A Little Problem with Web Studio
awilaz
Hi folks,
I installed Alfresco 3.4 and after many little problems caused by change Tomcat ports, this running, but I can`t access the web Studio. Always presents this error below.
My URL
http://10.33.4.11:8888/awe/page/metadata
Error:
type Exception report
message
description The server encountered an internal error () that prevented it from fulfilling this request.
exception
org.springframework.web.util.NestedServletException: Request processing failed; nested exception is java.lang.Exception: org.springframework.extensions.surf.exception.PlatformRuntimeException: 01140002 No 'login' page type configured - but page auth required it.
   org.springframework.web.servlet.FrameworkServlet.processRequest(FrameworkServlet.java:659)
   org.springframework.web.servlet.FrameworkServlet.doGet(FrameworkServlet.java:552)
   javax.servlet.http.HttpServlet.service(HttpServlet.java:617)
   javax.servlet.http.HttpServlet.service(HttpServlet.java:717)
root cause
   org.springframework.extensions.surf.mvc.AbstractWebFrameworkView.renderMergedOutputModel(AbstractWebFrameworkView.java:293)
   org.springframework.web.servlet.view.AbstractView.render(AbstractView.java:250)
   org.springframework.web.servlet.DispatcherServlet.render(DispatcherServlet.java:1060)
   org.springframework.web.servlet.DispatcherServlet.doDispatch(DispatcherServlet.java:798)
   org.springframework.web.servlet.DispatcherServlet.doService(DispatcherServlet.java:716)
   org.springframework.web.servlet.FrameworkServlet.processRequest(FrameworkServlet.java:647)
root cause
   org.springframework.extensions.surf.mvc.PageView.renderView(PageView.java:283)
   org.springframework.extensions.surf.mvc.AbstractWebFrameworkView.renderMergedOutputModel(AbstractWebFrameworkView.java:285)
note The full stack trace of the root cause is available in the Apache Tomcat/6.0.26 logs.
Anybody can help me?
lsibilla
I got the same problem. Did you solve it ? I'm runing on 3.4.d.
lemmy
Same here. Anyone out there with a solution?
Lemmy
