07-13-2007 03:27 AM
<process-definition xmlns="urn:jbpm.org:jpdl-3.1" name="ovs:ovaanvraag">
<swimlane name="initiator" />
<swimlane name="bouwadv">
<assignment class="org.alfresco.repo.workflow.jbpm.AlfrescoAssignment">
<actor>#{people.getMembers(people.getGroup("BouwAdviesGroep"))[0].properties['cm:userName']}</actor>
</assignment>
</swimlane>
<swimlane name="reclameadv">
<actor>#{people.getMembers(people.getGroup("ReclameAdviesGroep"))[0].properties['cm:userName']}</actor>
</assignment>
</swimlane>
<start-state name="start">
<task name="ovs:startaanvraag" swimlane="initiator"/>
<transition name="" to="DoAction1"></transition>
</start-state>
<task-node name="DoAction1">
<task name="ovs:DoBouw" swimlane="bouwadv"></task>
<transition name="" to="DoAction2"></transition>
</task-node>
<task-node name="DoAction2">
<task name="ovs:DoReclame" swimlane="reclameadv"></task>
<transition name="" to="task7"></transition>
</task-node>
<task-node name="task7">
<task name="ovs:DoEinde" swimlane="initiator"></task>
<transition name="" to="end1"></transition>
</task-node>
<end-state name="end1"></end-state>
</process-definition>
<decision name="testAction1">
<event type="node-enter">
<script>
pwf_doctype = bpm_package.children[0].properties["omgevingsvergunning:bouwvergunning"];
</script>
</event>
<condition>#{pwf_doctype==true}</condition>
</transition>
<transition name="tr2" to="join1"></transition>
</decision>
My idea was to use one fork node that has transactions to 6 decision nodes. These desicion node have transactions to one task node and to the join node (if property=true then task else the join). The tasks have transactions to the join also. The join then triggers a task for the initiator.
08:42:54,886 WARN [org.springframework.remoting.rmi.RmiRegistryFactoryBean] Could not detect RMI registry - creating new one
08:43:02,602 WARN [org.alfresco.repo.admin.ConfigurationChecker] The Alfresco 'dir.root' property is set to a relative path './alf_data'. 'dir.root' should be overridden to point to a specific folder.
08:43:02,602 INFO [org.alfresco.repo.admin.ConfigurationChecker] The Alfresco root data directory ('dir.root') is: .\alf_data
08:43:02,742 INFO [org.alfresco.repo.admin.patch.PatchExecuter] Checking for patches to apply …
08:43:02,774 INFO [org.alfresco.repo.admin.patch.PatchExecuter] No patches were required.
08:43:02,789 INFO [org.alfresco.repo.module.ModuleServiceImpl] Found 1 module(s).
08:43:02,867 INFO [org.alfresco.repo.module.ModuleServiceImpl] Starting module 'omgevingsvergunningspel' version 0.1.
08:43:03,350 INFO [org.alfresco.service.descriptor.DescriptorService] Alfresco JVM - v1.5.0_08-b03; maximum heap size 493,063MB
08:43:03,350 WARN [org.alfresco.service.descriptor.DescriptorService] Alfresco JVM - WARNING - maximum heap size 493,063MB is less than recommended 512MB
08:43:03,350 INFO [org.alfresco.service.descriptor.DescriptorService] Alfresco started (Community Network): Current version 2.0.0 (build-185) schema 38 - Installed version 2.0.0 (build-185) schema 38
08:45:29,323 ERROR [org.alfresco.web.ui.common.Utils] A system error happened during the operation: Failed to signal transition 'null' from workflow task 'jbpm$7'
org.alfresco.service.cmr.workflow.WorkflowException: Failed to signal transition 'null' from workflow task 'jbpm$7'
at org.alfresco.repo.workflow.jbpm.JBPMEngine.endTask(JBPMEngine.java:1064)
at org.alfresco.repo.workflow.WorkflowServiceImpl.endTask(WorkflowServiceImpl.java:347)
