10-17-2017 05:26 AM
Hello Everyone,
Will there be any changes in the functionality of the workflow from user's point of view if I change its engine properties in alfresco-global.properties? Right now I have system.workflow.engine.activiti.enabled=true in my global.properties file.
e.g.
system.workflow.engine.activiti.enabled=false
and
system.workflow.engine.jbpm.enabled=true
I would like to know the difference between these two, from the developers or performance point of view.
Thanks in Advance.
Kintu
10-17-2017 03:35 PM
Hello.
Well, it all depends on the Alfresco version you are using, as JBPM got removed from version 201605 (aka 5.1.g), as you can see here https://community.alfresco.com/docs/DOC-6297-alfresco-community-edition-201605-ga-release-notes#jive...
10-23-2017 06:48 AM
Hi Douglas C. R. Paes,
I am using Alfresco Community 5.0.
I have enabled jbpm engine by following properties in alfreaco-global.properties file.
system.workflow.engine.jbpm.definitions.visible=true
but I was getting 'activiti$xxxx' in task id.
Then I disabled activiti engine by following properties
system.workflow.engine.activiti.definitions.visible=false
And Its giving 'jbpm$xxxx' in task id.
It means just enabling jbpm engine is not enough, in order to make it work; you must disable activiti engine also.
Kintu
