Activiti design with a custom workflow engine
thabet
Hello everyone,
I am working on a customized workflow engine and I need a graphic tool to provide a instantly monitoring of my process. So I think I can use the design "power" of activiti.
jbarrez
You can, as long as the workflow engine understands BPMN 2.0 … if not .. then you will need to tweak the ouput generation or do a mapping from the one output to the other.
thabet
Yes it does Smiley Wink
jbarrez
Then it should be no problem 🙂
