Problem with Nuxeo jboss bundle.
pankaj_mishra
I am trying to run nuxeo-dm-5.4.0_01-jboss bundle but it throw error as below.
2013-11-09 16:59:44,148 INFO [org.nuxeo.runtime.deployment.preprocessor.ConfigurationGenerator] Nuxeo configuration: ./nuxeo.conf 2013-11-09 16:59:44,151 INFO [org.nuxeo.runtime.deployment.preprocessor.ConfigurationGenerator] Include template: /home/epankmi/Desktop/nuxeo-dm-5.4.0_01-jboss/nuxeo-dm-5.4.0.1-jboss/templates/common-deploydir 2013-11-09 16:59:44,151 INFO [org.nuxeo.runtime.deployment.preprocessor.ConfigurationGenerator] Include template: /home/epankmi/Desktop/nuxeo-dm-5.4.0_01-jboss/nuxeo-dm-5.4.0.1-jboss/templates/common-binding 2013-11-09 16:59:44,151 INFO [org.nuxeo.runtime.deployment.preprocessor.ConfigurationGenerator] Include template: /home/epankmi/Desktop/nuxeo-dm-5.4.0_01-jboss/nuxeo-dm-5.4.0.1-jboss/templates/common 2013-11-09 16:59:44,152 INFO [org.nuxeo.runtime.deployment.preprocessor.ConfigurationGenerator] Include template: /home/epankmi/Desktop/nuxeo-dm-5.4.0_01-jboss/nuxeo-dm-5.4.0.1-jboss/templates/default 2013-11-09 16:59:44,152 INFO [org.nuxeo.runtime.deployment.preprocessor.ServerConfigurator] Detected JBoss server. 2013-11-09 16:59:44,152 INFO [org.nuxeo.runtime.deployment.preprocessor.ConfigurationGenerator] No current configuration, generating files... 2013-11-09 16:59:44,180 INFO [org.nuxeo.runtime.deployment.preprocessor.ConfigurationGenerator] Configuration files generated. 2013-11-09 17:00:02,236 ERROR [org.jboss.kernel.plugins.dependency.AbstractKernelController] Error installing to Configured: name=WSServerConfig state=Instantiated java.lang.RuntimeException: Error configuring property: webServiceHost for WSServerConfig at org.jboss.kernel.plugins.dependency.ConfigureAction.dispatchSetProperty(ConfigureAction.java:112) at org.jboss.kernel.plugins.dependency.ConfigureAction.setAttributes(ConfigureAction.java:85) at org.jboss.kernel.plugins.dependency.ConfigureAction.installActionInternal(ConfigureAction.java:44) at org.jboss.kernel.plugins.dependency.InstallsAwareAction.installAction(InstallsAwareAction.java:54) at org.jboss.kernel.plugins.dependency.InstallsAwareAction.installAction(InstallsAwareAction.java:42) at org.jboss.dependency.plugins.action.SimpleControllerContextAction.simpleInstallAction(SimpleControllerContextAction.java:62) at org.jboss.dependency.plugins.action.AccessControllerContextAction.install(AccessControllerContextAction.java:71) at org.jboss.dependency.plugins.AbstractControllerContextActions.install(AbstractControllerContextActions.java:51) at org.jboss.dependency.plugins.AbstractControllerContext.install(AbstractControllerContext.java:348) at org.jboss.dependency.plugins.AbstractController.install(AbstractController.java:1631) at org.jboss.dependency.plugins.AbstractController.incrementState(AbstractController.java:934) at org.jboss.dependency.plugins.AbstractController.resolveContexts(AbstractController.java:1082) at org.jboss.dependency.plugins.AbstractController.resolveContexts(AbstractController.java:984) at org.jboss.dependency.plugins.AbstractController.install(AbstractController.java:774) at org.jboss.dependency.plugins.AbstractController.install(AbstractController.java:540) at org.jboss.deployers.vfs.deployer.kernel.BeanMetaDataDeployer.deploy(BeanMetaDataDeployer.java:121) at org.jboss.deployers.vfs.deployer.kernel.BeanMetaDataDeployer.deploy(BeanMetaDataDeployer.java:51) at org.jboss.deployers.spi.deployer.helpers.AbstractSimpleRealDeployer.internalDeploy(AbstractSimpleRealDeployer.java:62) at org.jboss.deployers.spi.deployer.helpers.AbstractRealDeployer.deploy(AbstractRealDeployer.java:50) at org.jboss.deployers.plugins.deployers.DeployerWrapper.deploy(DeployerWrapper.java:171) at org.jboss.deployers.plugins.deployers.DeployersImpl.doDeploy(DeployersImpl.java:1439) at org.jboss.deployers.plugins.deployers.DeployersImpl.doInstallParentFirst(DeployersImpl.java:1157) at org.jboss.deployers.plugins.deployers.DeployersImpl.doInstallParentFirst(DeployersImpl.java:1178) at org.jboss.deployers.plugins.deployers.DeployersImpl.install(DeployersImpl.java:1098) at org.jboss.dependency.plugins.AbstractControllerContext.install(AbstractControllerContext.java:348) at org.jboss.dependency.plugins.AbstractController.install(AbstractController.java:1631) at org.jboss.dependency.plugins.AbstractController.incrementState(AbstractController.java:934) at org.jboss.dependency.plugins.AbstractController.resolveContexts(AbstractController.java:1082) at org.jboss.dependency.plugins.AbstractController.resolveContexts(AbstractController.java:984) at org.jboss.dependency.plugins.AbstractController.change(AbstractController.java:822) at org.jboss.dependency.plugins.AbstractController.change(AbstractController.java:553) at org.jboss.deployers.plugins.deployers.DeployersImpl.process(DeployersImpl.java:781) at org.jboss.deployers.plugins.main.MainDeployerImpl.process(MainDeployerImpl.java:702) at org.jboss.system.server.profileservice.repository.MainDeployerAdapter.process(MainDeployerAdapter.java:117) at org.jboss.system.server.profileservice.repository.ProfileDeployAction.install(ProfileDeployAction.java:70) at org.jboss.system.server.profileservice.repository.AbstractProfileAction.install(AbstractProfileAction.java:53) at org.jboss.system.server.profileservice.repository.AbstractProfileService.install(AbstractProfileService.java:361) at org.jboss.dependency.plugins.AbstractControllerContext.install(AbstractControllerContext.java:348) at org.jboss.dependency.plugins.AbstractController.install(AbstractController.java:1631) at org.jboss.dependency.plugins.AbstractController.incrementState(AbstractController.java:934) at org.jboss.dependency.plugins.AbstractController.resolveContexts(AbstractController.java:1082) at org.jboss.dependency.plugins.AbstractController.resolveContexts(AbstractController.java:984) at org.jboss.dependency.plugins.AbstractController.change(AbstractController.java:822) at org.jboss.dependency.plugins.AbstractController.change(AbstractController.java:553) at org.jboss.system.server.profileservice.repository.AbstractProfileService.activateProfile(AbstractProfileService.java:306) at org.jboss.system.server.profileservice.ProfileServiceBootstrap.start(ProfileServiceBootstrap.java:271) at org.jboss.bootstrap.AbstractServerImpl.start(AbstractServerImpl.java:461) at org.jboss.Main.boot(Main.java:221) at org.jboss.Main$1.run(Main.java:556) at java.lang.Thread.run(Thread.java:679) Caused by: java.net.UnknownHostException: B1H68R1.egi.ericsson.com: B1H68R1.egi.ericsson.com at java.net.InetAddress.getLocalHost(InetAddress.java:1454) at org.jboss.wsf.common.management.AbstractServerConfig.setWebServiceHost(AbstractServerConfig.java:84) at sun.reflect.NativeMethodAccessorImpl.invoke0(Native Method) at sun.reflect.NativeMethodAccessorImpl.invoke(NativeMethodAccessorImpl.java:57) at sun.reflect.DelegatingMethodAccessorImpl.invoke(DelegatingMethodAccessorImpl.java:43) at java.lang.reflect.Method.invoke(Method.java:616) at org.jboss.reflect.plugins.introspection.ReflectionUtils.invoke(ReflectionUtils.java:59) at org.jboss.reflect.plugins.introspection.ReflectMethodInfoImpl.invoke(ReflectMethodInfoImpl.java:150) at org.jboss.beans.info.plugins.DefaultPropertyInfo.set(DefaultPropertyInfo.java:143) at org.jboss.beans.info.plugins.BeanInfoUtil.set(BeanInfoUtil.java:177) at org.jboss.beans.info.plugins.AbstractBeanInfo.setProperty(AbstractBeanInfo.java:289) at org.jboss.kernel.plugins.dependency.PropertyDispatchWrapper.execute(PropertyDispatchWrapper.java:113) at org.jboss.kernel.plugins.dependency.ExecutionWrapper.execute(ExecutionWrapper.java:47) at org.jboss.kernel.plugins.dependency.KernelControllerContextAction.dispatchExecutionWrapper(KernelControllerContextAction.java:109) at org.jboss.kernel.plugins.dependency.ConfigureAction.dispatchSetProperty(ConfigureAction.java:107) ... 49 more 2013-11-09 17:00:04,465 INFO [org.nuxeo.runtime.jboss.deployer.structure.NuxeoStructureDeployer] Found Nuxeo Deployment: nuxeo.ear 2013-11-09 17:00:04,511 INFO [org.nuxeo.runtime.deployment.preprocessor.DeploymentPreprocessor] Running custom installation for container: nuxeo.ear 2013-11-09 17:00:04,539 WARN [org.nuxeo.runtime.deployment.preprocessor.DeploymentPreprocessor] Entering compatibility mode - Please update the deployment-fragment.xml in nuxeo-opencmis-bindings-5.4.0.1.jar to use new dependency management 2013-11-09 17:00:04,541 WARN [org.nuxeo.runtime.deployment.preprocessor.DeploymentPreprocessor] Entering compatibility mode - Please update the deployment-fragment.xml in nuxeo-opencmis-impl-5.4.0.1.jar to use new dependency management 2013-11-09 17:00:04,616 WARN [org.nuxeo.runtime.deployment.preprocessor.DeploymentPreprocessor] Entering compatibility mode - Please update the deployment-fragment.xml in nuxeo-platform-lang-ext-5.4.0.1.jar to use new dependency management 2013-11-09 17:00:04,737 INFO [org.nuxeo.runtime.deployment.preprocessor.DeploymentPreprocessor] Preprocessing order: org.nuxeo.ecm.webengine.core org.nuxeo.ecm.platform.picture.facade org.nuxeo.ecm.platform.ui org.nuxeo.ecm.platform.types.core org.nuxeo.ecm.platform.uidgen.core org.nuxeo.ecm.platform.versioning org.nuxeo.ecm.core.storage.sql.ra org.nuxeo.ecm.platform.types.facade org.nuxeo.opensocial.service org.nuxeo.ecm.platform.forum org.nuxeo.ecm.platform.filemanager.api org.nuxeo.ecm.platform.ws.jbossws org.nuxeo.ecm.platform.audit.web org.nuxeo.ecm.platform.publisher.core org.nuxeo.ecm.platform.userworkspace.types org.nuxeo.ecm.annotations.repository org.nuxeo.ecm.relations.facade org.nuxeo.ecm.platform.notification.facade org.nuxeo.ecm.platform.audit org.nuxeo.ecm.platform.web.common org.nuxeo.ecm.platform.usermanager.facade org.nuxeo.opensocial.gadgets org.nuxeo.ecm.platform.preview org.nuxeo.ecm.platform.placeful.theme org.nuxeo.ecm.platform.url.facade org.nuxeo.ecm.platform.webapp.types org.nuxeo.ecm.platform.search.ejb org.nuxeo.ecm.platform.directory.facade org.nuxeo.ecm.platform.publisher.core.contrib org.nuxeo.ecm.platform.picture.dm org.nuxeo.ecm.platform.comment org.nuxeo.ecm.platform.forms.layout.client org.nuxeo.ecm.platform.types.api org.nuxeo.ecm.relations.core.listener org.nuxeo.ecm.platform.userworkspace.facade org.nuxeo.theme.editor org.nuxeo.ecm.platform.publisher.jbpm org.nuxeo.ecm.relations.web org.nuxeo.ecm.platform.filemanager.facade org.nuxeo.ecm.annotation.facade org.nuxeo.ecm.webapp.ui org.nuxeo.ecm.actions org.nuxeo.opensocial.container org.nuxeo.ecm.platform.publisher.web org.nuxeo.ecm.platform.filemanager.core org.nuxeo.ecm.platform.notification.web org.nuxeo.ecm.platform.jbpm.facade org.nuxeo.ecm.platform.placeful.facade org.nuxeo.ecm.platform.userworkspace.core org.nuxeo.theme.jsf org.nuxeo.ecm.annotations.client org.nuxeo.ecm.webapp.base org.nuxeo.ecm.webapp.core org.nuxeo.ecm.core.facade org.nuxeo.ecm.platform.pictures.tiles.preview org.nuxeo.ecm.platform.publisher.api org.nuxeo.ecm.platform.io.web org.nuxeo.ecm.platform.notification.core org.nuxeo.ecm.platform org.nuxeo.ecm.platform.comment.web org.nuxeo.theme.html org.nuxeo.ecm.platform.ui.compat org.nuxeo.ecm.platform.pictures.tiles org.nuxeo.ecm.platform.picture.jsf org.nuxeo.ecm.platform.jbpm.web org.nuxeo.theme.bank org.nuxeo.ecm.platform.faceted.search.jsf org.nuxeo.ecm.platform.url.api org.nuxeo.ecm.annotations.http org.nuxeo.ecm.platform.webengine.sites org.nuxeo.ecm.platform.io.facade org.nuxeo.ecm.platform.lang org.nuxeo.ecm.platform.mail.web org.nuxeo.ecm.platform.webengine.blogs org.nuxeo.admin.center.monitoring org.nuxeo.opensocial.spaces.web org.nuxeo.opensocial.dashboard org.nuxeo.ecm.platform.tag.web org.nuxeo.admin.center org.nuxeo.ecm.platform.lang.ext org.nuxeo.ecm.platform.faceted.search.dm org.nuxeo.ecm.platform.userworkspace.web org.nuxeo.platform.virtualnavigation.web org.nuxeo.ecm.platform.audit.ejb org.nuxeo.ecm.platform.tag.ejb org.nuxeo.ecm.platform.syndication org.nuxeo.ecm.platform.wss.backend org.nuxeo.ecm.platform.filemanager.core.listener org.nuxeo.ecm.platform.mimetype.core org.nuxeo.ecm.platform.placeful.core org.nuxeo.ecm.relations.jena org.nuxeo.ecm.platform.mimetype.facade org.nuxeo.ecm.core.opencmis.bindings org.nuxeo.ecm.core.opencmis.impl 2013-11-09 17:00:04,741 INFO [org.nuxeo.runtime.deployment.preprocessor.DeploymentPreprocessor] Running custom installation for fragment: org.nuxeo.ecm.platform.ui 2013-11-09 17:00:04,873 INFO [org.nuxeo.runtime.deployment.preprocessor.DeploymentPreprocessor] Running custom installation for fragment: org.nuxeo.ecm.platform.forum 2013-11-09 17:00:04,875 INFO [org.nuxeo.runtime.deployment.preprocessor.DeploymentPreprocessor] Running custom installation for fragment: org.nuxeo.ecm.platform.audit.web 2013-11-09 17:00:04,876 WARN [org.nuxeo.runtime.deployment.preprocessor.DeploymentPreprocessor] No template 'jaxws' found for deployment fragment: org.nuxeo.ecm.platform.audit.web 2013-11-09 17:00:04,876 INFO [org.nuxeo.runtime.deployment.preprocessor.DeploymentPreprocessor] Running custom installation for fragment: org.nuxeo.ecm.annotations.repository 2013-11-09 17:00:04,879 INFO [org.nuxeo.runtime.deployment.preprocessor.DeploymentPreprocessor] Running custom installation for fragment: org.nuxeo.opensocial.gadgets 2013-11-09 17:00:04,890 INFO [org.nuxeo.runtime.deployment.preprocessor.DeploymentPreprocessor] Running custom installation for fragment: org.nuxeo.ecm.platform.preview 2013-11-09 17:00:04,893 INFO [org.nuxeo.runtime.deployment.preprocessor.DeploymentPreprocessor] Running custom installation for fragment: org.nuxeo.ecm.platform.picture.dm 2013-11-09 17:00:04,898 INFO [org.nuxeo.runtime.deployment.preprocessor.DeploymentPreprocessor] Running custom installation for fragment: org.nuxeo.ecm.platform.forms.layout.client 2013-11-09 17:00:04,903 WARN [org.nuxeo.runtime.deployment.preprocessor.template.Template] The deployment-fragment contains illegal JEE java module contribution: nuxeo-theme-editor-5.4.0.1.jar 2013-11-09 17:00:04,904 INFO [org.nuxeo.runtime.deployment.preprocessor.DeploymentPreprocessor] Running custom installation for fragment: org.nuxeo.ecm.relations.web 2013-11-09 17:00:04,906 INFO [org.nuxeo.runtime.deployment.preprocessor.DeploymentPreprocessor] Running custom installation for fragment: org.nuxeo.ecm.webapp.ui 2013-11-09 17:00:04,958 INFO [org.nuxeo.runtime.deployment.preprocessor.DeploymentPreprocessor] Running custom installation for fragment: org.nuxeo.opensocial.container 2013-11-09 17:00:05,145 INFO [org.nuxeo.runtime.deployment.preprocessor.DeploymentPreprocessor] Running custom installation for fragment: org.nuxeo.ecm.platform.publisher.web 2013-11-09 17:00:05,147 INFO [org.nuxeo.runtime.deployment.preprocessor.DeploymentPreprocessor] Running custom installation for fragment: org.nuxeo.ecm.platform.notification.web 2013-11-09 17:00:05,149 INFO [org.nuxeo.runtime.deployment.preprocessor.DeploymentPreprocessor] Running custom installation for fragment: org.nuxeo.theme.jsf 2013-11-09 17:00:05,153 INFO [org.nuxeo.runtime.deployment.preprocessor.DeploymentPreprocessor] Running custom installation for fragment: org.nuxeo.ecm.annotations.client 2013-11-09 17:00:05,205 INFO [org.nuxeo.runtime.deployment.preprocessor.DeploymentPreprocessor] Running custom installation for fragment: org.nuxeo.ecm.webapp.base 2013-11-09 17:00:05,220 INFO [org.nuxeo.runtime.deployment.preprocessor.DeploymentPreprocessor] Running custom installation for fragment: org.nuxeo.ecm.platform.pictures.tiles.preview 2013-11-09 17:00:05,230 INFO [org.nuxeo.runtime.deployment.preprocessor.DeploymentPreprocessor] Running custom installation for fragment: org.nuxeo.ecm.platform.io.web 2013-11-09 17:00:05,231 INFO [org.nuxeo.runtime.deployment.preprocessor.DeploymentPreprocessor] Running custom installation for fragment: org.nuxeo.ecm.platform.comment.web 2013-11-09 17:00:05,232 INFO [org.nuxeo.runtime.deployment.preprocessor.DeploymentPreprocessor] Running custom installation for fragment: org.nuxeo.theme.html 2013-11-09 17:00:05,239 INFO [org.nuxeo.runtime.deployment.preprocessor.DeploymentPreprocessor] Running custom installation for fragment: org.nuxeo.ecm.platform.ui.compat 2013-11-09 17:00:05,285 INFO [org.nuxeo.runtime.deployment.preprocessor.DeploymentPreprocessor] Running custom installation for fragment: org.nuxeo.ecm.platform.pictures.tiles 2013-11-09 17:00:05,287 INFO [org.nuxeo.runtime.deployment.preprocessor.DeploymentPreprocessor] Running custom installation for fragment: org.nuxeo.ecm.platform.jbpm.web 2013-11-09 17:00:05,289 WARN [org.nuxeo.runtime.deployment.preprocessor.template.Template] The deployment-fragment contains illegal JEE java module contribution: nuxeo-theme-bank-5.4.0.1.jar 2013-11-09 17:00:05,290 INFO [org.nuxeo.runtime.deployment.preprocessor.DeploymentPreprocessor] Running custom installation for fragment: org.nuxeo.ecm.platform.faceted.search.jsf 2013-11-09 17:00:05,291 INFO [org.nuxeo.runtime.deployment.preprocessor.DeploymentPreprocessor] Running custom installation for fragment: org.nuxeo.ecm.annotations.http 2013-11-09 17:00:05,292 INFO [org.nuxeo.runtime.deployment.preprocessor.DeploymentPreprocessor] Running custom installation for fragment: org.nuxeo.ecm.platform.webengine.sites 2013-11-09 17:00:05,297 INFO [org.nuxeo.runtime.deployment.preprocessor.DeploymentPreprocessor] Running custom installation for fragment: org.nuxeo.ecm.platform.lang 2013-11-09 17:00:05,299 INFO [org.nuxeo.runtime.deployment.preprocessor.DeploymentPreprocessor] Running custom installation for fragment: org.nuxeo.ecm.platform.mail.web 2013-11-09 17:00:05,301 INFO [org.nuxeo.runtime.deployment.preprocessor.DeploymentPreprocessor] Running custom installation for fragment: org.nuxeo.ecm.platform.webengine.blogs 2013-11-09 17:00:05,310 INFO [org.nuxeo.runtime.deployment.preprocessor.DeploymentPreprocessor] Running custom installation for fragment: org.nuxeo.admin.center.monitoring 2013-11-09 17:00:05,314 INFO [org.nuxeo.runtime.deployment.preprocessor.DeploymentPreprocessor] Running custom installation for fragment: org.nuxeo.opensocial.spaces.web 2013-11-09 17:00:05,317 INFO [org.nuxeo.runtime.deployment.preprocessor.DeploymentPreprocessor] Running custom installation for fragment: org.nuxeo.opensocial.dashboard 2013-11-09 17:00:05,322 INFO [org.nuxeo.runtime.deployment.preprocessor.DeploymentPreprocessor] Running custom installation for fragment: org.nuxeo.ecm.platform.tag.web 2013-11-09 17:00:05,325 INFO [org.nuxeo.runtime.deployment.preprocessor.DeploymentPreprocessor] Running custom installation for fragment: org.nuxeo.admin.center 2013-11-09 17:00:05,342 INFO [org.nuxeo.runtime.deployment.preprocessor.DeploymentPreprocessor] Running custom installation for fragment: org.nuxeo.ecm.platform.lang.ext 2013-11-09 17:00:05,356 INFO [org.nuxeo.runtime.deployment.preprocessor.DeploymentPreprocessor] Running custom installation for fragment: org.nuxeo.ecm.platform.faceted.search.dm 2013-11-09 17:00:05,360 INFO [org.nuxeo.runtime.deployment.preprocessor.DeploymentPreprocessor] Running custom installation for fragment: org.nuxeo.ecm.platform.userworkspace.web 2013-11-09 17:00:05,361 INFO [org.nuxeo.runtime.deployment.preprocessor.DeploymentPreprocessor] Running custom installation for fragment: org.nuxeo.platform.virtualnavigation.web 2013-11-09 17:00:05,362 INFO [org.nuxeo.runtime.deployment.preprocessor.DeploymentPreprocessor] Running custom installation for fragment: org.nuxeo.ecm.platform.syndication 2013-11-09 17:00:05,367 INFO [org.nuxeo.runtime.deployment.preprocessor.DeploymentPreprocessor] Running custom installation for fragment: org.nuxeo.ecm.platform.wss.backend 2013-11-09 17:00:05,369 INFO [org.nuxeo.runtime.deployment.preprocessor.DeploymentPreprocessor] Running custom installation for fragment: org.nuxeo.ecm.core.opencmis.bindings 2013-11-09 17:00:05,370 WARN [org.nuxeo.runtime.deployment.preprocessor.template.Template] The deployment-fragment contains illegal JEE java module contribution: nuxeo-opencmis-bindings-5.4.0.1.jar 2013-11-09 17:00:05,370 WARN [org.nuxeo.runtime.deployment.preprocessor.DeploymentPreprocessor] No template 'jaxws' found for deployment fragment: org.nuxeo.ecm.core.opencmis.bindings 2013-11-09 17:00:05,370 WARN [org.nuxeo.runtime.deployment.preprocessor.template.Template] The deployment-fragment contains illegal JEE java module contribution: nuxeo-opencmis-impl-5.4.0.1.jar 2013-11-09 17:00:05,371 INFO [org.nuxeo.runtime.jboss.deployer.structure.NuxeoStructureDeployer] Nuxeo Preprocessing took 0.902 sec. 2013-11-09 17:00:05,472 INFO [org.nuxeo.runtime.jboss.deployer.structure.NuxeoStructureDeployer] Determining Nuxeo Deployment Structure took 1.024 sec. 2013-11-09 17:00:16,929 INFO [org.jboss.ejb3.deployers.Ejb3DependenciesDeployer] Encountered deployment AbstractVFSDeploymentContext@1765474380{vfsfile:/home/epankmi/Desktop/nuxeo-dm-5.4.0_01-jboss/nuxeo-dm-5.4.0.1-jboss/server/default/deploy/profileservice-secured.jar/} 2013-11-09 17:00:16,930 INFO [org.jboss.ejb3.deployers.Ejb3DependenciesDeployer] Encountered deployment AbstractVFSDeploymentContext@1765474380{vfsfile:/home/epankmi/Desktop/nuxeo-dm-5.4.0_01-jboss/nuxeo-dm-5.4.0.1-jboss/server/default/deploy/profileservice-secured.jar/} 2013-11-09 17:00:16,930 INFO [org.jboss.ejb3.deployers.Ejb3DependenciesDeployer] Encountered deployment AbstractVFSDeploymentContext@1765474380{vfsfile:/home/epankmi/Desktop/nuxeo-dm-5.4.0_01-jboss/nuxeo-dm-5.4.0.1-jboss/server/default/deploy/profileservice-secured.jar/} 2013-11-09 17:00:16,930 INFO [org.jboss.ejb3.deployers.Ejb3DependenciesDeployer] Encountered deployment AbstractVFSDeploymentContext@1765474380{vfsfile:/home/epankmi/Desktop/nuxeo-dm-5.4.0_01-jboss/nuxeo-dm-5.4.0.1-jboss/server/default/deploy/profileservice-secured.jar/} 2013-11-09 17:00:16,934 INFO [org.jboss.ejb3.deployers.Ejb3DependenciesDeployer] Encountered deployment AbstractVFSDeploymentContext@1544020214{vfsfile:/home/epankmi/Desktop/nuxeo-dm-5.4.0_01-jboss/nuxeo-dm-5.4.0.1-jboss/server/default/deploy/nuxeo.ear/} 2013-11-09 17:00:16,934 INFO [org.jboss.ejb3.deployers.Ejb3DependenciesDeployer] Encountered deployment AbstractVFSDeploymentContext@1544020214{vfsfile:/home/epankmi/Desktop/nuxeo-dm-5.4.0_01-jboss/nuxeo-dm-5.4.0.1-jboss/server/default/deploy/nuxeo.ear/} 2013-11-09 17:00:16,934 INFO [org.jboss.ejb3.deployers.Ejb3DependenciesDeployer] Encountered deployment AbstractVFSDeploymentContext@1408000612{vfszip:/home/epankmi/Desktop/nuxeo-dm-5.4.0_01-jboss/nuxeo-dm-5.4.0.1-jboss/server/default/deploy/nuxeo.ear/bundles/nuxeo-core-facade-5.4.0.1.jar/} 2013-11-09 17:00:16,934 INFO [org.jboss.ejb3.deployers.Ejb3DependenciesDeployer] Encountered deployment AbstractVFSDeploymentContext@1408000612{vfszip:/home/epankmi/Desktop/nuxeo-dm-5.4.0_01-jboss/nuxeo-dm-5.4.0.1-jboss/server/default/deploy/nuxeo.ear/bundles/nuxeo-core-facade-5.4.0.1.jar/} 2013-11-09 17:00:16,934 INFO [org.jboss.ejb3.deployers.Ejb3DependenciesDeployer] Encountered deployment AbstractVFSDeploymentContext@1408000612{vfszip:/home/epankmi/Desktop/nuxeo-dm-5.4.0_01-jboss/nuxeo-dm-5.4.0.1-jboss/server/default/deploy/nuxeo.ear/bundles/nuxeo-core-facade-5.4.0.1.jar/} 2013-11-09 17:00:16,934 INFO [org.jboss.ejb3.deployers.Ejb3DependenciesDeployer] Encountered deployment AbstractVFSDeploymentContext@1408000612{vfszip:/home/epankmi/Desktop/nuxeo-dm-5.4.0_01-jboss/nuxeo-dm-5.4.0.1-jboss/server/default/deploy/nuxeo.ear/bundles/nuxeo-core-facade-5.4.0.1.jar/} 2013-11-09 17:00:16,934 INFO [org.jboss.ejb3.deployers.Ejb3DependenciesDeployer] Encountered deployment AbstractVFSDeploymentContext@443894346{vfszip:/home/epankmi/Desktop/nuxeo-dm-5.4.0_01-jboss/nuxeo-dm-5.4.0.1-jboss/server/default/deploy/nuxeo.ear/bundles/nuxeo-platform-5.4.0.1.jar/} 2013-11-09 17:00:16,934 INFO [org.jboss.ejb3.deployers.Ejb3DependenciesDeployer] Encountered deployment AbstractVFSDeploymentContext@443894346{vfszip:/home/epankmi/Desktop/nuxeo-dm-5.4.0_01-jboss/nuxeo-dm-5.4.0.1-jboss/server/default/deploy/nuxeo.ear/bundles/nuxeo-platform-5.4.0.1.jar/} 2013-11-09 17:00:16,934 INFO [org.jboss.ejb3.deployers.Ejb3DependenciesDeployer] Encountered deployment AbstractVFSDeploymentContext@443894346{vfszip:/home/epankmi/Desktop/nuxeo-dm-5.4.0_01-jboss/nuxeo-dm-5.4.0.1-jboss/server/default/deploy/nuxeo.ear/bundles/nuxeo-platform-5.4.0.1.jar/} 2013-11-09 17:00:16,934 INFO [org.jboss.ejb3.deployers.Ejb3DependenciesDeployer] Encountered deployment AbstractVFSDeploymentContext@443894346{vfszip:/home/epankmi/Desktop/nuxeo-dm-5.4.0_01-jboss/nuxeo-dm-5.4.0.1-jboss/server/default/deploy/nuxeo.ear/bundles/nuxeo-platform-5.4.0.1.jar/} 2013-11-09 17:00:16,934 INFO [org.jboss.ejb3.deployers.Ejb3DependenciesDeployer] Encountered deployment AbstractVFSDeploymentContext@174083544{vfszip:/home/epankmi/Desktop/nuxeo-dm-5.4.0_01-jboss/nuxeo-dm-5.4.0.1-jboss/server/default/deploy/nuxeo.ear/bundles/nuxeo-platform-actions-core-5.4.0.1.jar/} 2013-11-09 17:00:16,935 INFO [org.jboss.ejb3.deployers.Ejb3DependenciesDeployer] Encountered deployment AbstractVFSDeploymentContext@174083544{vfszip:/home/epankmi/Desktop/nuxeo-dm-5.4.0_01-jboss/nuxeo-dm-5.4.0.1-jboss/server/default/deploy/nuxeo.ear/bundles/nuxeo-platform-actions-core-5.4.0.1.jar/} 2013-11-09 17:00:16,935 INFO [org.jboss.ejb3.deployers.Ejb3DependenciesDeployer] Encountered deployment AbstractVFSDeploymentContext@949396794{vfszip:/home/epankmi/Desktop/nuxeo-dm-5.4.0_01-jboss/nuxeo-dm-5.4.0.1-jboss/server/default/deploy/nuxeo.ear/bundles/nuxeo-platform-annotations-facade-5.4.0.1.jar/} 2013-11-09 17:00:16,935 INFO [org.jboss.ejb3.deployers.Ejb3DependenciesDeployer] Encountered deployment AbstractVFSDeploymentContext@949396794{vfszip:/home/epankmi/Desktop/nuxeo-dm-5.4.0_01-jboss/nuxeo-dm-5.4.0.1-jboss/server/default/deploy/nuxeo.ear/bundles/nuxeo-platform-annotations-facade-5.4.0.1.jar/} 2013-11-09 17:00:16,935 INFO [org.jboss.ejb3.deployers.Ejb3DependenciesDeployer] Encountered deployment AbstractVFSDeploymentContext@904738272{vfszip:/home/epankmi/Desktop/nuxeo-dm-5.4.0_01-jboss/nuxeo-dm-5.4.0.1-jboss/server/default/deploy/nuxeo.ear/bundles/nuxeo-platform-audit-facade-5.4.0.1.jar/} 2013-11-09 17:00:16,935 INFO [org.jboss.ejb3.deployers.Ejb3DependenciesDeployer] Encountered deployment AbstractVFSDeploymentContext@904738272{vfszip:/home/epankmi/Desktop/nuxeo-dm-5.4.0_01-jboss/nuxeo-dm-5.4.0.1-jboss/server/default/deploy/nuxeo.ear/bundles/nuxeo-platform-audit-facade-5.4.0.1.jar/} 2013-11-09 17:00:16,935 INFO [org.jboss.ejb3.deployers.Ejb3DependenciesDeployer] Encountered deployment AbstractVFSDeploymentContext@904738272{vfszip:/home/epankmi/Desktop/nuxeo-dm-5.4.0_01-jboss/nuxeo-dm-5.4.0.1-jboss/server/default/deploy/nuxeo.ear/bundles/nuxeo-platform-audit-facade-5.4.0.1.jar/} 2013-11-09 17:00:16,935 INFO [org.jboss.ejb3.deployers.Ejb3DependenciesDeployer] Encountered deployment AbstractVFSDeploymentContext@904738272{vfszip:/home/epankmi/Desktop/nuxeo-dm-5.4.0_01-jboss/nuxeo-dm-5.4.0.1-jboss/server/default/deploy/nuxeo.ear/bundles/nuxeo-platform-audit-facade-5.4.0.1.jar/} 2013-11-09 17:00:16,935 INFO [org.jboss.ejb3.deployers.Ejb3DependenciesDeployer] Encountered deployment AbstractVFSDeploymentContext@1751916744{vfszip:/home/epankmi/Desktop/nuxeo-dm-5.4.0_01-jboss/nuxeo-dm-5.4.0.1-jboss/server/default/deploy/nuxeo.ear/bundles/nuxeo-platform-comment-5.4.0.1.jar/} 2013-11-09 17:00:16,935 INFO [org.jboss.ejb3.deployers.Ejb3DependenciesDeployer] Encountered deployment AbstractVFSDeploymentContext@1751916744{vfszip:/home/epankmi/Desktop/nuxeo-dm-5.4.0_01-jboss/nuxeo-dm-5.4.0.1-jboss/server/default/deploy/nuxeo.ear/bundles/nuxeo-platform-comment-5.4.0.1.jar/} 2013-11-09 17:00:16,935 INFO [org.jboss.ejb3.deployers.Ejb3DependenciesDeployer] Encountered deployment AbstractVFSDeploymentContext@316432391{vfszip:/home/epankmi/Desktop/nuxeo-dm-5.4.0_01-jboss/nuxeo-dm-5.4.0.1-jboss/server/default/deploy/nuxeo.ear/bundles/nuxeo-platform-directory-facade-5.4.0.1.jar/} 2013-11-09 17:00:16,935 INFO [org.jboss.ejb3.deployers.Ejb3DependenciesDeployer] Encountered deployment AbstractVFSDeploymentContext@316432391{vfszip:/home/epankmi/Desktop/nuxeo-dm-5.4.0_01-jboss/nuxeo-dm-5.4.0.1-jboss/server/default/deploy/nuxeo.ear/bundles/nuxeo-platform-directory-facade-5.4.0.1.jar/} 2013-11-09 17:00:16,935 INFO [org.jboss.ejb3.deployers.Ejb3DependenciesDeployer] Encountered deployment AbstractVFSDeploymentContext@1883348499{vfszip:/home/epankmi/Desktop/nuxeo-dm-5.4.0_01-jboss/nuxeo-dm-5.4.0.1-jboss/server/default/deploy/nuxeo.ear/bundles/nuxeo-platform-filemanager-facade-5.4.0.1.jar/} 2013-11-09 17:00:16,935 INFO [org.jboss.ejb3.deployers.Ejb3DependenciesDeployer] Encountered deployment AbstractVFSDeploymentContext@1883348499{vfszip:/home/epankmi/Desktop/nuxeo-dm-5.4.0_01-jboss/nuxeo-dm-5.4.0.1-jboss/server/default/deploy/nuxeo.ear/bundles/nuxeo-platform-filemanager-facade-5.4.0.1.jar/} 2013-11-09 17:00:16,936 INFO [org.jboss.ejb3.deployers.Ejb3DependenciesDeployer] Encountered deployment AbstractVFSDeploymentContext@1849438986{vfszip:/home/epankmi/Desktop/nuxeo-dm-5.4.0_01-jboss/nuxeo-dm-5.4.0.1-jboss/server/default/deploy/nuxeo.ear/bundles/nuxeo-platform-imaging-facade-5.4.0.1.jar/} 2013-11-09 17:00:16,936 INFO [org.jboss.ejb3.deployers.Ejb3DependenciesDeployer] Encountered deployment AbstractVFSDeploymentContext@1849438986{vfszip:/home/epankmi/Desktop/nuxeo-dm-5.4.0_01-jboss/nuxeo-dm-5.4.0.1-jboss/server/default/deploy/nuxeo.ear/bundles/nuxeo-platform-imaging-facade-5.4.0.1.jar/} 2013-11-09 17:00:16,936 INFO [org.jboss.ejb3.deployers.Ejb3DependenciesDeployer] Encountered deployment AbstractVFSDeploymentContext@1125668403{vfszip:/home/epankmi/Desktop/nuxeo-dm-5.4.0_01-jboss/nuxeo-dm-5.4.0.1-jboss/server/default/deploy/nuxeo.ear/bundles/nuxeo-platform-io-facade-5.4.0.1.jar/} 