02-27-2017 05:12 PM
I created a Repository AMP project and a Share AMP project to put my Alfresco extensions.
But when I run this projects I have the following problem:
I know that in order to solve this in my local installation I have to install alfresco-share-services.amp in the Repository, but I don't know how to solve this in my Repository AMP project.
I already tried to put alfresco-share-services-5.2.e.jar in the folder pucp-repo1/target/amp/lib but it didn't work.
Thanks in advance!
02-28-2017 01:59 AM
You can use below link(Point #19)
Installing Alfresco on Windows using the Share Installer | Alfresco Documentation
Steps are(Copied from above link)
02-28-2017 09:01 AM
My repository AMP project has the following structure:
I don't have an amps folder and I can't use bin/apply_amps because this is a extension project.
I also tried:
<dependency>
<groupId>org.alfresco</groupId>
<artifactId>alfresco-share-services</artifactId>
<version>5.2.e</version>
</dependency>
But I get this error:
[ERROR] Failed to execute goal on project pucp-repo1: Could not resolve dependencies for project pe.pucp ucp-repo1:amp:1.0-SNAPSHOT: Failure to find org.alfresco:alfresco-share-services:jar:5.2.e in https://artifacts.alfresco.com/nexus/content/groups/public was cached in the local repository, resolution will not be reattempted until the update interval of alfresco-public has elapsed or updates are forced -> [Help 1]
03-01-2017 03:09 AM
Try adding below dependency
(Source : https://github.com/binduwavell/generator-alfresco/issues/127)
<dependency>       <groupId>org.alfresco</groupId>       <artifactId>alfresco-share-services</artifactId>       <version>5.2.e</version>       <type>amp</type> </dependency>
