Alfresco 6.2 Installation using docker-compose.yml and dockerfile
Aswani_Juvva
sanjaybandhaniya
Elite Collaborator
Elite Collaborator
Check attached docker compose file .
May be helpful to you.
# This docker-compose file will spin up an ACS cluster on a local host or on a server and it requires a minimum of 12GB Memory to distribute among containers.
# Limit container memory and assign X percentage to JVM.  There are couple of ways to allocate JVM Memory for ACS Containers
# For example: 'JAVA_OPTS: "$JAVA_OPTS -XX:+PrintFlagsFinal -XX:+UnlockExperimentalVMOptions -XX:+UseCGroupMemoryLimitForHeap"'
# See Oracle docs (https://docs.oracle.com/javase/9/gctuning/parallel-collector1.htm#JSGCT-GUID-CAB83393-3438-44ED-98F0-D15641B43C7D).
# If the container memory is not explicitly set then the flags above will set the max heap default to 1/4 of the container's memory, which may not be ideal.
# For performance tuning, assign the container memory and give a percentage of it to the JVM.
# Using version 2 as 3 does not support resource constraint options (cpu_*, mem_* limits) for non swarm mode in Compose
version: "2"
services:
    alfresco:
        image: alfresco/alfresco-content-repository-community:6.2.1-A8
        mem_limit: 1500m
        environment:
            JAVA_OPTS: "
                -Ddb.driver=org.postgresql.Driver
                -Ddb.username=alfresco
                -Ddb.password=alfresco
                -Ddb.url=jdbc:postgresql://postgres:5432/alfresco
                -Dsolr.host=solr6
                -Dsolr.port=8983
                -Dsolr.secureComms=none
                -Dsolr.base.url=/solr
                -Dindex.subsystem.name=solr6
                -Dshare.host=127.0.0.1
                -Dshare.port=8080
                -Dalfresco.host=localhost
                -Dalfresco.port=8080
                -Daos.baseUrlOverwrite=http://localhost:8080/alfresco/aos
                -Dmessaging.broker.url=\"failover:(nio://activemq:61616)?timeout=3000&jms.useCompression=true\"
                -Ddeployment.method=DOCKER_COMPOSE
                -DlocalTransform.core-aio.url=http://transform-core-aio:8090/
                -Dalfresco-pdf-renderer.url=http://transform-core-aio:8090/
                -Djodconverter.url=http://transform-core-aio:8090/
                -Dimg.url=http://transform-core-aio:8090/
                -Dtika.url=http://transform-core-aio:8090/
                -Dtransform.misc.url=http://transform-core-aio:8090/
                -Dcsrf.filter.enabled=false
                -Xms1500m -Xmx1500m
    transform-core-aio:
        image: alfresco/alfresco-transform-core-aio:2.3.4
        mem_limit: 1536m
        environment:
            JAVA_OPTS: " -Xms256m -Xmx1536m"
        ports:
            - 8090:8090
    share:
        image: alfresco/alfresco-share:6.2.1
        mem_limit: 1g
        environment:
            REPO_HOST: "alfresco"
            REPO_PORT: "8080"
            JAVA_OPTS: "
                -Xms500m
                -Xmx500m
                -Dalfresco.context=alfresco
                -Dalfresco.protocol=http
    postgres:
        image: postgres:11.7
        mem_limit: 512m
        environment:
            - POSTGRES_PASSWORD=alfresco
            - POSTGRES_USER=alfresco
            - POSTGRES_DB=alfresco
        command: postgres -c max_connections=300 -c log_min_messages=LOG
        ports:
            - 5432:5432
    solr6:
        image: alfresco/alfresco-search-services:2.0.0
        mem_limit: 2g
        environment:
            #Solr needs to know how to register itself with Alfresco
            - SOLR_ALFRESCO_HOST=alfresco
            - SOLR_ALFRESCO_PORT=8080
            #Alfresco needs to know how to call solr
            - SOLR_SOLR_HOST=solr6
            - SOLR_SOLR_PORT=8983
            #Create the default alfresco and archive cores
            - SOLR_CREATE_ALFRESCO_DEFAULTS=alfresco,archive
            #HTTP by default
            - ALFRESCO_SECURE_COMMS=none
            - "SOLR_JAVA_MEM=-Xms2g -Xmx2g"
        ports:
            - 8083:8983 #Browser port
    activemq:
        image: alfresco/alfresco-activemq:5.15.8
        mem_limit: 1g
        ports:
            - 8161:8161 # Web Console
            - 5672:5672 # AMQP
            - 61616:61616 # OpenWire
            - 61613:61613 # STOMP
    proxy:
        image: alfresco/acs-community-ngnix:1.0.0
        mem_limit: 128m
        depends_on:
            - alfresco
        ports:
            - 8080:8080
        links:
            - alfresco
            - share