at org.springframework.aop.support.AopUtils.invokeJoinpointUsingReflection(AopUtils.java:335)
at org.springframework.aop.framework.ReflectiveMethodInvocation.invokeJoinpoint(ReflectiveMethodInvocation.java:181)
at org.springframework.aop.framework.ReflectiveMethodInvocation.proceed(ReflectiveMethodInvocation.java:148)
at org.springframework.aop.support.DelegatingIntroductionInterceptor.invoke(DelegatingIntroductionInterceptor.java:116)
at org.springframework.aop.framework.ReflectiveMethodInvocation.proceed(ReflectiveMethodInvocation.java:170)
at org.alfresco.repo.security.permissions.impl.AlwaysProceedMethodInterceptor.invoke(AlwaysProceedMethodInterceptor.java:40)
at org.alfresco.repo.security.permissions.impl.ExceptionTranslatorMethodInterceptor.invoke(ExceptionTranslatorMethodInterceptor.java:49)
at org.alfresco.repo.audit.AuditComponentImpl.auditImpl(AuditComponentImpl.java:219)
at org.alfresco.repo.audit.AuditComponentImpl.audit(AuditComponentImpl.java:165)
at org.alfresco.repo.audit.AuditMethodInterceptor.invoke(AuditMethodInterceptor.java:69)
at org.springframework.transaction.interceptor.TransactionInterceptor.invoke(TransactionInterceptor.java:96)
at org.springframework.aop.framework.JdkDynamicAopProxy.invoke(JdkDynamicAopProxy.java:176)
at $Proxy22.endTask(Unknown Source)
at org.alfresco.web.bean.workflow.StartWorkflowWizard.finishImpl(StartWorkflowWizard.java:194)
at org.alfresco.web.bean.dialog.BaseDialogBean.finish(BaseDialogBean.java:115)
at org.alfresco.web.bean.wizard.WizardManager.finish(WizardManager.java:521)
at org.apache.myfaces.el.MethodBindingImpl.invoke(MethodBindingImpl.java:129)
at org.apache.myfaces.application.ActionListenerImpl.processAction(ActionListenerImpl.java:63)
at javax.faces.component.UICommand.broadcast(UICommand.java:106)
at javax.faces.component.UIViewRoot._broadcastForPhase(UIViewRoot.java:90)
at javax.faces.component.UIViewRoot.processApplication(UIViewRoot.java:164)
at org.apache.myfaces.lifecycle.LifecycleImpl.invokeApplication(LifecycleImpl.java:316)
at org.apache.myfaces.lifecycle.LifecycleImpl.execute(LifecycleImpl.java:86)
at javax.faces.webapp.FacesServlet.service(FacesServlet.java:105)
at org.apache.catalina.core.ApplicationFilterChain.internalDoFilter(ApplicationFilterChain.java:252)
at org.alfresco.web.app.servlet.AuthenticationFilter.doFilter(AuthenticationFilter.java:81)
at org.apache.catalina.core.ApplicationFilterChain.internalDoFilter(ApplicationFilterChain.java:202)
at org.apache.coyote.http11.Http11Processor.process(Http11Processor.java:869)
at org.apache.coyote.http11.Http11BaseProtocol$Http11ConnectionHandler.processConnection(Http11BaseProtocol.java:664)
Caused by: org.jbpm.graph.def.DelegationException
at org.jbpm.taskmgmt.exe.TaskMgmtInstance.performAssignment(TaskMgmtInstance.java:208)
at org.jbpm.taskmgmt.exe.TaskMgmtInstance.getInitializedSwimlaneInstance(TaskMgmtInstance.java:176)
at org.jbpm.taskmgmt.exe.TaskInstance.assign(TaskInstance.java:192)
at org.jbpm.taskmgmt.exe.TaskMgmtInstance.createTaskInstance(TaskMgmtInstance.java:148)
at org.jbpm.graph.node.TaskNode.execute(TaskNode.java:167)
at org.jbpm.graph.def.Node.enter(Node.java:316)
at org.jbpm.graph.def.Node$$FastClassByCGLIB$$d187eeda.invoke(<generated>)
at net.sf.cglib.proxy.MethodProxy.invoke(MethodProxy.java:163)
at org.hibernate.proxy.CGLIBLazyInitializer.intercept(CGLIBLazyInitializer.java:161)
at org.jbpm.graph.def.Node$$EnhancerByCGLIB$$fa63675b.enter(<generated>)
