Run Activiti 6.0.0.4 process engine on mysql
malex56
When I run Activiti 6.0.0.4 process engine on mysql I get error:
Error creating bean with name 'processEngine': FactoryBean threw exception on object creation; nested exception is org.activiti.engine.ActivitiException: Could not update Activiti database schema: unknown version from database: '6.0.0.4'
I find also LAST_V5_VERSION = "5.99.0.0" in DbSqlSession
How can I avoid this error?
Thanks in advance,
Alex
malex56
Found a mistake in itself.
The version of the libraries did not match the schema version
malex56
