Problem executing a Shell Task
edagher
I'm trying to execute a shell task as per the activiti user guide example:
<serviceTask id="shellEcho" activiti:type="shell" >
   <extensionElements>
      <activiti:field name="command" stringValue="cmd" />
     <activiti:field name="arg1" stringValue="/c" />
     <activiti:field name="arg2" stringValue="echo" />
     <activiti:field name="arg3" stringValue="EchoTest" />
     <activiti:field name="wait" stringValue="true" />
     <activiti:field name="outputVariable" stringValue="resultVar" />
  </extensionElements>
</serviceTask>
It's giving me the below error:
Errors while parsing:[Validation set: 'activiti-executable-process' | Problem: 'activiti-servicetask-missing-implementation'] : One of the attributes 'class', 'delegateExpression', 'type', 'operation', or 'expression' is mandatory on serviceTask.
Can anyone help on how to fix this? what values do i need to set in these attributes.
Thank you
mgreene
I'm bumping this as I had the same issue and want to raise visibility.
I noticed that when exporting the module, the
part of the ServiceTask was removed, although it was definitely there when I imported the module file.
