AIX + Websphere installation (Lucene Alfresco stack problem)
jmgab
Hy,
we are trying to deploy Alfresco 1.4 on AIX (5.3) for Websphere (6.1).
Unfortunately, we encounter the following exception (the cause is in bold) :
[21/02/07 15:51:41:384 GMT] 00000042 WebApp        E   Exception caught while initializing context
org.alfresco.error.AlfrescoRuntimeException: Bootstrap failed
com.ibm.io.async.AbstractAsyncFuture.invokeCallback(AbstractAsyncFuture.java:213)
   at com.ibm.io.async.AsyncChannelFuture$1.run(AsyncChannelFuture.java:163)
   at com.ibm.ws.util.ThreadPool$Worker.run(ThreadPool.java:1469)
Caused by: java.nio.BufferUnderflowException
   at java.nio.Buffer.nextGetIndex(Buffer.java:419)
   at java.nio.DirectByteBuffer.getLong(DirectByteBuffer.java:783)
   at org.alfresco.repo.search.impl.lucene.index.IndexInfo.setStatusFromFile(IndexInfo.java:1489)
   at
org.alfresco.repo.search.impl.lucene.index.IndexInfo.setStatusFromFile(IndexInfo.java:1298)
   at org.alfresco.repo.search.impl.lucene.index.IndexInfo.access$32(IndexInfo.java:1294)
   at org.alfresco.repo.search.impl.lucene.index.IndexInfo$2.doWork(IndexInfo.java:348)
   at org.alfresco.repo.search.impl.lucene.index.IndexInfo.doWithFileLock(IndexInfo.java:1742)
   at org.alfresco.repo.search.impl.lucene.index.IndexInfo.<init>(IndexInfo.java:344)
   at org.alfresco.repo.search.impl.lucene.index.IndexInfo.getIndexInfo(IndexInfo.java:243)
   at org.alfresco.repo.search.impl.lucene.LuceneBase2.initialise(LuceneBase2.java:97)
   at org.alfresco.repo.search.impl.lucene.LuceneIndexerImpl2.getUpdateIndexer(LuceneIndexerImpl2.java:477)
   at org.alfresco.repo.search.impl.lucene.LuceneIndexerAndSearcherFactory2.createIndexer(LuceneIndexerAndSearcherFactory2.java:352)
   at org.alfresco.repo.search.impl.lucene.LuceneIndexerAndSearcherFactory2.getThreadLocalIndexer(LuceneIndexerAndSearcherFactory2.java:309)
   at org.alfresco.repo.search.impl.lucene.LuceneIndexerAndSearcherFactory2.getIndexer(LuceneIndexerAndSearcherFactory2.java:293)
   at org.alfresco.repo.search.impl.lucene.LuceneIndexerAndSearcherFactory2.getIndexer(LuceneIndexerAndSearcherFactory2.java:72)
   at sun.reflect.NativeMethodAccessorImpl.invoke(NativeMethodAccessorImpl.java:64)
   at java.lang.reflect.Method.invoke(Method.java:615)
   at org.alfresco.repo.service.StoreRedirectorProxyFactory$RedirectorInvocationHandler.invoke(StoreRedirectorProxyFactory.java:213)
   at $Proxy17.getIndexer(Unknown Source)
   at org.alfresco.repo.search.IndexerComponent.updateNode(IndexerComponent.java:51)
   at org.springframework.aop.support.AopUtils.invokeJoinpointUsingReflection(AopUtils.java:335)
   at org.springframework.aop.framework.JdkDynamicAopProxy.invoke(JdkDynamicAopProxy.java:165)
   at $Proxy57.updateNode(Unknown Source)
   at org.alfresco.repo.node.index.NodeIndexer.onUpdateNode(NodeIndexer.java:96)
   at org.alfresco.repo.policy.JavaBehaviour$JavaMethodInvocationHandler.invoke(JavaBehaviour.java:243)
   at $Proxy60.onUpdateNode(Unknown Source)
   at org.alfresco.repo.policy.PolicyFactory$MultiHandler.invoke(PolicyFactory.java:243)
   at org.alfresco.repo.policy.$Proxy76.onUpdateNode(Unknown Source)
   at org.alfresco.repo.node.AbstractNodeServiceImpl.invokeOnUpdateNode(AbstractNodeServiceImpl.java:267)
   at org.alfresco.repo.node.db.DbNodeServiceImpl.setProperties(DbNodeServiceImpl.java:889)
   at org.alfresco.repo.node.db.DbNodeServiceImpl.addAspect(DbNodeServiceImpl.java:589)
   at org.alfresco.repo.node.db.DbNodeServiceImpl.createStore(DbNodeServiceImpl.java:193)
   at $Proxy13.createStore(Unknown Source)
   at org.alfresco.repo.importer.ImporterBootstrap.bootstrap(ImporterBootstrap.java:358)
   … 100 more
now, we don't know if it comes from the AIX file management system or from the IBM Jdk.
