09-19-2017 07:08 AM
Hi everyone,
I have a clean installation of Alfresco (installed with the alfresco-ubuntu-installer) and in the Home dashboard, in the "My Documents" dashlet I see an error saying "error loading item".
If I delete the models from solr folder in
/opt/alfresco/solr4/alfrescoModelsThe error disappears and I get the default placeholder text, as you can see in the "My-Documents-Dashlet" image.
In alfresco.log I see this line (among other errors as well)
08190019 Failed to execute search: +@cm\:modified:[2017\-9\-12T00\:00\:00.000 TO 2017\-9\-19T23\:59\:59.999] +@cm\:modifier:"admin" +TYPE:"cm:content" -TYPE:"cm:systemfolder" -TYPE:"fm:forums" -TYPE:"fm:forum" -TYPE:"fm:topic" -TYPE:"fm:post" +(TYPE:"content" OR TYPE:"app:filelink" OR TYPE:"folder")and in solr.log I see this line (again, among other errors as well)
ERROR [org.apache.solr.util.ConcurrentLRUCache] ConcurrentLRUCache was not destroyed prior to finalize(), indicates a bug -- POSSIBLE RESOURCE LEAK!!!Bellow I have attached both alfresco and solr log files. I didn't include the share.log because it had no errors in it.
I have found this question Dashlet 'My Documents' empty where someone mentioned that the Dashlet "My Documents" only picks up documents from sites. I created a new site and added/modified a few documents but still the dashlets remained empty, only showing the default placeholder text.
Does anyone else have a simillar problem or faced a simillar behaviour?
Thank you very much for any future help ![]()
09-19-2017 08:54 AM
After a few tries of reindexing following the instractions of this documentation Performing a full reindex with Solr,
it finally worked. I don't know why it took more than just one time to reindex, it might not even have been required to reindex more than once.
Anyway...
I don't know if it was because I installed Alfresco using the alfresco-ubuntu-install, but the folder paths were a bit different for me.
Archive SpacesStore:
/opt/alfresco/alf_data/solr4/archive/SpacesStore/index/Workspace SpacesStore:
/opt/alfresco/alf_data/solr4/workspace/SpacesStore/index/Models:
/opt/alfresco/solr4/alfrescoModels/Content:
/opt/alfresco/alf_data/solr4/content/
09-19-2017 08:54 AM
Anyway...