2013-11-09 17:00:16,936 INFO [org.jboss.ejb3.deployers.Ejb3DependenciesDeployer] Encountered deployment AbstractVFSDeploymentContext@1125668403{vfszip:/home/epankmi/Desktop/nuxeo-dm-5.4.0_01-jboss/nuxeo-dm-5.4.0.1-jboss/server/default/deploy/nuxeo.ear/bundles/nuxeo-platform-io-facade-5.4.0.1.jar/} 2013-11-09 17:00:16,936 INFO [org.jboss.ejb3.deployers.Ejb3DependenciesDeployer] Encountered deployment AbstractVFSDeploymentContext@1925402798{vfszip:/home/epankmi/Desktop/nuxeo-dm-5.4.0_01-jboss/nuxeo-dm-5.4.0.1-jboss/server/default/deploy/nuxeo.ear/bundles/nuxeo-platform-jbpm-facade-5.4.0.1.jar/} 2013-11-09 17:00:16,936 INFO [org.jboss.ejb3.deployers.Ejb3DependenciesDeployer] Encountered deployment AbstractVFSDeploymentContext@1925402798{vfszip:/home/epankmi/Desktop/nuxeo-dm-5.4.0_01-jboss/nuxeo-dm-5.4.0.1-jboss/server/default/deploy/nuxeo.ear/bundles/nuxeo-platform-jbpm-facade-5.4.0.1.jar/} 2013-11-09 17:00:16,936 INFO [org.jboss.ejb3.deployers.Ejb3DependenciesDeployer] Encountered deployment AbstractVFSDeploymentContext@716365127{vfszip:/home/epankmi/Desktop/nuxeo-dm-5.4.0_01-jboss/nuxeo-dm-5.4.0.1-jboss/server/default/deploy/nuxeo.ear/bundles/nuxeo-platform-mimetype-facade-5.4.0.1.jar/} 2013-11-09 17:00:16,936 INFO [org.jboss.ejb3.deployers.Ejb3DependenciesDeployer] Encountered deployment AbstractVFSDeploymentContext@716365127{vfszip:/home/epankmi/Desktop/nuxeo-dm-5.4.0_01-jboss/nuxeo-dm-5.4.0.1-jboss/server/default/deploy/nuxeo.ear/bundles/nuxeo-platform-mimetype-facade-5.4.0.1.jar/} 2013-11-09 17:00:16,936 INFO [org.jboss.ejb3.deployers.Ejb3DependenciesDeployer] Encountered deployment AbstractVFSDeploymentContext@662452275{vfszip:/home/epankmi/Desktop/nuxeo-dm-5.4.0_01-jboss/nuxeo-dm-5.4.0.1-jboss/server/default/deploy/nuxeo.ear/bundles/nuxeo-platform-notification-facade-5.4.0.1.jar/} 2013-11-09 17:00:16,936 INFO [org.jboss.ejb3.deployers.Ejb3DependenciesDeployer] Encountered deployment AbstractVFSDeploymentContext@662452275{vfszip:/home/epankmi/Desktop/nuxeo-dm-5.4.0_01-jboss/nuxeo-dm-5.4.0.1-jboss/server/default/deploy/nuxeo.ear/bundles/nuxeo-platform-notification-facade-5.4.0.1.jar/} 2013-11-09 17:00:16,936 INFO [org.jboss.ejb3.deployers.Ejb3DependenciesDeployer] Encountered deployment AbstractVFSDeploymentContext@1482209867{vfszip:/home/epankmi/Desktop/nuxeo-dm-5.4.0_01-jboss/nuxeo-dm-5.4.0.1-jboss/server/default/deploy/nuxeo.ear/bundles/nuxeo-platform-placeful-facade-5.4.0.1.jar/} 2013-11-09 17:00:16,936 INFO [org.jboss.ejb3.deployers.Ejb3DependenciesDeployer] Encountered deployment AbstractVFSDeploymentContext@1482209867{vfszip:/home/epankmi/Desktop/nuxeo-dm-5.4.0_01-jboss/nuxeo-dm-5.4.0.1-jboss/server/default/deploy/nuxeo.ear/bundles/nuxeo-platform-placeful-facade-5.4.0.1.jar/} 2013-11-09 17:00:16,937 INFO [org.jboss.ejb3.deployers.Ejb3DependenciesDeployer] Encountered deployment AbstractVFSDeploymentContext@1504062519{vfszip:/home/epankmi/Desktop/nuxeo-dm-5.4.0_01-jboss/nuxeo-dm-5.4.0.1-jboss/server/default/deploy/nuxeo.ear/bundles/nuxeo-platform-relations-facade-5.4.0.1.jar/} 2013-11-09 17:00:16,937 INFO [org.jboss.ejb3.deployers.Ejb3DependenciesDeployer] Encountered deployment AbstractVFSDeploymentContext@1504062519{vfszip:/home/epankmi/Desktop/nuxeo-dm-5.4.0_01-jboss/nuxeo-dm-5.4.0.1-jboss/server/default/deploy/nuxeo.ear/bundles/nuxeo-platform-relations-facade-5.4.0.1.jar/} 2013-11-09 17:00:16,937 INFO [org.jboss.ejb3.deployers.Ejb3DependenciesDeployer] Encountered deployment AbstractVFSDeploymentContext@580826219{vfszip:/home/epankmi/Desktop/nuxeo-dm-5.4.0_01-jboss/nuxeo-dm-5.4.0.1-jboss/server/default/deploy/nuxeo.ear/bundles/nuxeo-platform-search-facade-5.4.0.1.jar/} 2013-11-09 17:00:16,937 INFO [org.jboss.ejb3.deployers.Ejb3DependenciesDeployer] Encountered deployment AbstractVFSDeploymentContext@580826219{vfszip:/home/epankmi/Desktop/nuxeo-dm-5.4.0_01-jboss/nuxeo-dm-5.4.0.1-jboss/server/default/deploy/nuxeo.ear/bundles/nuxeo-platform-search-facade-5.4.0.1.jar/} 2013-11-09 17:00:16,937 INFO [org.jboss.ejb3.deployers.Ejb3DependenciesDeployer] Encountered deployment AbstractVFSDeploymentContext@580826219{vfszip:/home/epankmi/Desktop/nuxeo-dm-5.4.0_01-jboss/nuxeo-dm-5.4.0.1-jboss/server/default/deploy/nuxeo.ear/bundles/nuxeo-platform-search-facade-5.4.0.1.jar/} 2013-11-09 17:00:16,937 INFO [org.jboss.ejb3.deployers.Ejb3DependenciesDeployer] Encountered deployment AbstractVFSDeploymentContext@580826219{vfszip:/home/epankmi/Desktop/nuxeo-dm-5.4.0_01-jboss/nuxeo-dm-5.4.0.1-jboss/server/default/deploy/nuxeo.ear/bundles/nuxeo-platform-search-facade-5.4.0.1.jar/} 2013-11-09 17:00:16,937 INFO [org.jboss.ejb3.deployers.Ejb3DependenciesDeployer] Encountered deployment AbstractVFSDeploymentContext@1633087118{vfszip:/home/epankmi/Desktop/nuxeo-dm-5.4.0_01-jboss/nuxeo-dm-5.4.0.1-jboss/server/default/deploy/nuxeo.ear/bundles/nuxeo-platform-tag-facade-5.4.0.1.jar/} 2013-11-09 17:00:16,937 INFO [org.jboss.ejb3.deployers.Ejb3DependenciesDeployer] Encountered deployment AbstractVFSDeploymentContext@1633087118{vfszip:/home/epankmi/Desktop/nuxeo-dm-5.4.0_01-jboss/nuxeo-dm-5.4.0.1-jboss/server/default/deploy/nuxeo.ear/bundles/nuxeo-platform-tag-facade-5.4.0.1.jar/} 2013-11-09 17:00:16,937 INFO [org.jboss.ejb3.deployers.Ejb3DependenciesDeployer] Encountered deployment AbstractVFSDeploymentContext@1633087118{vfszip:/home/epankmi/Desktop/nuxeo-dm-5.4.0_01-jboss/nuxeo-dm-5.4.0.1-jboss/server/default/deploy/nuxeo.ear/bundles/nuxeo-platform-tag-facade-5.4.0.1.jar/} 2013-11-09 17:00:16,937 INFO [org.jboss.ejb3.deployers.Ejb3DependenciesDeployer] Encountered deployment AbstractVFSDeploymentContext@1633087118{vfszip:/home/epankmi/Desktop/nuxeo-dm-5.4.0_01-jboss/nuxeo-dm-5.4.0.1-jboss/server/default/deploy/nuxeo.ear/bundles/nuxeo-platform-tag-facade-5.4.0.1.jar/} 2013-11-09 17:00:16,937 INFO [org.jboss.ejb3.deployers.Ejb3DependenciesDeployer] Encountered deployment AbstractVFSDeploymentContext@243064210{vfszip:/home/epankmi/Desktop/nuxeo-dm-5.4.0_01-jboss/nuxeo-dm-5.4.0.1-jboss/server/default/deploy/nuxeo.ear/bundles/nuxeo-platform-types-facade-5.4.0.1.jar/} 2013-11-09 17:00:16,937 INFO [org.jboss.ejb3.deployers.Ejb3DependenciesDeployer] Encountered deployment AbstractVFSDeploymentContext@243064210{vfszip:/home/epankmi/Desktop/nuxeo-dm-5.4.0_01-jboss/nuxeo-dm-5.4.0.1-jboss/server/default/deploy/nuxeo.ear/bundles/nuxeo-platform-types-facade-5.4.0.1.jar/} 2013-11-09 17:00:16,937 INFO [org.jboss.ejb3.deployers.Ejb3DependenciesDeployer] Encountered deployment AbstractVFSDeploymentContext@1202947474{vfszip:/home/epankmi/Desktop/nuxeo-dm-5.4.0_01-jboss/nuxeo-dm-5.4.0.1-jboss/server/default/deploy/nuxeo.ear/bundles/nuxeo-platform-uidgen-core-5.4.0.1.jar/} 2013-11-09 17:00:16,937 INFO [org.jboss.ejb3.deployers.Ejb3DependenciesDeployer] Encountered deployment AbstractVFSDeploymentContext@1202947474{vfszip:/home/epankmi/Desktop/nuxeo-dm-5.4.0_01-jboss/nuxeo-dm-5.4.0.1-jboss/server/default/deploy/nuxeo.ear/bundles/nuxeo-platform-uidgen-core-5.4.0.1.jar/} 2013-11-09 17:00:16,938 INFO [org.jboss.ejb3.deployers.Ejb3DependenciesDeployer] Encountered deployment AbstractVFSDeploymentContext@2109621323{vfszip:/home/epankmi/Desktop/nuxeo-dm-5.4.0_01-jboss/nuxeo-dm-5.4.0.1-jboss/server/default/deploy/nuxeo.ear/bundles/nuxeo-platform-url-facade-5.4.0.1.jar/} 2013-11-09 17:00:16,938 INFO [org.jboss.ejb3.deployers.Ejb3DependenciesDeployer] Encountered deployment AbstractVFSDeploymentContext@2109621323{vfszip:/home/epankmi/Desktop/nuxeo-dm-5.4.0_01-jboss/nuxeo-dm-5.4.0.1-jboss/server/default/deploy/nuxeo.ear/bundles/nuxeo-platform-url-facade-5.4.0.1.jar/} 2013-11-09 17:00:16,938 INFO [org.jboss.ejb3.deployers.Ejb3DependenciesDeployer] Encountered deployment AbstractVFSDeploymentContext@1450563691{vfszip:/home/epankmi/Desktop/nuxeo-dm-5.4.0_01-jboss/nuxeo-dm-5.4.0.1-jboss/server/default/deploy/nuxeo.ear/bundles/nuxeo-platform-usermanager-facade-5.4.0.1.jar/} 2013-11-09 17:00:16,938 INFO [org.jboss.ejb3.deployers.Ejb3DependenciesDeployer] Encountered deployment AbstractVFSDeploymentContext@1450563691{vfszip:/home/epankmi/Desktop/nuxeo-dm-5.4.0_01-jboss/nuxeo-dm-5.4.0.1-jboss/server/default/deploy/nuxeo.ear/bundles/nuxeo-platform-usermanager-facade-5.4.0.1.jar/} 2013-11-09 17:00:16,938 INFO [org.jboss.ejb3.deployers.Ejb3DependenciesDeployer] Encountered deployment AbstractVFSDeploymentContext@1019898526{vfszip:/home/epankmi/Desktop/nuxeo-dm-5.4.0_01-jboss/nuxeo-dm-5.4.0.1-jboss/server/default/deploy/nuxeo.ear/bundles/nuxeo-platform-userworkspace-facade-5.4.0.1.jar/} 2013-11-09 17:00:16,938 INFO [org.jboss.ejb3.deployers.Ejb3DependenciesDeployer] Encountered deployment AbstractVFSDeploymentContext@1019898526{vfszip:/home/epankmi/Desktop/nuxeo-dm-5.4.0_01-jboss/nuxeo-dm-5.4.0.1-jboss/server/default/deploy/nuxeo.ear/bundles/nuxeo-platform-userworkspace-facade-5.4.0.1.jar/} 2013-11-09 17:00:16,938 INFO [org.jboss.ejb3.deployers.Ejb3DependenciesDeployer] Encountered deployment AbstractVFSDeploymentContext@739742560{vfszip:/home/epankmi/Desktop/nuxeo-dm-5.4.0_01-jboss/nuxeo-dm-5.4.0.1-jboss/server/default/deploy/nuxeo.ear/bundles/nuxeo-platform-versioning-core-5.4.0.1.jar/} 2013-11-09 17:00:16,938 INFO [org.jboss.ejb3.deployers.Ejb3DependenciesDeployer] Encountered deployment AbstractVFSDeploymentContext@739742560{vfszip:/home/epankmi/Desktop/nuxeo-dm-5.4.0_01-jboss/nuxeo-dm-5.4.0.1-jboss/server/default/deploy/nuxeo.ear/bundles/nuxeo-platform-versioning-core-5.4.0.1.jar/} 2013-11-09 17:00:16,938 INFO [org.jboss.ejb3.deployers.Ejb3DependenciesDeployer] Encountered deployment AbstractVFSDeploymentContext@295844740{vfszip:/home/epankmi/Desktop/nuxeo-dm-5.4.0_01-jboss/nuxeo-dm-5.4.0.1-jboss/server/default/deploy/nuxeo.ear/bundles/nuxeo-platform-webapp-core-5.4.0.1.jar/} 2013-11-09 17:00:16,938 INFO [org.jboss.ejb3.deployers.Ejb3DependenciesDeployer] Encountered deployment AbstractVFSDeploymentContext@295844740{vfszip:/home/epankmi/Desktop/nuxeo-dm-5.4.0_01-jboss/nuxeo-dm-5.4.0.1-jboss/server/default/deploy/nuxeo.ear/bundles/nuxeo-platform-webapp-core-5.4.0.1.jar/} 2013-11-09 17:00:16,938 INFO [org.jboss.ejb3.deployers.Ejb3DependenciesDeployer] Encountered deployment AbstractVFSDeploymentContext@295844740{vfszip:/home/epankmi/Desktop/nuxeo-dm-5.4.0_01-jboss/nuxeo-dm-5.4.0.1-jboss/server/default/deploy/nuxeo.ear/bundles/nuxeo-platform-webapp-core-5.4.0.1.jar/} 2013-11-09 17:00:18,394 ERROR [org.jboss.kernel.plugins.dependency.AbstractKernelController] Error installing to Start: name=jboss:service=invoker,type=http state=Create mode=Manual requiredState=Installed java.net.UnknownHostException: B1H68R1.egi.ericsson.com: B1H68R1.egi.ericsson.com at java.net.InetAddress.getLocalHost(InetAddress.java:1454) at org.jboss.invocation.http.server.HttpInvoker.checkInvokerURL(HttpInvoker.java:204) at org.jboss.invocation.http.server.HttpInvoker.startService(HttpInvoker.java:101) at org.jboss.system.ServiceMBeanSupport.jbossInternalStart(ServiceMBeanSupport.java:376) at org.jboss.system.ServiceMBeanSupport.jbossInternalLifecycle(ServiceMBeanSupport.java:322) at sun.reflect.GeneratedMethodAccessor81.invoke(Unknown Source) at sun.reflect.DelegatingMethodAccessorImpl.invoke(DelegatingMethodAccessorImpl.java:43) at java.lang.reflect.Method.invoke(Method.java:616) at org.jboss.mx.interceptor.ReflectedDispatcher.invoke(ReflectedDispatcher.java:157) at org.jboss.mx.server.Invocation.dispatch(Invocation.java:96) at org.jboss.mx.server.Invocation.invoke(Invocation.java:88) at org.jboss.mx.server.AbstractMBeanInvoker.invoke(AbstractMBeanInvoker.java:264) at org.jboss.mx.server.MBeanServerImpl.invoke(MBeanServerImpl.java:668) at org.jboss.system.microcontainer.ServiceProxy.invoke(ServiceProxy.java:189) at sun.proxy.$Proxy38.start(Unknown Source) at org.jboss.system.microcontainer.StartStopLifecycleAction.installAction(StartStopLifecycleAction.java:42) at org.jboss.system.microcontainer.StartStopLifecycleAction.installAction(StartStopLifecycleAction.java:37) at org.jboss.dependency.plugins.action.SimpleControllerContextAction.simpleInstallAction(SimpleControllerContextAction.java:62) at org.jboss.dependency.plugins.action.AccessControllerContextAction.install(AccessControllerContextAction.java:71) at org.jboss.dependency.plugins.AbstractControllerContextActions.install(AbstractControllerContextActions.java:51) at org.jboss.dependency.plugins.AbstractControllerContext.install(AbstractControllerContext.java:348) at org.jboss.system.microcontainer.ServiceControllerContext.install(ServiceControllerContext.java:286) at org.jboss.dependency.plugins.AbstractController.install(AbstractController.java:1631) at org.jboss.dependency.plugins.AbstractController.incrementState(AbstractController.java:934) at org.jboss.dependency.plugins.AbstractController.resolveContexts(AbstractController.java:1082) at org.jboss.dependency.plugins.AbstractController.resolveContexts(AbstractController.java:984) at org.jboss.dependency.plugins.AbstractController.change(AbstractController.java:822) at org.jboss.dependency.plugins.AbstractController.change(AbstractController.java:553) at org.jboss.system.ServiceController.doChange(ServiceController.java:688) at org.jboss.system.ServiceController.start(ServiceController.java:460) at org.jboss.system.deployers.ServiceDeployer.start(ServiceDeployer.java:163) at org.jboss.system.deployers.ServiceDeployer.deploy(ServiceDeployer.java:99) at org.jboss.system.deployers.ServiceDeployer.deploy(ServiceDeployer.java:46) at org.jboss.deployers.spi.deployer.helpers.AbstractSimpleRealDeployer.internalDeploy(AbstractSimpleRealDeployer.java:62) at org.jboss.deployers.spi.deployer.helpers.AbstractRealDeployer.deploy(AbstractRealDeployer.java:50) at org.jboss.deployers.plugins.deployers.DeployerWrapper.deploy(DeployerWrapper.java:171) at org.jboss.deployers.plugins.deployers.DeployersImpl.doDeploy(DeployersImpl.java:1439) at org.jboss.deployers.plugins.deployers.DeployersImpl.doInstallParentFirst(DeployersImpl.java:1157) at org.jboss.deployers.plugins.deployers.DeployersImpl.doInstallParentFirst(DeployersImpl.java:1178) at org.jboss.deployers.plugins.deployers.DeployersImpl.install(DeployersImpl.java:1098) at org.jboss.dependency.plugins.AbstractControllerContext.install(AbstractControllerContext.java:348) at org.jboss.dependency.plugins.AbstractController.install(AbstractController.java:1631) at org.jboss.dependency.plugins.AbstractController.incrementState(AbstractController.java:934) at org.jboss.dependency.plugins.AbstractController.resolveContexts(AbstractController.java:1082) at org.jboss.dependency.plugins.AbstractController.resolveContexts(AbstractController.java:984) at org.jboss.dependency.plugins.AbstractController.change(AbstractController.java:822) at org.jboss.dependency.plugins.AbstractController.change(AbstractController.java:553) at org.jboss.deployers.plugins.deployers.DeployersImpl.process(DeployersImpl.java:781) at org.jboss.deployers.plugins.main.MainDeployerImpl.process(MainDeployerImpl.java:702) at org.jboss.system.server.profileservice.repository.MainDeployerAdapter.process(MainDeployerAdapter.java:117) at org.jboss.system.server.profileservice.repository.ProfileDeployAction.install(ProfileDeployAction.java:70) at org.jboss.system.server.profileservice.repository.AbstractProfileAction.install(AbstractProfileAction.java:53) at org.jboss.system.server.profileservice.repository.AbstractProfileService.install(AbstractProfileService.java:361) at org.jboss.dependency.plugins.AbstractControllerContext.install(AbstractControllerContext.java:348) at org.jboss.dependency.plugins.AbstractController.install(AbstractController.java:1631) at org.jboss.dependency.plugins.AbstractController.incrementState(AbstractController.java:934) at org.jboss.dependency.plugins.AbstractController.resolveContexts(AbstractController.java:1082) at org.jboss.dependency.plugins.AbstractController.resolveContexts(AbstractController.java:984) at org.jboss.dependency.plugins.AbstractController.change(AbstractController.java:822) at org.jboss.dependency.plugins.AbstractController.change(AbstractController.java:553) at org.jboss.system.server.profileservice.repository.AbstractProfileService.activateProfile(AbstractProfileService.java:306) at org.jboss.system.server.profileservice.ProfileServiceBootstrap.start(ProfileServiceBootstrap.java:271) at org.jboss.bootstrap.AbstractServerImpl.start(AbstractServerImpl.java:461) at org.jboss.Main.boot(Main.java:221) at org.jboss.Main$1.run(Main.java:556) at java.lang.Thread.run(Thread.java:679) 2013-11-09 17:00:18,405 ERROR [org.jboss.kernel.plugins.dependency.AbstractKernelController] Error installing to Real: name=vfsfile:/home/epankmi/Desktop/nuxeo-dm-5.4.0_01-jboss/nuxeo-dm-5.4.0.1-jboss/server/default/deploy/http-invoker.sar/ state=PreReal mode=Manual requiredState=Real org.jboss.deployers.spi.DeploymentException: Error deploying: jboss:service=invoker,type=http at org.jboss.deployers.spi.DeploymentException.rethrowAsDeploymentException(DeploymentException.java:49) at org.jboss.system.deployers.ServiceDeployer.deploy(ServiceDeployer.java:118) at org.jboss.system.deployers.ServiceDeployer.deploy(ServiceDeployer.java:46) at org.jboss.deployers.spi.deployer.helpers.AbstractSimpleRealDeployer.internalDeploy(AbstractSimpleRealDeployer.java:62) at org.jboss.deployers.spi.deployer.helpers.AbstractRealDeployer.deploy(AbstractRealDeployer.java:50) at org.jboss.deployers.plugins.deployers.DeployerWrapper.deploy(DeployerWrapper.java:171) at org.jboss.deployers.plugins.deployers.DeployersImpl.doDeploy(DeployersImpl.java:1439) at org.jboss.deployers.plugins.deployers.DeployersImpl.doInstallParentFirst(DeployersImpl.java:1157) at org.jboss.deployers.plugins.deployers.DeployersImpl.doInstallParentFirst(DeployersImpl.java:1178) at org.jboss.deployers.plugins.deployers.DeployersImpl.install(DeployersImpl.java:1098) at org.jboss.dependency.plugins.AbstractControllerContext.install(AbstractControllerContext.java:348) at org.jboss.dependency.plugins.AbstractController.install(AbstractController.java:1631) at org.jboss.dependency.plugins.AbstractController.incrementState(AbstractController.java:934) at org.jboss.dependency.plugins.AbstractController.resolveContexts(AbstractController.java:1082) at org.jboss.dependency.plugins.AbstractController.resolveContexts(AbstractController.java:984) at org.jboss.dependency.plugins.AbstractController.change(AbstractController.java:822) at org.jboss.dependency.plugins.AbstractController.change(AbstractController.java:553) at org.jboss.deployers.plugins.deployers.DeployersImpl.process(DeployersImpl.java:781) at org.jboss.deployers.plugins.main.MainDeployerImpl.process(MainDeployerImpl.java:702) at org.jboss.system.server.profileservice.repository.MainDeployerAdapter.process(MainDeployerAdapter.java:117) at org.jboss.system.server.profileservice.repository.ProfileDeployAction.install(ProfileDeployAction.java:70) at org.jboss.system.server.profileservice.repository.AbstractProfileAction.install(AbstractProfileAction.java:53) at org.jboss.system.server.profileservice.repository.AbstractProfileService.install(AbstractProfileService.java:361) at org.jboss.dependency.plugins.AbstractControllerContext.install(AbstractControllerContext.java:348) at org.jboss.dependency.plugins.AbstractController.install(AbstractController.java:1631) at org.jboss.dependency.plugins.AbstractController.incrementState(AbstractController.java:934) at org.jboss.dependency.plugins.AbstractController.resolveContexts(AbstractController.java:1082) at org.jboss.dependency.plugins.AbstractController.resolveContexts(AbstractController.java:984) at org.jboss.dependency.plugins.AbstractController.change(AbstractController.java:822) at org.jboss.dependency.plugins.AbstractController.change(AbstractController.java:553) at org.jboss.system.server.profileservice.repository.AbstractProfileService.activateProfile(AbstractProfileService.java:306) at org.jboss.system.server.profileservice.ProfileServiceBootstrap.start(ProfileServiceBootstrap.java:271) at org.jboss.bootstrap.AbstractServerImpl.start(AbstractServerImpl.java:461) at org.jboss.Main.boot(Main.java:221) at org.jboss.Main$1.run(Main.java:556) at java.lang.Thread.run(Thread.java:679) Caused by: java.net.UnknownHostException: B1H68R1.egi.ericsson.com: B1H68R1.egi.ericsson.com at java.net.InetAddress.getLocalHost(InetAddress.java:1454) at org.jboss.invocation.http.server.HttpInvoker.checkInvokerURL(HttpInvoker.java:204) at org.jboss.invocation.http.server.HttpInvoker.startService(HttpInvoker.java:101) at org.jboss.system.ServiceMBeanSupport.jbossInternalStart(ServiceMBeanSupport.java:376) at org.jboss.system.ServiceMBeanSupport.jbossInternalLifecycle(ServiceMBeanSupport.java:322) at sun.reflect.GeneratedMethodAccessor81.invoke(Unknown Source) at sun.reflect.DelegatingMethodAccessorImpl.invoke(DelegatingMethodAccessorImpl.java:43) at java.lang.reflect.Method.invoke(Method.java:616) at org.jboss.mx.interceptor.ReflectedDispatcher.invoke(ReflectedDispatcher.java:157) at org.jboss.mx.server.Invocation.dispatch(Invocation.java:96) at org.jboss.mx.server.Invocation.invoke(Invocation.java:88) at org.jboss.mx.server.AbstractMBeanInvoker.invoke(AbstractMBeanInvoker.java:264) at org.jboss.mx.server.MBeanServerImpl.invoke(MBeanServerImpl.java:668) at org.jboss.system.microcontainer.ServiceProxy.invoke(ServiceProxy.java:189) at sun.proxy.$Proxy38.start(Unknown Source) at org.jboss.system.microcontainer.StartStopLifecycleAction.installAction(StartStopLifecycleAction.java:42) at org.jboss.system.microcontainer.StartStopLifecycleAction.installAction(StartStopLifecycleAction.java:37) at org.jboss.dependency.plugins.action.SimpleControllerContextAction.simpleInstallAction(SimpleControllerContextAction.java:62) at org.jboss.dependency.plugins.action.AccessControllerContextAction.install(AccessControllerContextAction.java:71) at org.jboss.dependency.plugins.AbstractControllerContextActions.install(AbstractControllerContextActions.java:51) at org.jboss.dependency.plugins.AbstractControllerContext.install(AbstractControllerContext.java:348) at org.jboss.system.microcontainer.ServiceControllerContext.install(ServiceControllerContext.java:286) at org.jboss.dependency.plugins.AbstractController.install(AbstractController.java:1631) at org.jboss.dependency.plugins.AbstractController.incrementState(AbstractController.java:934) at org.jboss.dependency.plugins.AbstractController.resolveContexts(AbstractController.java:1082) at org.jboss.dependency.plugins.AbstractController.resolveContexts(AbstractController.java:984) at org.jboss.dependency.plugins.AbstractController.change(AbstractController.java:822) at org.jboss.dependency.plugins.AbstractController.change(AbstractController.java:553) at org.jboss.system.ServiceController.doChange(ServiceController.java:688) at org.jboss.system.ServiceController.start(ServiceController.java:460) at org.jboss.system.deployers.ServiceDeployer.start(ServiceDeployer.java:163) at org.jboss.system.deployers.ServiceDeployer.deploy(ServiceDeployer.java:99) ... 34 more 2013-11-09 17:00:20,795 ERROR [org.jboss.kernel.plugins.dependency.AbstractKernelController] Error installing to Start: name=jboss.remoting:protocol=rmi,service=JMXConnectorServer state=Create mode=Manual requiredState=Installed java.io.IOException: Cannot bind to URL [rmi://0.0.0.0:1090/jmxconnector]: javax.naming.ConfigurationException [Root exception is java.rmi.UnknownHostException: Unknown host: 0.0.0.0; nested exception is: java.net.UnknownHostException: B1H68R1.egi.ericsson.com: B1H68R1.egi.ericsson.com] at javax.management.remote.rmi.RMIConnectorServer.newIOException(RMIConnectorServer.java:818) at javax.management.remote.rmi.RMIConnectorServer.start(RMIConnectorServer.java:431) at org.jboss.mx.remoting.service.JMXConnectorServerService.start(JMXConnectorServerService.java:131) at sun.reflect.NativeMethodAccessorImpl.invoke0(Native Method) at sun.reflect.NativeMethodAccessorImpl.invoke(NativeMethodAccessorImpl.java:57) at sun.reflect.DelegatingMethodAccessorImpl.invoke(DelegatingMethodAccessorImpl.java:43) at java.lang.reflect.Method.invoke(Method.java:616) at org.jboss.mx.interceptor.ReflectedDispatcher.invoke(ReflectedDispatcher.java:157) at org.jboss.mx.server.Invocation.dispatch(Invocation.java:96) at org.jboss.mx.server.Invocation.invoke(Invocation.java:88) at org.jboss.mx.server.AbstractMBeanInvoker.invoke(AbstractMBeanInvoker.java:264) at org.jboss.mx.server.MBeanServerImpl.invoke(MBeanServerImpl.java:668) at org.jboss.system.microcontainer.ServiceProxy.invoke(ServiceProxy.java:206) at sun.proxy.$Proxy38.start(Unknown Source) at org.jboss.system.microcontainer.StartStopLifecycleAction.installAction(StartStopLifecycleAction.java:42) at org.jboss.system.microcontainer.StartStopLifecycleAction.installAction(StartStopLifecycleAction.java:37) at org.jboss.dependency.plugins.action.SimpleControllerContextAction.simpleInstallAction(SimpleControllerContextAction.java:62) at org.jboss.dependency.plugins.action.AccessControllerContextAction.install(AccessControllerContextAction.java:71) at org.jboss.dependency.plugins.AbstractControllerContextActions.install(AbstractControllerContextActions.java:51) at org.jboss.dependency.plugins.AbstractControllerContext.install(AbstractControllerContext.java:348) at org.jboss.system.microcontainer.ServiceControllerContext.install(ServiceControllerContext.java:286) at org.jboss.dependency.plugins.AbstractController.install(AbstractController.java:1631) at org.jboss.dependency.plugins.AbstractController.incrementState(AbstractController.java:934) at org.jboss.dependency.plugins.AbstractController.resolveContexts(AbstractController.java:1082) at org.jboss.dependency.plugins.AbstractController.resolveContexts(AbstractController.java:984) at org.jboss.dependency.plugins.AbstractController.change(AbstractController.java:822) at org.jboss.dependency.plugins.AbstractController.change(AbstractController.java:553) at org.jboss.system.ServiceController.doChange(ServiceController.java:688) at org.jboss.system.ServiceController.start(ServiceController.java:460) at org.jboss.system.deployers.ServiceDeployer.start(ServiceDeployer.java:163) at org.jboss.system.deployers.ServiceDeployer.deploy(ServiceDeployer.java:99) at org.jboss.system.deployers.ServiceDeployer.deploy(ServiceDeployer.java:46) at org.jboss.deployers.spi.deployer.helpers.AbstractSimpleRealDeployer.internalDeploy(AbstractSimpleRealDeployer.java:62) at org.jboss.deployers.spi.deployer.helpers.AbstractRealDeployer.deploy(AbstractRealDeployer.java:50) at org.jboss.deployers.plugins.deployers.DeployerWrapper.deploy(DeployerWrapper.java:171) at org.jboss.deployers.plugins.deployers.DeployersImpl.doDeploy(DeployersImpl.java:1439) at org.jboss.deployers.plugins.deployers.DeployersImpl.doInstallParentFirst(DeployersImpl.java:1157) at org.jboss.deployers.plugins.deployers.DeployersImpl.doInstallParentFirst(DeployersImpl.java:1178) at org.jboss.deployers.plugins.deployers.DeployersImpl.install(DeployersImpl.java:1098) at org.jboss.dependency.plugins.AbstractControllerContext.install(AbstractControllerContext.java:348) at org.jboss.dependency.plugins.AbstractController.install(AbstractController.java:1631) at org.jboss.dependency.plugins.AbstractController.incrementState(AbstractController.java:934) at org.jboss.dependency.plugins.AbstractController.resolveContexts(AbstractController.java:1082) at org.jboss.dependency.plugins.AbstractController.resolveContexts(AbstractController.java:984) at org.jboss.dependency.plugins.AbstractController.change(AbstractController.java:822) at org.jboss.dependency.plugins.AbstractController.change(AbstractController.java:553) at org.jboss.deployers.plugins.deployers.DeployersImpl.process(DeployersImpl.java:781) at org.jboss.deployers.plugins.main.MainDeployerImpl.process(MainDeployerImpl.java:702) at org.jboss.system.server.profileservice.repository.MainDeployerAdapter.process(MainDeployerAdapter.java:117) at org.jboss.system.server.profileservice.repository.ProfileDeployAction.install(ProfileDeployAction.java:70) at org.jboss.system.server.profileservice.repository.AbstractProfileAction.install(AbstractProfileAction.java:53) at org.jboss.system.server.profileservice.repository.AbstractProfileService.install(AbstractProfileService.java:361) at org.jboss.dependency.plugins.AbstractControllerContext.install(AbstractControllerContext.java:348) at org.jboss.dependency.plugins.AbstractController.install(AbstractController.java:1631) at org.jboss.dependency.plugins.AbstractController.incrementState(AbstractController.java:934) at org.jboss.dependency.plugins.AbstractController.resolveContexts(AbstractController.java:1082) at org.jboss.dependency.plugins.AbstractController.resolveContexts(AbstractController.java:984) at org.jboss.dependency.plugins.AbstractController.change(AbstractController.java:822) at org.jboss.dependency.plugins.AbstractController.change(AbstractController.java:553) at org.jboss.system.server.profileservice.repository.AbstractProfileService.activateProfile(AbstractProfileService.java:306) at org.jboss.system.server.profileservice.ProfileServiceBootstrap.start(ProfileServiceBootstrap.java:271) at org.jboss.bootstrap.AbstractServerImpl.start(AbstractServerImpl.java:461) at org.jboss.Main.boot(Main.java:221) at org.jboss.Main$1.run(Main.java:556) at java.lang.Thread.run(Thread.java:679) Caused by: javax.naming.ConfigurationException [Root exception is java.rmi.UnknownHostException: Unknown host: 0.0.0.0; nested exception is: java.net.UnknownHostException: B1H68R1.egi.ericsson.com: B1H68R1.egi.ericsson.com] at com.sun.jndi.rmi.registry.RegistryContext.bind(RegistryContext.java:143) at com.sun.jndi.toolkit.url.GenericURLContext.bind(GenericURLContext.java:226) at javax.naming.InitialContext.bind(InitialContext.java:417) at javax.management.remote.rmi.RMIConnectorServer.bind(RMIConnectorServer.java:639) at javax.management.remote.rmi.RMIConnectorServer.start(RMIConnectorServer.java:426) ... 