Problems with Modeler
jcosano
1) The name of the process is not create in xxxx.bpmn20.xml and after deploy process, explorer crash, (If i edit the process manually and add name tag, process works fine)
2) Every time that i modify process in modeler, i must delete xxxx.bpmn20.xml because changes aren't save in this file.
Thanks!
jbarrez
Thanks for posting this. I will investigate your points and check with Signavio if something is bugged.
I think out the top of my head that case 1) is indeed valid.
