Activiti Default H2 JDBC Connection String Is not longer valid
juacosta
I am using Activiti v5.16.3 and H2 v1.4.181 to run my JUnit test suite.
My test suite is using "ProcessEngineConfiguration.createStandaloneProcessEngineConfiguration()". After I upgraded the H2 DB engine to v1.4.181 calling the the method fails to connect. It seems H2 has changed the URL from "jdbc:h2:tcp://localhost/activiti" to "jdbc:h2:tcp://localhost/~/activiti" and the exception thrown indicates it is now required to specify either a relative of fully qualified path.
have you seen this? are there any patches you recommend applying?
Here is in example of the error:
09 Oct 2014 16:57:26,731 [main] DEBUG org.activiti.engine.impl.cfg.ProcessEngineConfigurationImpl:563 - initializing datasource to db: jdbc:h2:tcp://localhost/activiti
09 Oct 2014 16:57:26,781 [main] DEBUG org.apache.ibatis.logging.LogFactory:124 - Logging initialized using 'class org.apache.ibatis.logging.slf4j.Slf4jImpl' adapter.
09 Oct 2014 16:57:26,790 [main] DEBUG org.apache.ibatis.datasource.pooled.PooledDataSource:304 - PooledDataSource forcefully closed/removed all connections.
09 Oct 2014 16:57:26,900 [main] ERROR org.activiti.engine.impl.cfg.ProcessEngineConfigurationImpl:657 - Exception while initializing Database connection
org.h2.jdbc.JdbcSQLException: A file path that is implicitly relative to the current working directory is not allowed in the database URL "jdbc:h2:tcp://localhost/activiti". Use an absolute path, ~/name, ./name, or the baseDir setting instead. [90011-181]
   at org.h2.message.DbException.getJdbcSQLException(DbException.java:345)
   at org.h2.message.DbException.get(DbException.java:179)
   at org.h2.message.DbException.get(DbException.java:155)
   at org.h2.engine.ConnectionInfo.getName(ConnectionInfo.java:398)
   at org.h2.engine.Engine.openSession(Engine.java:45)
   at org.h2.engine.Engine.openSession(Engine.java:167)
   at org.h2.engine.Engine.createSessionAndValidate(Engine.java:145)
   at org.h2.engine.Engine.createSession(Engine.java:128)
   at org.h2.server.TcpServerThread.run(TcpServerThread.java:149)
trademak
Ok, for now you can manually configure the H2 database URL using the Activiti ProcessEngineConfiguration. We'll look into upgrading to a more recent H2 version for the new Activiti release.
Best regards,
juacosta
Tijs,
Thanks a lot for acknowledging, I switched my code already. I will be looking forward to hear about the patch