at org.jbpm.graph.def.Transition.take(Transition.java:119)
at org.jbpm.graph.def.Node.leave(Node.java:383)
at org.jbpm.graph.node.StartState.leave(StartState.java:70)
at org.jbpm.graph.def.Node$$EnhancerByCGLIB$$fa63675b.leave(<generated>)
at org.jbpm.graph.exe.Token.signal(Token.java:174)
at org.jbpm.graph.exe.Token.signal(Token.java:123)
at org.jbpm.taskmgmt.exe.TaskInstance.end(TaskInstance.java:441)
at org.alfresco.repo.workflow.jbpm.WorkflowTaskInstance.end(WorkflowTaskInstance.java:126)
at org.jbpm.taskmgmt.exe.TaskInstance.end(TaskInstance.java:355)
at org.alfresco.repo.workflow.jbpm.JBPMEngine$19.doInJbpm(JBPMEngine.java:1040)
at org.springframework.orm.hibernate3.HibernateTemplate.execute(HibernateTemplate.java:365)
at org.springframework.orm.hibernate3.HibernateTemplate.execute(HibernateTemplate.java:333)
at org.alfresco.repo.workflow.jbpm.JBPMEngine.endTask(JBPMEngine.java:1017)
… 54 more
Caused by: org.alfresco.service.cmr.repository.ScriptException: Failed to execute supplied script: Wrapped java.lang.NullPointerException (AlfrescoScript#1)
at org.alfresco.repo.jscript.RhinoScriptService.executeScriptString(RhinoScriptService.java:235)
at org.alfresco.repo.audit.AuditComponentImpl.audit(AuditComponentImpl.java:204)
at $Proxy55.executeScriptString(Unknown Source)
at org.alfresco.repo.workflow.jbpm.AlfrescoJavaScript.executeScript(AlfrescoJavaScript.java:157)
at org.alfresco.repo.workflow.jbpm.AlfrescoAssignment.assign(AlfrescoAssignment.java:89)
at org.jbpm.taskmgmt.exe.TaskMgmtInstance.performAssignmentDelegation(TaskMgmtInstance.java:217)
at org.jbpm.taskmgmt.exe.TaskMgmtInstance.performAssignment(TaskMgmtInstance.java:193)
… 81 more
Caused by: org.alfresco.error.AlfrescoRuntimeException: Wrapped java.lang.NullPointerException (AlfrescoScript#1)
at org.alfresco.repo.jscript.RhinoScriptService.executeScriptImpl(RhinoScriptService.java:311)
at org.alfresco.repo.jscript.RhinoScriptService.executeScriptString(RhinoScriptService.java:231)
… 105 more
Caused by: org.mozilla.javascript.WrappedException: Wrapped java.lang.NullPointerException (AlfrescoScript#1)
at org.mozilla.javascript.Context.throwAsScriptRuntimeEx(Context.java:1705)
at org.mozilla.javascript.MemberBox.invoke(MemberBox.java:157)
at org.mozilla.javascript.NativeJavaMethod.call(NativeJavaMethod.java:201)
at org.mozilla.javascript.Interpreter.interpretLoop(Interpreter.java:3082)
at org.mozilla.javascript.Interpreter.interpret(Interpreter.java:2248)
at org.mozilla.javascript.InterpretedFunction.call(InterpretedFunction.java:158)
at org.mozilla.javascript.ContextFactory.doTopCall(ContextFactory.java:337)
at org.mozilla.javascript.ScriptRuntime.doTopCall(ScriptRuntime.java:2755)
at org.mozilla.javascript.InterpretedFunction.exec(InterpretedFunction.java:169)
at org.mozilla.javascript.Context.evaluateReader(Context.java:1175)
at org.alfresco.repo.jscript.RhinoScriptService.executeScriptImpl(RhinoScriptService.java:299)
… 106 more
at org.alfresco.repo.jscript.People.getContainedAuthorities(People.java:150)
at org.alfresco.repo.jscript.People.getMembers(People.java:136)
at org.mozilla.javascript.MemberBox.invoke(MemberBox.java:142)
… 115 more
08:53:40,128 WARN [org.springframework.remoting.rmi.RmiRegistryFactoryBean] Could not detect RMI registry - creating new one
08:53:47,635 WARN [org.alfresco.repo.admin.ConfigurationChecker] The Alfresco 'dir.root' property is set to a relative path './alf_data'. 'dir.root' should be overridden to point to a specific folder.
