Establish a connection with sql from AIO proyect, ¿where is <TOMCAT_HOME>/lib directory?
Options
08-26-2019 06:06 PM
Hi
I want to establish a comnnection with a sql database,but I don't know where is the <TOMCAT_HOME>/lib directory in my AIO proyect
I'm using the alfresco-allinone-archetype version 3.1.0
Labels:
Alfresco Content Services
Options
09-19-2019 10:36 AM
I assume you are looking for the lib directory because you want to put your database driver in it.
Instead, why not add the database driver to your dependencies in your pom.xml file. You can mark it with a scope of provided so it doesn't package the driver into your AMP.
Later, when you are ready to deploy, put the driver JAR in the lib directory of whatever Tomcat you are deploying to.