Anybody can give us some advices ?
For instance, it is possible to avoir Lucene index file locking ? (if it may be the effective cause …)
thanks a lot
JM
ps : it's working on Windows XP for the same Websphere (6.1).
14 REPLIES 14
jperez
Hi
Would you please tell me the steeps you did to deploy Alfresco 2 or 2.1 to WAS 6.1
I’m trying to deploy but I have this exception when I try to start the application:
[6/12/07 17:05:31:171 COT] 00000028 WebApp        A   SRVE0180I: [alfresco_war#alfresco.war] [/alfresco] [Servlet.LOG]: Loading Spring root
WebApplicationContext
[6/12/07 17:05:36:500 COT] 00000028 SystemOut     O 17:05:36,406 ERROR [web.context.ContextLoader] Context initialization failed
        at org.alfresco.util.RuntimeSystemPropertiesSetter.postProcessBeanFactory(RuntimeSystemPropertiesSetter.java:68)
        at org.springframework.context.support.AbstractApplicationContext.invokeBeanFactoryPostProcessors(AbstractApplicationContext.java:38
0)
        at org.springframework.context.support.AbstractApplicationContext.refresh(AbstractApplicationContext.java:302)
        at org.springframework.web.context.support.AbstractRefreshableWebApplicationContext.refresh(AbstractRefreshableWebApplicationContext
.java:134)
        at com.ibm.ws.wswebcontainer.webapp.WebApp.notifyServletContextCreated(WebApp.java:635)
        at com.ibm.ws.webcontainer.webapp.WebApp.commonInitializationFinish(WebApp.java:279)
Thanks in advance
andy
Hi
The steps are going on the wiki.
I have not seen you issue - my guess is it has something to do with logging. Make sure remove the commons-logging stuff in the alfresco distribution as it foes not agree with WAS.
I am still getting jsp error on mixed jstl/jsf pages
Andy
vipul
Hiya,
I am also having the exception (java.nio.BufferUnderflowException) on AIX/WebSphere7/DB2/Alfresc2.1.1E.
Can somebody suggest a solution for this issue?
I am gonna try "useNIOMemoryMapping = false;". But i am really concerned if it will have major side effect. (On load testing, clustering).
It will be great if anyone can suggest on this as well.
dward
See notes on http://wiki.alfresco.com/wiki/Installing_on_WebSphere
It is very important that before commencing installation, you update Websphere with all applicable service packs, including WASSDK (embedded JDK) patches. This is because Alfresco's optimized I/O code requires the very latest patches available from IBM and will not function on an unpatched Websphere 7 installation.
vipul
Thanks dward.
The wiki link is more on Alfresco 3.x releases on WebSphere 7, since I am using Alfresco 2.1.1 Enterprise, will it still require to have patched websphere?
The other link on wiki about installing older version of Alfresco, has instructions with reference to WebSphere 6.1
It will be great If you can also highlight effect on clustering and load testing using "useNIOMemoryMapping =false"