08:53:47,635 INFO [org.alfresco.repo.admin.ConfigurationChecker] The Alfresco root data directory ('dir.root') is: .\alf_data
08:53:47,823 INFO [org.alfresco.repo.admin.patch.PatchExecuter] Checking for patches to apply …
08:53:47,854 INFO [org.alfresco.repo.admin.patch.PatchExecuter] No patches were required.
08:53:47,870 INFO [org.alfresco.repo.module.ModuleServiceImpl] Found 1 module(s).
08:53:47,995 INFO [org.alfresco.repo.module.ModuleServiceImpl] Starting module 'omgevingsvergunningspel' version 0.1.
08:53:48,433 INFO [org.alfresco.service.descriptor.DescriptorService] Alfresco JVM - v1.5.0_08-b03; maximum heap size 493,063MB
08:53:48,433 WARN [org.alfresco.service.descriptor.DescriptorService] Alfresco JVM - WARNING - maximum heap size 493,063MB is less than recommended 512MB
08:53:48,433 INFO [org.alfresco.service.descriptor.DescriptorService] Alfresco started (Community Network): Current version 2.0.0 (build-185) schema 38 - Installed version 2.0.0 (build-185) schema 38
08:54:59,297 ERROR [org.alfresco.web.ui.common.Utils] A system error happened during the operation: Failed to signal transition 'null' from workflow task 'jbpm$9'
org.alfresco.service.cmr.workflow.WorkflowException: Failed to signal transition 'null' from workflow task 'jbpm$9'
at org.jbpm.graph.def.Node$$EnhancerByCGLIB$$fc9bfb93.enter(<generated>)
at org.jbpm.graph.def.Node$$EnhancerByCGLIB$$fc9bfb93.leave(<generated>)
… 54 more
… 81 more
… 105 more
… 106 more
at org.alfresco.repo.jscript.People.getMembers(People.java:124)
… 115 more
08:58:05,763 WARN [org.springframework.remoting.rmi.RmiRegistryFactoryBean] Could not detect RMI registry - creating new one
08:58:13,656 WARN [org.alfresco.repo.admin.ConfigurationChecker] The Alfresco 'dir.root' property is set to a relative path './alf_data'. 'dir.root' should be overridden to point to a specific folder.
08:58:13,656 INFO [org.alfresco.repo.admin.ConfigurationChecker] The Alfresco root data directory ('dir.root') is: .\alf_data
08:58:13,781 INFO [org.alfresco.repo.admin.patch.PatchExecuter] Checking for patches to apply …
08:58:13,875 INFO [org.alfresco.repo.admin.patch.PatchExecuter] No patches were required.
08:58:13,890 INFO [org.alfresco.repo.module.ModuleServiceImpl] Found 1 module(s).
08:58:13,984 INFO [org.alfresco.repo.module.ModuleServiceImpl] Starting module 'omgevingsvergunningspel' version 0.1.
08:58:14,516 INFO [org.alfresco.service.descriptor.DescriptorService] Alfresco JVM - v1.5.0_08-b03; maximum heap size 493,063MB
08:58:14,516 WARN [org.alfresco.service.descriptor.DescriptorService] Alfresco JVM - WARNING - maximum heap size 493,063MB is less than recommended 512MB
08:58:14,516 INFO [org.alfresco.service.descriptor.DescriptorService] Alfresco started (Community Network): Current version 2.0.0 (build-185) schema 38 - Installed version 2.0.0 (build-185) schema 38
08:59:05,845 ERROR [org.alfresco.web.ui.common.Utils] A system error happened during the operation: Failed to signal transition 'null' from workflow task 'jbpm$11'
org.alfresco.service.cmr.workflow.WorkflowException: Failed to signal transition 'null' from workflow task 'jbpm$11'
at org.jbpm.graph.def.Node$$EnhancerByCGLIB$$bda86dbf.enter(<generated>)
at org.jbpm.graph.def.Node$$EnhancerByCGLIB$$bda86dbf.leave(<generated>)
… 54 more
Caused by: org.alfresco.service.cmr.repository.ScriptException: Failed to execute supplied script: ReferenceError: "GROUP_BouwAdviesGroep" is not defined. (AlfrescoScript#1)
… 81 more
Caused by: org.alfresco.error.AlfrescoRuntimeException: ReferenceError: "GROUP_BouwAdviesGroep" is not defined. (AlfrescoScript#1)
… 105 more
Caused by: org.mozilla.javascript.EcmaError: ReferenceError: "GROUP_BouwAdviesGroep" is not defined. (AlfrescoScript#1)
at org.mozilla.javascript.ScriptRuntime.constructError(ScriptRuntime.java:3226)
at org.mozilla.javascript.ScriptRuntime.constructError(ScriptRuntime.java:3216)
at org.mozilla.javascript.ScriptRuntime.notFoundError(ScriptRuntime.java:3289)
at org.mozilla.javascript.ScriptRuntime.name(ScriptRuntime.java:1567)
at org.mozilla.javascript.Interpreter.interpretLoop(Interpreter.java:3159)
… 106 more
09:01:09,021 WARN [org.springframework.remoting.rmi.RmiRegistryFactoryBean] Could not detect RMI registry - creating new one
09:01:16,943 WARN [org.alfresco.repo.admin.ConfigurationChecker] The Alfresco 'dir.root' property is set to a relative path './alf_data'. 'dir.root' should be overridden to point to a specific folder.