63 more Caused by: java.rmi.UnknownHostException: Unknown host: 0.0.0.0; nested exception is: java.net.UnknownHostException: B1H68R1.egi.ericsson.com: B1H68R1.egi.ericsson.com at sun.rmi.transport.tcp.TCPEndpoint.newSocket(TCPEndpoint.java:616) at sun.rmi.transport.tcp.TCPChannel.createConnection(TCPChannel.java:216) at sun.rmi.transport.tcp.TCPChannel.newConnection(TCPChannel.java:202) at sun.rmi.server.UnicastRef.newCall(UnicastRef.java:340) at sun.rmi.registry.RegistryImpl_Stub.bind(Unknown Source) at com.sun.jndi.rmi.registry.RegistryContext.bind(RegistryContext.java:137) ... 67 more Caused by: java.net.UnknownHostException: B1H68R1.egi.ericsson.com: B1H68R1.egi.ericsson.com at java.net.InetAddress.getLocalHost(InetAddress.java:1454) at java.net.AbstractPlainSocketImpl.connectToAddress(AbstractPlainSocketImpl.java:191) at java.net.AbstractPlainSocketImpl.connect(AbstractPlainSocketImpl.java:180) at java.net.SocksSocketImpl.connect(SocksSocketImpl.java:385) at java.net.Socket.connect(Socket.java:546) at java.net.Socket.connect(Socket.java:495) at java.net.Socket.(Socket.java:392) at java.net.Socket.(Socket.java:206) at sun.rmi.transport.proxy.RMIDirectSocketFactory.createSocket(RMIDirectSocketFactory.java:40) at sun.rmi.transport.proxy.RMIMasterSocketFactory.createSocket(RMIMasterSocketFactory.java:146) at sun.rmi.transport.tcp.TCPEndpoint.newSocket(TCPEndpoint.java:613) ... 72 more 2013-11-09 17:00:20,802 ERROR [org.jboss.kernel.plugins.dependency.AbstractKernelController] Error installing to Real: name=vfsfile:/home/epankmi/Desktop/nuxeo-dm-5.4.0_01-jboss/nuxeo-dm-5.4.0.1-jboss/server/default/deploy/jmx-remoting.sar/ state=PreReal mode=Manual requiredState=Real org.jboss.deployers.spi.DeploymentException: Error deploying: jboss.remoting:service=JMXConnectorServer,protocol=rmi at org.jboss.deployers.spi.DeploymentException.rethrowAsDeploymentException(DeploymentException.java:49) at org.jboss.system.deployers.ServiceDeployer.deploy(ServiceDeployer.java:118) at org.jboss.system.deployers.ServiceDeployer.deploy(ServiceDeployer.java:46) at org.jboss.deployers.spi.deployer.helpers.AbstractSimpleRealDeployer.internalDeploy(AbstractSimpleRealDeployer.java:62) at org.jboss.deployers.spi.deployer.helpers.AbstractRealDeployer.deploy(AbstractRealDeployer.java:50) at org.jboss.deployers.plugins.deployers.DeployerWrapper.deploy(DeployerWrapper.java:171) at org.jboss.deployers.plugins.deployers.DeployersImpl.doDeploy(DeployersImpl.java:1439) at org.jboss.deployers.plugins.deployers.DeployersImpl.doInstallParentFirst(DeployersImpl.java:1157) at org.jboss.deployers.plugins.deployers.DeployersImpl.doInstallParentFirst(DeployersImpl.java:1178) at org.jboss.deployers.plugins.deployers.DeployersImpl.install(DeployersImpl.java:1098) at org.jboss.dependency.plugins.AbstractControllerContext.install(AbstractControllerContext.java:348) at org.jboss.dependency.plugins.AbstractController.install(AbstractController.java:1631) at org.jboss.dependency.plugins.AbstractController.incrementState(AbstractController.java:934) at org.jboss.dependency.plugins.AbstractController.resolveContexts(AbstractController.java:1082) at org.jboss.dependency.plugins.AbstractController.resolveContexts(AbstractController.java:984) at org.jboss.dependency.plugins.AbstractController.change(AbstractController.java:822) at org.jboss.dependency.plugins.AbstractController.change(AbstractController.java:553) at org.jboss.deployers.plugins.deployers.DeployersImpl.process(DeployersImpl.java:781) at org.jboss.deployers.plugins.main.MainDeployerImpl.process(MainDeployerImpl.java:702) at org.jboss.system.server.profileservice.repository.MainDeployerAdapter.process(MainDeployerAdapter.java:117) at org.jboss.system.server.profileservice.repository.ProfileDeployAction.install(ProfileDeployAction.java:70) at org.jboss.system.server.profileservice.repository.AbstractProfileAction.install(AbstractProfileAction.java:53) at org.jboss.system.server.profileservice.repository.AbstractProfileService.install(AbstractProfileService.java:361) at org.jboss.dependency.plugins.AbstractControllerContext.install(AbstractControllerContext.java:348) at org.jboss.dependency.plugins.AbstractController.install(AbstractController.java:1631) at org.jboss.dependency.plugins.AbstractController.incrementState(AbstractController.java:934) at org.jboss.dependency.plugins.AbstractController.resolveContexts(AbstractController.java:1082) at org.jboss.dependency.plugins.AbstractController.resolveContexts(AbstractController.java:984) at org.jboss.dependency.plugins.AbstractController.change(AbstractController.java:822) at org.jboss.dependency.plugins.AbstractController.change(AbstractController.java:553) at org.jboss.system.server.profileservice.repository.AbstractProfileService.activateProfile(AbstractProfileService.java:306) at org.jboss.system.server.profileservice.ProfileServiceBootstrap.start(ProfileServiceBootstrap.java:271) at org.jboss.bootstrap.AbstractServerImpl.start(AbstractServerImpl.java:461) at org.jboss.Main.boot(Main.java:221) at org.jboss.Main$1.run(Main.java:556) at java.lang.Thread.run(Thread.java:679) Caused by: java.io.IOException: Cannot bind to URL [rmi://0.0.0.0:1090/jmxconnector]: javax.naming.ConfigurationException [Root exception is java.rmi.UnknownHostException: Unknown host: 0.0.0.0; nested exception is: java.net.UnknownHostException: B1H68R1.egi.ericsson.com: B1H68R1.egi.ericsson.com] at javax.management.remote.rmi.RMIConnectorServer.newIOException(RMIConnectorServer.java:818) at javax.management.remote.rmi.RMIConnectorServer.start(RMIConnectorServer.java:431) at org.jboss.mx.remoting.service.JMXConnectorServerService.start(JMXConnectorServerService.java:131) at sun.reflect.NativeMethodAccessorImpl.invoke0(Native Method) at sun.reflect.NativeMethodAccessorImpl.invoke(NativeMethodAccessorImpl.java:57) at sun.reflect.DelegatingMethodAccessorImpl.invoke(DelegatingMethodAccessorImpl.java:43) at java.lang.reflect.Method.invoke(Method.java:616) at org.jboss.mx.interceptor.ReflectedDispatcher.invoke(ReflectedDispatcher.java:157) at org.jboss.mx.server.Invocation.dispatch(Invocation.java:96) at org.jboss.mx.server.Invocation.invoke(Invocation.java:88) at org.jboss.mx.server.AbstractMBeanInvoker.invoke(AbstractMBeanInvoker.java:264) at org.jboss.mx.server.MBeanServerImpl.invoke(MBeanServerImpl.java:668) at org.jboss.system.microcontainer.ServiceProxy.invoke(ServiceProxy.java:206) at sun.proxy.$Proxy38.start(Unknown Source) at org.jboss.system.microcontainer.StartStopLifecycleAction.installAction(StartStopLifecycleAction.java:42) at org.jboss.system.microcontainer.StartStopLifecycleAction.installAction(StartStopLifecycleAction.java:37) at org.jboss.dependency.plugins.action.SimpleControllerContextAction.simpleInstallAction(SimpleControllerContextAction.java:62) at org.jboss.dependency.plugins.action.AccessControllerContextAction.install(AccessControllerContextAction.java:71) at org.jboss.dependency.plugins.AbstractControllerContextActions.install(AbstractControllerContextActions.java:51) at org.jboss.dependency.plugins.AbstractControllerContext.install(AbstractControllerContext.java:348) at org.jboss.system.microcontainer.ServiceControllerContext.install(ServiceControllerContext.java:286) at org.jboss.dependency.plugins.AbstractController.install(AbstractController.java:1631) at org.jboss.dependency.plugins.AbstractController.incrementState(AbstractController.java:934) at org.jboss.dependency.plugins.AbstractController.resolveContexts(AbstractController.java:1082) at org.jboss.dependency.plugins.AbstractController.resolveContexts(AbstractController.java:984) at org.jboss.dependency.plugins.AbstractController.change(AbstractController.java:822) at org.jboss.dependency.plugins.AbstractController.change(AbstractController.java:553) at org.jboss.system.ServiceController.doChange(ServiceController.java:688) at org.jboss.system.ServiceController.start(ServiceController.java:460) at org.jboss.system.deployers.ServiceDeployer.start(ServiceDeployer.java:163) at org.jboss.system.deployers.ServiceDeployer.deploy(ServiceDeployer.java:99) ... 34 more Caused by: javax.naming.ConfigurationException [Root exception is java.rmi.UnknownHostException: Unknown host: 0.0.0.0; nested exception is: java.net.UnknownHostException: B1H68R1.egi.ericsson.com: B1H68R1.egi.ericsson.com] at com.sun.jndi.rmi.registry.RegistryContext.bind(RegistryContext.java:143) at com.sun.jndi.toolkit.url.GenericURLContext.bind(GenericURLContext.java:226) at javax.naming.InitialContext.bind(InitialContext.java:417) at javax.management.remote.rmi.RMIConnectorServer.bind(RMIConnectorServer.java:639) at javax.management.remote.rmi.RMIConnectorServer.start(RMIConnectorServer.java:426) ... 63 more Caused by: java.rmi.UnknownHostException: Unknown host: 0.0.0.0; nested exception is: java.net.UnknownHostException: B1H68R1.egi.ericsson.com: B1H68R1.egi.ericsson.com at sun.rmi.transport.tcp.TCPEndpoint.newSocket(TCPEndpoint.java:616) at sun.rmi.transport.tcp.TCPChannel.createConnection(TCPChannel.java:216) at sun.rmi.transport.tcp.TCPChannel.newConnection(TCPChannel.java:202) at sun.rmi.server.UnicastRef.newCall(UnicastRef.java:340) at sun.rmi.registry.RegistryImpl_Stub.bind(Unknown Source) at com.sun.jndi.rmi.registry.RegistryContext.bind(RegistryContext.java:137) ... 67 more Caused by: java.net.UnknownHostException: B1H68R1.egi.ericsson.com: B1H68R1.egi.ericsson.com at java.net.InetAddress.getLocalHost(InetAddress.java:1454) at java.net.AbstractPlainSocketImpl.connectToAddress(AbstractPlainSocketImpl.java:191) at java.net.AbstractPlainSocketImpl.connect(AbstractPlainSocketImpl.java:180) at java.net.SocksSocketImpl.connect(SocksSocketImpl.java:385) at java.net.Socket.connect(Socket.java:546) at java.net.Socket.connect(Socket.java:495) at java.net.Socket.(Socket.java:392) at java.net.Socket.(Socket.java:206) at sun.rmi.transport.proxy.RMIDirectSocketFactory.createSocket(RMIDirectSocketFactory.java:40) at sun.rmi.transport.proxy.RMIMasterSocketFactory.createSocket(RMIMasterSocketFactory.java:146) at sun.rmi.transport.tcp.TCPEndpoint.newSocket(TCPEndpoint.java:613) ... 72 more 2013-11-09 17:00:23,194 ERROR [org.jboss.kernel.plugins.dependency.AbstractKernelController] Error installing to Create: name=jboss.messaging:service=Connector,transport=bisocket state=Configured mode=Manual requiredState=Create java.lang.RuntimeException: Error setting up server invoker SocketServerInvoker[0.0.0.0:4457] at org.jboss.remoting.ServerInvoker.create(ServerInvoker.java:936) at org.jboss.remoting.transport.Connector.init(Connector.java:436) at org.jboss.remoting.transport.Connector.create(Connector.java:1143) at sun.reflect.NativeMethodAccessorImpl.invoke0(Native Method) at sun.reflect.NativeMethodAccessorImpl.invoke(NativeMethodAccessorImpl.java:57) at sun.reflect.DelegatingMethodAccessorImpl.invoke(DelegatingMethodAccessorImpl.java:43) at java.lang.reflect.Method.invoke(Method.java:616) at org.jboss.mx.interceptor.ReflectedDispatcher.invoke(ReflectedDispatcher.java:157) at org.jboss.mx.server.Invocation.dispatch(Invocation.java:96) at org.jboss.mx.server.Invocation.invoke(Invocation.java:88) at org.jboss.mx.server.AbstractMBeanInvoker.invoke(AbstractMBeanInvoker.java:264) at org.jboss.mx.server.MBeanServerImpl.invoke(MBeanServerImpl.java:668) at org.jboss.system.microcontainer.ServiceProxy.invoke(ServiceProxy.java:206) at sun.proxy.$Proxy38.create(Unknown Source) at org.jboss.system.microcontainer.CreateDestroyLifecycleAction.installAction(CreateDestroyLifecycleAction.java:42) at org.jboss.system.microcontainer.CreateDestroyLifecycleAction.installAction(CreateDestroyLifecycleAction.java:37) at org.jboss.dependency.plugins.action.SimpleControllerContextAction.simpleInstallAction(SimpleControllerContextAction.java:62) at org.jboss.dependency.plugins.action.AccessControllerContextAction.install(AccessControllerContextAction.java:71) at org.jboss.dependency.plugins.AbstractControllerContextActions.install(AbstractControllerContextActions.java:51) at org.jboss.dependency.plugins.AbstractControllerContext.install(AbstractControllerContext.java:348) at org.jboss.system.microcontainer.ServiceControllerContext.install(ServiceControllerContext.java:286) at org.jboss.dependency.plugins.AbstractController.install(AbstractController.java:1631) at org.jboss.dependency.plugins.AbstractController.incrementState(AbstractController.java:934) at org.jboss.dependency.plugins.AbstractController.resolveContexts(AbstractController.java:1082) at org.jboss.dependency.plugins.AbstractController.resolveContexts(AbstractController.java:984) at org.jboss.dependency.plugins.AbstractController.change(AbstractController.java:822) at org.jboss.dependency.plugins.AbstractController.change(AbstractController.java:553) at org.jboss.system.ServiceController.doChange(ServiceController.java:688) at org.jboss.system.ServiceController.create(ServiceController.java:422) at org.jboss.system.ServiceController.create(ServiceController.java:387) at org.jboss.system.deployers.ServiceDeployer.create(ServiceDeployer.java:158) at org.jboss.system.deployers.ServiceDeployer.deploy(ServiceDeployer.java:96) at org.jboss.system.deployers.ServiceDeployer.deploy(ServiceDeployer.java:46) at org.jboss.deployers.spi.deployer.helpers.AbstractSimpleRealDeployer.internalDeploy(AbstractSimpleRealDeployer.java:62) at org.jboss.deployers.spi.deployer.helpers.AbstractRealDeployer.deploy(AbstractRealDeployer.java:50) at org.jboss.deployers.plugins.deployers.DeployerWrapper.deploy(DeployerWrapper.java:171) at org.jboss.deployers.plugins.deployers.DeployersImpl.doDeploy(DeployersImpl.java:1439) at org.jboss.deployers.plugins.deployers.DeployersImpl.doInstallParentFirst(DeployersImpl.java:1157) at org.jboss.deployers.plugins.deployers.DeployersImpl.doInstallParentFirst(DeployersImpl.java:1178) at org.jboss.deployers.plugins.deployers.DeployersImpl.install(DeployersImpl.java:1098) at org.jboss.dependency.plugins.AbstractControllerContext.install(AbstractControllerContext.java:348) at org.jboss.dependency.plugins.AbstractController.install(AbstractController.java:1631) at org.jboss.dependency.plugins.AbstractController.incrementState(AbstractController.java:934) at org.jboss.dependency.plugins.AbstractController.resolveContexts(AbstractController.java:1082) at org.jboss.dependency.plugins.AbstractController.resolveContexts(AbstractController.java:984) at org.jboss.dependency.plugins.AbstractController.change(AbstractController.java:822) at org.jboss.dependency.plugins.AbstractController.change(AbstractController.java:553) at org.jboss.deployers.plugins.deployers.DeployersImpl.process(DeployersImpl.java:781) at org.jboss.deployers.plugins.main.MainDeployerImpl.process(MainDeployerImpl.java:702) at org.jboss.system.server.profileservice.repository.MainDeployerAdapter.process(MainDeployerAdapter.java:117) at org.jboss.system.server.profileservice.repository.ProfileDeployAction.install(ProfileDeployAction.java:70) at org.jboss.system.server.profileservice.repository.AbstractProfileAction.install(AbstractProfileAction.java:53) at org.jboss.system.server.profileservice.repository.AbstractProfileService.install(AbstractProfileService.java:361) at org.jboss.dependency.plugins.AbstractControllerContext.install(AbstractControllerContext.java:348) at org.jboss.dependency.plugins.AbstractController.install(AbstractController.java:1631) at org.jboss.dependency.plugins.AbstractController.incrementState(AbstractController.java:934) at org.jboss.dependency.plugins.AbstractController.resolveContexts(AbstractController.java:1082) at org.jboss.dependency.plugins.AbstractController.resolveContexts(AbstractController.java:984) at org.jboss.dependency.plugins.AbstractController.change(AbstractController.java:822) at org.jboss.dependency.plugins.AbstractController.change(AbstractController.java:553) at org.jboss.system.server.profileservice.repository.AbstractProfileService.activateProfile(AbstractProfileService.java:306) at org.jboss.system.server.profileservice.ProfileServiceBootstrap.start(ProfileServiceBootstrap.java:271) at org.jboss.bootstrap.AbstractServerImpl.start(AbstractServerImpl.java:461) at org.jboss.Main.boot(Main.java:221) at org.jboss.Main$1.run(Main.java:556) at java.lang.Thread.run(Thread.java:679) Caused by: java.lang.RuntimeException: Can not determine bindable address for locator (InvokerLocator [bisocket://0.0.0.0:4457/?JBM_clientMaxPoolSize=200&clientLeasePeriod=10000&clientSocketClass=org.jboss.jms.client.remoting.ClientSocketWrapper&connectionWait=10&dataType=jms&marshaller=org.jboss.jms.wireformat.JMSWireFormat&numberOfCallRetries=1&pingFrequency=214748364&pingWindowFactor=10&socket.check_connection=false&stopLeaseOnFailure=true&timeout=0&unmarshaller=org.jboss.jms.wireformat.JMSWireFormat&validatorPingPeriod=10000&validatorPingTimeout=5000]) at org.jboss.remoting.InvokerLocator.validateLocator(InvokerLocator.java:270) at org.jboss.remoting.ServerInvoker.setup(ServerInvoker.java:1148) at org.jboss.remoting.transport.socket.SocketServerInvoker.setup(SocketServerInvoker.java:212) at org.jboss.remoting.transport.bisocket.BisocketServerInvoker.setup(BisocketServerInvoker.java:651) at org.jboss.remoting.ServerInvoker.create(ServerInvoker.java:932) ... 65 more 2013-11-09 17:00:23,202 ERROR [org.jboss.kernel.plugins.dependency.AbstractKernelController] Error installing to Real: name=vfsfile:/home/epankmi/Desktop/nuxeo-dm-5.4.0_01-jboss/nuxeo-dm-5.4.0.1-jboss/server/default/deploy/messaging/remoting-bisocket-service.xml state=PreReal mode=Manual requiredState=Real org.jboss.deployers.spi.DeploymentException: Error deploying: jboss.messaging:service=Connector,transport=bisocket at org.jboss.deployers.spi.DeploymentException.rethrowAsDeploymentException(DeploymentException.java:49) at org.jboss.system.deployers.ServiceDeployer.deploy(ServiceDeployer.java:118) at org.jboss.system.deployers.ServiceDeployer.deploy(ServiceDeployer.java:46) at org.jboss.deployers.spi.deployer.helpers.AbstractSimpleRealDeployer.internalDeploy(AbstractSimpleRealDeployer.java:62) at org.jboss.deployers.spi.deployer.helpers.AbstractRealDeployer.deploy(AbstractRealDeployer.java:50) at org.jboss.deployers.plugins.deployers.DeployerWrapper.deploy(DeployerWrapper.java:171) at org.jboss.deployers.plugins.deployers.DeployersImpl.doDeploy(DeployersImpl.java:1439) at org.jboss.deployers.plugins.deployers.DeployersImpl.doInstallParentFirst(DeployersImpl.java:1157) at org.jboss.deployers.plugins.deployers.DeployersImpl.doInstallParentFirst(DeployersImpl.java:1178) at org.jboss.deployers.plugins.deployers.DeployersImpl.install(DeployersImpl.java:1098) at org.jboss.dependency.plugins.AbstractControllerContext.install(AbstractControllerContext.java:348) at org.jboss.dependency.plugins.AbstractController.install(AbstractController.java:1631) at org.jboss.dependency.plugins.AbstractController.incrementState(AbstractController.java:934) at org.jboss.dependency.plugins.AbstractController.resolveContexts(AbstractController.java:1082) at org.jboss.dependency.plugins.AbstractController.resolveContexts(AbstractController.java:984) at org.jboss.dependency.plugins.AbstractController.change(AbstractController.java:822) at org.jboss.dependency.plugins.AbstractController.change(AbstractController.java:553) at org.jboss.deployers.plugins.deployers.DeployersImpl.process(DeployersImpl.java:781) at org.jboss.deployers.plugins.main.MainDeployerImpl.process(MainDeployerImpl.java:702) at org.jboss.system.server.profileservice.repository.MainDeployerAdapter.process(MainDeployerAdapter.java:117) at org.jboss.system.server.profileservice.repository.ProfileDeployAction.install(ProfileDeployAction.java:70) at org.jboss.system.server.profileservice.repository.AbstractProfileAction.install(AbstractProfileAction.java:53) at org.jboss.system.server.profileservice.repository.AbstractProfileService.install(AbstractProfileService.java:361) at org.jboss.dependency.plugins.AbstractControllerContext.install(AbstractControllerContext.java:348) at org.jboss.dependency.plugins.AbstractController.install(AbstractController.java:1631) at org.jboss.dependency.plugins.AbstractController.incrementState(AbstractController.java:934) at org.jboss.dependency.plugins.AbstractController.resolveContexts(AbstractController.java:1082) at org.jboss.dependency.plugins.AbstractController.resolveContexts(AbstractController.java:984) at org.jboss.dependency.plugins.AbstractController.change(AbstractController.java:822) at org.jboss.dependency.plugins.AbstractController.change(AbstractController.java:553) at org.jboss.system.server.profileservice.repository.AbstractProfileService.activateProfile(AbstractProfileService.java:306) at org.jboss.system.server.profileservice.ProfileServiceBootstrap.start(ProfileServiceBootstrap.java:271) at org.jboss.bootstrap.AbstractServerImpl.start(AbstractServerImpl.java:461) at org.jboss.Main.boot(Main.java:221) at org.jboss.Main$1.run(Main.java:556) at java.lang.Thread.run(Thread.java:679) Caused by: java.lang.RuntimeException: Error setting up server invoker SocketServerInvoker[0.0.0.0:4457] at org.jboss.remoting.ServerInvoker.create(ServerInvoker.java:936) at org.jboss.remoting.transport.Connector.init(Connector.java:436) at org.jboss.remoting.transport.Connector.create(Connector.java:1143) at sun.reflect.NativeMethodAccessorImpl.invoke0(Native Method) at sun.reflect.NativeMethodAccessorImpl.invoke(NativeMethodAccessorImpl.java:57) at sun.reflect.DelegatingMethodAccessorImpl.invoke(DelegatingMethodAccessorImpl.java:43) at java.lang.reflect.Method.invoke(Method.java:616) at org.jboss.mx.interceptor.ReflectedDispatcher.invoke(ReflectedDispatcher.java:157) at org.jboss.mx.server.Invocation.dispatch(Invocation.java:96) at org.jboss.mx.server.Invocation.invoke(Invocation.java:88) at org.jboss.mx.server.AbstractMBeanInvoker.invoke(AbstractMBeanInvoker.java:264) at org.jboss.mx.server.MBeanServerImpl.invoke(MBeanServerImpl.java:668) at org.jboss.system.microcontainer.ServiceProxy.invoke(ServiceProxy.java:206) at sun.proxy.$Proxy38.create(Unknown Source) at org.jboss.system.microcontainer.CreateDestroyLifecycleAction.installAction(CreateDestroyLifecycleAction.java:42) at org.jboss.system.microcontainer.CreateDestroyLifecycleAction.installAction(CreateDestroyLifecycleAction.java:37) at org.jboss.dependency.plugins.action.SimpleControllerContextAction.simpleInstallAction(SimpleControllerContextAction.java:62) at org.jboss.dependency.plugins.action.AccessControllerContextAction.install(AccessControllerContextAction.java:71) at org.jboss.dependency.plugins.AbstractControllerContextActions.install(AbstractControllerContextActions.java:51) at org.jboss.dependency.plugins.AbstractControllerContext.install(AbstractControllerContext.java:348) at org.jboss.system.microcontainer.ServiceControllerContext.install(ServiceControllerContext.java:286) at org.jboss.dependency.plugins.AbstractController.install(AbstractController.java:1631) at org.jboss.dependency.plugins.AbstractController.incrementState(AbstractController.java:934) at org.jboss.dependency.plugins.AbstractController.resolveContexts(AbstractController.java:1082) at org.jboss.dependency.plugins.AbstractController.resolveContexts(AbstractController.java:984) at org.jboss.dependency.plugins.AbstractController.change(AbstractController.java:822) at org.jboss.dependency.plugins.AbstractController.change(AbstractController.java:553) at org.jboss.system.ServiceController.doChange(ServiceController.java:688) at org.jboss.system.ServiceController.create(ServiceController.java:422) at org.jboss.system.ServiceController.create(ServiceController.java:387) at org.jboss.system.deployers.ServiceDeployer.create(ServiceDeployer.java:158) at org.jboss.system.deployers.ServiceDeployer.deploy(ServiceDeployer.java:96) ... 34 more Caused by: java.lang.RuntimeException: Can not determine bindable address for locator (InvokerLocator [bisocket://0.0.0.0:4457/?JBM_clientMaxPoolSize=200&clientLeasePeriod=10000&clientSocketClass=org.jboss.jms.client.remoting.ClientSocketWrapper&connectionWait=10&dataType=jms&marshaller=org.jboss.jms.wireformat.JMSWireFormat&numberOfCallRetries=1&pingFrequency=214748364&pingWindowFactor=10&socket.check_connection=false&stopLeaseOnFailure=true&timeout=0&unmarshaller=org.jboss.jms.wireformat.JMSWireFormat&validatorPingPeriod=10000&validatorPingTimeout=5000]) at org.jboss.remoting.InvokerLocator.validateLocator(InvokerLocator.java:270) at org.jboss.remoting.ServerInvoker.setup(ServerInvoker.java:1148) at org.jboss.remoting.transport.socket.SocketServerInvoker.setup(SocketServerInvoker.java:212) at org.jboss.remoting.transport.bisocket.BisocketServerInvoker.setup(BisocketServerInvoker.java:651) at org.jboss.remoting.ServerInvoker.create(ServerInvoker.java:932) ... 65 more 2013-11-09 17:00:24,292 ERROR [org.jboss.kernel.plugins.dependency.AbstractKernelController] Error installing to Create: name=org.jboss.ejb3.RemotingConnector state=Configured java.lang.RuntimeException: Error setting up server invoker SocketServerInvoker[0.0.0.0:3873] at org.jboss.remoting.ServerInvoker.create(ServerInvoker.java:936) at org.jboss.remoting.transport.Connector.init(Connector.java:436) at org.jboss.remoting.transport.Connector.create(Connector.java:1143) at sun.reflect.NativeMethodAccessorImpl.invoke0(Native Method) at sun.reflect.NativeMethodAccessorImpl.invoke(NativeMethodAccessorImpl.java:57) at sun.reflect.DelegatingMethodAccessorImpl.invoke(DelegatingMethodAccessorImpl.java:43) at java.lang.reflect.Method.invoke(Method.java:616) at org.jboss.reflect.plugins.introspection.ReflectionUtils.invoke(ReflectionUtils.java:59) at org.jboss.reflect.plugins.introspection.ReflectMethodInfoImpl.invoke(ReflectMethodInfoImpl.java:150) at org.jboss.joinpoint.plugins.BasicMethodJoinPoint.dispatch(BasicMethodJoinPoint.java:66) at org.jboss.kernel.plugins.dependency.KernelControllerContextAction$JoinpointDispatchWrapper.execute(KernelControllerContextAction.java:241) at org.jboss.kernel.plugins.dependency.ExecutionWrapper.execute(ExecutionWrapper.java:47) at org.jboss.kernel.plugins.dependency.KernelControllerContextAction.dispatchExecutionWrapper(KernelControllerContextAction.java:109) at org.jboss.kernel.plugins.dependency.KernelControllerContextAction.dispatchJoinPoint(KernelControllerContextAction.java:70) at org.jboss.kernel.plugins.dependency.LifecycleAction.installActionInternal(LifecycleAction.java:221) at org.jboss.kernel.plugins.dependency.InstallsAwareAction.installAction(InstallsAwareAction.java:54) at org.jboss.kernel.plugins.dependency.InstallsAwareAction.installAction(InstallsAwareAction.java:42) at org.jboss.dependency.plugins.action.SimpleControllerContextAction.simpleInstallAction(SimpleControllerContextAction.java:62) at org.jboss.dependency.plugins.action.AccessControllerContextAction.install(AccessControllerContextAction.java:71) at org.jboss.dependency.plugins.AbstractControllerContextActions.install(AbstractControllerContextActions.java:51) at org.jboss.dependency.plugins.AbstractControllerContext.install(AbstractControllerContext.java:348) at org.jboss.dependency.plugins.AbstractController.install(AbstractController.java:1631) at org.jboss.dependency.plugins.AbstractController.incrementState(AbstractController.java:934) at org.jboss.dependency.plugins.AbstractController.resolveContexts(AbstractController.java:1082) at org.jboss.dependency.plugins.AbstractController.resolveContexts(AbstractController.java:984) at org.jboss.dependency.plugins.AbstractController.install(AbstractController.java:774) at org.jboss.dependency.plugins.AbstractController.install(AbstractController.java:540) at org.jboss.deployers.vfs.deployer.kernel.BeanMetaDataDeployer.deploy(BeanMetaDataDeployer.java:121) at org.jboss.deployers.vfs.deployer.kernel.BeanMetaDataDeployer.deploy(BeanMetaDataDeployer.java:51) at org.jboss.deployers.spi.deployer.helpers.AbstractSimpleRealDeployer.internalDeploy(AbstractSimpleRealDeployer.java:62) at org.jboss.deployers.spi.deployer.helpers.AbstractRealDeployer.deploy(AbstractRealDeployer.java:50) at org.jboss.deployers.plugins.deployers.DeployerWrapper.deploy(DeployerWrapper.java:171) at org.jboss.deployers.plugins.deployers.DeployersImpl.doDeploy(DeployersImpl.java:1439) at org.jboss.deployers.plugins.deployers.DeployersImpl.doInstallParentFirst(DeployersImpl.java:1157) at org.jboss.deployers.plugins.deployers.DeployersImpl.doInstallParentFirst(DeployersImpl.java:1178) at org.jboss.deployers.plugins.deployers.DeployersImpl.install(DeployersImpl.java:1098) at org.jboss.dependency.plugins.AbstractControllerContext.install(AbstractControllerContext.java:348) at org.jboss.dependency.plugins.AbstractController.install(AbstractController.java:1631) at org.jboss.dependency.plugins.AbstractController.incrementState(AbstractController.java:934) at org.jboss.dependency.plugins.AbstractController.resolveContexts(AbstractController.java:1082) at org.jboss.dependency.plugins.AbstractController.resolveContexts(AbstractController.java:984) at org.jboss.dependency.plugins.AbstractController.change(AbstractController.java:822) at org.jboss.dependency.plugins.AbstractController.change(AbstractController.java:553) at org.jboss.deployers.plugins.deployers.DeployersImpl.process(DeployersImpl.java:781) at org.jboss.deployers.plugins.main.MainDeployerImpl.process(MainDeployerImpl.java:702) at org.jboss.system.server.profileservice.repository.MainDeployerAdapter.process(MainDeployerAdapter.java:117) at org.jboss.system.server.profileservice.repository.ProfileDeployAction.install(ProfileDeployAction.java:70) at org.jboss.system.server.profileservice.repository.AbstractProfileAction.install(AbstractProfileAction.java:53) at org.jboss.system.server.profileservice.repository.AbstractProfileService.install(AbstractProfileService.java:361) at org.jboss.dependency.plugins.AbstractControllerContext.install(AbstractControllerContext.java:348) at org.jboss.dependency.plugins.AbstractController.install(AbstractController.java:1631) at org.jboss.dependency.plugins.AbstractController.incrementState(AbstractController.java:934) at org.jboss.dependency.plugins.AbstractController.resolveContexts(AbstractController.java:1082) at org.jboss.dependency.plugins.AbstractController.resolveContexts(AbstractController.java:984) at org.jboss.dependency.plugins.AbstractController.change(AbstractController.java:822) at org.jboss.dependency.plugins.AbstractController.change(AbstractController.java:553) at org.jboss.system.server.profileservice.repository.AbstractProfileService.activateProfile(AbstractProfileService.java:306) at org.jboss.system.server.profileservice.ProfileServiceBootstrap.start(ProfileServiceBootstrap.java:271) at org.jboss.bootstrap.AbstractServerImpl.start(AbstractServerImpl.java:461) at org.jboss.Main.boot(Main.java:221) at org.jboss.Main$1.run(Main.java:556) at java.lang.Thread.run(Thread.java:679) Caused by: java.lang.RuntimeException: Can not determine bindable address for locator (InvokerLocator [socket://0.0.0.0:3873/]) at org.jboss.remoting.InvokerLocator.validateLocator(InvokerLocator.java:270) at org.jboss.remoting.ServerInvoker.setup(ServerInvoker.java:1148) at org.jboss.remoting.transport.socket.SocketServerInvoker.setup(SocketServerInvoker.java:212) at org.jboss.remoting.ServerInvoker.create(ServerInvoker.java:932) ... 