08-04-2015 05:41 AM
I've been working on developping an angular application following this tutorial : https://doc.nuxeo.com/display/NXDOC/Developing+with+AngularJS and using the samples from the following page : https://github.com/nuxeo-sandbox/angular-nuxeo
From that, I could :
However, I couldn't find any example about CRUD methods on documents, or on users. These examples does not seem to work on Nuxeo 6 using the AngularJS module : https://github.com/dmetzler/nuxeo-book
Could I get any exemples on what's possible using the AngularJS module for the Nuxeo Automation and REST API. My id is to create a frontend portal of the Nuxeo platform for end users.
08-05-2015 04:59 AM
I’ve tried to get the current user of the platform, using the /api/automation/User.Get from the Automation API, but I can’t get it to work properly. It works fine in the Nuxeo API playground.
08-06-2015 09:35 AM
There was a typo in the angular-nuxeo client. It has been fixed. Just update the client in your project and it should work.
08-06-2015 10:31 AM
Thanks for your answer. It resolved the callback error, but I'm still getting another error in the JS console when calling 'User.Get' method.
08-06-2015 10:51 AM
Seems like operation User.Get does not exist on 6.0. Can you replace it by NuxeoPrincipal.Get and try again?
08-06-2015 11:15 AM
Thanks, it works fine!
