08-11-2017 12:19 PM
I am trying to configure a custom mybatis query and missing something.
I created my interface
package com.activiti.mappers;
import org.apache.ibatis.annotations.Select;
import java.util.List;
public interface CustomMybatisMapper {
@Select("SELECT ID_ FROM ACT_RE_PROCDEF WHERE KEY_ = #{key}")
String loadProcessDefinitionIdByKey(String key);
I added an xml file under src/main/resources/mappers/CustomMybatisXmlmapper.xml
<?xml version="1.0" encoding="UTF-8" ?>
<!DOCTYPE mapper PUBLIC "-//mybatis.org//DTD Mapper 3.0//EN" "http://mybatis.org/dtd/mybatis-3-mapper.dtd">
<mapper namespace="com.activiti.mappers.CustomMybatisMapper">
<!-- SELECT ALL PROCESS DEFINITION ID -->
<select id="selectProcessDefinitionDeploymentIdByKey" parameterType="String" resultType="String">
SELECT DEPLOYMENT_ID_ FROM ACT_RE_PROCDEF WHERE KEY_ = #{value}
</select>
</mapper>
I added an application.properties entry
spring.activiti.customMybatisXMLMappers[0] = mappers/CustomMybatisXmlMapper.xml
spring.activiti.customMybatisMappers[0] = com.activiti.mappers.CustomMybatisMapper
I put those in the activiti-app.properties too.
The one thing I cannot figure out is this part of the directions.
<property name="customMybatisMappers"> <set> <value>org.activiti.standalone.cfg.MyTestMapper</value> </set> </property>
which in my case would be
<property name="customMybatisMappers"> <set> <value>com.activiti.mappers.CustomMybatisMapper</value> </set> </property>
Where does this go???? I was also investigating doing the configuration using the
ProcessEngineConfigurationConfigurer
when I run the following code
String processDefinitionId = managementService.executeCustomSql(new AbstractCustomSqlExecution<CustomMybatisMapper, String>(CustomMybatisMapper.class) {
@Override
public String execute(CustomMybatisMapper customMybatisMapper) {
return customMybatisMapper.loadProcessDefinitionIdByKey("myprocesskey");
I get:
org.apache.ibatis.binding.BindingException: Type interface com.activiti.mappers.CustomMybatisMapper is not known to the MapperRegistry.
Alfresco Process Services
08-11-2017 03:45 PM
Ok after much banging my head agains the desk I have figured it out and will post here to help the next guy. The documentation I read only gets you so far or assumes you know something which I definitely didn't
I am running in a spring boot configuration in tomcat
In the pom.xml I added
<dependency>
<groupId>com.activiti</groupId>
<artifactId>activiti-spring-boot-starter-basic</artifactId>
<version>${activiti.version}</version>
</dependency>
To setup a custom sql query you first create you mapping interface ( i chose com.activiti.mappers as my namespace)
I just used a dummy query for this to see if it worked
under com.activiti.extension.conf namespace I created a configurer and a configuration (the configuration class was the final key for me)
package com.activiti.extension.conf;
import java.util.HashSet;
import java.util.Set;
import org.activiti.spring.SpringProcessEngineConfiguration;
import com.activiti.api.engine.ProcessEngineConfigurationConfigurer;
import org.springframework.context.annotation.Configuration;
import com.activiti.mappers.CustomMybatisMapper;
@Configuration
public class FooCustomMybatisConfigurer implements ProcessEngineConfigurationConfigurer {
@Override
public void processEngineConfigurationInitialized(
SpringProcessEngineConfiguration springProcessEngineConfiguration) {
Set<Class<?>> batisMappers = new HashSet<>();
batisMappers.add(CustomMybatisMapper.class);
springProcessEngineConfiguration.setCustomMybatisMappers(batisMappers);
System.out.println("Mapper added");
and then the bean creation in the configuration
import org.springframework.context.annotation.Bean;
@Configuration
public class FooProcessEngineConfig {
@Bean
public ProcessEngineConfigurationConfigurer processEngineConfigurationConfigurer(){
return new FooCustomMybatisConfigurer();
And the code to call the query
@Override
return customMybatisMapper.loadProcessDefinitionIdByKey("<your process here>");
No xml configuration needed or properties files tho I am sure you can and maybe should do it that way but this is working.
08-11-2017 03:45 PM
<dependency>
</dependency>
@Configuration
@Override
@Configuration
@Bean
@Override