61 more 2013-11-09 17:00:27,754 ERROR [org.jboss.kernel.plugins.dependency.AbstractKernelController] Error installing to Create: name=UnifiedInvokerConnector state=Configured java.lang.RuntimeException: Error setting up server invoker SocketServerInvoker[0.0.0.0:4446] at org.jboss.remoting.ServerInvoker.create(ServerInvoker.java:936) at org.jboss.remoting.transport.Connector.init(Connector.java:436) at org.jboss.remoting.transport.Connector.create(Connector.java:1143) at sun.reflect.NativeMethodAccessorImpl.invoke0(Native Method) at sun.reflect.NativeMethodAccessorImpl.invoke(NativeMethodAccessorImpl.java:57) at sun.reflect.DelegatingMethodAccessorImpl.invoke(DelegatingMethodAccessorImpl.java:43) at java.lang.reflect.Method.invoke(Method.java:616) at org.jboss.reflect.plugins.introspection.ReflectionUtils.invoke(ReflectionUtils.java:59) at org.jboss.reflect.plugins.introspection.ReflectMethodInfoImpl.invoke(ReflectMethodInfoImpl.java:150) at org.jboss.joinpoint.plugins.BasicMethodJoinPoint.dispatch(BasicMethodJoinPoint.java:66) at org.jboss.kernel.plugins.dependency.KernelControllerContextAction$JoinpointDispatchWrapper.execute(KernelControllerContextAction.java:241) at org.jboss.kernel.plugins.dependency.ExecutionWrapper.execute(ExecutionWrapper.java:47) at org.jboss.kernel.plugins.dependency.KernelControllerContextAction.dispatchExecutionWrapper(KernelControllerContextAction.java:109) at org.jboss.kernel.plugins.dependency.KernelControllerContextAction.dispatchJoinPoint(KernelControllerContextAction.java:70) at org.jboss.kernel.plugins.dependency.LifecycleAction.installActionInternal(LifecycleAction.java:221) at org.jboss.kernel.plugins.dependency.InstallsAwareAction.installAction(InstallsAwareAction.java:54) at org.jboss.kernel.plugins.dependency.InstallsAwareAction.installAction(InstallsAwareAction.java:42) at org.jboss.dependency.plugins.action.SimpleControllerContextAction.simpleInstallAction(SimpleControllerContextAction.java:62) at org.jboss.dependency.plugins.action.AccessControllerContextAction.install(AccessControllerContextAction.java:71) at org.jboss.dependency.plugins.AbstractControllerContextActions.install(AbstractControllerContextActions.java:51) at org.jboss.dependency.plugins.AbstractControllerContext.install(AbstractControllerContext.java:348) at org.jboss.dependency.plugins.AbstractController.install(AbstractController.java:1631) at org.jboss.dependency.plugins.AbstractController.incrementState(AbstractController.java:934) at org.jboss.dependency.plugins.AbstractController.resolveContexts(AbstractController.java:1082) at org.jboss.dependency.plugins.AbstractController.resolveContexts(AbstractController.java:984) at org.jboss.dependency.plugins.AbstractController.install(AbstractController.java:774) at org.jboss.dependency.plugins.AbstractController.install(AbstractController.java:540) at org.jboss.deployers.vfs.deployer.kernel.BeanMetaDataDeployer.deploy(BeanMetaDataDeployer.java:121) at org.jboss.deployers.vfs.deployer.kernel.BeanMetaDataDeployer.deploy(BeanMetaDataDeployer.java:51) at org.jboss.deployers.spi.deployer.helpers.AbstractSimpleRealDeployer.internalDeploy(AbstractSimpleRealDeployer.java:62) at org.jboss.deployers.spi.deployer.helpers.AbstractRealDeployer.deploy(AbstractRealDeployer.java:50) at org.jboss.deployers.plugins.deployers.DeployerWrapper.deploy(DeployerWrapper.java:171) at org.jboss.deployers.plugins.deployers.DeployersImpl.doDeploy(DeployersImpl.java:1439) at org.jboss.deployers.plugins.deployers.DeployersImpl.doInstallParentFirst(DeployersImpl.java:1157) at org.jboss.deployers.plugins.deployers.DeployersImpl.doInstallParentFirst(DeployersImpl.java:1178) at org.jboss.deployers.plugins.deployers.DeployersImpl.install(DeployersImpl.java:1098) at org.jboss.dependency.plugins.AbstractControllerContext.install(AbstractControllerContext.java:348) at org.jboss.dependency.plugins.AbstractController.install(AbstractController.java:1631) at org.jboss.dependency.plugins.AbstractController.incrementState(AbstractController.java:934) at org.jboss.dependency.plugins.AbstractController.resolveContexts(AbstractController.java:1082) at org.jboss.dependency.plugins.AbstractController.resolveContexts(AbstractController.java:984) at org.jboss.dependency.plugins.AbstractController.change(AbstractController.java:822) at org.jboss.dependency.plugins.AbstractController.change(AbstractController.java:553) at org.jboss.deployers.plugins.deployers.DeployersImpl.process(DeployersImpl.java:781) at org.jboss.deployers.plugins.main.MainDeployerImpl.process(MainDeployerImpl.java:702) at org.jboss.system.server.profileservice.repository.MainDeployerAdapter.process(MainDeployerAdapter.java:117) at org.jboss.system.server.profileservice.repository.ProfileDeployAction.install(ProfileDeployAction.java:70) at org.jboss.system.server.profileservice.repository.AbstractProfileAction.install(AbstractProfileAction.java:53) at org.jboss.system.server.profileservice.repository.AbstractProfileService.install(AbstractProfileService.java:361) at org.jboss.dependency.plugins.AbstractControllerContext.install(AbstractControllerContext.java:348) at org.jboss.dependency.plugins.AbstractController.install(AbstractController.java:1631) at org.jboss.dependency.plugins.AbstractController.incrementState(AbstractController.java:934) at org.jboss.dependency.plugins.AbstractController.resolveContexts(AbstractController.java:1082) at org.jboss.dependency.plugins.AbstractController.resolveContexts(AbstractController.java:984) at org.jboss.dependency.plugins.AbstractController.change(AbstractController.java:822) at org.jboss.dependency.plugins.AbstractController.change(AbstractController.java:553) at org.jboss.system.server.profileservice.repository.AbstractProfileService.activateProfile(AbstractProfileService.java:306) at org.jboss.system.server.profileservice.ProfileServiceBootstrap.start(ProfileServiceBootstrap.java:271) at org.jboss.bootstrap.AbstractServerImpl.start(AbstractServerImpl.java:461) at org.jboss.Main.boot(Main.java:221) at org.jboss.Main$1.run(Main.java:556) at java.lang.Thread.run(Thread.java:679) Caused by: java.lang.RuntimeException: Can not determine bindable address for locator (InvokerLocator [socket://0.0.0.0:4446/?dataType=invocation&enableTcpNoDelay=true&marshaller=org.jboss.invocation.unified.marshall.InvocationMarshaller&unmarshaller=org.jboss.invocation.unified.marshall.InvocationUnMarshaller]) at org.jboss.remoting.InvokerLocator.validateLocator(InvokerLocator.java:270) at org.jboss.remoting.ServerInvoker.setup(ServerInvoker.java:1148) at org.jboss.remoting.transport.socket.SocketServerInvoker.setup(SocketServerInvoker.java:212) at org.jboss.remoting.ServerInvoker.create(ServerInvoker.java:932) ... 61 more 2013-11-09 17:00:27,851 WARN [org.jboss.jms.server.jbosssx.JBossASSecurityMetadataStore] WARNING! POTENTIAL SECURITY RISK. It has been detected that the MessageSucker component which sucks messages from one node to another has not had its password changed from the installation default. Please see the JBoss Messaging user guide for instructions on how to do this. 2013-11-09 17:00:27,862 WARN [org.jboss.annotation.factory.AnnotationCreator] No ClassLoader provided, using TCCL: org.jboss.managed.api.annotation.ManagementComponent 2013-11-09 17:00:27,909 WARN [org.jboss.annotation.factory.AnnotationCreator] No ClassLoader provided, using TCCL: org.jboss.managed.api.annotation.ManagementComponent 2013-11-09 17:00:29,074 WARN [com.arjuna.ats.arjuna.logging.arjLoggerI18N] [com.arjuna.ats.arjuna.common.Uid_1] - cannot get local host. 2013-11-09 17:00:30,033 WARN [com.arjuna.ats.arjuna.logging.arjLoggerI18N] [com.arjuna.ats.arjuna.common.Uid_1] - cannot get local host. 2013-11-09 17:00:30,034 WARN [com.arjuna.ats.arjuna.logging.arjLoggerI18N] [com.arjuna.ats.internal.arjuna.recovery.TransactionStatusManagerItem_2] - Problem with storing host/port java.io.IOException: com.arjuna.ats.arjuna.state.OutputBuffer_10 - Invalid input buffer: string. 2013-11-09 17:00:31,022 WARN [com.arjuna.ats.arjuna.logging.arjLoggerI18N] [com.arjuna.ats.arjuna.common.Uid_1] - cannot get local host. 2013-11-09 17:00:31,981 WARN [com.arjuna.ats.arjuna.logging.arjLoggerI18N] [com.arjuna.ats.arjuna.common.Uid_1] - cannot get local host. 2013-11-09 17:00:32,941 WARN [com.arjuna.ats.arjuna.logging.arjLoggerI18N] [com.arjuna.ats.arjuna.common.Uid_1] - cannot get local host. 2013-11-09 17:00:33,874 WARN [com.arjuna.ats.arjuna.logging.arjLoggerI18N] [com.arjuna.ats.arjuna.common.Uid_1] - cannot get local host. 2013-11-09 17:00:33,875 WARN [com.arjuna.ats.arjuna.logging.arjLoggerI18N] [com.arjuna.ats.arjuna.recovery.TransactionStatusConnectionManager_2] - Object store exception com.arjuna.ats.arjuna.exceptions.ObjectStoreException: [com.arjuna.ats.internal.arjuna.objectstore.HashedStore_6] - HashedStore.allObjUids - could not pack end of list Uid. 2013-11-09 17:00:34,851 WARN [com.arjuna.ats.arjuna.logging.arjLoggerI18N] [com.arjuna.ats.arjuna.common.Uid_1] - cannot get local host. 2013-11-09 17:00:36,052 WARN [com.arjuna.ats.arjuna.logging.arjLoggerI18N] [com.arjuna.ats.arjuna.common.Uid_1] - cannot get local host. 2013-11-09 17:00:36,053 WARN [com.arjuna.ats.arjuna.logging.arjLoggerI18N] [com.arjuna.ats.internal.arjuna.recovery.AtomicActionRecoveryModule_1] - RecoveryManagerStatusModule: Object store exception: com.arjuna.ats.arjuna.exceptions.ObjectStoreException: [com.arjuna.ats.internal.arjuna.objectstore.HashedStore_6] - HashedStore.allObjUids - could not pack end of list Uid. 2013-11-09 17:00:36,782 INFO [org.apache.catalina.core.AprLifecycleListener] The Apache Tomcat Native library which allows optimal performance in production environments was not found on the java.library.path: /usr/lib/jvm/java-6-openjdk-amd64/jre/lib/amd64/server:/usr/lib/jvm/java-6-openjdk-amd64/jre/lib/amd64:/usr/lib/jvm/java-6-openjdk-amd64/jre/../lib/amd64:/usr/java/packages/lib/amd64:/usr/lib/x86_64-linux-gnu/jni:/lib/x86_64-linux-gnu:/usr/lib/x86_64-linux-gnu:/usr/lib/jni:/lib:/usr/lib 2013-11-09 17:00:36,822 INFO [org.apache.coyote.http11.Http11Protocol] Initializing Coyote HTTP/1.1 on http-0.0.0.0-8080 2013-11-09 17:00:36,823 INFO [org.apache.coyote.ajp.AjpProtocol] Initializing Coyote AJP/1.3 on ajp-0.0.0.0-8009 2013-11-09 17:00:36,837 INFO [org.apache.catalina.core.StandardService] Starting service jboss.web 2013-11-09 17:00:36,839 INFO [org.apache.catalina.core.StandardEngine] Starting Servlet Engine: JBoss Web/2.1.3.GA 2013-11-09 17:00:36,871 INFO [org.apache.catalina.startup.Catalina] Server startup in 47 ms 2013-11-09 17:00:37,155 WARN [com.arjuna.ats.arjuna.logging.arjLoggerI18N] [com.arjuna.ats.arjuna.common.Uid_1] - cannot get local host. 2013-11-09 17:00:37,529 WARN [com.arjuna.ats.txoj.logging.txojLoggerI18N] [com.arjuna.ats.internal.txoj.recovery.TORecoveryModule_5] - TORecoveryModule: searching for TOs: com.arjuna.ats.arjuna.exceptions.ObjectStoreException: [com.arjuna.ats.internal.arjuna.objectstore.FileSystemStore_5] - FileSystemStore::allTypes - could not pack end of list string. at com.arjuna.ats.internal.arjuna.objectstore.FileSystemStore.allTypes(FileSystemStore.java:380) at com.arjuna.ats.arjuna.objectstore.ObjectStore.allTypes(ObjectStore.java:226) at com.arjuna.ats.internal.txoj.recovery.TORecoveryModule.periodicWorkFirstPass(TORecoveryModule.java:127) at com.arjuna.ats.internal.arjuna.recovery.PeriodicRecovery.doWorkInternal(PeriodicRecovery.java:745) at com.arjuna.ats.internal.arjuna.recovery.PeriodicRecovery.run(PeriodicRecovery.java:412) 2013-11-09 17:00:37,797 INFO [org.quartz.simpl.SimpleThreadPool] Job execution threads will use class loader of thread: main 2013-11-09 17:00:37,814 INFO [org.quartz.core.QuartzScheduler] Quartz Scheduler v.1.5.2 created. 2013-11-09 17:00:37,815 INFO [org.quartz.simpl.RAMJobStore] RAMJobStore initialized. 2013-11-09 17:00:37,816 INFO [org.quartz.impl.StdSchedulerFactory] Quartz scheduler 'DefaultQuartzScheduler' initialized from default resource file in Quartz package: 'quartz.properties' 2013-11-09 17:00:37,816 INFO [org.quartz.impl.StdSchedulerFactory] Quartz scheduler version: 1.5.2 2013-11-09 17:00:37,816 INFO [org.quartz.core.QuartzScheduler] Scheduler DefaultQuartzScheduler_$NON_CLUSTERED started. 2013-11-09 17:00:38,453 WARN [com.arjuna.ats.arjuna.logging.arjLoggerI18N] [com.arjuna.ats.arjuna.common.Uid_1] - cannot get local host. 2013-11-09 17:00:38,454 WARN [com.arjuna.ats.jta.logging.loggerI18N] [com.arjuna.ats.internal.jta.recovery.objstoreerror] {0} com.arjuna.ats.arjuna.exceptions.ObjectStoreException: [com.arjuna.ats.internal.arjuna.objectstore.FileSystemStore_3] - FileSystemStore::allObjUids - could not pack end of list Uid. at com.arjuna.ats.internal.arjuna.objectstore.FileSystemStore.allObjUids(FileSystemStore.java:322) at com.arjuna.ats.arjuna.objectstore.ObjectStore.allObjUids(ObjectStore.java:221) at com.arjuna.ats.internal.jta.recovery.arjunacore.XARecoveryModule.periodicWorkFirstPass(XARecoveryModule.java:128) at com.arjuna.ats.internal.arjuna.recovery.PeriodicRecovery.doWorkInternal(PeriodicRecovery.java:745) at com.arjuna.ats.internal.arjuna.recovery.PeriodicRecovery.run(PeriodicRecovery.java:412) 2013-11-09 17:00:39,412 WARN [com.arjuna.ats.arjuna.logging.arjLoggerI18N] [com.arjuna.ats.arjuna.common.Uid_1] - cannot get local host. 2013-11-09 17:00:39,425 WARN [com.arjuna.ats.arjuna.logging.arjLoggerI18N] [com.arjuna.ats.arjuna.common.Uid_6] - Uid.generateHash called for invalid Uid. Will ignore. 2013-11-09 17:00:39,426 WARN [com.arjuna.ats.arjuna.logging.arjLoggerI18N] [com.arjuna.ats.arjuna.common.Uid_6] - Uid.generateHash called for invalid Uid. Will ignore. 2013-11-09 17:00:39,478 WARN [com.arjuna.ats.arjuna.logging.arjLoggerI18N] [com.arjuna.ats.arjuna.common.Uid_6] - Uid.generateHash called for invalid Uid. Will ignore. 2013-11-09 17:00:39,505 WARN [com.arjuna.ats.arjuna.logging.arjLoggerI18N] [com.arjuna.ats.arjuna.common.Uid_6] - Uid.generateHash called for invalid Uid. Will ignore. 2013-11-09 17:00:39,506 WARN [com.arjuna.ats.arjuna.logging.arjLoggerI18N] [com.arjuna.ats.arjuna.common.Uid_6] - Uid.generateHash called for invalid Uid. Will ignore. 2013-11-09 17:00:39,508 WARN [com.arjuna.ats.arjuna.logging.arjLoggerI18N] [com.arjuna.ats.arjuna.common.Uid_6] - Uid.generateHash called for invalid Uid. Will ignore. 2013-11-09 17:00:40,492 WARN [com.arjuna.ats.arjuna.logging.arjLoggerI18N] [com.arjuna.ats.arjuna.common.Uid_1] - cannot get local host. 2013-11-09 17:00:41,475 WARN [com.arjuna.ats.arjuna.logging.arjLoggerI18N] [com.arjuna.ats.arjuna.common.Uid_1] - cannot get local host. 2013-11-09 17:00:41,497 WARN [com.arjuna.ats.arjuna.logging.arjLoggerI18N] [com.arjuna.ats.arjuna.common.Uid_6] - Uid.generateHash called for invalid Uid. Will ignore. 2013-11-09 17:00:41,502 WARN [com.arjuna.ats.arjuna.logging.arjLoggerI18N] [com.arjuna.ats.arjuna.common.Uid_6] - Uid.generateHash called for invalid Uid. Will ignore. 2013-11-09 17:00:41,506 WARN [com.arjuna.ats.arjuna.logging.arjLoggerI18N] [com.arjuna.ats.arjuna.common.Uid_6] - Uid.generateHash called for invalid Uid. Will ignore. 2013-11-09 17:00:41,507 WARN [com.arjuna.ats.arjuna.logging.arjLoggerI18N] [com.arjuna.ats.arjuna.common.Uid_6] - Uid.generateHash called for invalid Uid. Will ignore. 2013-11-09 17:00:41,507 WARN [com.arjuna.ats.arjuna.logging.arjLoggerI18N] [com.arjuna.ats.arjuna.common.Uid_6] - Uid.generateHash called for invalid Uid. Will ignore. 2013-11-09 17:00:41,507 WARN [com.arjuna.ats.arjuna.logging.arjLoggerI18N] [com.arjuna.ats.arjuna.common.Uid_6] - Uid.generateHash called for invalid Uid. Will ignore. 2013-11-09 17:00:41,507 WARN [com.arjuna.ats.arjuna.logging.arjLoggerI18N] [com.arjuna.ats.arjuna.common.Uid_6] - Uid.generateHash called for invalid Uid. Will ignore. 2013-11-09 17:00:41,507 WARN [com.arjuna.ats.arjuna.logging.arjLoggerI18N] [com.arjuna.ats.arjuna.common.Uid_6] - Uid.generateHash called for invalid Uid. Will ignore. 2013-11-09 17:00:42,532 WARN [com.arjuna.ats.arjuna.logging.arjLoggerI18N] [com.arjuna.ats.arjuna.common.Uid_1] - cannot get local host. 2013-11-09 17:00:42,532 WARN [com.arjuna.ats.arjuna.logging.arjLoggerI18N] [com.arjuna.ats.arjuna.common.Uid_6] - Uid.generateHash called for invalid Uid. Will ignore. 2013-11-09 17:00:42,533 WARN [com.arjuna.ats.arjuna.logging.arjLoggerI18N] [com.arjuna.ats.arjuna.common.Uid_6] - Uid.generateHash called for invalid Uid. Will ignore. 2013-11-09 17:00:42,533 WARN [com.arjuna.ats.arjuna.logging.arjLoggerI18N] [com.arjuna.ats.arjuna.common.Uid_6] - Uid.generateHash called for invalid Uid. Will ignore. 2013-11-09 17:00:42,534 WARN [com.arjuna.ats.arjuna.logging.arjLoggerI18N] [com.arjuna.ats.arjuna.common.Uid_6] - Uid.generateHash called for invalid Uid. Will ignore. 2013-11-09 17:00:42,535 WARN [com.arjuna.ats.arjuna.logging.arjLoggerI18N] [com.arjuna.ats.arjuna.common.Uid_6] - Uid.generateHash called for invalid Uid. Will ignore. 2013-11-09 17:00:42,535 WARN [com.arjuna.ats.arjuna.logging.arjLoggerI18N] [com.arjuna.ats.arjuna.common.Uid_6] - Uid.generateHash called for invalid Uid. Will ignore. 2013-11-09 17:00:43,455 WARN [com.arjuna.ats.arjuna.logging.arjLoggerI18N] [com.arjuna.ats.arjuna.common.Uid_1] - cannot get local host. 2013-11-09 17:00:44,415 WARN [com.arjuna.ats.arjuna.logging.arjLoggerI18N] [com.arjuna.ats.arjuna.common.Uid_1] - cannot get local host. 2013-11-09 17:00:44,416 WARN [com.arjuna.ats.arjuna.logging.arjLoggerI18N] [com.arjuna.ats.arjuna.common.Uid_6] - Uid.generateHash called for invalid Uid. Will ignore. 2013-11-09 17:00:44,416 WARN [com.arjuna.ats.arjuna.logging.arjLoggerI18N] [com.arjuna.ats.arjuna.common.Uid_6] - Uid.generateHash called for invalid Uid. Will ignore. 2013-11-09 17:00:44,417 WARN [com.arjuna.ats.arjuna.logging.arjLoggerI18N] [com.arjuna.ats.arjuna.common.Uid_6] - Uid.generateHash called for invalid Uid. Will ignore. 2013-11-09 17:00:44,417 WARN [com.arjuna.ats.arjuna.logging.arjLoggerI18N] [com.arjuna.ats.arjuna.common.Uid_6] - Uid.generateHash called for invalid Uid. Will ignore. 2013-11-09 17:00:44,418 WARN [com.arjuna.ats.arjuna.logging.arjLoggerI18N] [com.arjuna.ats.arjuna.common.Uid_6] - Uid.generateHash called for invalid Uid. Will ignore. 2013-11-09 17:00:44,418 WARN [com.arjuna.ats.arjuna.logging.arjLoggerI18N] [com.arjuna.ats.arjuna.common.Uid_6] - Uid.generateHash called for invalid Uid. Will ignore. 2013-11-09 17:00:44,418 WARN [com.arjuna.ats.arjuna.logging.arjLoggerI18N] [com.arjuna.ats.arjuna.common.Uid_6] - Uid.generateHash called for invalid Uid. Will ignore. 2013-11-09 17:00:44,418 WARN [com.arjuna.ats.arjuna.logging.arjLoggerI18N] [com.arjuna.ats.arjuna.common.Uid_6] - Uid.generateHash called for invalid Uid. Will ignore. 2013-11-09 17:00:45,375 WARN [com.arjuna.ats.arjuna.logging.arjLoggerI18N] [com.arjuna.ats.arjuna.common.Uid_1] - cannot get local host. 2013-11-09 17:00:45,375 WARN [com.arjuna.ats.arjuna.logging.arjLoggerI18N] [com.arjuna.ats.arjuna.common.Uid_6] - Uid.generateHash called for invalid Uid. Will ignore. 2013-11-09 17:00:45,376 WARN [com.arjuna.ats.arjuna.logging.arjLoggerI18N] [com.arjuna.ats.arjuna.common.Uid_6] - Uid.generateHash called for invalid Uid. Will ignore. 2013-11-09 17:00:45,376 WARN [com.arjuna.ats.arjuna.logging.arjLoggerI18N] [com.arjuna.ats.arjuna.common.Uid_6] - Uid.generateHash called for invalid Uid. Will ignore. 2013-11-09 17:00:45,376 WARN [com.arjuna.ats.arjuna.logging.arjLoggerI18N] [com.arjuna.ats.arjuna.common.Uid_6] - Uid.generateHash called for invalid Uid. Will ignore. 2013-11-09 17:00:45,377 WARN [com.arjuna.ats.arjuna.logging.arjLoggerI18N] [com.arjuna.ats.arjuna.common.Uid_6] - Uid.generateHash called for invalid Uid. Will ignore. 2013-11-09 17:00:45,377 WARN [com.arjuna.ats.arjuna.logging.arjLoggerI18N] [com.arjuna.ats.arjuna.common.Uid_6] - Uid.generateHash called for invalid Uid. Will ignore. 2013-11-09 17:00:46,353 WARN [com.arjuna.ats.arjuna.logging.arjLoggerI18N] [com.arjuna.ats.arjuna.common.Uid_1] - cannot get local host. 2013-11-09 17:00:47,313 WARN [com.arjuna.ats.arjuna.logging.arjLoggerI18N] [com.arjuna.ats.arjuna.common.Uid_1] - cannot get local host. 2013-11-09 17:00:47,314 WARN [com.arjuna.ats.arjuna.logging.arjLoggerI18N] [com.arjuna.ats.arjuna.common.Uid_6] - Uid.generateHash called for invalid Uid. Will ignore. 2013-11-09 17:00:47,314 WARN [com.arjuna.ats.arjuna.logging.arjLoggerI18N] [com.arjuna.ats.arjuna.common.Uid_6] - Uid.generateHash called for invalid Uid. Will ignore. 2013-11-09 17:00:47,336 WARN [com.arjuna.ats.arjuna.logging.arjLoggerI18N] [com.arjuna.ats.arjuna.common.Uid_6] - Uid.generateHash called for invalid Uid. Will ignore. 2013-11-09 17:00:47,336 WARN [com.arjuna.ats.arjuna.logging.arjLoggerI18N] [com.arjuna.ats.arjuna.common.Uid_6] - Uid.generateHash called for invalid Uid. Will ignore. 2013-11-09 17:00:47,336 WARN [com.arjuna.ats.arjuna.logging.arjLoggerI18N] [com.arjuna.ats.arjuna.common.Uid_6] - Uid.generateHash called for invalid Uid. Will ignore. 2013-11-09 17:00:47,336 WARN [com.arjuna.ats.arjuna.logging.arjLoggerI18N] [com.arjuna.ats.arjuna.common.Uid_6] - Uid.generateHash called for invalid Uid. Will ignore. 2013-11-09 17:00:47,336 WARN [com.arjuna.ats.arjuna.logging.arjLoggerI18N] [com.arjuna.ats.arjuna.common.Uid_6] - Uid.generateHash called for invalid Uid. Will ignore. 2013-11-09 17:00:47,336 WARN [com.arjuna.ats.arjuna.logging.arjLoggerI18N] [com.arjuna.ats.arjuna.common.Uid_6] - Uid.generateHash called for invalid Uid. Will ignore. 2013-11-09 17:00:48,301 WARN [com.arjuna.ats.arjuna.logging.arjLoggerI18N] [com.arjuna.ats.arjuna.common.Uid_1] - cannot get local host. 2013-11-09 17:00:48,302 WARN [com.arjuna.ats.arjuna.logging.arjLoggerI18N] [com.arjuna.ats.arjuna.common.Uid_6] - Uid.generateHash called for invalid Uid. Will ignore. 2013-11-09 17:00:48,302 WARN [com.arjuna.ats.arjuna.logging.arjLoggerI18N] [com.arjuna.ats.arjuna.common.Uid_6] - Uid.generateHash called for invalid Uid. Will ignore. 2013-11-09 17:00:48,302 WARN [com.arjuna.ats.arjuna.logging.arjLoggerI18N] [com.arjuna.ats.arjuna.common.Uid_6] - Uid.generateHash called for invalid Uid. Will ignore. 2013-11-09 17:00:48,303 WARN [com.arjuna.ats.arjuna.logging.arjLoggerI18N] [com.arjuna.ats.arjuna.common.Uid_6] - Uid.generateHash called for invalid Uid. Will ignore. 2013-11-09 17:00:48,303 WARN [com.arjuna.ats.arjuna.logging.arjLoggerI18N] [com.arjuna.ats.arjuna.common.Uid_6] - Uid.generateHash called for invalid Uid. Will ignore. 2013-11-09 17:00:48,303 WARN [com.arjuna.ats.arjuna.logging.arjLoggerI18N] [com.arjuna.ats.arjuna.common.Uid_6] - Uid.generateHash called for invalid Uid. Will ignore. 2013-11-09 17:00:49,253 WARN [com.arjuna.ats.arjuna.logging.arjLoggerI18N] [com.arjuna.ats.arjuna.common.Uid_1] - cannot get local host. 2013-11-09 17:00:50,133 WARN [com.arjuna.ats.arjuna.logging.arjLoggerI18N] [com.arjuna.ats.arjuna.common.Uid_1] - cannot get local host. 2013-11-09 17:00:50,134 WARN [com.arjuna.ats.arjuna.logging.arjLoggerI18N] [com.arjuna.ats.arjuna.common.Uid_6] - Uid.generateHash called for invalid Uid. Will ignore. 2013-11-09 17:00:50,134 WARN [com.arjuna.ats.arjuna.logging.arjLoggerI18N] [com.arjuna.ats.arjuna.common.Uid_6] - Uid.generateHash called for invalid Uid. Will ignore. 2013-11-09 17:00:50,135 WARN [com.arjuna.ats.arjuna.logging.arjLoggerI18N] [com.arjuna.ats.arjuna.common.Uid_6] - Uid.generateHash called for invalid Uid. Will ignore. 2013-11-09 17:00:50,136 WARN [com.arjuna.ats.arjuna.logging.arjLoggerI18N] [com.arjuna.ats.arjuna.common.Uid_6] - Uid.generateHash called for invalid Uid. Will ignore. 2013-11-09 17:00:50,136 WARN [com.arjuna.ats.arjuna.logging.arjLoggerI18N] [com.arjuna.ats.arjuna.common.Uid_6] - Uid.generateHash called for invalid Uid. Will ignore. 2013-11-09 17:00:50,136 WARN [com.arjuna.ats.arjuna.logging.arjLoggerI18N] [com.arjuna.ats.arjuna.common.Uid_6] - Uid.generateHash called for invalid Uid. Will ignore. 2013-11-09 17:00:50,136 WARN [com.arjuna.ats.arjuna.logging.arjLoggerI18N] [com.arjuna.ats.arjuna.common.Uid_6] - Uid.generateHash called for invalid Uid. Will ignore. 2013-11-09 17:00:50,136 WARN [com.arjuna.ats.arjuna.logging.arjLoggerI18N] [com.arjuna.ats.arjuna.common.Uid_6] - Uid.generateHash called for invalid Uid. Will ignore. 2013-11-09 17:00:51,574 WARN [com.arjuna.ats.arjuna.logging.arjLoggerI18N] [com.arjuna.ats.arjuna.common.Uid_1] - cannot get local host. 2013-11-09 17:00:51,574 WARN [com.arjuna.ats.arjuna.logging.arjLoggerI18N] [com.arjuna.ats.arjuna.common.Uid_6] - Uid.generateHash called for invalid Uid. Will ignore. 2013-11-09 17:00:51,574 WARN [com.arjuna.ats.arjuna.logging.arjLoggerI18N] [com.arjuna.ats.arjuna.common.Uid_6] - Uid.generateHash called for invalid Uid. Will ignore. 2013-11-09 17:00:51,574 WARN [com.arjuna.ats.arjuna.logging.arjLoggerI18N] [com.arjuna.ats.arjuna.common.Uid_6] - Uid.generateHash called for invalid Uid. Will ignore. 2013-11-09 17:00:51,575 WARN [com.arjuna.ats.arjuna.logging.arjLoggerI18N] [com.arjuna.ats.arjuna.common.Uid_6] - Uid.generateHash called for invalid Uid. Will ignore. 2013-11-09 17:00:51,575 WARN [com.arjuna.ats.arjuna.logging.arjLoggerI18N] [com.arjuna.ats.arjuna.common.Uid_6] - Uid.generateHash called for invalid Uid. Will ignore. 2013-11-09 17:00:51,575 WARN [com.arjuna.ats.arjuna.logging.arjLoggerI18N] [com.arjuna.ats.arjuna.common.Uid_6] - Uid.generateHash called for invalid Uid. Will ignore. 2013-11-09 17:00:52,552 WARN [com.arjuna.ats.arjuna.logging.arjLoggerI18N] [com.arjuna.ats.arjuna.common.Uid_1] - cannot get local host. 2013-11-09 17:00:53,544 WARN [com.arjuna.ats.arjuna.logging.arjLoggerI18N] [com.arjuna.ats.arjuna.common.Uid_1] - cannot get local host. 2013-11-09 17:00:53,545 WARN [com.arjuna.ats.arjuna.logging.arjLoggerI18N] [com.arjuna.ats.arjuna.common.Uid_6] - Uid.generateHash called for invalid Uid. Will ignore. 2013-11-09 17:00:53,545 WARN [com.arjuna.ats.arjuna.logging.arjLoggerI18N] [com.arjuna.ats.arjuna.common.Uid_6] - Uid.generateHash called for invalid Uid. Will ignore. 2013-11-09 17:00:53,546 WARN [com.arjuna.ats.arjuna.logging.arjLoggerI18N] [com.arjuna.ats.arjuna.common.Uid_6] - Uid.generateHash called for invalid Uid. Will ignore. 2013-11-09 17:00:53,546 WARN [com.arjuna.ats.arjuna.logging.arjLoggerI18N] [com.arjuna.ats.arjuna.common.Uid_6] - Uid.generateHash called for invalid Uid. Will ignore. 2013-11-09 17:00:53,546 WARN [com.arjuna.ats.arjuna.logging.arjLoggerI18N] [com.arjuna.ats.arjuna.common.Uid_6] - Uid.generateHash called for invalid Uid. Will ignore. 2013-11-09 17:00:53,546 WARN [com.arjuna.ats.arjuna.logging.arjLoggerI18N] [com.arjuna.ats.arjuna.common.Uid_6] - Uid.generateHash called for invalid Uid. Will ignore. 2013-11-09 17:00:53,547 WARN [com.arjuna.ats.arjuna.logging.arjLoggerI18N] [com.arjuna.ats.arjuna.common.Uid_6] - Uid.generateHash called for invalid Uid. Will ignore. 2013-11-09 17:00:53,547 WARN [com.arjuna.ats.arjuna.logging.arjLoggerI18N] [com.arjuna.ats.arjuna.common.Uid_6] - Uid.generateHash called for invalid Uid. Will ignore. 2013-11-09 17:00:54,504 WARN [com.arjuna.ats.arjuna.logging.arjLoggerI18N] [com.arjuna.ats.arjuna.common.Uid_1] - cannot get local host. 2013-11-09 17:00:54,505 WARN [com.arjuna.ats.arjuna.logging.arjLoggerI18N] [com.arjuna.ats.arjuna.common.Uid_6] - Uid.generateHash called for invalid Uid. Will ignore. 2013-11-09 17:00:54,505 WARN [com.arjuna.ats.arjuna.logging.arjLoggerI18N] [com.arjuna.ats.arjuna.common.Uid_6] - Uid.generateHash called for invalid Uid. Will ignore. 2013-11-09 17:00:54,505 WARN [com.arjuna.ats.arjuna.logging.arjLoggerI18N] [com.arjuna.ats.arjuna.common.Uid_6] - Uid.generateHash called for invalid Uid. Will ignore. 