04-21-2017 10:06 AM
We configured SSO based authentication with header set and we are facing one issue, while hitting
even with http://hostname:8080/share it shows (gives) me popup asking for credentials (simple authentication dialog)
I twice checked configuration as per the docs.alfresco.com ( we are using alfresco 5.2 )
http://docs.alfresco.com/5.2/tasks/auth-alfrescoexternal-sso.html
How do I successfully get into login page atleast with providing port ( consider I am not using LB URL for siteminder auth) even with port it ask for this simple authentication then if I do cancel , it redirect me to share login page.
Here is my share-config-custom
<config evaluator="string-compare" condition="Remote">
 <remote>
 <keystore>
 <path>alfresco/web-extension/alfresco-system.p12</path>
 <type>pkcs12</type>
 <password>alfresco-system</password>
 </keystore>
 <ssl-config>
 <keystore-path>alfresco/web-extension/alfresco-system.p12</keystore-path>
 <keystore-type>pkcs12</keystore-type>
 <keystore-password>alfresco-system</keystore-password>
<truststore-path>alfresco/web-extension/ssl-truststore</truststore-path>
 <truststore-type>JCEKS</truststore-type>
 <truststore-password>kT9X6oe68t</truststore-password>
<verify-hostname>true</verify-hostname>
 </ssl-config>
 <connector>
 <id>alfrescoCookie</id>
 <name>Alfresco Connector</name>
 <description>Connects to an Alfresco instance using cookie-based authentication</description>
 <class>org.alfresco.web.site.servlet.SlingshotAlfrescoConnector</class>
 </connector>
 <connector>
 <id>alfrescoHeader</id>
 <description>Connects to an Alfresco instance using header and cookie-based authentication</description>
 <userHeader>SM_USER</userHeader>
 </connector>
<endpoint>
 <id>alfresco</id>
 <name>Alfresco - user access</name>
 <description>Access to Alfresco Repository WebScripts that require user authentication</description>
 <connector-id>alfrescoHeader</connector-id>
 <endpoint-url>http://localhost:8080/alfresco/s</endpoint-url>
 <identity>user</identity>
 <external-auth>true</external-auth>
 </endpoint>
 <endpoint>
 <id>alfresco-feed</id>
 <parent-id>alfresco</parent-id>
 <name>Alfresco Feed</name>
 <description>Alfresco Feed - supports basic HTTP authentication via the EndPointProxyServlet</description>
 <endpoint-url>http://localhost:8080/alfresco/wcs</endpoint-url>
 </endpoint> -->
 <endpoint>
 <id>alfresco-api</id>
 <name>Alfresco Public API - user access</name>
 <description>Access to Alfresco Repository Public API that require user authentication.
 This makes use of the authentication that is provided by parent 'alfresco' endpoint.</description>
 <endpoint-url>http://localhost:8080/alfresco/api</endpoint-url>
 </endpoint>
 </remote>
 </config>
What is wrong here ?
05-11-2017 03:14 AM
I contacted alfresco support and it is official bug.
11-30-2017 04:02 AM
Following this documentation Configuring Alfresco Share to use an external SSO | Alfresco Documentation helps.
But, there is one thing which is not explicitly mentioned. There are two sections which have <config evaluator="string-compare" condition="Remote">. When you do you fresh install the first section is enabled, and the second one is commented out. So, when you have SSO, you will have to comment out the first section and uncomment the second one along with the changes mentioned in the above document.
Hope this works!
#SSO #siteminder
