbc3.jar but I get the same problems.
Using  postgresql-9.0-801.jdbc4.jar  the alfresco db doesn’t filled.
I deleted the directory alf_data that is substituted with the directory data configured in the custom-repository.properties file.
When I launch  alf_start.bat the database alfresco is filled but the Alfresco page doesn’t start..
alfresco.log:
11:34:45,181 WARN  [org.springframework.remoting.rmi.RmiRegistryFactoryBean] Could not detect RMI registry - creating new one
11:34:48,613 WARN  [org.alfresco.util.OpenOfficeConnectionTester] A connection to OpenOffice could not be established.
11:34:54,572 INFO  [org.alfresco.repo.domain.schema.SchemaBootstrap] Schema managed by database dialect org.hibernate.dialect.PostgreSQLDialect.
11:34:54,728 INFO  [org.alfresco.repo.domain.schema.SchemaBootstrap] Executing database script C:\alfresco\tomcat\temp\Alfresco\AlfrescoSchemaCreate-org.hibernate.dialect.PostgreSQLDialect-7594952547763709728.sql (Generated).
11:35:03,683 INFO  [org.alfresco.repo.domain.schema.SchemaBootstrap] Executing database script C:\alfresco\tomcat\temp\Alfresco\AlfrescoSchemaUpdate-org.hibernate.dialect.PostgreSQLDialect-6410981750726339490.sql (Copied from classpath:alfresco/dbscripts/create/2.1/org.hibernate.dialect.PostgreSQLDialect/AlfrescoPostCreate-2.1-FKIndexes.sql).
11:35:05,804 INFO  [org.alfresco.repo.domain.schema.SchemaBootstrap] All executed statements written to file C:\alfresco\tomcat\temp\Alfresco\AlfrescoSchemaUpdate-All_Statements-7539457490348660135.sql.
11:35:58,860 ERROR [org.springframework.web.context.ContextLoader] Context initialization failed
org.hibernate.type.SerializationException: could not deserialize
   at org.hibernate.util.SerializationHelper.deserialize(SerializationHelper.java:217)
   at org.hibernate.util.SerializationHelper.deserialize(SerializationHelper.java:240)
   at org.hibernate.type.SerializableType.fromBytes(SerializableType.java:82)
   at org.hibernate.type.SerializableType.get(SerializableType.java:39)
   at org.hibernate.type.NullableType.nullSafeGet(NullableType.java:113)
   at org.hibernate.type.NullableType.nullSafeGet(NullableType.java:102)
   at org.hibernate.type.AbstractType.hydrate(AbstractType.java:81)
   at org.hibernate.type.ComponentType.hydrate(ComponentType.java:560)
   at org.hibernate.type.ComponentType.nullSafeGet(ComponentType.java:275)
Caused by: java.io.StreamCorruptedException: invalid stream header: BB656430
   at java.io.ObjectInputStream.readStreamHeader(ObjectInputStream.java:783)
   at java.io.ObjectInputStream.<init>(ObjectInputStream.java:280)
   at org.hibernate.util.SerializationHelper$CustomObjectInputStream.<init>(SerializationHelper.java:252)
   at org.hibernate.util.SerializationHelper.deserialize(SerializationHelper.java:209)
   … 86 more
11:35:59,140 ERROR [org.apache.catalina.core.ContainerBase.[Catalina].[localhost].[/alfresco]] Exception sending context initialized event to listener instance of class org.springframework.web.context.ContextLoaderListener
   … 86 more
11:35:59,374 ERROR [org.apache.catalina.core.ContainerBase.[Catalina].[localhost].[/alfresco]] Exception sending context initialized event to listener instance of class org.alfresco.web.app.ContextListener
   … 86 more
Please help me.
Thanks a lot.
mrogers
Have you installed the Postgress AMP?    Alfresco 2.1 is "before my involvement with Alfresco" but I believe that there used to be a separate AMP that you had to install to get alfresco to use Postgress.
I'd urge you to install a more recent version, especially if you want or need help in the forums.
giuseppe
Hi mrogers
Unfortunately I have to use Alfresco 2.1 because Cmdbuild works only with this version. Do you think that postgres 9.0 is not compatible with Alfresco 2.1?
Is Postgres AMP a particular version? I know Postgres 8.3 only.
giuseppe
Nobody has any idea?