2013-11-09 17:00:54,506 WARN [com.arjuna.ats.arjuna.logging.arjLoggerI18N] [com.arjuna.ats.arjuna.common.Uid_6] - Uid.generateHash called for invalid Uid. Will ignore. 2013-11-09 17:00:54,506 WARN [com.arjuna.ats.arjuna.logging.arjLoggerI18N] [com.arjuna.ats.arjuna.common.Uid_6] - Uid.generateHash called for invalid Uid. Will ignore. 2013-11-09 17:00:54,506 WARN [com.arjuna.ats.arjuna.logging.arjLoggerI18N] [com.arjuna.ats.arjuna.common.Uid_6] - Uid.generateHash called for invalid Uid. Will ignore. 2013-11-09 17:00:55,432 WARN [com.arjuna.ats.arjuna.logging.arjLoggerI18N] [com.arjuna.ats.arjuna.common.Uid_1] - cannot get local host. 2013-11-09 17:00:56,416 WARN [com.arjuna.ats.arjuna.logging.arjLoggerI18N] [com.arjuna.ats.arjuna.common.Uid_1] - cannot get local host. 2013-11-09 17:00:56,417 WARN [com.arjuna.ats.arjuna.logging.arjLoggerI18N] [com.arjuna.ats.arjuna.common.Uid_6] - Uid.generateHash called for invalid Uid. Will ignore. 2013-11-09 17:00:56,417 WARN [com.arjuna.ats.arjuna.logging.arjLoggerI18N] [com.arjuna.ats.arjuna.common.Uid_6] - Uid.generateHash called for invalid Uid. Will ignore. 2013-11-09 17:00:56,418 WARN [com.arjuna.ats.arjuna.logging.arjLoggerI18N] [com.arjuna.ats.arjuna.common.Uid_6] - Uid.generateHash called for invalid Uid. Will ignore. 2013-11-09 17:00:56,418 WARN [com.arjuna.ats.arjuna.logging.arjLoggerI18N] [com.arjuna.ats.arjuna.common.Uid_6] - Uid.generateHash called for invalid Uid. Will ignore. 2013-11-09 17:00:56,418 WARN [com.arjuna.ats.arjuna.logging.arjLoggerI18N] [com.arjuna.ats.arjuna.common.Uid_6] - Uid.generateHash called for invalid Uid. Will ignore. 2013-11-09 17:00:56,418 WARN [com.arjuna.ats.arjuna.logging.arjLoggerI18N] [com.arjuna.ats.arjuna.common.Uid_6] - Uid.generateHash called for invalid Uid. Will ignore. 2013-11-09 17:00:56,418 WARN [com.arjuna.ats.arjuna.logging.arjLoggerI18N] [com.arjuna.ats.arjuna.common.Uid_6] - Uid.generateHash called for invalid Uid. Will ignore. 2013-11-09 17:00:56,418 WARN [com.arjuna.ats.arjuna.logging.arjLoggerI18N] [com.arjuna.ats.arjuna.common.Uid_6] - Uid.generateHash called for invalid Uid. Will ignore. 2013-11-09 17:00:57,370 WARN [com.arjuna.ats.arjuna.logging.arjLoggerI18N] [com.arjuna.ats.arjuna.common.Uid_1] - cannot get local host. 2013-11-09 17:00:57,371 WARN [com.arjuna.ats.arjuna.logging.arjLoggerI18N] [com.arjuna.ats.arjuna.common.Uid_6] - Uid.generateHash called for invalid Uid. Will ignore. 2013-11-09 17:00:57,371 WARN [com.arjuna.ats.arjuna.logging.arjLoggerI18N] [com.arjuna.ats.arjuna.common.Uid_6] - Uid.generateHash called for invalid Uid. Will ignore. 2013-11-09 17:00:57,371 WARN [com.arjuna.ats.arjuna.logging.arjLoggerI18N] [com.arjuna.ats.arjuna.common.Uid_6] - Uid.generateHash called for invalid Uid. Will ignore. 2013-11-09 17:00:57,372 WARN [com.arjuna.ats.arjuna.logging.arjLoggerI18N] [com.arjuna.ats.arjuna.common.Uid_6] - Uid.generateHash called for invalid Uid. Will ignore. 2013-11-09 17:00:57,372 WARN [com.arjuna.ats.arjuna.logging.arjLoggerI18N] [com.arjuna.ats.arjuna.common.Uid_6] - Uid.generateHash called for invalid Uid. Will ignore. 2013-11-09 17:00:57,372 WARN [com.arjuna.ats.arjuna.logging.arjLoggerI18N] [com.arjuna.ats.arjuna.common.Uid_6] - Uid.generateHash called for invalid Uid. Will ignore. 2013-11-09 17:00:58,354 WARN [com.arjuna.ats.arjuna.logging.arjLoggerI18N] [com.arjuna.ats.arjuna.common.Uid_1] - cannot get local host. 2013-11-09 17:00:59,296 WARN [com.arjuna.ats.arjuna.logging.arjLoggerI18N] [com.arjuna.ats.arjuna.common.Uid_1] - cannot get local host. 2013-11-09 17:00:59,297 WARN [com.arjuna.ats.arjuna.logging.arjLoggerI18N] [com.arjuna.ats.arjuna.common.Uid_6] - Uid.generateHash called for invalid Uid. Will ignore. 2013-11-09 17:00:59,297 WARN [com.arjuna.ats.arjuna.logging.arjLoggerI18N] [com.arjuna.ats.arjuna.common.Uid_6] - Uid.generateHash called for invalid Uid. Will ignore. 2013-11-09 17:00:59,298 WARN [com.arjuna.ats.arjuna.logging.arjLoggerI18N] [com.arjuna.ats.arjuna.common.Uid_6] - Uid.generateHash called for invalid Uid. Will ignore. 2013-11-09 17:00:59,298 WARN [com.arjuna.ats.arjuna.logging.arjLoggerI18N] [com.arjuna.ats.arjuna.common.Uid_6] - Uid.generateHash called for invalid Uid. Will ignore. 2013-11-09 17:00:59,298 WARN [com.arjuna.ats.arjuna.logging.arjLoggerI18N] [com.arjuna.ats.arjuna.common.Uid_6] - Uid.generateHash called for invalid Uid. Will ignore. 2013-11-09 17:00:59,298 WARN [com.arjuna.ats.arjuna.logging.arjLoggerI18N] [com.arjuna.ats.arjuna.common.Uid_6] - Uid.generateHash called for invalid Uid. Will ignore. 2013-11-09 17:00:59,298 WARN [com.arjuna.ats.arjuna.logging.arjLoggerI18N] [com.arjuna.ats.arjuna.common.Uid_6] - Uid.generateHash called for invalid Uid. Will ignore. 2013-11-09 17:00:59,299 WARN [com.arjuna.ats.arjuna.logging.arjLoggerI18N] [com.arjuna.ats.arjuna.common.Uid_6] - Uid.generateHash called for invalid Uid. Will ignore. 2013-11-09 17:01:00,301 WARN [com.arjuna.ats.arjuna.logging.arjLoggerI18N] [com.arjuna.ats.arjuna.common.Uid_1] - cannot get local host. 2013-11-09 17:01:00,301 WARN [com.arjuna.ats.arjuna.logging.arjLoggerI18N] [com.arjuna.ats.arjuna.common.Uid_6] - Uid.generateHash called for invalid Uid. Will ignore. 2013-11-09 17:01:00,302 WARN [com.arjuna.ats.arjuna.logging.arjLoggerI18N] [com.arjuna.ats.arjuna.common.Uid_6] - Uid.generateHash called for invalid Uid. Will ignore. 2013-11-09 17:01:00,302 WARN [com.arjuna.ats.arjuna.logging.arjLoggerI18N] [com.arjuna.ats.arjuna.common.Uid_6] - Uid.generateHash called for invalid Uid. Will ignore. 2013-11-09 17:01:00,303 WARN [com.arjuna.ats.arjuna.logging.arjLoggerI18N] [com.arjuna.ats.arjuna.common.Uid_6] - Uid.generateHash called for invalid Uid. Will ignore. 2013-11-09 17:01:00,303 WARN [com.arjuna.ats.arjuna.logging.arjLoggerI18N] [com.arjuna.ats.arjuna.common.Uid_6] - Uid.generateHash called for invalid Uid. Will ignore. 2013-11-09 17:01:00,303 WARN [com.arjuna.ats.arjuna.logging.arjLoggerI18N] [com.arjuna.ats.arjuna.common.Uid_6] - Uid.generateHash called for invalid Uid. Will ignore. 2013-11-09 17:01:01,233 WARN [com.arjuna.ats.arjuna.logging.arjLoggerI18N] [com.arjuna.ats.arjuna.common.Uid_1] - cannot get local host. 2013-11-09 17:01:02,193 WARN [com.arjuna.ats.arjuna.logging.arjLoggerI18N] [com.arjuna.ats.arjuna.common.Uid_1] - cannot get local host. 2013-11-09 17:01:02,194 WARN [com.arjuna.ats.arjuna.logging.arjLoggerI18N] [com.arjuna.ats.arjuna.common.Uid_6] - Uid.generateHash called for invalid Uid. Will ignore. 2013-11-09 17:01:02,194 WARN [com.arjuna.ats.arjuna.logging.arjLoggerI18N] [com.arjuna.ats.arjuna.common.Uid_6] - Uid.generateHash called for invalid Uid. Will ignore. 2013-11-09 17:01:02,195 WARN [com.arjuna.ats.arjuna.logging.arjLoggerI18N] [com.arjuna.ats.arjuna.common.Uid_6] - Uid.generateHash called for invalid Uid. Will ignore. 2013-11-09 17:01:02,195 WARN [com.arjuna.ats.arjuna.logging.arjLoggerI18N] [com.arjuna.ats.arjuna.common.Uid_6] - Uid.generateHash called for invalid Uid. Will ignore. 2013-11-09 17:01:02,195 WARN [com.arjuna.ats.arjuna.logging.arjLoggerI18N] [com.arjuna.ats.arjuna.common.Uid_6] - Uid.generateHash called for invalid Uid. Will ignore. 2013-11-09 17:01:02,195 WARN [com.arjuna.ats.arjuna.logging.arjLoggerI18N] [com.arjuna.ats.arjuna.common.Uid_6] - Uid.generateHash called for invalid Uid. Will ignore. 2013-11-09 17:01:02,196 WARN [com.arjuna.ats.arjuna.logging.arjLoggerI18N] [com.arjuna.ats.arjuna.common.Uid_6] - Uid.generateHash called for invalid Uid. Will ignore. 2013-11-09 17:01:02,196 WARN [com.arjuna.ats.arjuna.logging.arjLoggerI18N] [com.arjuna.ats.arjuna.common.Uid_6] - Uid.generateHash called for invalid Uid. Will ignore. 2013-11-09 17:01:03,195 WARN [com.arjuna.ats.arjuna.logging.arjLoggerI18N] [com.arjuna.ats.arjuna.common.Uid_1] - cannot get local host. 2013-11-09 17:01:03,195 WARN [com.arjuna.ats.arjuna.logging.arjLoggerI18N] [com.arjuna.ats.arjuna.common.Uid_6] - Uid.generateHash called for invalid Uid. Will ignore. 2013-11-09 17:01:03,196 WARN [com.arjuna.ats.arjuna.logging.arjLoggerI18N] [com.arjuna.ats.arjuna.common.Uid_6] - Uid.generateHash called for invalid Uid. Will ignore. 2013-11-09 17:01:03,196 WARN [com.arjuna.ats.arjuna.logging.arjLoggerI18N] [com.arjuna.ats.arjuna.common.Uid_6] - Uid.generateHash called for invalid Uid. Will ignore. 2013-11-09 17:01:03,197 WARN [com.arjuna.ats.arjuna.logging.arjLoggerI18N] [com.arjuna.ats.arjuna.common.Uid_6] - Uid.generateHash called for invalid Uid. Will ignore. 2013-11-09 17:01:03,197 WARN [com.arjuna.ats.arjuna.logging.arjLoggerI18N] [com.arjuna.ats.arjuna.common.Uid_6] - Uid.generateHash called for invalid Uid. Will ignore. 2013-11-09 17:01:03,197 WARN [com.arjuna.ats.arjuna.logging.arjLoggerI18N] [com.arjuna.ats.arjuna.common.Uid_6] - Uid.generateHash called for invalid Uid. Will ignore. 2013-11-09 17:01:04,132 WARN [com.arjuna.ats.arjuna.logging.arjLoggerI18N] [com.arjuna.ats.arjuna.common.Uid_1] - cannot get local host. 2013-11-09 17:01:05,092 WARN [com.arjuna.ats.arjuna.logging.arjLoggerI18N] [com.arjuna.ats.arjuna.common.Uid_1] - cannot get local host. 2013-11-09 17:01:05,093 WARN [com.arjuna.ats.arjuna.logging.arjLoggerI18N] [com.arjuna.ats.arjuna.common.Uid_6] - Uid.generateHash called for invalid Uid. Will ignore. 2013-11-09 17:01:05,093 WARN [com.arjuna.ats.arjuna.logging.arjLoggerI18N] [com.arjuna.ats.arjuna.common.Uid_6] - Uid.generateHash called for invalid Uid. Will ignore. 2013-11-09 17:01:05,093 WARN [com.arjuna.ats.arjuna.logging.arjLoggerI18N] [com.arjuna.ats.arjuna.common.Uid_6] - Uid.generateHash called for invalid Uid. Will ignore. 2013-11-09 17:01:05,094 WARN [com.arjuna.ats.arjuna.logging.arjLoggerI18N] [com.arjuna.ats.arjuna.common.Uid_6] - Uid.generateHash called for invalid Uid. Will ignore. 2013-11-09 17:01:05,094 WARN [com.arjuna.ats.arjuna.logging.arjLoggerI18N] [com.arjuna.ats.arjuna.common.Uid_6] - Uid.generateHash called for invalid Uid. Will ignore. 2013-11-09 17:01:05,094 WARN [com.arjuna.ats.arjuna.logging.arjLoggerI18N] [com.arjuna.ats.arjuna.common.Uid_6] - Uid.generateHash called for invalid Uid. Will ignore. 2013-11-09 17:01:05,094 WARN [com.arjuna.ats.arjuna.logging.arjLoggerI18N] [com.arjuna.ats.arjuna.common.Uid_6] - Uid.generateHash called for invalid Uid. Will ignore. 2013-11-09 17:01:05,094 WARN [com.arjuna.ats.arjuna.logging.arjLoggerI18N] [com.arjuna.ats.arjuna.common.Uid_6] - Uid.generateHash called for invalid Uid. Will ignore. 2013-11-09 17:01:06,084 WARN [com.arjuna.ats.arjuna.logging.arjLoggerI18N] [com.arjuna.ats.arjuna.common.Uid_1] - cannot get local host. 2013-11-09 17:01:06,085 WARN [com.arjuna.ats.arjuna.logging.arjLoggerI18N] [com.arjuna.ats.arjuna.common.Uid_6] - Uid.generateHash called for invalid Uid. Will ignore. 2013-11-09 17:01:06,085 WARN [com.arjuna.ats.arjuna.logging.arjLoggerI18N] [com.arjuna.ats.arjuna.common.Uid_6] - Uid.generateHash called for invalid Uid. Will ignore. 2013-11-09 17:01:06,085 WARN [com.arjuna.ats.arjuna.logging.arjLoggerI18N] [com.arjuna.ats.arjuna.common.Uid_6] - Uid.generateHash called for invalid Uid. Will ignore. 2013-11-09 17:01:06,086 WARN [com.arjuna.ats.arjuna.logging.arjLoggerI18N] [com.arjuna.ats.arjuna.common.Uid_6] - Uid.generateHash called for invalid Uid. Will ignore. 2013-11-09 17:01:06,086 WARN [com.arjuna.ats.arjuna.logging.arjLoggerI18N] [com.arjuna.ats.arjuna.common.Uid_6] - Uid.generateHash called for invalid Uid. Will ignore. 2013-11-09 17:01:06,086 WARN [com.arjuna.ats.arjuna.logging.arjLoggerI18N] [com.arjuna.ats.arjuna.common.Uid_6] - Uid.generateHash called for invalid Uid. Will ignore. 2013-11-09 17:01:07,013 WARN [com.arjuna.ats.arjuna.logging.arjLoggerI18N] [com.arjuna.ats.arjuna.common.Uid_1] - cannot get local host. 2013-11-09 17:01:08,013 WARN [com.arjuna.ats.arjuna.logging.arjLoggerI18N] [com.arjuna.ats.arjuna.common.Uid_1] - cannot get local host. 2013-11-09 17:01:08,014 WARN [com.arjuna.ats.arjuna.logging.arjLoggerI18N] [com.arjuna.ats.arjuna.common.Uid_6] - Uid.generateHash called for invalid Uid. Will ignore. 2013-11-09 17:01:08,014 WARN [com.arjuna.ats.arjuna.logging.arjLoggerI18N] [com.arjuna.ats.arjuna.common.Uid_6] - Uid.generateHash called for invalid Uid. Will ignore. 2013-11-09 17:01:08,015 WARN [com.arjuna.ats.arjuna.logging.arjLoggerI18N] [com.arjuna.ats.arjuna.common.Uid_6] - Uid.generateHash called for invalid Uid. Will ignore. 2013-11-09 17:01:08,015 WARN [com.arjuna.ats.arjuna.logging.arjLoggerI18N] [com.arjuna.ats.arjuna.common.Uid_6] - Uid.generateHash called for invalid Uid. Will ignore. 2013-11-09 17:01:08,015 WARN [com.arjuna.ats.arjuna.logging.arjLoggerI18N] [com.arjuna.ats.arjuna.common.Uid_6] - Uid.generateHash called for invalid Uid. Will ignore. 2013-11-09 17:01:08,016 WARN [com.arjuna.ats.arjuna.logging.arjLoggerI18N] [com.arjuna.ats.arjuna.common.Uid_6] - Uid.generateHash called for invalid Uid. Will ignore. 2013-11-09 17:01:08,016 WARN [com.arjuna.ats.arjuna.logging.arjLoggerI18N] [com.arjuna.ats.arjuna.common.Uid_6] - Uid.generateHash called for invalid Uid. Will ignore. 2013-11-09 17:01:08,016 WARN [com.arjuna.ats.arjuna.logging.arjLoggerI18N] [com.arjuna.ats.arjuna.common.Uid_6] - Uid.generateHash called for invalid Uid. Will ignore. 2013-11-09 17:01:08,973 WARN [com.arjuna.ats.arjuna.logging.arjLoggerI18N] [com.arjuna.ats.arjuna.common.Uid_1] - cannot get local host. 2013-11-09 17:01:08,974 WARN [com.arjuna.ats.arjuna.logging.arjLoggerI18N] [com.arjuna.ats.arjuna.common.Uid_6] - Uid.generateHash called for invalid Uid. Will ignore. 2013-11-09 17:01:08,974 WARN [com.arjuna.ats.arjuna.logging.arjLoggerI18N] [com.arjuna.ats.arjuna.common.Uid_6] - Uid.generateHash called for invalid Uid. Will ignore. 2013-11-09 17:01:08,974 WARN [com.arjuna.ats.arjuna.logging.arjLoggerI18N] [com.arjuna.ats.arjuna.common.Uid_6] - Uid.generateHash called for invalid Uid. Will ignore. 2013-11-09 17:01:08,975 WARN [com.arjuna.ats.arjuna.logging.arjLoggerI18N] [com.arjuna.ats.arjuna.common.Uid_6] - Uid.generateHash called for invalid Uid. Will ignore. 2013-11-09 17:01:08,975 WARN [com.arjuna.ats.arjuna.logging.arjLoggerI18N] [com.arjuna.ats.arjuna.common.Uid_6] - Uid.generateHash called for invalid Uid. Will ignore. 2013-11-09 17:01:08,975 WARN [com.arjuna.ats.arjuna.logging.arjLoggerI18N] [com.arjuna.ats.arjuna.common.Uid_6] - Uid.generateHash called for invalid Uid. Will ignore. 2013-11-09 17:01:10,053 WARN [com.arjuna.ats.arjuna.logging.arjLoggerI18N] [com.arjuna.ats.arjuna.common.Uid_1] - cannot get local host. 2013-11-09 17:01:11,064 WARN [com.arjuna.ats.arjuna.logging.arjLoggerI18N] [com.arjuna.ats.arjuna.common.Uid_1] - cannot get local host. 2013-11-09 17:01:11,065 WARN [com.arjuna.ats.arjuna.logging.arjLoggerI18N] [com.arjuna.ats.arjuna.common.Uid_6] - Uid.generateHash called for invalid Uid. Will ignore. 2013-11-09 17:01:11,065 WARN [com.arjuna.ats.arjuna.logging.arjLoggerI18N] [com.arjuna.ats.arjuna.common.Uid_6] - Uid.generateHash called for invalid Uid. Will ignore. 2013-11-09 17:01:11,066 WARN [com.arjuna.ats.arjuna.logging.arjLoggerI18N] [com.arjuna.ats.arjuna.common.Uid_6] - Uid.generateHash called for invalid Uid. Will ignore. 2013-11-09 17:01:11,066 WARN [com.arjuna.ats.arjuna.logging.arjLoggerI18N] [com.arjuna.ats.arjuna.common.Uid_6] - Uid.generateHash called for invalid Uid. Will ignore. 2013-11-09 17:01:11,066 WARN [com.arjuna.ats.arjuna.logging.arjLoggerI18N] [com.arjuna.ats.arjuna.common.Uid_6] - Uid.generateHash called for invalid Uid. Will ignore. 2013-11-09 17:01:11,066 WARN [com.arjuna.ats.arjuna.logging.arjLoggerI18N] [com.arjuna.ats.arjuna.common.Uid_6] - Uid.generateHash called for invalid Uid. Will ignore. 2013-11-09 17:01:11,067 WARN [com.arjuna.ats.arjuna.logging.arjLoggerI18N] [com.arjuna.ats.arjuna.common.Uid_6] - Uid.generateHash called for invalid Uid. Will ignore. 2013-11-09 17:01:11,067 WARN [com.arjuna.ats.arjuna.logging.arjLoggerI18N] [com.arjuna.ats.arjuna.common.Uid_6] - Uid.generateHash called for invalid Uid. Will ignore. 2013-11-09 17:01:12,112 WARN [com.arjuna.ats.arjuna.logging.arjLoggerI18N] [com.arjuna.ats.arjuna.common.Uid_1] - cannot get local host. 2013-11-09 17:01:12,112 WARN [com.arjuna.ats.arjuna.logging.arjLoggerI18N] [com.arjuna.ats.arjuna.common.Uid_6] - Uid.generateHash called for invalid Uid. Will ignore. 2013-11-09 17:01:12,113 WARN [com.arjuna.ats.arjuna.logging.arjLoggerI18N] [com.arjuna.ats.arjuna.common.Uid_6] - Uid.generateHash called for invalid Uid. Will ignore. 2013-11-09 17:01:12,113 WARN [com.arjuna.ats.arjuna.logging.arjLoggerI18N] [com.arjuna.ats.arjuna.common.Uid_6] - Uid.generateHash called for invalid Uid. Will ignore. 2013-11-09 17:01:12,113 WARN [com.arjuna.ats.arjuna.logging.arjLoggerI18N] [com.arjuna.ats.arjuna.common.Uid_6] - Uid.generateHash called for invalid Uid. Will ignore. 2013-11-09 17:01:12,113 WARN [com.arjuna.ats.arjuna.logging.arjLoggerI18N] [com.arjuna.ats.arjuna.common.Uid_6] - Uid.generateHash called for invalid Uid. Will ignore. 2013-11-09 17:01:12,114 WARN [com.arjuna.ats.arjuna.logging.arjLoggerI18N] [com.arjuna.ats.arjuna.common.Uid_6] - Uid.generateHash called for invalid Uid. Will ignore. 2013-11-09 17:01:13,114 WARN [com.arjuna.ats.arjuna.logging.arjLoggerI18N] [com.arjuna.ats.arjuna.common.Uid_1] - cannot get local host. 2013-11-09 17:01:14,133 WARN [com.arjuna.ats.arjuna.logging.arjLoggerI18N] [com.arjuna.ats.arjuna.common.Uid_1] - cannot get local host. 2013-11-09 17:01:14,134 WARN [com.arjuna.ats.arjuna.logging.arjLoggerI18N] [com.arjuna.ats.arjuna.common.Uid_6] - Uid.generateHash called for invalid Uid. Will ignore. 2013-11-09 17:01:14,134 WARN [com.arjuna.ats.arjuna.logging.arjLoggerI18N] [com.arjuna.ats.arjuna.common.Uid_6] - Uid.generateHash called for invalid Uid. Will ignore. 2013-11-09 17:01:14,135 WARN [com.arjuna.ats.arjuna.logging.arjLoggerI18N] [com.arjuna.ats.arjuna.common.Uid_6] - Uid.generateHash called for invalid Uid. Will ignore. 2013-11-09 17:01:14,135 WARN [com.arjuna.ats.arjuna.logging.arjLoggerI18N] [com.arjuna.ats.arjuna.common.Uid_6] - Uid.generateHash called for invalid Uid. Will ignore. 2013-11-09 17:01:14,135 WARN [com.arjuna.ats.arjuna.logging.arjLoggerI18N] [com.arjuna.ats.arjuna.common.Uid_6] - Uid.generateHash called for invalid Uid. Will ignore. 2013-11-09 17:01:14,136 WARN [com.arjuna.ats.arjuna.logging.arjLoggerI18N] [com.arjuna.ats.arjuna.common.Uid_6] - Uid.generateHash called for invalid Uid. Will ignore. 2013-11-09 17:01:14,136 WARN [com.arjuna.ats.arjuna.logging.arjLoggerI18N] [com.arjuna.ats.arjuna.common.Uid_6] - Uid.generateHash called for invalid Uid. Will ignore. 2013-11-09 17:01:14,136 WARN [com.arjuna.ats.arjuna.logging.arjLoggerI18N] [com.arjuna.ats.arjuna.common.Uid_6] - Uid.generateHash called for invalid Uid. Will ignore. 2013-11-09 17:01:15,113 WARN [com.arjuna.ats.arjuna.logging.arjLoggerI18N] [com.arjuna.ats.arjuna.common.Uid_1] - cannot get local host. 2013-11-09 17:01:15,113 WARN [com.arjuna.ats.arjuna.logging.arjLoggerI18N] [com.arjuna.ats.arjuna.common.Uid_6] - Uid.generateHash called for invalid Uid. Will ignore. 2013-11-09 17:01:15,114 WARN [com.arjuna.ats.arjuna.logging.arjLoggerI18N] [com.arjuna.ats.arjuna.common.Uid_6] - Uid.generateHash called for invalid Uid. Will ignore. 2013-11-09 17:01:15,114 WARN [com.arjuna.ats.arjuna.logging.arjLoggerI18N] [com.arjuna.ats.arjuna.common.Uid_6] - Uid.generateHash called for invalid Uid. Will ignore. 2013-11-09 17:01:15,115 WARN [com.arjuna.ats.arjuna.logging.arjLoggerI18N] [com.arjuna.ats.arjuna.common.Uid_6] - Uid.generateHash called for invalid Uid. Will ignore. 2013-11-09 17:01:15,115 WARN [com.arjuna.ats.arjuna.logging.arjLoggerI18N] [com.arjuna.ats.arjuna.common.Uid_6] - Uid.generateHash called for invalid Uid. Will ignore. 2013-11-09 17:01:15,115 WARN [com.arjuna.ats.arjuna.logging.arjLoggerI18N] [com.arjuna.ats.arjuna.common.Uid_6] - Uid.generateHash called for invalid Uid. Will ignore. 2013-11-09 17:01:16,173 WARN [com.arjuna.ats.arjuna.logging.arjLoggerI18N] [com.arjuna.ats.arjuna.common.Uid_1] - cannot get local host. 2013-11-09 17:01:17,184 WARN [com.arjuna.ats.arjuna.logging.arjLoggerI18N] [com.arjuna.ats.arjuna.common.Uid_1] - cannot get local host. 2013-11-09 17:01:17,185 WARN [com.arjuna.ats.arjuna.logging.arjLoggerI18N] [com.arjuna.ats.arjuna.common.Uid_6] - Uid.generateHash called for invalid Uid. Will ignore. 2013-11-09 17:01:17,185 WARN [com.arjuna.ats.arjuna.logging.arjLoggerI18N] [com.arjuna.ats.arjuna.common.Uid_6] - Uid.generateHash called for invalid Uid. Will ignore. 2013-11-09 17:01:17,186 WARN [com.arjuna.ats.arjuna.logging.arjLoggerI18N] [com.arjuna.ats.arjuna.common.Uid_6] - Uid.generateHash called for invalid Uid. Will ignore. 2013-11-09 17:01:17,186 WARN [com.arjuna.ats.arjuna.logging.arjLoggerI18N] [com.arjuna.ats.arjuna.common.Uid_6] - Uid.generateHash called for invalid Uid. Will ignore. 2013-11-09 17:01:17,186 WARN [com.arjuna.ats.arjuna.logging.arjLoggerI18N] [com.arjuna.ats.arjuna.common.Uid_6] - Uid.generateHash called for invalid Uid. Will ignore. 2013-11-09 17:01:17,186 WARN [com.arjuna.ats.arjuna.logging.arjLoggerI18N] [com.arjuna.ats.arjuna.common.Uid_6] - Uid.generateHash called for invalid Uid. Will ignore. 2013-11-09 17:01:17,186 WARN [com.arjuna.ats.arjuna.logging.arjLoggerI18N] [com.arjuna.ats.arjuna.common.Uid_6] - Uid.generateHash called for invalid Uid. Will ignore. 2013-11-09 17:01:17,187 WARN [com.arjuna.ats.arjuna.logging.arjLoggerI18N] [com.arjuna.ats.arjuna.common.Uid_6] - Uid.generateHash called for invalid Uid. Will ignore. 2013-11-09 17:01:18,144 WARN [com.arjuna.ats.arjuna.logging.arjLoggerI18N] [com.arjuna.ats.arjuna.common.Uid_1] - cannot get local host. 2013-11-09 17:01:18,144 WARN [com.arjuna.ats.arjuna.logging.arjLoggerI18N] [com.arjuna.ats.arjuna.common.Uid_6] - Uid.generateHash called for invalid Uid. Will ignore. 2013-11-09 17:01:18,145 WARN [com.arjuna.ats.arjuna.logging.arjLoggerI18N] [com.arjuna.ats.arjuna.common.Uid_6] - Uid.generateHash called for invalid Uid. Will ignore. 2013-11-09 17:01:18,145 WARN [com.arjuna.ats.arjuna.logging.arjLoggerI18N] [com.arjuna.ats.arjuna.common.Uid_6] - Uid.generateHash called for invalid Uid. Will ignore. 2013-11-09 17:01:18,146 WARN [com.arjuna.ats.arjuna.logging.arjLoggerI18N] [com.arjuna.ats.arjuna.common.Uid_6] - Uid.generateHash called for invalid Uid. Will ignore. 2013-11-09 17:01:18,146 WARN [com.arjuna.ats.arjuna.logging.arjLoggerI18N] [com.arjuna.ats.arjuna.common.Uid_6] - Uid.generateHash called for invalid Uid. Will ignore. 2013-11-09 17:01:18,146 WARN [com.arjuna.ats.arjuna.logging.arjLoggerI18N] [com.arjuna.ats.arjuna.common.Uid_6] - Uid.generateHash called for invalid Uid. Will ignore. 2013-11-09 17:01:19,035 WARN [com.arjuna.ats.arjuna.logging.arjLoggerI18N] [com.arjuna.ats.arjuna.common.Uid_1] - cannot get local host. 2013-11-09 17:01:19,995 WARN [com.arjuna.ats.arjuna.logging.arjLoggerI18N] [com.arjuna.ats.arjuna.common.Uid_1] - cannot get local host. 2013-11-09 17:01:19,995 WARN [com.arjuna.ats.arjuna.logging.arjLoggerI18N] [com.arjuna.ats.arjuna.common.Uid_6] - Uid.generateHash called for invalid Uid. Will ignore. 2013-11-09 17:01:19,996 WARN [com.arjuna.ats.arjuna.logging.arjLoggerI18N] [com.arjuna.ats.arjuna.common.Uid_6] - Uid.generateHash called for invalid Uid. Will ignore. 2013-11-09 17:01:19,996 WARN [com.arjuna.ats.arjuna.logging.arjLoggerI18N] [com.arjuna.ats.arjuna.common.Uid_6] - Uid.generateHash called for invalid Uid. Will ignore. 2013-11-09 17:01:19,997 WARN [com.arjuna.ats.arjuna.logging.arjLoggerI18N] [com.arjuna.ats.arjuna.common.Uid_6] - Uid.generateHash called for invalid Uid. Will ignore. 2013-11-09 17:01:19,997 WARN [com.arjuna.ats.arjuna.logging.arjLoggerI18N] [com.arjuna.ats.arjuna.common.Uid_6] - Uid.generateHash called for invalid Uid. Will ignore. 2013-11-09 17:01:19,997 WARN [com.arjuna.ats.arjuna.logging.arjLoggerI18N] [com.arjuna.ats.arjuna.common.Uid_6] - Uid.generateHash called for invalid Uid. Will ignore. 2013-11-09 17:01:19,997 WARN [com.arjuna.ats.arjuna.logging.arjLoggerI18N] [com.arjuna.ats.arjuna.common.Uid_6] - Uid.generateHash called for invalid Uid. Will ignore. 2013-11-09 17:01:19,997 WARN [com.arjuna.ats.arjuna.logging.arjLoggerI18N] [com.arjuna.ats.arjuna.common.Uid_6] - Uid.generateHash called for invalid Uid. Will ignore. 2013-11-09 17:01:21,001 WARN [com.arjuna.ats.arjuna.logging.arjLoggerI18N] [com.arjuna.ats.arjuna.common.Uid_1] - cannot get local host. 2013-11-09 17:01:21,001 WARN [com.arjuna.ats.arjuna.logging.arjLoggerI18N] [com.arjuna.ats.arjuna.common.Uid_6] - Uid.generateHash called for invalid Uid. Will ignore. 2013-11-09 17:01:21,002 WARN [com.arjuna.ats.arjuna.logging.arjLoggerI18N] [com.arjuna.ats.arjuna.common.Uid_6] - Uid.generateHash called for invalid Uid. Will ignore. 2013-11-09 17:01:21,002 WARN [com.arjuna.ats.arjuna.logging.arjLoggerI18N] [com.arjuna.ats.arjuna.common.Uid_6] - Uid.generateHash called for invalid Uid. Will ignore. 2013-11-09 17:01:21,003 WARN [com.arjuna.ats.arjuna.logging.arjLoggerI18N] [com.arjuna.ats.arjuna.common.Uid_6] - Uid.generateHash called for invalid Uid. Will ignore. 2013-11-09 17:01:21,003 WARN [com.arjuna.ats.arjuna.logging.arjLoggerI18N] [com.arjuna.ats.arjuna.common.Uid_6] - Uid.generateHash called for invalid Uid. Will ignore. 2013-11-09 17:01:21,003 WARN [com.arjuna.ats.arjuna.logging.arjLoggerI18N] [com.arjuna.ats.arjuna.common.Uid_6] - Uid.generateHash called for invalid Uid. Will ignore. 2013-11-09 17:01:22,321 WARN [com.arjuna.ats.arjuna.logging.arjLoggerI18N] [com.arjuna.ats.arjuna.common.Uid_1] - cannot get local host. 2013-11-09 17:01:23,553 WARN [com.arjuna.ats.arjuna.logging.arjLoggerI18N] [com.arjuna.ats.arjuna.common.Uid_1] - cannot get local host. 2013-11-09 17:01:23,554 WARN [com.arjuna.ats.arjuna.logging.arjLoggerI18N] [com.arjuna.ats.arjuna.common.Uid_6] - Uid.generateHash called for invalid Uid. Will ignore. 2013-11-09 17:01:23,554 WARN [com.arjuna.ats.arjuna.logging.arjLoggerI18N] [com.arjuna.ats.arjuna.common.Uid_6] - Uid.generateHash called for invalid Uid. Will ignore. 2013-11-09 17:01:23,555 WARN [com.arjuna.ats.arjuna.logging.arjLoggerI18N] [com.arjuna.ats.arjuna.common.Uid_6] - Uid.generateHash called for invalid Uid. Will ignore. 2013-11-09 17:01:23,555 WARN [com.arjuna.ats.arjuna.logging.arjLoggerI18N] [com.arjuna.ats.arjuna.common.Uid_6] - Uid.generateHash called for invalid Uid. Will ignore. 2013-11-09 17:01:23,555 WARN [com.arjuna.ats.arjuna.logging.arjLoggerI18N] [com.arjuna.ats.arjuna.common.Uid_6] - Uid.generateHash called for invalid Uid. Will ignore. 2013-11-09 17:01:23,556 WARN [com.arjuna.ats.arjuna.logging.arjLoggerI18N] [com.arjuna.ats.arjuna.common.Uid_6] - Uid.generateHash called for invalid Uid. Will ignore. 2013-11-09 17:01:23,556 WARN [com.arjuna.ats.arjuna.logging.arjLoggerI18N] [com.arjuna.ats.arjuna.common.Uid_6] - Uid.generateHash called for invalid Uid. Will ignore. 2013-11-09 17:01:23,556 WARN [com.arjuna.ats.arjuna.logging.arjLoggerI18N] [com.arjuna.ats.arjuna.common.Uid_6] - Uid.generateHash called for invalid Uid. Will ignore. 2013-11-09 17:01:24,495 WARN [com.arjuna.ats.arjuna.logging.arjLoggerI18N] [com.arjuna.ats.arjuna.common.Uid_1] - cannot get local host. 2013-11-09 17:01:24,495 WARN [com.arjuna.ats.arjuna.logging.arjLoggerI18N] [com.arjuna.ats.arjuna.common.Uid_6] - Uid.generateHash called for invalid Uid. Will ignore. 2013-11-09 17:01:24,496 WARN [com.arjuna.ats.arjuna.logging.arjLoggerI18N] [com.arjuna.ats.arjuna.common.Uid_6] - Uid.generateHash called for invalid Uid. Will ignore. 2013-11-09 17:01:24,496 WARN [com.arjuna.ats.arjuna.logging.arjLoggerI18N] [com.arjuna.ats.arjuna.common.Uid_6] - Uid.generateHash called for invalid Uid. Will ignore. 2013-11-09 17:01:24,496 WARN [com.arjuna.ats.arjuna.logging.arjLoggerI18N] [com.arjuna.ats.arjuna.common.Uid_6] - Uid.generateHash called for invalid Uid. Will ignore. 2013-11-09 17:01:24,496 WARN [com.arjuna.ats.arjuna.logging.arjLoggerI18N] [com.arjuna.ats.arjuna.common.Uid_6] - Uid.generateHash called for invalid Uid. Will ignore. 2013-11-09 17:01:24,497 WARN [com.arjuna.ats.arjuna.logging.arjLoggerI18N] [com.arjuna.ats.arjuna.common.Uid_6] - Uid.generateHash called for invalid Uid. Will ignore. 2013-11-09 17:01:25,455 WARN [com.arjuna.ats.arjuna.logging.arjLoggerI18N] [com.arjuna.ats.arjuna.common.Uid_1] - cannot get local host. 2013-11-09 17:01:26,416 WARN [com.arjuna.ats.arjuna.logging.arjLoggerI18N] [com.arjuna.ats.arjuna.common.Uid_1] - cannot get local host. 2013-11-09 17:01:26,417 WARN [com.arjuna.ats.arjuna.logging.arjLoggerI18N] [com.arjuna.ats.arjuna.common.Uid_6] - Uid.generateHash called for invalid Uid. Will ignore. 2013-11-09 17:01:26,417 WARN [com.arjuna.ats.arjuna.logging.arjLoggerI18N] [com.arjuna.ats.arjuna.common.Uid_6] - Uid.generateHash called for invalid Uid. Will ignore. 2013-11-09 17:01:26,418 WARN [com.arjuna.ats.arjuna.logging.arjLoggerI18N] [com.arjuna.ats.arjuna.common.Uid_6] - Uid.generateHash called for invalid Uid. Will ignore. 2013-11-09 17:01:26,418 WARN [com.arjuna.ats.arjuna.logging.arjLoggerI18N] [com.arjuna.ats.arjuna.common.Uid_6] - Uid.generateHash called for invalid Uid. Will ignore. 2013-11-09 17:01:26,418 WARN [com.arjuna.ats.arjuna.logging.arjLoggerI18N] [com.arjuna.ats.arjuna.common.Uid_6] - Uid.generateHash called for invalid Uid. Will ignore. 2013-11-09 17:01:26,418 WARN [com.arjuna.ats.arjuna.logging.arjLoggerI18N] [com.arjuna.ats.arjuna.common.Uid_6] - Uid.generateHash called for invalid Uid. Will ignore. 2013-11-09 17:01:26,418 WARN [com.arjuna.ats.arjuna.logging.arjLoggerI18N] [com.arjuna.ats.arjuna.common.Uid_6] - Uid.generateHash called for invalid Uid. Will ignore. 2013-11-09 17:01:26,418 WARN [com.arjuna.ats.arjuna.logging.arjLoggerI18N] [com.arjuna.ats.arjuna.common.Uid_6] - Uid.generateHash called for invalid Uid. Will ignore. 