Activiti 5.0 Engine ported to SQL Server 2008
k_kunti
Hi All
I was trying to port Activiti 5.0 (ENGINE ONLY) to Microsoft SQL server (as mentioned in the WIKI); got some encouraging results:
Tests run: 460, Failures: 2, Errors: 0, Skipped: 0
These two cases relates to
1. classname="org.activiti.engine.test.api.repository.ProcessDefinitionQueryTest" name="testQueryByNameLike"
2. classname="org.activiti.engine.test.api.runtime.RuntimeServiceTest" name="testNonUniqueBusinessKey"… unique business key
I have in included the files in the zip file (MS SQL SERVER Support\TestSuiteErrorDetails)
I have also included scripts for create and dropping of database; Please check if something needs to be modified here.
Have modified one test suite class : org.activiti.examples.mgmt.ManagementServiceTest; to include appropriate data time for SQL server  assertOneOf(new String [] {"TIMESTAMP", "TIMESTAMP(6)","DATETIME"}. Please find the class at location: MS SQL SERVER Support\Test_Suite_class_change\org\activiti\examples\mgmt
Have added one new class (MssqlDbMetaDataHandler.java) and modified one existing class (TableMetaDataCacheHandler.java), I have included these classes at location:
MS SQL SERVER Support\activiti-engine\org\activiti\engine\impl\db
The code was built in Activiti 5.0 tag , SVN details can be found in: Activiti 5.0 tag URL.txt. The command to run the code is included in: command.txt
There is some discussion on the web on creation of (MS SQL server specific) unique constraints on a column that allows multiple NULL…the URL is included in the document  Link for SQL for unique constraint Business Key.txt…. I tried this one but runs into issues.
HELP Needed from Activity team and Community on the following:
1. Run the test to confirm the results I am getting, correct any mistakes made in the SQL.
2. Creation of MYbatis SQL server query for Link for SQL for unique constraint Business Key.txtclassname="org.activiti.engine.test.api.repository.ProcessDefinitionQueryTest" name="testQueryByNameLike"
3. Help regarding solving: classname="org.activiti.engine.test.api.runtime.RuntimeServiceTest" name="testNonUniqueBusinessKey"… unique business key
4.Tying any loose end.
Thanks in advance
Krish
11 REPLIES 11
jschnitzer
Will there be support for SQL Server 2005? We seem to be hitting issues on unique keys that have a filter:
create unique index ACT_UNIQ_RU_BUS_KEY on ACT_RU_EXECUTION (PROC_DEF_ID_, BUSINESS_KEY_) where BUSINESS_KEY_ is not null;
Also, of note: I attempted to install the schema from the following file:
https://svn.codehaus.org/activiti/activiti/tags/activiti-5.3/modules/activiti-engine/src/main/resour...
I am using the 5.3 version of the engine. If you inspect this file you can see:
insert into ACT_GE_PROPERTY
values ('schema.version', '5.1', 1);
values ('schema.history', 'create(5.1)', 1);
Seems to be set to 5.1
Granted I am hacking around a bit to try to get this schema installed as I could not install it from the auto create due to the index issues on 2005.
We are stoked to add Activiti into our environment. Just currently limited by having to use a MS SQL SERVER 2005 database.
Thank you.
Jason
frederikherema1
There are no plans for supporting mssql 2005 yet.
About the version-issue in the create-scripts, thank you for reporting, i'll fix this on trunk. We still don't have full QA set up for mssql now (also thats why it's still marked as "experimental"), this slipped in under the radar.
