06-15-2021 02:09 PM
I currently run Community 5.2.x and was tasked with migrating us to Community 7.0 (via ansible installation method).
I've been reading through numerous installation/migration guides trying to piece together the steps required to do this into one spot.
This is what I have accomplished.
1. Unzip alfresco-ansible-deployment-1.0 zip file on new Centos/7 VM.
2. Copy alfresco-global.properties from Community 5.2.x to ~/alfresco-ansible-deployment-1.0/configuration_files
3. Copy keystores from Community 5.2.x to ~/alfresco-ansible-deployment-1.0/configuration_files/keystores
4. Installed Community 7.0 (via ansible installation method) per installation guide per Alfresco Community Ansible Installation guide.
5. Verified I can log into http://localhost:8080/share with my ldap username/password!
6. IT WORKED! I Have a blank running copy of Community 7.0
This leaves me with some of the following key alfresco directories to work with:
/var/opt/alfresco/
/var/log/alfresco/
/etc/opt/alfresco/
/opt/alfresco /opt/apache-activemq-5.16.1 /opt/apache-tomcat-9.0.41 /opt/libreoffice6.3 /opt/openjdk-11.0.7
#QUESTIONS! QUESTIONS! QUESTIONS!QUESTIONS! QUESTIONS! QUESTIONS!QUESTIONS! QUESTIONS
This is what I believe I need to do at this point but have some questions:
1. On my Community 5.2.x server, Upgrade solr4 to Solr6 because solr4 is incompatible with the community7 build.
(Really? Even if I'm okay with a Re-Index? I'm not looking forward to this step but I'll do it if we have to.)
2. Dump the database On my Community 5.2.x server and Import the database to Community 7.0
(Something like
[postgres@alfresco52 ~] pg_dump alfresco > alfresco_52_db.dump
[postgres@alfresco7 ~] psql -U alfresco -d alfresco -f alfresco_52_db.dump
4. Copy Community 5.2.x contentstore* into Community 7.0 /var/opt/alfresco/content-services/content/
(Is that right? when I did a ps -ef after installing community 7 I see openjdk with this defined
"-Dsolr.content.dir=/opt/alfresco/search-services-2.0.1/contentstore"
5. Community 7.0 to re-index
(Not sure how to do this)
I'm sure I'm missing many many steps, if there is a 5.2 to Community 7 step-by-step migration guide someplace I would love to be directed to it!
Thank you in advance for your time.
06-17-2021 03:56 PM
*** EDITED ***
BELOW ARE MY STEPS FOR A SUCCESSFUL 5.2 too 7.0 MIGRATION VIA ANSIBLE INSTALLER.
(NOTE: Pay close attention to the hostnames (alfresco.52 vs alfresco.70))
1. Stage ContentStore
[[email protected] ]# mkdir -p /var/opt/alfresco/content-services/content;chown alfresco:alfresco /var/opt/alfresco/content-services/content [[email protected] ]# rsync -a /opt/alfresco/alf_data/contentstore* alfresco.70:/var/opt/alfresco/content-services/content/
[[email protected] ]# rsync /opt/alfresco/alf_data/keystore/* alfresco.70:~/alfresco-ansible-deployment-1.0/configuration_files/keystores/
[[email protected] ]# cp /tmp/alfresco-global.properties ~/alfresco-ansible-deployment-1.0/configuration_files/alfresco-global.properties
[[email protected] ]# chown -R alfresco:alfresco /var/opt/alfresco/content-services/content
[[email protected] ]# ansible-playbook playbooks/acs.yml -i inventory_local.yml -e "@community-extra-vars.yml"
[[email protected]]# systemctl stop activemq alfresco-content alfresco-tengine-aio alfresco-search
[[email protected]]# /opt/alfresco/alfresco.sh stop
[[email protected]]# pg_dump alfresco > alfresco52.db.sql
[[email protected]]# echo "local all alfresco password" >> /var/lib/pgsql/13/data/pg_hba.conf
[[email protected]]# systemctl restart postgresql-13
[[email protected]]# psql -U alfresco -d postgres
= \c postgres
= DROP DATABASE alfresco;
= CREATE DATABASE alfresco OWNER alfresco ENCODING 'utf8';
= GRANT ALL PRIVILEGES ON DATABASE alfresco TO alfresco;
= exit
[[email protected]]# psql -U alfresco -D alfresco -f alfresco52.db.sql
password: **********************
[root@alfresco70 ~]# rm -rf /var/opt/alfresco/search-services/alfresco/index/* [root@alfresco70 ~]# rm -rf /var/opt/alfresco/search-services/archive/index/*
[[email protected]]# systemctl start activemq alfresco-content alfresco-tengine-aio alfresco-search
06-21-2021 07:09 AM
Great news that you've been successful and thanks for updating your thread on how you resolved your issue - that's really helpful to other users!
Thanks again,