2013-11-09 17:01:27,444 WARN [com.arjuna.ats.arjuna.logging.arjLoggerI18N] [com.arjuna.ats.arjuna.common.Uid_1] - cannot get local host. 2013-11-09 17:01:27,444 WARN [com.arjuna.ats.arjuna.logging.arjLoggerI18N] [com.arjuna.ats.arjuna.common.Uid_6] - Uid.generateHash called for invalid Uid. Will ignore. 2013-11-09 17:01:27,445 WARN [com.arjuna.ats.arjuna.logging.arjLoggerI18N] [com.arjuna.ats.arjuna.common.Uid_6] - Uid.generateHash called for invalid Uid. Will ignore. 2013-11-09 17:01:27,445 WARN [com.arjuna.ats.arjuna.logging.arjLoggerI18N] [com.arjuna.ats.arjuna.common.Uid_6] - Uid.generateHash called for invalid Uid. Will ignore. 2013-11-09 17:01:27,446 WARN [com.arjuna.ats.arjuna.logging.arjLoggerI18N] [com.arjuna.ats.arjuna.common.Uid_6] - Uid.generateHash called for invalid Uid. Will ignore. 2013-11-09 17:01:27,446 WARN [com.arjuna.ats.arjuna.logging.arjLoggerI18N] [com.arjuna.ats.arjuna.common.Uid_6] - Uid.generateHash called for invalid Uid. Will ignore. 2013-11-09 17:01:27,446 WARN [com.arjuna.ats.arjuna.logging.arjLoggerI18N] [com.arjuna.ats.arjuna.common.Uid_6] - Uid.generateHash called for invalid Uid. Will ignore. 2013-11-09 17:01:28,395 WARN [com.arjuna.ats.arjuna.logging.arjLoggerI18N] [com.arjuna.ats.arjuna.common.Uid_1] - cannot get local host. 2013-11-09 17:01:29,373 WARN [com.arjuna.ats.arjuna.logging.arjLoggerI18N] [com.arjuna.ats.arjuna.common.Uid_1] - cannot get local host. 2013-11-09 17:01:29,374 WARN [com.arjuna.ats.arjuna.logging.arjLoggerI18N] [com.arjuna.ats.arjuna.common.Uid_6] - Uid.generateHash called for invalid Uid. Will ignore. 2013-11-09 17:01:29,374 WARN [com.arjuna.ats.arjuna.logging.arjLoggerI18N] [com.arjuna.ats.arjuna.common.Uid_6] - Uid.generateHash called for invalid Uid. Will ignore. 2013-11-09 17:01:29,375 WARN [com.arjuna.ats.arjuna.logging.arjLoggerI18N] [com.arjuna.ats.arjuna.common.Uid_6] - Uid.generateHash called for invalid Uid. Will ignore. 2013-11-09 17:01:29,375 WARN [com.arjuna.ats.arjuna.logging.arjLoggerI18N] [com.arjuna.ats.arjuna.common.Uid_6] - Uid.generateHash called for invalid Uid. Will ignore. 2013-11-09 17:01:29,376 WARN [com.arjuna.ats.arjuna.logging.arjLoggerI18N] [com.arjuna.ats.arjuna.common.Uid_6] - Uid.generateHash called for invalid Uid. Will ignore. 2013-11-09 17:01:29,376 WARN [com.arjuna.ats.arjuna.logging.arjLoggerI18N] [com.arjuna.ats.arjuna.common.Uid_6] - Uid.generateHash called for invalid Uid. Will ignore. 2013-11-09 17:01:29,376 WARN [com.arjuna.ats.arjuna.logging.arjLoggerI18N] [com.arjuna.ats.arjuna.common.Uid_6] - Uid.generateHash called for invalid Uid. Will ignore. 2013-11-09 17:01:29,376 WARN [com.arjuna.ats.arjuna.logging.arjLoggerI18N] [com.arjuna.ats.arjuna.common.Uid_6] - Uid.generateHash called for invalid Uid. Will ignore. 2013-11-09 17:01:30,333 WARN [com.arjuna.ats.arjuna.logging.arjLoggerI18N] [com.arjuna.ats.arjuna.common.Uid_1] - cannot get local host. 2013-11-09 17:01:30,334 WARN [com.arjuna.ats.arjuna.logging.arjLoggerI18N] [com.arjuna.ats.arjuna.common.Uid_6] - Uid.generateHash called for invalid Uid. Will ignore. 2013-11-09 17:01:30,334 WARN [com.arjuna.ats.arjuna.logging.arjLoggerI18N] [com.arjuna.ats.arjuna.common.Uid_6] - Uid.generateHash called for invalid Uid. Will ignore. 2013-11-09 17:01:30,334 WARN [com.arjuna.ats.arjuna.logging.arjLoggerI18N] [com.arjuna.ats.arjuna.common.Uid_6] - Uid.generateHash called for invalid Uid. Will ignore. 2013-11-09 17:01:30,335 WARN [com.arjuna.ats.arjuna.logging.arjLoggerI18N] [com.arjuna.ats.arjuna.common.Uid_6] - Uid.generateHash called for invalid Uid. Will ignore. 2013-11-09 17:01:30,335 WARN [com.arjuna.ats.arjuna.logging.arjLoggerI18N] [com.arjuna.ats.arjuna.common.Uid_6] - Uid.generateHash called for invalid Uid. Will ignore. 2013-11-09 17:01:30,335 WARN [com.arjuna.ats.arjuna.logging.arjLoggerI18N] [com.arjuna.ats.arjuna.common.Uid_6] - Uid.generateHash called for invalid Uid. Will ignore. 2013-11-09 17:01:31,432 WARN [com.arjuna.ats.arjuna.logging.arjLoggerI18N] [com.arjuna.ats.arjuna.common.Uid_1] - cannot get local host. 2013-11-09 17:01:32,392 WARN [com.arjuna.ats.arjuna.logging.arjLoggerI18N] [com.arjuna.ats.arjuna.common.Uid_1] - cannot get local host. 2013-11-09 17:01:32,392 WARN [com.arjuna.ats.arjuna.logging.arjLoggerI18N] [com.arjuna.ats.arjuna.common.Uid_6] - Uid.generateHash called for invalid Uid. Will ignore. 2013-11-09 17:01:32,393 WARN [com.arjuna.ats.arjuna.logging.arjLoggerI18N] [com.arjuna.ats.arjuna.common.Uid_6] - Uid.generateHash called for invalid Uid. Will ignore. 2013-11-09 17:01:32,394 WARN [com.arjuna.ats.arjuna.logging.arjLoggerI18N] [com.arjuna.ats.arjuna.common.Uid_6] - Uid.generateHash called for invalid Uid. Will ignore. 2013-11-09 17:01:32,394 WARN [com.arjuna.ats.arjuna.logging.arjLoggerI18N] [com.arjuna.ats.arjuna.common.Uid_6] - Uid.generateHash called for invalid Uid. Will ignore. 2013-11-09 17:01:32,394 WARN [com.arjuna.ats.arjuna.logging.arjLoggerI18N] [com.arjuna.ats.arjuna.common.Uid_6] - Uid.generateHash called for invalid Uid. Will ignore. 2013-11-09 17:01:32,395 WARN [com.arjuna.ats.arjuna.logging.arjLoggerI18N] [com.arjuna.ats.arjuna.common.Uid_6] - Uid.generateHash called for invalid Uid. Will ignore. 2013-11-09 17:01:32,395 WARN [com.arjuna.ats.arjuna.logging.arjLoggerI18N] [com.arjuna.ats.arjuna.common.Uid_6] - Uid.generateHash called for invalid Uid. Will ignore. 2013-11-09 17:01:32,395 WARN [com.arjuna.ats.arjuna.logging.arjLoggerI18N] [com.arjuna.ats.arjuna.common.Uid_6] - Uid.generateHash called for invalid Uid. Will ignore. 2013-11-09 17:01:33,375 WARN [com.arjuna.ats.arjuna.logging.arjLoggerI18N] [com.arjuna.ats.arjuna.common.Uid_1] - cannot get local host. 2013-11-09 17:01:33,375 WARN [com.arjuna.ats.arjuna.logging.arjLoggerI18N] [com.arjuna.ats.arjuna.common.Uid_6] - Uid.generateHash called for invalid Uid. Will ignore. 2013-11-09 17:01:33,376 WARN [com.arjuna.ats.arjuna.logging.arjLoggerI18N] [com.arjuna.ats.arjuna.common.Uid_6] - Uid.generateHash called for invalid Uid. Will ignore. 2013-11-09 17:01:33,376 WARN [com.arjuna.ats.arjuna.logging.arjLoggerI18N] [com.arjuna.ats.arjuna.common.Uid_6] - Uid.generateHash called for invalid Uid. Will ignore. 2013-11-09 17:01:33,376 WARN [com.arjuna.ats.arjuna.logging.arjLoggerI18N] [com.arjuna.ats.arjuna.common.Uid_6] - Uid.generateHash called for invalid Uid. Will ignore. 2013-11-09 17:01:33,377 WARN [com.arjuna.ats.arjuna.logging.arjLoggerI18N] [com.arjuna.ats.arjuna.common.Uid_6] - Uid.generateHash called for invalid Uid. Will ignore. 2013-11-09 17:01:33,377 WARN [com.arjuna.ats.arjuna.logging.arjLoggerI18N] [com.arjuna.ats.arjuna.common.Uid_6] - Uid.generateHash called for invalid Uid. Will ignore. 2013-11-09 17:01:34,336 WARN [com.arjuna.ats.arjuna.logging.arjLoggerI18N] [com.arjuna.ats.arjuna.common.Uid_1] - cannot get local host. 2013-11-09 17:01:35,332 WARN [com.arjuna.ats.arjuna.logging.arjLoggerI18N] [com.arjuna.ats.arjuna.common.Uid_1] - cannot get local host. 2013-11-09 17:01:35,333 WARN [com.arjuna.ats.arjuna.logging.arjLoggerI18N] [com.arjuna.ats.arjuna.common.Uid_6] - Uid.generateHash called for invalid Uid. Will ignore. 2013-11-09 17:01:35,333 WARN [com.arjuna.ats.arjuna.logging.arjLoggerI18N] [com.arjuna.ats.arjuna.common.Uid_6] - Uid.generateHash called for invalid Uid. Will ignore. 2013-11-09 17:01:35,341 WARN [com.arjuna.ats.arjuna.logging.arjLoggerI18N] [com.arjuna.ats.arjuna.common.Uid_6] - Uid.generateHash called for invalid Uid. Will ignore. 2013-11-09 17:01:35,341 WARN [com.arjuna.ats.arjuna.logging.arjLoggerI18N] [com.arjuna.ats.arjuna.common.Uid_6] - Uid.generateHash called for invalid Uid. Will ignore. 2013-11-09 17:01:35,341 WARN [com.arjuna.ats.arjuna.logging.arjLoggerI18N] [com.arjuna.ats.arjuna.common.Uid_6] - Uid.generateHash called for invalid Uid. Will ignore. 2013-11-09 17:01:35,341 WARN [com.arjuna.ats.arjuna.logging.arjLoggerI18N] [com.arjuna.ats.arjuna.common.Uid_6] - Uid.generateHash called for invalid Uid. Will ignore. 2013-11-09 17:01:35,341 WARN [com.arjuna.ats.arjuna.logging.arjLoggerI18N] [com.arjuna.ats.arjuna.common.Uid_6] - Uid.generateHash called for invalid Uid. Will ignore. 2013-11-09 17:01:35,342 WARN [com.arjuna.ats.arjuna.logging.arjLoggerI18N] [com.arjuna.ats.arjuna.common.Uid_6] - Uid.generateHash called for invalid Uid. Will ignore. 2013-11-09 17:01:36,315 WARN [com.arjuna.ats.arjuna.logging.arjLoggerI18N] [com.arjuna.ats.arjuna.common.Uid_1] - cannot get local host. 2013-11-09 17:01:36,315 WARN [com.arjuna.ats.arjuna.logging.arjLoggerI18N] [com.arjuna.ats.arjuna.common.Uid_6] - Uid.generateHash called for invalid Uid. Will ignore. 2013-11-09 17:01:36,316 WARN [com.arjuna.ats.arjuna.logging.arjLoggerI18N] [com.arjuna.ats.arjuna.common.Uid_6] - Uid.generateHash called for invalid Uid. Will ignore. 2013-11-09 17:01:36,316 WARN [com.arjuna.ats.arjuna.logging.arjLoggerI18N] [com.arjuna.ats.arjuna.common.Uid_6] - Uid.generateHash called for invalid Uid. Will ignore. 2013-11-09 17:01:36,317 WARN [com.arjuna.ats.arjuna.logging.arjLoggerI18N] [com.arjuna.ats.arjuna.common.Uid_6] - Uid.generateHash called for invalid Uid. Will ignore. 2013-11-09 17:01:36,317 WARN [com.arjuna.ats.arjuna.logging.arjLoggerI18N] [com.arjuna.ats.arjuna.common.Uid_6] - Uid.generateHash called for invalid Uid. Will ignore. 2013-11-09 17:01:36,317 WARN [com.arjuna.ats.arjuna.logging.arjLoggerI18N] [com.arjuna.ats.arjuna.common.Uid_6] - Uid.generateHash called for invalid Uid. Will ignore. 2013-11-09 17:01:37,293 WARN [com.arjuna.ats.arjuna.logging.arjLoggerI18N] [com.arjuna.ats.arjuna.common.Uid_1] - cannot get local host. 2013-11-09 17:01:38,632 WARN [com.arjuna.ats.arjuna.logging.arjLoggerI18N] [com.arjuna.ats.arjuna.common.Uid_1] - cannot get local host. 2013-11-09 17:01:38,633 WARN [com.arjuna.ats.arjuna.logging.arjLoggerI18N] [com.arjuna.ats.arjuna.common.Uid_6] - Uid.generateHash called for invalid Uid. Will ignore. 2013-11-09 17:01:38,634 WARN [com.arjuna.ats.arjuna.logging.arjLoggerI18N] [com.arjuna.ats.arjuna.common.Uid_6] - Uid.generateHash called for invalid Uid. Will ignore. 2013-11-09 17:01:38,635 WARN [com.arjuna.ats.arjuna.logging.arjLoggerI18N] [com.arjuna.ats.arjuna.common.Uid_6] - Uid.generateHash called for invalid Uid. Will ignore. 2013-11-09 17:01:38,635 WARN [com.arjuna.ats.arjuna.logging.arjLoggerI18N] [com.arjuna.ats.arjuna.common.Uid_6] - Uid.generateHash called for invalid Uid. Will ignore. 2013-11-09 17:01:38,635 WARN [com.arjuna.ats.arjuna.logging.arjLoggerI18N] [com.arjuna.ats.arjuna.common.Uid_6] - Uid.generateHash called for invalid Uid. Will ignore. 2013-11-09 17:01:38,636 WARN [com.arjuna.ats.arjuna.logging.arjLoggerI18N] [com.arjuna.ats.arjuna.common.Uid_6] - Uid.generateHash called for invalid Uid. Will ignore. 2013-11-09 17:01:38,636 WARN [com.arjuna.ats.arjuna.logging.arjLoggerI18N] [com.arjuna.ats.arjuna.common.Uid_6] - Uid.generateHash called for invalid Uid. Will ignore. 2013-11-09 17:01:38,636 WARN [com.arjuna.ats.arjuna.logging.arjLoggerI18N] [com.arjuna.ats.arjuna.common.Uid_6] - Uid.generateHash called for invalid Uid. Will ignore. 2013-11-09 17:01:39,616 WARN [com.arjuna.ats.arjuna.logging.arjLoggerI18N] [com.arjuna.ats.arjuna.common.Uid_1] - cannot get local host. 2013-11-09 17:01:39,616 WARN [com.arjuna.ats.arjuna.logging.arjLoggerI18N] [com.arjuna.ats.arjuna.common.Uid_6] - Uid.generateHash called for invalid Uid. Will ignore. 2013-11-09 17:01:39,617 WARN [com.arjuna.ats.arjuna.logging.arjLoggerI18N] [com.arjuna.ats.arjuna.common.Uid_6] - Uid.generateHash called for invalid Uid. Will ignore. 2013-11-09 17:01:39,617 WARN [com.arjuna.ats.arjuna.logging.arjLoggerI18N] [com.arjuna.ats.arjuna.common.Uid_6] - Uid.generateHash called for invalid Uid. Will ignore. 2013-11-09 17:01:39,617 WARN [com.arjuna.ats.arjuna.logging.arjLoggerI18N] [com.arjuna.ats.arjuna.common.Uid_6] - Uid.generateHash called for invalid Uid. Will ignore. 2013-11-09 17:01:39,617 WARN [com.arjuna.ats.arjuna.logging.arjLoggerI18N] [com.arjuna.ats.arjuna.common.Uid_6] - Uid.generateHash called for invalid Uid. Will ignore. 2013-11-09 17:01:39,618 WARN [com.arjuna.ats.arjuna.logging.arjLoggerI18N] [com.arjuna.ats.arjuna.common.Uid_6] - Uid.generateHash called for invalid Uid. Will ignore. 2013-11-09 17:01:40,635 WARN [com.arjuna.ats.arjuna.logging.arjLoggerI18N] [com.arjuna.ats.arjuna.common.Uid_1] - cannot get local host. 2013-11-09 17:01:41,753 WARN [com.arjuna.ats.arjuna.logging.arjLoggerI18N] [com.arjuna.ats.arjuna.common.Uid_1] - cannot get local host. 2013-11-09 17:01:41,754 WARN [com.arjuna.ats.arjuna.logging.arjLoggerI18N] [com.arjuna.ats.arjuna.common.Uid_6] - Uid.generateHash called for invalid Uid. Will ignore. 2013-11-09 17:01:41,754 WARN [com.arjuna.ats.arjuna.logging.arjLoggerI18N] [com.arjuna.ats.arjuna.common.Uid_6] - Uid.generateHash called for invalid Uid. Will ignore. 2013-11-09 17:01:41,755 WARN [com.arjuna.ats.arjuna.logging.arjLoggerI18N] [com.arjuna.ats.arjuna.common.Uid_6] - Uid.generateHash called for invalid Uid. Will ignore. 2013-11-09 17:01:41,755 WARN [com.arjuna.ats.arjuna.logging.arjLoggerI18N] [com.arjuna.ats.arjuna.common.Uid_6] - Uid.generateHash called for invalid Uid. Will ignore. 2013-11-09 17:01:41,755 WARN [com.arjuna.ats.arjuna.logging.arjLoggerI18N] [com.arjuna.ats.arjuna.common.Uid_6] - Uid.generateHash called for invalid Uid. Will ignore. 2013-11-09 17:01:41,756 WARN [com.arjuna.ats.arjuna.logging.arjLoggerI18N] [com.arjuna.ats.arjuna.common.Uid_6] - Uid.generateHash called for invalid Uid. Will ignore. 2013-11-09 17:01:41,756 WARN [com.arjuna.ats.arjuna.logging.arjLoggerI18N] [com.arjuna.ats.arjuna.common.Uid_6] - Uid.generateHash called for invalid Uid. Will ignore. 2013-11-09 17:01:41,756 WARN [com.arjuna.ats.arjuna.logging.arjLoggerI18N] [com.arjuna.ats.arjuna.common.Uid_6] - Uid.generateHash called for invalid Uid. Will ignore. 2013-11-09 17:01:42,873 WARN [com.arjuna.ats.arjuna.logging.arjLoggerI18N] [com.arjuna.ats.arjuna.common.Uid_1] - cannot get local host. 2013-11-09 17:01:42,874 WARN [com.arjuna.ats.arjuna.logging.arjLoggerI18N] [com.arjuna.ats.arjuna.common.Uid_6] - Uid.generateHash called for invalid Uid. Will ignore. 2013-11-09 17:01:42,874 WARN [com.arjuna.ats.arjuna.logging.arjLoggerI18N] [com.arjuna.ats.arjuna.common.Uid_6] - Uid.generateHash called for invalid Uid. Will ignore. 2013-11-09 17:01:42,874 WARN [com.arjuna.ats.arjuna.logging.arjLoggerI18N] [com.arjuna.ats.arjuna.common.Uid_6] - Uid.generateHash called for invalid Uid. Will ignore. 2013-11-09 17:01:42,875 WARN [com.arjuna.ats.arjuna.logging.arjLoggerI18N] [com.arjuna.ats.arjuna.common.Uid_6] - Uid.generateHash called for invalid Uid. Will ignore. 2013-11-09 17:01:42,875 WARN [com.arjuna.ats.arjuna.logging.arjLoggerI18N] [com.arjuna.ats.arjuna.common.Uid_6] - Uid.generateHash called for invalid Uid. Will ignore. 2013-11-09 17:01:42,875 WARN [com.arjuna.ats.arjuna.logging.arjLoggerI18N] [com.arjuna.ats.arjuna.common.Uid_6] - Uid.generateHash called for invalid Uid. Will ignore. 2013-11-09 17:01:43,995 WARN [com.arjuna.ats.arjuna.logging.arjLoggerI18N] [com.arjuna.ats.arjuna.common.Uid_1] - cannot get local host. 2013-11-09 17:01:44,992 WARN [com.arjuna.ats.arjuna.logging.arjLoggerI18N] [com.arjuna.ats.arjuna.common.Uid_1] - cannot get local host. 2013-11-09 17:01:44,992 WARN [com.arjuna.ats.arjuna.logging.arjLoggerI18N] [com.arjuna.ats.arjuna.common.Uid_6] - Uid.generateHash called for invalid Uid. Will ignore. 2013-11-09 17:01:44,993 WARN [com.arjuna.ats.arjuna.logging.arjLoggerI18N] [com.arjuna.ats.arjuna.common.Uid_6] - Uid.generateHash called for invalid Uid. Will ignore. 2013-11-09 17:01:44,994 WARN [com.arjuna.ats.arjuna.logging.arjLoggerI18N] [com.arjuna.ats.arjuna.common.Uid_6] - Uid.generateHash called for invalid Uid. Will ignore. 2013-11-09 17:01:44,994 WARN [com.arjuna.ats.arjuna.logging.arjLoggerI18N] [com.arjuna.ats.arjuna.common.Uid_6] - Uid.generateHash called for invalid Uid. Will ignore. 2013-11-09 17:01:44,994 WARN [com.arjuna.ats.arjuna.logging.arjLoggerI18N] [com.arjuna.ats.arjuna.common.Uid_6] - Uid.generateHash called for invalid Uid. Will ignore. 2013-11-09 17:01:44,994 WARN [com.arjuna.ats.arjuna.logging.arjLoggerI18N] [com.arjuna.ats.arjuna.common.Uid_6] - Uid.generateHash called for invalid Uid. Will ignore. 2013-11-09 17:01:44,994 WARN [com.arjuna.ats.arjuna.logging.arjLoggerI18N] [com.arjuna.ats.arjuna.common.Uid_6] - Uid.generateHash called for invalid Uid. Will ignore. 2013-11-09 17:01:44,994 WARN [com.arjuna.ats.arjuna.logging.arjLoggerI18N] [com.arjuna.ats.arjuna.common.Uid_6] - Uid.generateHash called for invalid Uid. Will ignore. 2013-11-09 17:01:45,933 WARN [com.arjuna.ats.arjuna.logging.arjLoggerI18N] [com.arjuna.ats.arjuna.common.Uid_1] - cannot get local host. 2013-11-09 17:01:45,934 WARN [com.arjuna.ats.arjuna.logging.arjLoggerI18N] [com.arjuna.ats.arjuna.common.Uid_6] - Uid.generateHash called for invalid Uid. Will ignore. 2013-11-09 17:01:45,934 WARN [com.arjuna.ats.arjuna.logging.arjLoggerI18N] [com.arjuna.ats.arjuna.common.Uid_6] - Uid.generateHash called for invalid Uid. Will ignore. 2013-11-09 17:01:45,935 WARN [com.arjuna.ats.arjuna.logging.arjLoggerI18N] [com.arjuna.ats.arjuna.common.Uid_6] - Uid.generateHash called for invalid Uid. Will ignore. 2013-11-09 17:01:45,935 WARN [com.arjuna.ats.arjuna.logging.arjLoggerI18N] [com.arjuna.ats.arjuna.common.Uid_6] - Uid.generateHash called for invalid Uid. Will ignore. 2013-11-09 17:01:45,936 WARN [com.arjuna.ats.arjuna.logging.arjLoggerI18N] [com.arjuna.ats.arjuna.common.Uid_6] - Uid.generateHash called for invalid Uid. Will ignore. 2013-11-09 17:01:45,936 WARN [com.arjuna.ats.arjuna.logging.arjLoggerI18N] [com.arjuna.ats.arjuna.common.Uid_6] - Uid.generateHash called for invalid Uid. Will ignore. 2013-11-09 17:01:46,894 WARN [com.arjuna.ats.arjuna.logging.arjLoggerI18N] [com.arjuna.ats.arjuna.common.Uid_1] - cannot get local host. 2013-11-09 17:01:47,872 WARN [com.arjuna.ats.arjuna.logging.arjLoggerI18N] [com.arjuna.ats.arjuna.common.Uid_1] - cannot get local host. 2013-11-09 17:01:47,872 WARN [com.arjuna.ats.arjuna.logging.arjLoggerI18N] [com.arjuna.ats.arjuna.common.Uid_6] - Uid.generateHash called for invalid Uid. Will ignore. 2013-11-09 17:01:47,873 WARN [com.arjuna.ats.arjuna.logging.arjLoggerI18N] [com.arjuna.ats.arjuna.common.Uid_6] - Uid.generateHash called for invalid Uid. Will ignore. 2013-11-09 17:01:47,874 WARN [com.arjuna.ats.arjuna.logging.arjLoggerI18N] [com.arjuna.ats.arjuna.common.Uid_6] - Uid.generateHash called for invalid Uid. Will ignore. 2013-11-09 17:01:47,874 WARN [com.arjuna.ats.arjuna.logging.arjLoggerI18N] [com.arjuna.ats.arjuna.common.Uid_6] - Uid.generateHash called for invalid Uid. Will ignore. 2013-11-09 17:01:47,874 WARN [com.arjuna.ats.arjuna.logging.arjLoggerI18N] [com.arjuna.ats.arjuna.common.Uid_6] - Uid.generateHash called for invalid Uid. Will ignore. 2013-11-09 17:01:47,874 WARN [com.arjuna.ats.arjuna.logging.arjLoggerI18N] [com.arjuna.ats.arjuna.common.Uid_6] - Uid.generateHash called for invalid Uid. Will ignore. 2013-11-09 17:01:47,874 WARN [com.arjuna.ats.arjuna.logging.arjLoggerI18N] [com.arjuna.ats.arjuna.common.Uid_6] - Uid.generateHash called for invalid Uid. Will ignore. 2013-11-09 17:01:47,875 WARN [com.arjuna.ats.arjuna.logging.arjLoggerI18N] [com.arjuna.ats.arjuna.common.Uid_6] - Uid.generateHash called for invalid Uid. Will ignore. 2013-11-09 17:01:48,732 WARN [org.jboss.system.server.profileservice.ProfileServiceBootstrap] Error deactivating profile: ProfileKey@20dbd794[domain=default, server=default, name=default] org.jboss.profileservice.spi.NoSuchProfileException: No active profile for: ProfileKey@20dbd794[domain=default, server=default, name=default] at org.jboss.system.server.profileservice.repository.AbstractProfileService.deactivateProfile(AbstractProfileService.java:391) at org.jboss.system.server.profileservice.ProfileServiceBootstrap.shutdown(ProfileServiceBootstrap.java:327) at org.jboss.bootstrap.AbstractServerImpl.shutdownServer(AbstractServerImpl.java:571) at org.jboss.bootstrap.AbstractServerImpl$ShutdownHook.run(AbstractServerImpl.java:909) 2013-11-09 17:01:48,861 INFO [org.apache.catalina.core.StandardService] Stopping service jboss.web 2013-11-09 17:01:48,873 WARN [com.arjuna.ats.arjuna.logging.arjLoggerI18N] [com.arjuna.ats.arjuna.common.Uid_1] - cannot get local host. 2013-11-09 17:01:48,874 WARN [com.arjuna.ats.arjuna.logging.arjLoggerI18N] [com.arjuna.ats.arjuna.common.Uid_6] - Uid.generateHash called for invalid Uid. Will ignore. 2013-11-09 17:01:48,874 WARN [com.arjuna.ats.arjuna.logging.arjLoggerI18N] [com.arjuna.ats.arjuna.common.Uid_6] - Uid.generateHash called for invalid Uid. Will ignore. 2013-11-09 17:01:48,874 WARN [com.arjuna.ats.arjuna.logging.arjLoggerI18N] [com.arjuna.ats.arjuna.common.Uid_6] - Uid.generateHash called for invalid Uid. Will ignore. 2013-11-09 17:01:48,874 WARN [com.arjuna.ats.arjuna.logging.arjLoggerI18N] [com.arjuna.ats.arjuna.common.Uid_6] - Uid.generateHash called for invalid Uid. Will ignore. 2013-11-09 17:01:48,875 WARN [com.arjuna.ats.arjuna.logging.arjLoggerI18N] [com.arjuna.ats.arjuna.common.Uid_6] - Uid.generateHash called for invalid Uid. Will ignore. 2013-11-09 17:01:48,875 WARN [com.arjuna.ats.arjuna.logging.arjLoggerI18N] [com.arjuna.ats.arjuna.common.Uid_6] - Uid.generateHash called for invalid Uid. Will ignore. 2013-11-09 17:01:48,875 WARN [com.arjuna.ats.arjuna.logging.arjLoggerI18N] [com.arjuna.ats.arjuna.common.Uid_6] - Uid.generateHash called for invalid Uid. Will ignore. 2013-11-09 17:01:48,875 WARN [com.arjuna.ats.arjuna.logging.arjLoggerI18N] [com.arjuna.ats.arjuna.common.Uid_6] - Uid.generateHash called for invalid Uid. Will ignore. 2013-11-09 17:01:50,101 WARN [com.arjuna.ats.arjuna.logging.arjLoggerI18N] [com.arjuna.ats.arjuna.common.Uid_1] - cannot get local host. 2013-11-09 17:01:50,230 INFO [org.quartz.core.QuartzScheduler] Scheduler DefaultQuartzScheduler$NON_CLUSTERED shutting down. 2013-11-09 17:01:50,230 INFO [org.quartz.core.QuartzScheduler] Scheduler DefaultQuartzScheduler$NON_CLUSTERED paused. 2013-11-09 17:01:50,233 INFO [org.quartz.simpl.SimpleThreadPool] There are still 16 worker threads active. See javadoc runInThread(Runnable) for a possible explanation 2013-11-09 17:01:50,233 INFO [org.quartz.core.QuartzScheduler] Scheduler DefaultQuartzScheduler$_NON_CLUSTERED shutdown complete. 2013-11-09 17:01:51,052 WARN [com.arjuna.ats.arjuna.logging.arjLoggerI18N] [com.arjuna.ats.arjuna.common.Uid_1] - cannot get local host. 2013-11-09 17:01:51,055 WARN [com.arjuna.ats.arjuna.logging.arjLoggerI18N] [com.arjuna.ats.arjuna.common.Uid_6] - Uid.generateHash called for invalid Uid. Will ignore. 2013-11-09 17:01:51,056 WARN [com.arjuna.ats.arjuna.logging.arjLoggerI18N] [com.arjuna.ats.arjuna.common.Uid_6] - Uid.generateHash called for invalid Uid. Will ignore. 2013-11-09 17:01:51,056 WARN [com.arjuna.ats.arjuna.logging.arjLoggerI18N] [com.arjuna.ats.arjuna.common.Uid_6] - Uid.generateHash called for invalid Uid. Will ignore. 2013-11-09 17:01:51,057 WARN [com.arjuna.ats.arjuna.logging.arjLoggerI18N] [com.arjuna.ats.arjuna.common.Uid_6] - Uid.generateHash called for invalid Uid. Will ignore. 2013-11-09 17:01:51,058 WARN [com.arjuna.ats.arjuna.logging.arjLoggerI18N] [com.arjuna.ats.arjuna.common.Uid_6] - Uid.generateHash called for invalid Uid. Will ignore. 2013-11-09 17:01:51,063 ERROR [org.jboss.messaging.util.ExceptionUtil] org.jboss.messaging.core.jmx.JDBCPersistenceManagerService@330b9bfe startService org.jboss.util.NestedSQLException: No transaction manager: jboss.jca:service=CachedConnectionManager; - nested throwable: (java.lang.IllegalStateException: No transaction manager: jboss.jca:service=CachedConnectionManager) at org.jboss.resource.adapter.jdbc.WrapperDataSource.checkTransactionActive(WrapperDataSource.java:165) at org.jboss.resource.adapter.jdbc.WrappedConnection.checkTransactionActive(WrappedConnection.java:833) at org.jboss.resource.adapter.jdbc.WrappedConnection.checkStatus(WrappedConnection.java:848) at org.jboss.resource.adapter.jdbc.WrappedConnection.getTransactionIsolation(WrappedConnection.java:604) at org.jboss.messaging.core.impl.JDBCPersistenceManager.start(JDBCPersistenceManager.java:162) at org.jboss.messaging.core.jmx.JDBCPersistenceManagerService.startService(JDBCPersistenceManagerService.java:100) at org.jboss.system.ServiceMBeanSupport.jbossInternalStart(ServiceMBeanSupport.java:376) at org.jboss.system.ServiceMBeanSupport.start(ServiceMBeanSupport.java:269) at sun.reflect.NativeMethodAccessorImpl.invoke0(Native Method) at sun.reflect.NativeMethodAccessorImpl.invoke(NativeMethodAccessorImpl.java:57) at sun.reflect.DelegatingMethodAccessorImpl.invoke(DelegatingMethodAccessorImpl.java:43) at java.lang.reflect.Method.invoke(Method.java:616) at org.jboss.mx.interceptor.ReflectedDispatcher.invoke(ReflectedDispatcher.java:157) at org.jboss.mx.server.Invocation.dispatch(Invocation.java:96) at org.jboss.mx.interceptor.AbstractInterceptor.invoke(AbstractInterceptor.java:138) at org.jboss.mx.server.Invocation.invoke(Invocation.java:90) at org.jboss.mx.interceptor.ModelMBeanOperationInterceptor.invoke(ModelMBeanOperationInterceptor.java:140) at org.jboss.mx.server.Invocation.invoke(Invocation.java:90) at org.jboss.mx.server.AbstractMBeanInvoker.invoke(AbstractMBeanInvoker.java:264) at org.jboss.mx.server.MBeanServerImpl.invoke(MBeanServerImpl.java:668) at org.jboss.system.microcontainer.ServiceProxy.invoke(ServiceProxy.java:206) at sun.proxy.$Proxy38.start(Unknown Source) at org.jboss.system.microcontainer.StartStopLifecycleAction.installAction(StartStopLifecycleAction.java:42) at org.jboss.system.microcontainer.StartStopLifecycleAction.installAction(StartStopLifecycleAction.java:37) at org.jboss.dependency.plugins.action.SimpleControllerContextAction.simpleInstallAction(SimpleControllerContextAction.java:62) at org.jboss.dependency.plugins.action.AccessControllerContextAction.install(AccessControllerContextAction.java:71) at org.jboss.dependency.plugins.AbstractControllerContextActions.install(AbstractControllerContextActions.java:51) at org.jboss.dependency.plugins.AbstractControllerContext.install(AbstractControllerContext.java:348) at org.jboss.system.microcontainer.ServiceControllerContext.install(ServiceControllerContext.java:286) at org.jboss.dependency.plugins.AbstractController.install(AbstractController.java:1631) at org.jboss.dependency.plugins.AbstractController.incrementState(AbstractController.java:934) at org.jboss.dependency.plugins.AbstractController.resolveContexts(AbstractController.java:1082) at org.jboss.dependency.plugins.AbstractController.resolveContexts(AbstractController.java:984) at org.jboss.dependency.plugins.AbstractController.change(AbstractController.java:822) at org.jboss.dependency.plugins.AbstractController.change(AbstractController.java:553) at org.jboss.system.ServiceController.doChange(ServiceController.java:688) at org.jboss.system.ServiceController.start(ServiceController.java:460) at org.jboss.system.deployers.ServiceDeployer.start(ServiceDeployer.java:163) at org.jboss.system.deployers.ServiceDeployer.deploy(ServiceDeployer.java:99) at org.jboss.system.deployers.ServiceDeployer.deploy(ServiceDeployer.java:46) at org.jboss.deployers.spi.deployer.helpers.AbstractSimpleRealDeployer.internalDeploy(AbstractSimpleRealDeployer.java:62) at org.jboss.deployers.spi.deployer.helpers.AbstractRealDeployer.deploy(AbstractRealDeployer.java:50) at org.jboss.deployers.plugins.deployers.DeployerWrapper.deploy(DeployerWrapper.java:171) at org.jboss.deployers.plugins.deployers.DeployersImpl.doDeploy(DeployersImpl.java:1439) at org.jboss.deployers.plugins.deployers.DeployersImpl.doInstallParentFirst(DeployersImpl.java:1157) at org.jboss.deployers.plugins.deployers.DeployersImpl.doInstallParentFirst(DeployersImpl.java:1178) at org.jboss.deployers.plugins.deployers.DeployersImpl.install(DeployersImpl.java:1098) at org.jboss.dependency.plugins.AbstractControllerContext.install(AbstractControllerContext.java:348) at org.jboss.dependency.plugins.AbstractController.install(AbstractController.java:1631) at org.jboss.dependency.plugins.AbstractController.incrementState(AbstractController.java:934) at org.jboss.dependency.plugins.AbstractController.resolveContexts(AbstractController.java:1082) at org.jboss.dependency.plugins.AbstractController.resolveContexts(AbstractController.java:984) at org.jboss.dependency.plugins.AbstractController.change(AbstractController.java:822) at org.jboss.dependency.plugins.AbstractController.change(AbstractController.java:553) at org.jboss.deployers.plugins.deployers.DeployersImpl.process(DeployersImpl.java:781) at org.jboss.deployers.plugins.main.MainDeployerImpl.process(MainDeployerImpl.java:702) at org.jboss.system.server.profileservice.repository.MainDeployerAdapter.process(MainDeployerAdapter.java:117) at org.jboss.system.server.profileservice.repository.ProfileDeployAction.install(ProfileDeployAction.java:70) at org.jboss.system.server.profileservice.repository.AbstractProfileAction.install(AbstractProfileAction.java:53) at org.jboss.system.server.profileservice.repository.AbstractProfileService.install(AbstractProfileService.java:361) at org.jboss.dependency.plugins.AbstractControllerContext.install(AbstractControllerContext.java:348) at org.jboss.dependency.plugins.AbstractController.install(AbstractController.java:1631) at org.jboss.dependency.plugins.AbstractController.incrementState(AbstractController.java:934) at org.jboss.dependency.plugins.AbstractController.resolveContexts(AbstractController.java:1082) at org.jboss.dependency.plugins.AbstractController.resolveContexts(AbstractController.java:984) at org.jboss.dependency.plugins.AbstractController.change(AbstractController.java:822) at org.jboss.dependency.plugins.AbstractController.change(AbstractController.java:553) at org.jboss.system.server.profileservice.repository.AbstractProfileService.activateProfile(AbstractProfileService.java:306) at org.jboss.system.server.profileservice.ProfileServiceBootstrap.start(ProfileServiceBootstrap.java:271) at org.jboss.bootstrap.AbstractServerImpl.start(AbstractServerImpl.java:461) at org.jboss.Main.boot(Main.java:221) at org.jboss.Main$1.run(Main.java:556) at java.lang.Thread.run(Thread.java:679) Caused by: java.lang.IllegalStateException: No transaction manager: jboss.jca:service=CachedConnectionManager at org.jboss.resource.connectionmanager.TxConnectionManager.checkTransactionActive(TxConnectionManager.java:325) at org.jboss.resource.connectionmanager.BaseConnectionManager2$ConnectionManagerProxy.checkTransactionActive(BaseConnectionManager2.java:972) at org.jboss.resource.adapter.jdbc.WrapperDataSource.checkTransactionActive(WrapperDataSource.java:161) ... 