Failed to connect or to read the response from T-Engine on http://localhost:8090/transform/config
Bilal_MB
I am installing the alfresco6.2 version manually  (distribution.zip) on my mac locally using the alfresco documentation. I have come across the below error regarding the transform/config. By Default in the alfresco documentation, it states that for Transform Service is disabled for the zip distribution.  (https://docs.alfresco.com/transform/concepts/transform-local-legacy.html) Could you please advise on how I disable the transform? I have attached my global.properties below
Thank You
2020-09-14 15:28:50,004  ERROR [content.transform.LocalTransformServiceRegistry] [QuartzScheduler_Worker-2] 08140477 Failed to connect or to read the response from T-Engine on http://localhost:8090/transform/config
2020-09-14 15:28:50,004  ERROR [content.transform.LocalTransformServiceRegistry] [QuartzScheduler_Worker-2] 08140372 Failed to connect or to read the response from T-Engine on http://localhost:8090/transform/config
2020-09-14 15:28:50,006  ERROR [content.transform.LocalTransformServiceRegistry] [QuartzScheduler_Worker-2] 08140478 Failed to connect or to read the response from T-Engine on http://localhost:8093/transform/config
2020-09-14 15:28:50,006  ERROR [content.transform.LocalTransformServiceRegistry] [QuartzScheduler_Worker-2] 08140373 Failed to connect or to read the response from T-Engine on http://localhost:8093/transform/config
2020-09-14 15:28:50,007  ERROR [content.transform.LocalTransformServiceRegistry] [QuartzScheduler_Worker-2] 08140479 Failed to connect or to read the response from T-Engine on http://localhost:8091/transform/config
2020-09-14 15:28:50,007  ERROR [content.transform.LocalTransformServiceRegistry] [QuartzScheduler_Worker-2] 08140374 Failed to connect or to read the response from T-Engine on http://localhost:8091/transform/config
2020-09-14 15:28:50,008  ERROR [content.transform.LocalTransformServiceRegistry] [QuartzScheduler_Worker-2] 08140480 Failed to connect or to read the response from T-Engine on http://localhost:8094/transform/config
2020-09-14 15:28:50,009  ERROR [content.transform.LocalTransformServiceRegistry] [QuartzScheduler_Worker-2] 08140375 Failed to connect or to read the response from T-Engine on http://localhost:8094/transform/config
2020-09-14 15:28:50,010  ERROR [content.transform.LocalTransformServiceRegistry] [QuartzScheduler_Worker-2] 08140481 Failed to connect or to read the response from T-Engine on http://localhost:8092/transform/config
# Set this property unless you have explicitly chosen to expose some repository APIs without authentication
# Custom content and index data location
dir.root=/srv/alfresco/alf_data
dir.keystore=${dir.root}/keystore
# Sample database connection properties
db.username=root
db.password=alfresco
# Choose DB connection properties for your database, e.g. for PostgreSQL
db.driver=org.mysql.Driver
db.url=jdbc:mysql://localhost:3306/alfresco
# URL Generation Parameters (The ${localname} token is replaced by the local server name)
alfresco.context=alfresco
alfresco.host=${localname}
alfresco.port=8080
alfresco.protocol=http
share.context=share
share.host=${localname}
share.port=8080
share.protocol=http
transform.service.enabled=false
local.transform.service.enabled=false
legacy.transform.service.enabled=false
kaynezhang
World-Class Innovator
You have already disable it by setting local.transform.service.enabled=false, Those errors are thrown during startup ,you can just ignore it.
kaynezhang
sp2
Elite Collaborator
Elite Collaborator
I am also getting same error and not able to open /share or /alfresco page.
abhinavmishra14
@sanjaybandhniya  Please create a new thread and provide docker-compose.yml, output of "docker ps -a" command. Please provide output of "docker stats", System condiguration including total memory. Make sure at least 8gb memory is available.
If you have used distribution zip for setup (as indicated originally on this thread), please provide the alfresco-global.properties, and error logs to analysis. To cross check you can verify the setup setps here: https://javaworld-abhinav.blogspot.com/2020/12/setup-acs62-ga-and-ass14-distribution-stepbystep.html
~Abhinav
(ACSCE, AWS SAA, Azure Admin)