09:01:16,943 INFO [org.alfresco.repo.admin.ConfigurationChecker] The Alfresco root data directory ('dir.root') is: .\alf_data
09:01:17,115 INFO [org.alfresco.repo.admin.patch.PatchExecuter] Checking for patches to apply …
09:01:17,162 INFO [org.alfresco.repo.admin.patch.PatchExecuter] No patches were required.
09:01:17,178 INFO [org.alfresco.repo.module.ModuleServiceImpl] Found 1 module(s).
09:01:17,256 INFO [org.alfresco.repo.module.ModuleServiceImpl] Starting module 'omgevingsvergunningspel' version 0.1.
09:01:17,881 INFO [org.alfresco.service.descriptor.DescriptorService] Alfresco JVM - v1.5.0_08-b03; maximum heap size 493,063MB
09:01:17,881 WARN [org.alfresco.service.descriptor.DescriptorService] Alfresco JVM - WARNING - maximum heap size 493,063MB is less than recommended 512MB
09:01:17,881 INFO [org.alfresco.service.descriptor.DescriptorService] Alfresco started (Community Network): Current version 2.0.0 (build-185) schema 38 - Installed version 2.0.0 (build-185) schema 38
09:01:46,587 ERROR [org.alfresco.web.ui.common.Utils] A system error happened during the operation: Failed to signal transition 'null' from workflow task 'jbpm$13'
org.alfresco.service.cmr.workflow.WorkflowException: Failed to signal transition 'null' from workflow task 'jbpm$13'
… 54 more
… 81 more
… 105 more
… 106 more
09:03:24,201 WARN [org.springframework.remoting.rmi.RmiRegistryFactoryBean] Could not detect RMI registry - creating new one
09:03:32,065 WARN [org.alfresco.repo.admin.ConfigurationChecker] The Alfresco 'dir.root' property is set to a relative path './alf_data'. 'dir.root' should be overridden to point to a specific folder.
09:03:32,065 INFO [org.alfresco.repo.admin.ConfigurationChecker] The Alfresco root data directory ('dir.root') is: .\alf_data
09:03:32,237 INFO [org.alfresco.repo.admin.patch.PatchExecuter] Checking for patches to apply …
09:03:32,268 INFO [org.alfresco.repo.admin.patch.PatchExecuter] No patches were required.
09:03:32,283 INFO [org.alfresco.repo.module.ModuleServiceImpl] Found 1 module(s).
09:03:32,393 INFO [org.alfresco.repo.module.ModuleServiceImpl] Starting module 'omgevingsvergunningspel' version 0.1.
09:03:32,922 INFO [org.alfresco.service.descriptor.DescriptorService] Alfresco JVM - v1.5.0_08-b03; maximum heap size 493,063MB
09:03:32,922 WARN [org.alfresco.service.descriptor.DescriptorService] Alfresco JVM - WARNING - maximum heap size 493,063MB is less than recommended 512MB
09:03:32,938 INFO [org.alfresco.service.descriptor.DescriptorService] Alfresco started (Community Network): Current version 2.0.0 (build-185) schema 38 - Installed version 2.0.0 (build-185) schema 38
09:04:12,495 ERROR [org.alf
10-03-2007 02:46 AM