72 more 2013-11-09 17:01:51,067 ERROR [org.jboss.kernel.plugins.dependency.AbstractKernelController] Error installing to Start: name=jboss.messaging:service=PersistenceManager state=Configured mode=Manual requiredState=Installed org.jboss.util.NestedSQLException: No transaction manager: jboss.jca:service=CachedConnectionManager; - nested throwable: (java.lang.IllegalStateException: No transaction manager: jboss.jca:service=CachedConnectionManager) at org.jboss.resource.adapter.jdbc.WrapperDataSource.checkTransactionActive(WrapperDataSource.java:165) at org.jboss.resource.adapter.jdbc.WrappedConnection.checkTransactionActive(WrappedConnection.java:833) at org.jboss.resource.adapter.jdbc.WrappedConnection.checkStatus(WrappedConnection.java:848) at org.jboss.resource.adapter.jdbc.WrappedConnection.getTransactionIsolation(WrappedConnection.java:604) at org.jboss.messaging.core.impl.JDBCPersistenceManager.start(JDBCPersistenceManager.java:162) at org.jboss.messaging.core.jmx.JDBCPersistenceManagerService.startService(JDBCPersistenceManagerService.java:100) at org.jboss.system.ServiceMBeanSupport.jbossInternalStart(ServiceMBeanSupport.java:376) at org.jboss.system.ServiceMBeanSupport.start(ServiceMBeanSupport.java:269) at sun.reflect.NativeMethodAccessorImpl.invoke0(Native Method) at sun.reflect.NativeMethodAccessorImpl.invoke(NativeMethodAccessorImpl.java:57) at sun.reflect.DelegatingMethodAccessorImpl.invoke(DelegatingMethodAccessorImpl.java:43) at java.lang.reflect.Method.invoke(Method.java:616) at org.jboss.mx.interceptor.ReflectedDispatcher.invoke(ReflectedDispatcher.java:157) at org.jboss.mx.server.Invocation.dispatch(Invocation.java:96) at org.jboss.mx.interceptor.AbstractInterceptor.invoke(AbstractInterceptor.java:138) at org.jboss.mx.server.Invocation.invoke(Invocation.java:90) at org.jboss.mx.interceptor.ModelMBeanOperationInterceptor.invoke(ModelMBeanOperationInterceptor.java:140) at org.jboss.mx.server.Invocation.invoke(Invocation.java:90) at org.jboss.mx.server.AbstractMBeanInvoker.invoke(AbstractMBeanInvoker.java:264) at org.jboss.mx.server.MBeanServerImpl.invoke(MBeanServerImpl.java:668) at org.jboss.system.microcontainer.ServiceProxy.invoke(ServiceProxy.java:206) at sun.proxy.$Proxy38.start(Unknown Source) at org.jboss.system.microcontainer.StartStopLifecycleAction.installAction(StartStopLifecycleAction.java:42) at org.jboss.system.microcontainer.StartStopLifecycleAction.installAction(StartStopLifecycleAction.java:37) at org.jboss.dependency.plugins.action.SimpleControllerContextAction.simpleInstallAction(SimpleControllerContextAction.java:62) at org.jboss.dependency.plugins.action.AccessControllerContextAction.install(AccessControllerContextAction.java:71) at org.jboss.dependency.plugins.AbstractControllerContextActions.install(AbstractControllerContextActions.java:51) at org.jboss.dependency.plugins.AbstractControllerContext.install(AbstractControllerContext.java:348) at org.jboss.system.microcontainer.ServiceControllerContext.install(ServiceControllerContext.java:286) at org.jboss.dependency.plugins.AbstractController.install(AbstractController.java:1631) at org.jboss.dependency.plugins.AbstractController.incrementState(AbstractController.java:934) at org.jboss.dependency.plugins.AbstractController.resolveContexts(AbstractController.java:1082) at org.jboss.dependency.plugins.AbstractController.resolveContexts(AbstractController.java:984) at org.jboss.dependency.plugins.AbstractController.change(AbstractController.java:822) at org.jboss.dependency.plugins.AbstractController.change(AbstractController.java:553) at org.jboss.system.ServiceController.doChange(ServiceController.java:688) at org.jboss.system.ServiceController.start(ServiceController.java:460) at org.jboss.system.deployers.ServiceDeployer.start(ServiceDeployer.java:163) at org.jboss.system.deployers.ServiceDeployer.deploy(ServiceDeployer.java:99) at org.jboss.system.deployers.ServiceDeployer.deploy(ServiceDeployer.java:46) at org.jboss.deployers.spi.deployer.helpers.AbstractSimpleRealDeployer.internalDeploy(AbstractSimpleRealDeployer.java:62) at org.jboss.deployers.spi.deployer.helpers.AbstractRealDeployer.deploy(AbstractRealDeployer.java:50) at org.jboss.deployers.plugins.deployers.DeployerWrapper.deploy(DeployerWrapper.java:171) at org.jboss.deployers.plugins.deployers.DeployersImpl.doDeploy(DeployersImpl.java:1439) at org.jboss.deployers.plugins.deployers.DeployersImpl.doInstallParentFirst(DeployersImpl.java:1157) at org.jboss.deployers.plugins.deployers.DeployersImpl.doInstallParentFirst(DeployersImpl.java:1178) at org.jboss.deployers.plugins.deployers.DeployersImpl.install(DeployersImpl.java:1098) at org.jboss.dependency.plugins.AbstractControllerContext.install(AbstractControllerContext.java:348) at org.jboss.dependency.plugins.AbstractController.install(AbstractController.java:1631) at org.jboss.dependency.plugins.AbstractController.incrementState(AbstractController.java:934) at org.jboss.dependency.plugins.AbstractController.resolveContexts(AbstractController.java:1082) at org.jboss.dependency.plugins.AbstractController.resolveContexts(AbstractController.java:984) at org.jboss.dependency.plugins.AbstractController.change(AbstractController.java:822) at org.jboss.dependency.plugins.AbstractController.change(AbstractController.java:553) at org.jboss.deployers.plugins.deployers.DeployersImpl.process(DeployersImpl.java:781) at org.jboss.deployers.plugins.main.MainDeployerImpl.process(MainDeployerImpl.java:702) at org.jboss.system.server.profileservice.repository.MainDeployerAdapter.process(MainDeployerAdapter.java:117) at org.jboss.system.server.profileservice.repository.ProfileDeployAction.install(ProfileDeployAction.java:70) at org.jboss.system.server.profileservice.repository.AbstractProfileAction.install(AbstractProfileAction.java:53) at org.jboss.system.server.profileservice.repository.AbstractProfileService.install(AbstractProfileService.java:361) at org.jboss.dependency.plugins.AbstractControllerContext.install(AbstractControllerContext.java:348) at org.jboss.dependency.plugins.AbstractController.install(AbstractController.java:1631) at org.jboss.dependency.plugins.AbstractController.incrementState(AbstractController.java:934) at org.jboss.dependency.plugins.AbstractController.resolveContexts(AbstractController.java:1082) at org.jboss.dependency.plugins.AbstractController.resolveContexts(AbstractController.java:984) at org.jboss.dependency.plugins.AbstractController.change(AbstractController.java:822) at org.jboss.dependency.plugins.AbstractController.change(AbstractController.java:553) at org.jboss.system.server.profileservice.repository.AbstractProfileService.activateProfile(AbstractProfileService.java:306) at org.jboss.system.server.profileservice.ProfileServiceBootstrap.start(ProfileServiceBootstrap.java:271) at org.jboss.bootstrap.AbstractServerImpl.start(AbstractServerImpl.java:461) at org.jboss.Main.boot(Main.java:221) at org.jboss.Main$1.run(Main.java:556) at java.lang.Thread.run(Thread.java:679) Caused by: java.lang.IllegalStateException: No transaction manager: jboss.jca:service=CachedConnectionManager at org.jboss.resource.connectionmanager.TxConnectionManager.checkTransactionActive(TxConnectionManager.java:325) at org.jboss.resource.connectionmanager.BaseConnectionManager2$ConnectionManagerProxy.checkTransactionActive(BaseConnectionManager2.java:972) at org.jboss.resource.adapter.jdbc.WrapperDataSource.checkTransactionActive(WrapperDataSource.java:161) ... 72 more 2013-11-09 17:01:51,090 ERROR [org.jboss.kernel.plugins.dependency.AbstractKernelController] Error installing to Instantiated: name=jboss.jdbc:datasource=DefaultDS,service=metadata state=Described mode=Manual requiredState=Configured java.lang.ClassNotFoundException: org.jboss.ejb.plugins.cmp.jdbc.metadata.DataSourceMetaData from BaseClassLoader@afe676b{VFSClassLoaderPolicy@4437a770{name=vfsfile:/home/epankmi/Desktop/nuxeo-dm-5.4.0_01-jboss/nuxeo-dm-5.4.0.1-jboss/server/default/deploy/hsqldb-ds.xml domain=ClassLoaderDomain@4ee14d81{name=DefaultDomain parentPolicy=BEFORE parent=org.jboss.bootstrap.NoAnnotationURLClassLoader@b61d36b} roots=[MemoryContextHandler@567397645[path= context=vfsmemory://0000-u2t9zl-hnsru2sk-1-hnsrujjq-25 real=vfsmemory://0000-u2t9zl-hnsru2sk-1-hnsrujjq-25]] delegates=null exported=[] NON_EMPTY}} at org.jboss.classloader.spi.base.BaseClassLoader.loadClass(BaseClassLoader.java:448) at java.lang.ClassLoader.loadClass(ClassLoader.java:266) at org.jboss.mx.server.MBeanServerImpl.instantiate(MBeanServerImpl.java:1213) at org.jboss.mx.server.MBeanServerImpl.instantiate(MBeanServerImpl.java:286) at org.jboss.mx.server.MBeanServerImpl.createMBean(MBeanServerImpl.java:344) at org.jboss.system.ServiceCreator.installPlainMBean(ServiceCreator.java:211) at org.jboss.system.ServiceCreator.install(ServiceCreator.java:130) at org.jboss.system.microcontainer.InstantiateAction.installAction(InstantiateAction.java:45) at org.jboss.system.microcontainer.InstantiateAction.installAction(InstantiateAction.java:37) at org.jboss.dependency.plugins.action.SimpleControllerContextAction.simpleInstallAction(SimpleControllerContextAction.java:62) at org.jboss.dependency.plugins.action.AccessControllerContextAction.install(AccessControllerContextAction.java:71) at org.jboss.dependency.plugins.AbstractControllerContextActions.install(AbstractControllerContextActions.java:51) at org.jboss.dependency.plugins.AbstractControllerContext.install(AbstractControllerContext.java:348) at org.jboss.system.microcontainer.ServiceControllerContext.install(ServiceControllerContext.java:286) at org.jboss.dependency.plugins.AbstractController.install(AbstractController.java:1631) at org.jboss.dependency.plugins.AbstractController.incrementState(AbstractController.java:934) at org.jboss.dependency.plugins.AbstractController.resolveContexts(AbstractController.java:1082) at org.jboss.dependency.plugins.AbstractController.resolveContexts(AbstractController.java:984) at org.jboss.dependency.plugins.AbstractController.change(AbstractController.java:822) at org.jboss.dependency.plugins.AbstractController.change(AbstractController.java:553) at org.jboss.system.ServiceController.doChange(ServiceController.java:688) at org.jboss.system.ServiceController.install(ServiceController.java:274) at org.jboss.system.deployers.ServiceDeployer.deploy(ServiceDeployer.java:90) at org.jboss.system.deployers.ServiceDeployer.deploy(ServiceDeployer.java:46) at org.jboss.deployers.spi.deployer.helpers.AbstractSimpleRealDeployer.internalDeploy(AbstractSimpleRealDeployer.java:62) at org.jboss.deployers.spi.deployer.helpers.AbstractRealDeployer.deploy(AbstractRealDeployer.java:50) at org.jboss.deployers.plugins.deployers.DeployerWrapper.deploy(DeployerWrapper.java:171) at org.jboss.deployers.plugins.deployers.DeployersImpl.doDeploy(DeployersImpl.java:1439) at org.jboss.deployers.plugins.deployers.DeployersImpl.doInstallParentFirst(DeployersImpl.java:1157) at org.jboss.deployers.plugins.deployers.DeployersImpl.doInstallParentFirst(DeployersImpl.java:1178) at org.jboss.deployers.plugins.deployers.DeployersImpl.install(DeployersImpl.java:1098) at org.jboss.dependency.plugins.AbstractControllerContext.install(AbstractControllerContext.java:348) at org.jboss.dependency.plugins.AbstractController.install(AbstractController.java:1631) at org.jboss.dependency.plugins.AbstractController.incrementState(AbstractController.java:934) at org.jboss.dependency.plugins.AbstractController.resolveContexts(AbstractController.java:1082) at org.jboss.dependency.plugins.AbstractController.resolveContexts(AbstractController.java:984) at org.jboss.dependency.plugins.AbstractController.change(AbstractController.java:822) at org.jboss.dependency.plugins.AbstractController.change(AbstractController.java:553) at org.jboss.deployers.plugins.deployers.DeployersImpl.process(DeployersImpl.java:781) at org.jboss.deployers.plugins.main.MainDeployerImpl.process(MainDeployerImpl.java:702) at org.jboss.system.server.profileservice.repository.MainDeployerAdapter.process(MainDeployerAdapter.java:117) at org.jboss.system.server.profileservice.repository.ProfileDeployAction.install(ProfileDeployAction.java:70) at org.jboss.system.server.profileservice.repository.AbstractProfileAction.install(AbstractProfileAction.java:53) at org.jboss.system.server.profileservice.repository.AbstractProfileService.install(AbstractProfileService.java:361) at org.jboss.dependency.plugins.AbstractControllerContext.install(AbstractControllerContext.java:348) at org.jboss.dependency.plugins.AbstractController.install(AbstractController.java:1631) at org.jboss.dependency.plugins.AbstractController.incrementState(AbstractController.java:934) at org.jboss.dependency.plugins.AbstractController.resolveContexts(AbstractController.java:1082) at org.jboss.dependency.plugins.AbstractController.resolveContexts(AbstractController.java:984) at org.jboss.dependency.plugins.AbstractController.change(AbstractController.java:822) at org.jboss.dependency.plugins.AbstractController.change(AbstractController.java:553) at org.jboss.system.server.profileservice.repository.AbstractProfileService.activateProfile(AbstractProfileService.java:306) at org.jboss.system.server.profileservice.ProfileServiceBootstrap.start(ProfileServiceBootstrap.java:271) at org.jboss.bootstrap.AbstractServerImpl.start(AbstractServerImpl.java:461) at org.jboss.Main.boot(Main.java:221) at org.jboss.Main$1.run(Main.java:556) at java.lang.Thread.run(Thread.java:679) 2013-11-09 17:01:51,331 WARN [org.jboss.jdbc.HypersonicDatabase] Stopping failed jboss:service=Hypersonic,database=localDB java.sql.SQLException: General error: java.lang.IllegalStateException: BaseClassLoader@1367f48c{vfsfile:/home/epankmi/Desktop/nuxeo-dm-5.4.0_01-jboss/nuxeo-dm-5.4.0.1-jboss/server/default/conf/jboss-service.xml} classLoader is not connected to a domain (probably undeployed?) for class java.io.DataInput in statement [SHUTDOWN COMPACT] at org.hsqldb.jdbc.Util.sqlException(Unknown Source) at org.hsqldb.jdbc.jdbcStatement.fetchResult(Unknown Source) at org.hsqldb.jdbc.jdbcStatement.executeQuery(Unknown Source) at org.jboss.jdbc.HypersonicDatabase.stopStandaloneDatabase(HypersonicDatabase.java:713) at org.jboss.jdbc.HypersonicDatabase.stopService(HypersonicDatabase.java:590) at org.jboss.system.ServiceMBeanSupport.jbossInternalStop(ServiceMBeanSupport.java:405) at org.jboss.system.ServiceMBeanSupport.jbossInternalLifecycle(ServiceMBeanSupport.java:324) at sun.reflect.GeneratedMethodAccessor81.invoke(Unknown Source) at sun.reflect.DelegatingMethodAccessorImpl.invoke(DelegatingMethodAccessorImpl.java:43) at java.lang.reflect.Method.invoke(Method.java:616) at org.jboss.mx.interceptor.ReflectedDispatcher.invoke(ReflectedDispatcher.java:157) at org.jboss.mx.server.Invocation.dispatch(Invocation.java:96) at org.jboss.mx.server.Invocation.invoke(Invocation.java:88) at org.jboss.mx.server.AbstractMBeanInvoker.invoke(AbstractMBeanInvoker.java:264) at org.jboss.mx.server.MBeanServerImpl.invoke(MBeanServerImpl.java:668) at org.jboss.system.microcontainer.ServiceProxy.invoke(ServiceProxy.java:189) at sun.proxy.$Proxy38.stop(Unknown Source) at org.jboss.system.microcontainer.StartStopLifecycleAction.uninstallAction(StartStopLifecycleAction.java:56) at org.jboss.system.microcontainer.StartStopLifecycleAction.uninstallAction(StartStopLifecycleAction.java:37) at org.jboss.dependency.plugins.action.SimpleControllerContextAction.simpleUninstallAction(SimpleControllerContextAction.java:79) at org.jboss.dependency.plugins.action.AccessControllerContextAction.uninstall(AccessControllerContextAction.java:131) at org.jboss.dependency.plugins.AbstractControllerContextActions.uninstall(AbstractControllerContextActions.java:58) at org.jboss.dependency.plugins.AbstractControllerContext.uninstall(AbstractControllerContext.java:354) at org.jboss.dependency.plugins.AbstractController.uninstall(AbstractController.java:1664) at org.jboss.dependency.plugins.AbstractController.uninstallContext(AbstractController.java:1275) at org.jboss.dependency.plugins.AbstractController.change(AbstractController.java:827) at org.jboss.dependency.plugins.AbstractController.change(AbstractController.java:553) at org.jboss.system.ServiceController.doChange(ServiceController.java:688) at org.jboss.system.ServiceController.stop(ServiceController.java:510) at org.jboss.system.deployers.ServiceDeployer.stop(ServiceDeployer.java:170) at org.jboss.system.deployers.ServiceDeployer.undeploy(ServiceDeployer.java:150) at org.jboss.system.deployers.ServiceDeployer.undeploy(ServiceDeployer.java:46) at org.jboss.deployers.spi.deployer.helpers.AbstractSimpleRealDeployer.internalUndeploy(AbstractSimpleRealDeployer.java:69) at org.jboss.deployers.spi.deployer.helpers.AbstractRealDeployer.undeploy(AbstractRealDeployer.java:112) at org.jboss.deployers.plugins.deployers.DeployerWrapper.undeploy(DeployerWrapper.java:196) at org.jboss.deployers.plugins.deployers.DeployersImpl.doUndeploy(DeployersImpl.java:1469) at org.jboss.deployers.plugins.deployers.DeployersImpl.doUninstallParentLast(DeployersImpl.java:1376) at org.jboss.deployers.plugins.deployers.DeployersImpl.doInstallParentFirst(DeployersImpl.java:1186) at org.jboss.deployers.plugins.deployers.DeployersImpl.install(DeployersImpl.java:1098) at org.jboss.dependency.plugins.AbstractControllerContext.install(AbstractControllerContext.java:348) at org.jboss.dependency.plugins.AbstractController.install(AbstractController.java:1631) at org.jboss.dependency.plugins.AbstractController.incrementState(AbstractController.java:934) at org.jboss.dependency.plugins.AbstractController.resolveContexts(AbstractController.java:1082) at org.jboss.dependency.plugins.AbstractController.resolveContexts(AbstractController.java:984) at org.jboss.dependency.plugins.AbstractController.change(AbstractController.java:822) at org.jboss.dependency.plugins.AbstractController.change(AbstractController.java:553) at org.jboss.deployers.plugins.deployers.DeployersImpl.process(DeployersImpl.java:781) at org.jboss.deployers.plugins.main.MainDeployerImpl.process(MainDeployerImpl.java:702) at org.jboss.system.server.profileservice.repository.MainDeployerAdapter.process(MainDeployerAdapter.java:117) at org.jboss.system.server.profileservice.repository.ProfileDeployAction.install(ProfileDeployAction.java:70) at org.jboss.system.server.profileservice.repository.AbstractProfileAction.install(AbstractProfileAction.java:53) at org.jboss.system.server.profileservice.repository.AbstractProfileService.install(AbstractProfileService.java:361) at org.jboss.dependency.plugins.AbstractControllerContext.install(AbstractControllerContext.java:348) at org.jboss.dependency.plugins.AbstractController.install(AbstractController.java:1631) at org.jboss.dependency.plugins.AbstractController.incrementState(AbstractController.java:934) at org.jboss.dependency.plugins.AbstractController.resolveContexts(AbstractController.java:1082) at org.jboss.dependency.plugins.AbstractController.resolveContexts(AbstractController.java:984) at org.jboss.dependency.plugins.AbstractController.change(AbstractController.java:822) at org.jboss.dependency.plugins.AbstractController.change(AbstractController.java:553) at org.jboss.system.server.profileservice.repository.AbstractProfileService.activateProfile(AbstractProfileService.java:306) at org.jboss.system.server.profileservice.ProfileServiceBootstrap.start(ProfileServiceBootstrap.java:271) at org.jboss.bootstrap.AbstractServerImpl.start(AbstractServerImpl.java:461) at org.jboss.Main.boot(Main.java:221) at org.jboss.Main$1.run(Main.java:556) at java.lang.Thread.run(Thread.java:679) 2013-11-09 17:01:51,339 ERROR [org.jboss.kernel.plugins.dependency.AbstractKernelController] Error installing to Real: name=vfsfile:/home/epankmi/Desktop/nuxeo-dm-5.4.0_01-jboss/nuxeo-dm-5.4.0.1-jboss/server/default/deploy/hsqldb-ds.xml state=PreReal mode=Manual requiredState=Real org.jboss.deployers.spi.DeploymentException: Error deploying: jboss.jdbc:service=metadata,datasource=DefaultDS at org.jboss.deployers.spi.DeploymentException.rethrowAsDeploymentException(DeploymentException.java:49) at org.jboss.system.deployers.ServiceDeployer.deploy(ServiceDeployer.java:118) at org.jboss.system.deployers.ServiceDeployer.deploy(ServiceDeployer.java:46) at org.jboss.deployers.spi.deployer.helpers.AbstractSimpleRealDeployer.internalDeploy(AbstractSimpleRealDeployer.java:62) at org.jboss.deployers.spi.deployer.helpers.AbstractRealDeployer.deploy(AbstractRealDeployer.java:50) at org.jboss.deployers.plugins.deployers.DeployerWrapper.deploy(DeployerWrapper.java:171) at org.jboss.deployers.plugins.deployers.DeployersImpl.doDeploy(DeployersImpl.java:1439) at org.jboss.deployers.plugins.deployers.DeployersImpl.doInstallParentFirst(DeployersImpl.java:1157) at org.jboss.deployers.plugins.deployers.DeployersImpl.doInstallParentFirst(DeployersImpl.java:1178) at org.jboss.deployers.plugins.deployers.DeployersImpl.install(DeployersImpl.java:1098) at org.jboss.dependency.plugins.AbstractControllerContext.install(AbstractControllerContext.java:348) at org.jboss.dependency.plugins.AbstractController.install(AbstractController.java:1631) at org.jboss.dependency.plugins.AbstractController.incrementState(AbstractController.java:934) at org.jboss.dependency.plugins.AbstractController.resolveContexts(AbstractController.java:1082) at org.jboss.dependency.plugins.AbstractController.resolveContexts(AbstractController.java:984) at org.jboss.dependency.plugins.AbstractController.change(AbstractController.java:822) at org.jboss.dependency.plugins.AbstractController.change(AbstractController.java:553) at org.jboss.deployers.plugins.deployers.DeployersImpl.process(DeployersImpl.java:781) at org.jboss.deployers.plugins.main.MainDeployerImpl.process(MainDeployerImpl.java:702) at org.jboss.system.server.profileservice.repository.MainDeployerAdapter.process(MainDeployerAdapter.java:117) at org.jboss.system.server.profileservice.repository.ProfileDeployAction.install(ProfileDeployAction.java:70) at org.jboss.system.server.profileservice.repository.AbstractProfileAction.install(AbstractProfileAction.java:53) at org.jboss.system.server.profileservice.repository.AbstractProfileService.install(AbstractProfileService.java:361) at org.jboss.dependency.plugins.AbstractControllerContext.install(AbstractControllerContext.java:348) at org.jboss.dependency.plugins.AbstractController.install(AbstractController.java:1631) at org.jboss.dependency.plugins.AbstractController.incrementState(AbstractController.java:934) at org.jboss.dependency.plugins.AbstractController.resolveContexts(AbstractController.java:1082) at org.jboss.dependency.plugins.AbstractController.resolveContexts(AbstractController.java:984) at org.jboss.dependency.plugins.AbstractController.change(AbstractController.java:822) at org.jboss.dependency.plugins.AbstractController.change(AbstractController.java:553) at org.jboss.system.server.profileservice.repository.AbstractProfileService.activateProfile(AbstractProfileService.java:306) at org.jboss.system.server.profileservice.ProfileServiceBootstrap.start(ProfileServiceBootstrap.java:271) at org.jboss.bootstrap.AbstractServerImpl.start(AbstractServerImpl.java:461) at org.jboss.Main.boot(Main.java:221) at org.jboss.Main$1.run(Main.java:556) at java.lang.Thread.run(Thread.java:679) Caused by: java.lang.ClassNotFoundException: org.jboss.ejb.plugins.cmp.jdbc.metadata.DataSourceMetaData from BaseClassLoader@afe676b{VFSClassLoaderPolicy@4437a770{name=vfsfile:/home/epankmi/Desktop/nuxeo-dm-5.4.0_01-jboss/nuxeo-dm-5.4.0.1-jboss/server/default/deploy/hsqldb-ds.xml domain=ClassLoaderDomain@4ee14d81{name=DefaultDomain parentPolicy=BEFORE parent=org.jboss.bootstrap.NoAnnotationURLClassLoader@b61d36b} roots=[MemoryContextHandler@567397645[path= context=vfsmemory://0000-u2t9zl-hnsru2sk-1-hnsrujjq-25 real=vfsmemory://0000-u2t9zl-hnsru2sk-1-hnsrujjq-25]] delegates=null exported=[] NON_EMPTY}} at org.jboss.classloader.spi.base.BaseClassLoader.loadClass(BaseClassLoader.java:448) at java.lang.ClassLoader.loadClass(ClassLoader.java:266) at org.jboss.mx.server.MBeanServerImpl.instantiate(MBeanServerImpl.java:1213) at org.jboss.mx.server.MBeanServerImpl.instantiate(MBeanServerImpl.java:286) at org.jboss.mx.server.MBeanServerImpl.createMBean(MBeanServerImpl.java:344) at org.jboss.system.ServiceCreator.installPlainMBean(ServiceCreator.java:211) at org.jboss.system.ServiceCreator.install(ServiceCreator.java:130) at org.jboss.system.microcontainer.InstantiateAction.installAction(InstantiateAction.java:45) at org.jboss.system.microcontainer.InstantiateAction.installAction(InstantiateAction.java:37) at org.jboss.dependency.plugins.action.SimpleControllerContextAction.simpleInstallAction(SimpleControllerContextAction.java:62) at org.jboss.dependency.plugins.action.AccessControllerContextAction.install(AccessControllerContextAction.java:71) at org.jboss.dependency.plugins.AbstractControllerContextActions.install(AbstractControllerContextActions.java:51) at org.jboss.dependency.plugins.AbstractControllerContext.install(AbstractControllerContext.java:348) at org.jboss.system.microcontainer.ServiceControllerContext.install(ServiceControllerContext.java:286) at org.jboss.dependency.plugins.AbstractController.install(AbstractController.java:1631) at org.jboss.dependency.plugins.AbstractController.incrementState(AbstractController.java:934) at org.jboss.dependency.plugins.AbstractController.resolveContexts(AbstractController.java:1082) at org.jboss.dependency.plugins.AbstractController.resolveContexts(AbstractController.java:984) at org.jboss.dependency.plugins.AbstractController.change(AbstractController.java:822) at org.jboss.dependency.plugins.AbstractController.change(AbstractController.java:553) at org.jboss.system.ServiceController.doChange(ServiceController.java:688) at org.jboss.system.ServiceController.install(ServiceController.java:274) at org.jboss.system.deployers.ServiceDeployer.deploy(ServiceDeployer.java:90) ... 34 more 2013-11-09 17:01:51,344 ERROR [org.jboss.system.server.profileservice.repository.ScopedProfileServiceController] Error installing to Deploy: name=ProfileKey@73e2bda7[domain=default, server=default, name=applications] state=PreInstall mode=On Demand requiredState=Installed java.lang.IllegalStateException: Deployers are shutdown at org.jboss.deployers.plugins.deployers.DeployersImpl.checkShutdown(DeployersImpl.java:187) at org.jboss.deployers.plugins.deployers.DeployersImpl.process(DeployersImpl.java:778) at org.jboss.deployers.plugins.main.MainDeployerImpl.process(MainDeployerImpl.java:702) at org.jboss.system.server.profileservice.repository.MainDeployerAdapter.process(MainDeployerAdapter.java:117) at org.jboss.system.server.profileservice.repository.ProfileDeployAction.install(ProfileDeployAction.java:70) at org.jboss.system.server.profileservice.repository.AbstractProfileAction.install(AbstractProfileAction.java:53) at org.jboss.system.server.profileservice.repository.AbstractProfileService.install(AbstractProfileService.java:361) at org.jboss.dependency.plugins.AbstractControllerContext.install(AbstractControllerContext.java:348) at org.jboss.dependency.plugins.AbstractController.install(AbstractController.java:1631) at org.jboss.dependency.plugins.AbstractController.incrementState(AbstractController.java:934) at org.jboss.dependency.plugins.AbstractController.resolveContexts(AbstractController.java:1082) at org.jboss.dependency.plugins.AbstractController.resolveContexts(AbstractController.java:984) at org.jboss.dependency.plugins.AbstractController.change(AbstractController.java:822) at org.jboss.dependency.plugins.AbstractController.change(AbstractController.java:553) at org.jboss.system.server.profileservice.repository.AbstractProfileService.activateProfile(AbstractProfileService.java:306) at org.jboss.system.server.profileservice.ProfileServiceBootstrap.start(ProfileServiceBootstrap.java:271) at org.jboss.bootstrap.AbstractServerImpl.start(AbstractServerImpl.java:461) at org.jboss.Main.boot(Main.java:221) at org.jboss.Main$1.run(Main.java:556) at java.lang.Thread.run(Thread.java:679) 2013-11-09 17:02:03,796 INFO [org.nuxeo.runtime.deployment.preprocessor.ConfigurationGenerator] Nuxeo configuration: ./nuxeo.conf 2013-11-09 17:02:03,799 INFO [org.nuxeo.runtime.deployment.preprocessor.ConfigurationGenerator] Include template: /home/epankmi/Desktop/nuxeo-dm-5.4.0_01-jboss/nuxeo-dm-5.4.0.1-jboss/templates/common-deploydir 2013-11-09 17:02:03,800 INFO [org.nuxeo.runtime.deployment.preprocessor.ConfigurationGenerator] Include template: /home/epankmi/Desktop/nuxeo-dm-5.4.0_01-jboss/nuxeo-dm-5.4.0.1-jboss/templates/common-binding 2013-11-09 17:02:03,800 INFO [org.nuxeo.runtime.deployment.preprocessor.ConfigurationGenerator] Include template: /home/epankmi/Desktop/nuxeo-dm-5.4.0_01-jboss/nuxeo-dm-5.4.0.1-jboss/templates/common 2013-11-09 17:02:03,800 INFO [org.nuxeo.runtime.deployment.preprocessor.ConfigurationGenerator] Include template: /home/epankmi/Desktop/nuxeo-dm-5.4.0_01-jboss/nuxeo-dm-5.4.0.1-jboss/templates/default 2013-11-09 17:02:03,801 INFO [org.nuxeo.runtime.deployment.preprocessor.ServerConfigurator] Detected JBoss server. 