04-17-2017 06:17 AM
One of our instance, CE 5.1, shuts down due to an error - org.alfresco.repo.security.permissions.AccessDeniedException: 03160005 Access Denied. The system is currently in read-only mode.
I am not sure why this is happening but my suspicion is that somehow my alf_data is not available. My alf_data is on a Azure File System.
Please let me know what can be the reason behind this. Full logs here .
Hiten Rastogi
04-18-2017 07:20 AM
I wonder if an earlier alfresco/schema patch may have failed (eg. clean alf prop tables) ?
Also, check that another repo startup process was not already running, since I notice that your log includes:
2017-04-09 23:50:01,232 ERROR [org.alfresco.fileserver] [CIFS Server] Error from JLAN org.alfresco.jlan.server.config.InvalidConfigurationException: Error initializing TCP-IP SMB session handler, Address already in use at org.alfresco.jlan.smb.server.nio.NIOCifsConnectionsHandler.initializeHandler(NIOCifsConnectionsHandler.java:259) at org.alfresco.jlan.smb.server.SMBServer.run(SMBServer.java:479) at java.lang.Thread.run(Thread.java:745)
Regards,
Jan