2013-11-09 17:02:03,801 INFO [org.nuxeo.runtime.deployment.preprocessor.ConfigurationGenerator] Configuration files generation (nuxeo.force.generation=true)... 2013-11-09 17:02:03,832 INFO [org.nuxeo.runtime.deployment.preprocessor.ConfigurationGenerator] Configuration files generated. 2013-11-09 17:02:21,555 ERROR [org.jboss.kernel.plugins.dependency.AbstractKernelController] Error installing to Configured: name=WSServerConfig state=Instantiated java.lang.RuntimeException: Error configuring property: webServiceHost for WSServerConfig at org.jboss.kernel.plugins.dependency.ConfigureAction.dispatchSetProperty(ConfigureAction.java:112) at org.jboss.kernel.plugins.dependency.ConfigureAction.setAttributes(ConfigureAction.java:85) at org.jboss.kernel.plugins.dependency.ConfigureAction.installActionInternal(ConfigureAction.java:44) at org.jboss.kernel.plugins.dependency.InstallsAwareAction.installAction(InstallsAwareAction.java:54) at org.jboss.kernel.plugins.dependency.InstallsAwareAction.installAction(InstallsAwareAction.java:42) at org.jboss.dependency.plugins.action.SimpleControllerContextAction.simpleInstallAction(SimpleControllerContextAction.java:62) at org.jboss.dependency.plugins.action.AccessControllerContextAction.install(AccessControllerContextAction.java:71) at org.jboss.dependency.plugins.AbstractControllerContextActions.install(AbstractControllerContextActions.java:51) at org.jboss.dependency.plugins.AbstractControllerContext.install(AbstractControllerContext.java:348) at org.jboss.dependency.plugins.AbstractController.install(AbstractController.java:1631) at org.jboss.dependency.plugins.AbstractController.incrementState(AbstractController.java:934) at org.jboss.dependency.plugins.AbstractController.resolveContexts(AbstractController.java:1082) at org.jboss.dependency.plugins.AbstractController.resolveContexts(AbstractController.java:984) at org.jboss.dependency.plugins.AbstractController.install(AbstractController.java:774) at org.jboss.dependency.plugins.AbstractController.install(AbstractController.java:540) at org.jboss.deployers.vfs.deployer.kernel.BeanMetaDataDeployer.deploy(BeanMetaDataDeployer.java:121) at org.jboss.deployers.vfs.deployer.kernel.BeanMetaDataDeployer.deploy(BeanMetaDataDeployer.java:51) at org.jboss.deployers.spi.deployer.helpers.AbstractSimpleRealDeployer.internalDeploy(AbstractSimpleRealDeployer.java:62) at org.jboss.deployers.spi.deployer.helpers.AbstractRealDeployer.deploy(AbstractRealDeployer.java:50) at org.jboss.deployers.plugins.deployers.DeployerWrapper.deploy(DeployerWrapper.java:171) at org.jboss.deployers.plugins.deployers.DeployersImpl.doDeploy(DeployersImpl.java:1439) at org.jboss.deployers.plugins.deployers.DeployersImpl.doInstallParentFirst(DeployersImpl.java:1157) at org.jboss.deployers.plugins.deployers.DeployersImpl.doInstallParentFirst(DeployersImpl.java:1178) at org.jboss.deployers.plugins.deployers.DeployersImpl.install(DeployersImpl.java:1098) at org.jboss.dependency.plugins.AbstractControllerContext.install(AbstractControllerContext.java:348) at org.jboss.dependency.plugins.AbstractController.install(AbstractController.java:1631) at org.jboss.dependency.plugins.AbstractController.incrementState(AbstractController.java:934) at org.jboss.dependency.plugins.AbstractController.resolveContexts(AbstractController.java:1082) at org.jboss.dependency.plugins.AbstractController.resolveContexts(AbstractController.java:984) at org.jboss.dependency.plugins.AbstractController.change(AbstractController.java:822) at org.jboss.dependency.plugins.AbstractController.change(AbstractController.java:553) at org.jboss.deployers.plugins.deployers.DeployersImpl.process(DeployersImpl.java:781) at org.jboss.deployers.plugins.main.MainDeployerImpl.process(MainDeployerImpl.java:702) at org.jboss.system.server.profileservice.repository.MainDeployerAdapter.process(MainDeployerAdapter.java:117) at org.jboss.system.server.profileservice.repository.ProfileDeployAction.install(ProfileDeployAction.java:70) at org.jboss.system.server.profileservice.repository.AbstractProfileAction.install(AbstractProfileAction.java:53) at org.jboss.system.server.profileservice.repository.AbstractProfileService.install(AbstractProfileService.java:361) at org.jboss.dependency.plugins.AbstractControllerContext.install(AbstractControllerContext.java:348) at org.jboss.dependency.plugins.AbstractController.install(AbstractController.java:1631) at org.jboss.dependency.plugins.AbstractController.incrementState(AbstractController.java:934) at org.jboss.dependency.plugins.AbstractController.resolveContexts(AbstractController.java:1082) at org.jboss.dependency.plugins.AbstractController.resolveContexts(AbstractController.java:984) at org.jboss.dependency.plugins.AbstractController.change(AbstractController.java:822) at org.jboss.dependency.plugins.AbstractController.change(AbstractController.java:553) at org.jboss.system.server.profileservice.repository.AbstractProfileService.activateProfile(AbstractProfileService.java:306) at org.jboss.system.server.profileservice.ProfileServiceBootstrap.start(ProfileServiceBootstrap.java:271) at org.jboss.bootstrap.AbstractServerImpl.start(AbstractServerImpl.java:461) at org.jboss.Main.boot(Main.java:221) at org.jboss.Main$1.run(Main.java:556) at java.lang.Thread.run(Thread.java:679) Caused by: java.net.UnknownHostException: B1H68R1.egi.ericsson.com: B1H68R1.egi.ericsson.com at java.net.InetAddress.getLocalHost(InetAddress.java:1454) at org.jboss.wsf.common.management.AbstractServerConfig.setWebServiceHost(AbstractServerConfig.java:84) at sun.reflect.NativeMethodAccessorImpl.invoke0(Native Method) at sun.reflect.NativeMethodAccessorImpl.invoke(NativeMethodAccessorImpl.java:57) at sun.reflect.DelegatingMethodAccessorImpl.invoke(DelegatingMethodAccessorImpl.java:43) at java.lang.reflect.Method.invoke(Method.java:616) at org.jboss.reflect.plugins.introspection.ReflectionUtils.invoke(ReflectionUtils.java:59) at org.jboss.reflect.plugins.introspection.ReflectMethodInfoImpl.invoke(ReflectMethodInfoImpl.java:150) at org.jboss.beans.info.plugins.DefaultPropertyInfo.set(DefaultPropertyInfo.java:143) at org.jboss.beans.info.plugins.BeanInfoUtil.set(BeanInfoUtil.java:177) at org.jboss.beans.info.plugins.AbstractBeanInfo.setProperty(AbstractBeanInfo.java:289) at org.jboss.kernel.plugins.dependency.PropertyDispatchWrapper.execute(PropertyDispatchWrapper.java:113) at org.jboss.kernel.plugins.dependency.ExecutionWrapper.execute(ExecutionWrapper.java:47) at org.jboss.kernel.plugins.dependency.KernelControllerContextAction.dispatchExecutionWrapper(KernelControllerContextAction.java:109) at org.jboss.kernel.plugins.dependency.ConfigureAction.dispatchSetProperty(ConfigureAction.java:107) ... 49 more 2013-11-09 17:02:24,023 INFO [org.nuxeo.runtime.jboss.deployer.structure.NuxeoStructureDeployer] Found Nuxeo Deployment: nuxeo.ear 2013-11-09 17:02:24,079 INFO [org.nuxeo.runtime.deployment.preprocessor.DeploymentPreprocessor] Running custom installation for container: nuxeo.ear 2013-11-09 17:02:24,216 WARN [org.nuxeo.runtime.deployment.preprocessor.DeploymentPreprocessor] Entering compatibility mode - Please update the deployment-fragment.xml in nuxeo-opencmis-bindings-5.4.0.1.jar to use new dependency management 2013-11-09 17:02:24,219 WARN [org.nuxeo.runtime.deployment.preprocessor.DeploymentPreprocessor] Entering compatibility mode - Please update the deployment-fragment.xml in nuxeo-opencmis-impl-5.4.0.1.jar to use new dependency management 2013-11-09 17:02:24,296 WARN [org.nuxeo.runtime.deployment.preprocessor.DeploymentPreprocessor] Entering compatibility mode - Please update the deployment-fragment.xml in nuxeo-platform-lang-ext-5.4.0.1.jar to use new dependency management 2013-11-09 17:02:24,454 INFO [org.nuxeo.runtime.deployment.preprocessor.DeploymentPreprocessor] Preprocessing order: org.nuxeo.ecm.webengine.core org.nuxeo.ecm.platform.picture.facade org.nuxeo.ecm.platform.ui org.nuxeo.ecm.platform.types.core org.nuxeo.ecm.platform.uidgen.core org.nuxeo.ecm.platform.versioning org.nuxeo.ecm.core.storage.sql.ra org.nuxeo.ecm.platform.types.facade org.nuxeo.opensocial.service org.nuxeo.ecm.platform.forum org.nuxeo.ecm.platform.filemanager.api org.nuxeo.ecm.platform.ws.jbossws org.nuxeo.ecm.platform.audit.web org.nuxeo.ecm.platform.publisher.core org.nuxeo.ecm.platform.userworkspace.types org.nuxeo.ecm.annotations.repository org.nuxeo.ecm.relations.facade org.nuxeo.ecm.platform.notification.facade org.nuxeo.ecm.platform.audit org.nuxeo.ecm.platform.web.common org.nuxeo.ecm.platform.usermanager.facade org.nuxeo.opensocial.gadgets org.nuxeo.ecm.platform.preview org.nuxeo.ecm.platform.placeful.theme org.nuxeo.ecm.platform.url.facade org.nuxeo.ecm.platform.webapp.types org.nuxeo.ecm.platform.search.ejb org.nuxeo.ecm.platform.directory.facade org.nuxeo.ecm.platform.publisher.core.contrib org.nuxeo.ecm.platform.picture.dm org.nuxeo.ecm.platform.comment org.nuxeo.ecm.platform.forms.layout.client org.nuxeo.ecm.platform.types.api org.nuxeo.ecm.relations.core.listener org.nuxeo.ecm.platform.userworkspace.facade org.nuxeo.theme.editor org.nuxeo.ecm.platform.publisher.jbpm org.nuxeo.ecm.relations.web org.nuxeo.ecm.platform.filemanager.facade org.nuxeo.ecm.annotation.facade org.nuxeo.ecm.webapp.ui org.nuxeo.ecm.actions org.nuxeo.opensocial.container org.nuxeo.ecm.platform.publisher.web org.nuxeo.ecm.platform.filemanager.core org.nuxeo.ecm.platform.notification.web org.nuxeo.ecm.platform.jbpm.facade org.nuxeo.ecm.platform.placeful.facade org.nuxeo.ecm.platform.userworkspace.core org.nuxeo.theme.jsf org.nuxeo.ecm.annotations.client org.nuxeo.ecm.webapp.base org.nuxeo.ecm.webapp.core org.nuxeo.ecm.core.facade org.nuxeo.ecm.platform.pictures.tiles.preview org.nuxeo.ecm.platform.publisher.api org.nuxeo.ecm.platform.io.web org.nuxeo.ecm.platform.notification.core org.nuxeo.ecm.platform org.nuxeo.ecm.platform.comment.web org.nuxeo.theme.html org.nuxeo.ecm.platform.ui.compat org.nuxeo.ecm.platform.pictures.tiles org.nuxeo.ecm.platform.picture.jsf org.nuxeo.ecm.platform.jbpm.web org.nuxeo.theme.bank org.nuxeo.ecm.platform.faceted.search.jsf org.nuxeo.ecm.platform.url.api org.nuxeo.ecm.annotations.http org.nuxeo.ecm.platform.webengine.sites org.nuxeo.ecm.platform.io.facade org.nuxeo.ecm.platform.lang org.nuxeo.ecm.platform.mail.web org.nuxeo.ecm.platform.webengine.blogs org.nuxeo.admin.center.monitoring org.nuxeo.opensocial.spaces.web org.nuxeo.opensocial.dashboard org.nuxeo.ecm.platform.tag.web org.nuxeo.admin.center org.nuxeo.ecm.platform.lang.ext org.nuxeo.ecm.platform.faceted.search.dm org.nuxeo.ecm.platform.userworkspace.web org.nuxeo.platform.virtualnavigation.web org.nuxeo.ecm.platform.audit.ejb org.nuxeo.ecm.platform.tag.ejb org.nuxeo.ecm.platform.syndication org.nuxeo.ecm.platform.wss.backend org.nuxeo.ecm.platform.filemanager.core.listener org.nuxeo.ecm.platform.mimetype.core org.nuxeo.ecm.platform.placeful.core org.nuxeo.ecm.relations.jena org.nuxeo.ecm.platform.mimetype.facade org.nuxeo.ecm.core.opencmis.bindings org.nuxeo.ecm.core.opencmis.impl 2013-11-09 17:02:24,457 INFO [org.nuxeo.runtime.deployment.preprocessor.DeploymentPreprocessor] Running custom installation for fragment: org.nuxeo.ecm.platform.ui 2013-11-09 17:02:24,595 INFO [org.nuxeo.runtime.deployment.preprocessor.DeploymentPreprocessor] Running custom installation for fragment: org.nuxeo.ecm.platform.forum 2013-11-09 17:02:24,597 INFO [org.nuxeo.runtime.deployment.preprocessor.DeploymentPreprocessor] Running custom installation for fragment: org.nuxeo.ecm.platform.audit.web 2013-11-09 17:02:24,598 WARN [org.nuxeo.runtime.deployment.preprocessor.DeploymentPreprocessor] No template 'jaxws' found for deployment fragment: org.nuxeo.ecm.platform.audit.web 2013-11-09 17:02:24,599 INFO [org.nuxeo.runtime.deployment.preprocessor.DeploymentPreprocessor] Running custom installation for fragment: org.nuxeo.ecm.annotations.repository 2013-11-09 17:02:24,601 INFO [org.nuxeo.runtime.deployment.preprocessor.DeploymentPreprocessor] Running custom installation for fragment: org.nuxeo.opensocial.gadgets 2013-11-09 17:02:24,612 INFO [org.nuxeo.runtime.deployment.preprocessor.DeploymentPreprocessor] Running custom installation for fragment: org.nuxeo.ecm.platform.preview 2013-11-09 17:02:24,615 INFO [org.nuxeo.runtime.deployment.preprocessor.DeploymentPreprocessor] Running custom installation for fragment: org.nuxeo.ecm.platform.picture.dm 2013-11-09 17:02:24,621 INFO [org.nuxeo.runtime.deployment.preprocessor.DeploymentPreprocessor] Running custom installation for fragment: org.nuxeo.ecm.platform.forms.layout.client 2013-11-09 17:02:24,628 WARN [org.nuxeo.runtime.deployment.preprocessor.template.Template] The deployment-fragment contains illegal JEE java module contribution: nuxeo-theme-editor-5.4.0.1.jar 2013-11-09 17:02:24,628 INFO [org.nuxeo.runtime.deployment.preprocessor.DeploymentPreprocessor] Running custom installation for fragment: org.nuxeo.ecm.relations.web 2013-11-09 17:02:24,630 INFO [org.nuxeo.runtime.deployment.preprocessor.DeploymentPreprocessor] Running custom installation for fragment: org.nuxeo.ecm.webapp.ui 2013-11-09 17:02:24,702 INFO [org.nuxeo.runtime.deployment.preprocessor.DeploymentPreprocessor] Running custom installation for fragment: org.nuxeo.opensocial.container 2013-11-09 17:02:25,064 INFO [org.nuxeo.runtime.deployment.preprocessor.DeploymentPreprocessor] Running custom installation for fragment: org.nuxeo.ecm.platform.publisher.web 2013-11-09 17:02:25,066 INFO [org.nuxeo.runtime.deployment.preprocessor.DeploymentPreprocessor] Running custom installation for fragment: org.nuxeo.ecm.platform.notification.web 2013-11-09 17:02:25,067 INFO [org.nuxeo.runtime.deployment.preprocessor.DeploymentPreprocessor] Running custom installation for fragment: org.nuxeo.theme.jsf 2013-11-09 17:02:25,072 INFO [org.nuxeo.runtime.deployment.preprocessor.DeploymentPreprocessor] Running custom installation for fragment: org.nuxeo.ecm.annotations.client 2013-11-09 17:02:25,141 INFO [org.nuxeo.runtime.deployment.preprocessor.DeploymentPreprocessor] Running custom installation for fragment: org.nuxeo.ecm.webapp.base 2013-11-09 17:02:25,157 INFO [org.nuxeo.runtime.deployment.preprocessor.DeploymentPreprocessor] Running custom installation for fragment: org.nuxeo.ecm.platform.pictures.tiles.preview 2013-11-09 17:02:25,172 INFO [org.nuxeo.runtime.deployment.preprocessor.DeploymentPreprocessor] Running custom installation for fragment: org.nuxeo.ecm.platform.io.web 2013-11-09 17:02:25,173 INFO [org.nuxeo.runtime.deployment.preprocessor.DeploymentPreprocessor] Running custom installation for fragment: org.nuxeo.ecm.platform.comment.web 2013-11-09 17:02:25,174 INFO [org.nuxeo.runtime.deployment.preprocessor.DeploymentPreprocessor] Running custom installation for fragment: org.nuxeo.theme.html 2013-11-09 17:02:25,189 INFO [org.nuxeo.runtime.deployment.preprocessor.DeploymentPreprocessor] Running custom installation for fragment: org.nuxeo.ecm.platform.ui.compat 2013-11-09 17:02:25,247 INFO [org.nuxeo.runtime.deployment.preprocessor.DeploymentPreprocessor] Running custom installation for fragment: org.nuxeo.ecm.platform.pictures.tiles 2013-11-09 17:02:25,249 INFO [org.nuxeo.runtime.deployment.preprocessor.DeploymentPreprocessor] Running custom installation for fragment: org.nuxeo.ecm.platform.jbpm.web 2013-11-09 17:02:25,252 WARN [org.nuxeo.runtime.deployment.preprocessor.template.Template] The deployment-fragment contains illegal JEE java module contribution: nuxeo-theme-bank-5.4.0.1.jar 2013-11-09 17:02:25,252 INFO [org.nuxeo.runtime.deployment.preprocessor.DeploymentPreprocessor] Running custom installation for fragment: org.nuxeo.ecm.platform.faceted.search.jsf 2013-11-09 17:02:25,254 INFO [org.nuxeo.runtime.deployment.preprocessor.DeploymentPreprocessor] Running custom installation for fragment: org.nuxeo.ecm.annotations.http 2013-11-09 17:02:25,256 INFO [org.nuxeo.runtime.deployment.preprocessor.DeploymentPreprocessor] Running custom installation for fragment: org.nuxeo.ecm.platform.webengine.sites 2013-11-09 17:02:25,264 INFO [org.nuxeo.runtime.deployment.preprocessor.DeploymentPreprocessor] Running custom installation for fragment: org.nuxeo.ecm.platform.lang 2013-11-09 17:02:25,268 INFO [org.nuxeo.runtime.deployment.preprocessor.DeploymentPreprocessor] Running custom installation for fragment: org.nuxeo.ecm.platform.mail.web 2013-11-09 17:02:25,270 INFO [org.nuxeo.runtime.deployment.preprocessor.DeploymentPreprocessor] Running custom installation for fragment: org.nuxeo.ecm.platform.webengine.blogs 2013-11-09 17:02:25,283 INFO [org.nuxeo.runtime.deployment.preprocessor.DeploymentPreprocessor] Running custom installation for fragment: org.nuxeo.admin.center.monitoring 2013-11-09 17:02:25,540 INFO [org.nuxeo.runtime.deployment.preprocessor.DeploymentPreprocessor] Running custom installation for fragment: org.nuxeo.opensocial.spaces.web 2013-11-09 17:02:25,543 INFO [org.nuxeo.runtime.deployment.preprocessor.DeploymentPreprocessor] Running custom installation for fragment: org.nuxeo.opensocial.dashboard 2013-11-09 17:02:25,548 INFO [org.nuxeo.runtime.deployment.preprocessor.DeploymentPreprocessor] Running custom installation for fragment: org.nuxeo.ecm.platform.tag.web 2013-11-09 17:02:25,550 INFO [org.nuxeo.runtime.deployment.preprocessor.DeploymentPreprocessor] Running custom installation for fragment: org.nuxeo.admin.center 2013-11-09 17:02:25,567 INFO [org.nuxeo.runtime.deployment.preprocessor.DeploymentPreprocessor] Running custom installation for fragment: org.nuxeo.ecm.platform.lang.ext 2013-11-09 17:02:25,582 INFO [org.nuxeo.runtime.deployment.preprocessor.DeploymentPreprocessor] Running custom installation for fragment: org.nuxeo.ecm.platform.faceted.search.dm 2013-11-09 17:02:25,586 INFO [org.nuxeo.runtime.deployment.preprocessor.DeploymentPreprocessor] Running custom installation for fragment: org.nuxeo.ecm.platform.userworkspace.web 2013-11-09 17:02:25,587 INFO [org.nuxeo.runtime.deployment.preprocessor.DeploymentPreprocessor] Running custom installation for fragment: org.nuxeo.platform.virtualnavigation.web 2013-11-09 17:02:25,588 INFO [org.nuxeo.runtime.deployment.preprocessor.DeploymentPreprocessor] Running custom installation for fragment: org.nuxeo.ecm.platform.syndication 2013-11-09 17:02:25,593 INFO [org.nuxeo.runtime.deployment.preprocessor.DeploymentPreprocessor] Running custom installation for fragment: org.nuxeo.ecm.platform.wss.backend 2013-11-09 17:02:25,595 INFO [org.nuxeo.runtime.deployment.preprocessor.DeploymentPreprocessor] Running custom installation for fragment: org.nuxeo.ecm.core.opencmis.bindings 2013-11-09 17:02:25,597 WARN [org.nuxeo.runtime.deployment.preprocessor.template.Template] The deployment-fragment contains illegal JEE java module contribution: nuxeo-opencmis-bindings-5.4.0.1.jar 2013-11-09 17:02:25,597 WARN [org.nuxeo.runtime.deployment.preprocessor.DeploymentPreprocessor] No template 'jaxws' found for deployment fragment: org.nuxeo.ecm.core.opencmis.bindings 2013-11-09 17:02:25,597 WARN [org.nuxeo.runtime.deployment.preprocessor.template.Template] The deployment-fragment contains illegal JEE java module contribution: nuxeo-opencmis-impl-5.4.0.1.jar 2013-11-09 17:02:25,597 INFO [org.nuxeo.runtime.jboss.deployer.structure.NuxeoStructureDeployer] Nuxeo Preprocessing took 1.57 sec. 2013-11-09 17:02:25,767 INFO [org.nuxeo.runtime.jboss.deployer.structure.NuxeoStructureDeployer] Determining Nuxeo Deployment Structure took 1.762 sec. 2013-11-09 17:02:36,798 INFO [org.jboss.ejb3.deployers.Ejb3DependenciesDeployer] Encountered deployment AbstractVFSDeploymentContext@169371530{vfsfile:/home/epankmi/Desktop/nuxeo-dm-5.4.0_01-jboss/nuxeo-dm-5.4.0.1-jboss/server/default/deploy/profileservice-secured.jar/} 2013-11-09 17:02:36,799 INFO [org.jboss.ejb3.deployers.Ejb3DependenciesDeployer] Encountered deployment AbstractVFSDeploymentContext@169371530{vfsfile:/home/epankmi/Desktop/nuxeo-dm-5.4.0_01-jboss/nuxeo-dm-5.4.0.1-jboss/server/default/deploy/profileservice-secured.jar/} 2013-11-09 17:02:36,799 INFO [org.jboss.ejb3.deployers.Ejb3DependenciesDeployer] Encountered deployment AbstractVFSDeploymentContext@169371530{vfsfile:/home/epankmi/Desktop/nuxeo-dm-5.4.0_01-jboss/nuxeo-dm-5.4.0.1-jboss/server/default/deploy/profileservice-secured.jar/} 2013-11-09 17:02:36,799 INFO [org.jboss.ejb3.deployers.Ejb3DependenciesDeployer] Encountered deployment AbstractVFSDeploymentContext@169371530{vfsfile:/home/epankmi/Desktop/nuxeo-dm-5.4.0_01-jboss/nuxeo-dm-5.4.0.1-jboss/server/default/deploy/profileservice-secured.jar/} 2013-11-09 17:02:36,803 INFO [org.jboss.ejb3.deployers.Ejb3DependenciesDeployer] Encountered deployment AbstractVFSDeploymentContext@924505996{vfsfile:/home/epankmi/Desktop/nuxeo-dm-5.4.0_01-jboss/nuxeo-dm-5.4.0.1-jboss/server/default/deploy/nuxeo.ear/} 2013-11-09 17:02:36,803 INFO [org.jboss.ejb3.deployers.Ejb3DependenciesDeployer] Encountered deployment AbstractVFSDeploymentContext@924505996{vfsfile:/home/epankmi/Desktop/nuxeo-dm-5.4.0_01-jboss/nuxeo-dm-5.4.0.1-jboss/server/default/deploy/nuxeo.ear/} 2013-11-09 17:02:36,803 INFO [org.jboss.ejb3.deployers.Ejb3DependenciesDeployer] Encountered deployment AbstractVFSDeploymentContext@438984209{vfszip:/home/epankmi/Desktop/nuxeo-dm-5.4.0_01-jboss/nuxeo-dm-5.4.0.1-jboss/server/default/deploy/nuxeo.ear/bundles/nuxeo-core-facade-5.4.0.1.jar/} 2013-11-09 17:02:36,803 INFO [org.jboss.ejb3.deployers.Ejb3DependenciesDeployer] Encountered deployment AbstractVFSDeploymentContext@438984209{vfszip:/home/epankmi/Desktop/nuxeo-dm-5.4.0_01-jboss/nuxeo-dm-5.4.0.1-jboss/server/default/deploy/nuxeo.ear/bundles/nuxeo-core-facade-5.4.0.1.jar/} 2013-11-09 17:02:36,803 INFO [org.jboss.ejb3.deployers.Ejb3DependenciesDeployer] Encountered deployment AbstractVFSDeploymentContext@438984209{vfszip:/home/epankmi/Desktop/nuxeo-dm-5.4.0_01-jboss/nuxeo-dm-5.4.0.1-jboss/server/default/deploy/nuxeo.ear/bundles/nuxeo-core-facade-5.4.0.1.jar/} 2013-11-09 17:02:36,803 INFO [org.jboss.ejb3.deployers.Ejb3DependenciesDeployer] Encountered deployment AbstractVFSDeploymentContext@438984209{vfszip:/home/epankmi/Desktop/nuxeo-dm-5.4.0_01-jboss/nuxeo-dm-5.4.0.1-jboss/server/default/deploy/nuxeo.ear/bundles/nuxeo-core-facade-5.4.0.1.jar/} 2013-11-09 17:02:36,803 INFO [org.jboss.ejb3.deployers.Ejb3DependenciesDeployer] Encountered deployment AbstractVFSDeploymentContext@1893301924{vfszip:/home/epankmi/Desktop/nuxeo-dm-5.4.0_01-jboss/nuxeo-dm-5.4.0.1-jboss/server/default/deploy/nuxeo.ear/bundles/nuxeo-platform-5.4.0.1.jar/} 2013-11-09 17:02:36,803 INFO [org.jboss.ejb3.deployers.Ejb3DependenciesDeployer] Encountered deployment AbstractVFSDeploymentContext@1893301924{vfszip:/home/epankmi/Desktop/nuxeo-dm-5.4.0_01-jboss/nuxeo-dm-5.4.0.1-jboss/server/default/deploy/nuxeo.ear/bundles/nuxeo-platform-5.4.0.1.jar/} 2013-11-09 17:02:36,803 INFO [org.jboss.ejb3.deployers.Ejb3DependenciesDeployer] Encountered deployment AbstractVFSDeploymentContext@1893301924{vfszip:/home/epankmi/Desktop/nuxeo-dm-5.4.0_01-jboss/nuxeo-dm-5.4.0.1-jboss/server/default/deploy/nuxeo.ear/bundles/nuxeo-platform-5.4.0.1.jar/} 2013-11-09 17:02:36,803 INFO [org.jboss.ejb3.deployers.Ejb3DependenciesDeployer] Encountered deployment AbstractVFSDeploymentContext@1893301924{vfszip:/home/epankmi/Desktop/nuxeo-dm-5.4.0_01-jboss/nuxeo-dm-5.4.0.1-jboss/server/default/deploy/nuxeo.ear/bundles/nuxeo-platform-5.4.0.1.jar/} 2013-11-09 17:02:36,803 INFO [org.jboss.ejb3.deployers.Ejb3DependenciesDeployer] Encountered deployment AbstractVFSDeploymentContext@1460239069{vfszip:/home/epankmi/Desktop/nuxeo-dm-5.4.0_01-jboss/nuxeo-dm-5.4.0.1-jboss/server/default/deploy/nuxeo.ear/bundles/nuxeo-platform-actions-core-5.4.0.1.jar/} 2013-11-09 17:02:36,803 INFO [org.jboss.ejb3.deployers.Ejb3DependenciesDeployer] Encountered deployment AbstractVFSDeploymentContext@1460239069{vfszip:/home/epankmi/Desktop/nuxeo-dm-5.4.0_01-jboss/nuxeo-dm-5.4.0.1-jboss/server/default/deploy/nuxeo.ear/bundles/nuxeo-platform-actions-core-5.4.0.1.jar/} 2013-11-09 17:02:36,803 INFO [org.jboss.ejb3.deployers.Ejb3DependenciesDeployer] Encountered deployment AbstractVFSDeploymentContext@794914767{vfszip:/home/epankmi/Desktop/nuxeo-dm-5.4.0_01-jboss/nuxeo-dm-5.4.0.1-jboss/server/default/deploy/nuxeo.ear/bundles/nuxeo-platform-annotations-facade-5.4.0.1.jar/} 2013-11-09 17:02:36,803 INFO [org.jboss.ejb3.deployers.Ejb3DependenciesDeployer] Encountered deployment AbstractVFSDeploymentContext@794914767{vfszip:/home/epankmi/Desktop/nuxeo-dm-5.4.0_01-jboss/nuxeo-dm-5.4.0.1-jboss/server/default/deploy/nuxeo.ear/bundles/nuxeo-platform-annotations-facade-5.4.0.1.jar/} 2013-11-09 17:02:36,804 INFO [org.jboss.ejb3.deployers.Ejb3DependenciesDeployer] Encountered deployment AbstractVFSDeploymentContext@1367141275{vfszip:/home/epankmi/Desktop/nuxeo-dm-5.4.0_01-jboss/nuxeo-dm-5.4.0.1-jboss/server/default/deploy/nuxeo.ear/bundles/nuxeo-platform-audit-facade-5.4.0.1.jar/} 2013-11-09 17:02:36,804 INFO [org.jboss.ejb3.deployers.Ejb3DependenciesDeployer] Encountered deployment AbstractVFSDeploymentContext@1367141275{vfszip:/home/epankmi/Desktop/nuxeo-dm-5.4.0_01-jboss/nuxeo-dm-5.4.0.1-jboss/server/default/deploy/nuxeo.ear/bundles/nuxeo-platform-audit-facade-5.4.0.1.jar/} 2013-11-09 17:02:36,804 INFO [org.jboss.ejb3.deployers.Ejb3DependenciesDeployer] Encountered deployment AbstractVFSDeploymentContext@1367141275{vfszip:/home/epankmi/Desktop/nuxeo-dm-5.4.0_01-jboss/nuxeo-dm-5.4.0.1-jboss/server/default/deploy/nuxeo.ear/bundles/nuxeo-platform-audit-facade-5.4.0.1.jar/} 2013-11-09 17:02:36,804 INFO [org.jboss.ejb3.deployers.Ejb3DependenciesDeployer] Encountered deployment AbstractVFSDeploymentContext@1367141275{vfszip:/home/epankmi/Desktop/nuxeo-dm-5.4.0_01-jboss/nuxeo-dm-5.4.0.1-jboss/server/default/deploy/nuxeo.ear/bundles/nuxeo-platform-audit-facade-5.4.0.1.jar/} 2013-11-09 17:02:36,804 INFO [org.jboss.ejb3.deployers.Ejb3DependenciesDeployer] Encountered deployment AbstractVFSDeploymentContext@1615869672{vfszip:/home/epankmi/Desktop/nuxeo-dm-5.4.0_01-jboss/nuxeo-dm-5.4.0.1-jboss/server/default/deploy/nuxeo.ear/bundles/nuxeo-platform-comment-5.4.0.1.jar/} 2013-11-09 17:02:36,804 INFO [org.jboss.ejb3.deployers.Ejb3DependenciesDeployer] Encountered deployment AbstractVFSDeploymentContext@1615869672{vfszip:/home/epankmi/Desktop/nuxeo-dm-5.4.0_01-jboss/nuxeo-dm-5.4.0.1-jboss/server/default/deploy/nuxeo.ear/bundles/nuxeo-platform-comment-5.4.0.1.jar/} 2013-11-09 17:02:36,804 INFO [org.jboss.ejb3.deployers.Ejb3DependenciesDeployer] Encountered deployment AbstractVFSDeploymentContext@843377342{vfszip:/home/epankmi/Desktop/nuxeo-dm-5.4.0_01-jboss/nuxeo-dm-5.4.0.1-jboss/server/default/deploy/nuxeo.ear/bundles/nuxeo-platform-directory-facade-5.4.0.1.jar/} 2013-11-09 17:02:36,804 INFO [org.jboss.ejb3.deployers.Ejb3DependenciesDeployer] Encountered deployment AbstractVFSDeploymentContext@843377342{vfszip:/home/epankmi/Desktop/nuxeo-dm-5.4.0_01-jboss/nuxeo-dm-5.4.0.1-jboss/server/default/deploy/nuxeo.ear/bundles/nuxeo-platform-directory-facade-5.4.0.1.jar/} 2013-11-09 17:02:36,804 INFO [org.jboss.ejb3.deployers.Ejb3DependenciesDeployer] Encountered deployment AbstractVFSDeploymentContext@364101573{vfszip:/home/epankmi/Desktop/nuxeo-dm-5.4.0_01-jboss/nuxeo-dm-5.4.0.1-jboss/server/default/deploy/nuxeo.ear/bundles/nuxeo-platform-filemanager-facade-5.4.0.1.jar/} 2013-11-09 17:02:36,804 INFO [org.jboss.ejb3.deployers.Ejb3DependenciesDeployer] Encountered deployment AbstractVFSDeploymentContext@364101573{vfszip:/home/epankmi/Desktop/nuxeo-dm-5.4.0_01-jboss/nuxeo-dm-5.4.0.1-jboss/server/default/deploy/nuxeo.ear/bundles/nuxeo-platform-filemanager-facade-5.4.0.1.jar/} 2013-11-09 17:02:36,804 INFO [org.jboss.ejb3.deployers.Ejb3DependenciesDeployer] Encountered deployment AbstractVFSDeploymentContext@1228076272{vfszip:/home/epankmi/Desktop/nuxeo-dm-5.4.0_01-jboss/nuxeo-dm-5.4.0.1-jboss/server/default/deploy/nuxeo.ear/bundles/nuxeo-platform-imaging-facade-5.4.0.1.jar/} 2013-11-09 17:02:36,804 INFO [org.jboss.ejb3.deployers.Ejb3DependenciesDeployer] Encountered deployment AbstractVFSDeploymentContext@1228076272{vfszip:/home/epankmi/Desktop/nuxeo-dm-5.4.0_01-jboss/nuxeo-dm-5.4.0.1-jboss/server/default/deploy/nuxeo.ear/bundles/nuxeo-platform-imaging-facade-5.4.0.1.jar/} 2013-11-09 17:02:36,804 INFO [org.jboss.ejb3.deployers.Ejb3DependenciesDeployer] Encountered deployment AbstractVFSDeploymentContext@1052235636{vfszip:/home/epankmi/Desktop/nuxeo-dm-5.4.0_01-jboss/nuxeo-dm-5.4.0.1-jboss/server/default/deploy/nuxeo.ear/bundles/nuxeo-platform-io-facade-5.4.0.1.jar/} 2013-11-09 17:02:36,804 INFO [org.jboss.ejb3.deployers.Ejb3DependenciesDeployer] Encountered deployment AbstractVFSDeploymentContext@1052235636{vfszip:/home/epankmi/Desktop/nuxeo-dm-5.4.0_01-jboss/nuxeo-dm-5.4.0.1-jboss/server/default/deploy/nuxeo.ear/bundles/nuxeo-platform-io-facade-5.4.0.1.jar/} 2013-11-09 17:02:36,804 INFO [org.jboss.ejb3.deployers.Ejb3DependenciesDeployer] Encountered deployment AbstractVFSDeploymentContext@396501207{vfszip:/home/epankmi/Desktop/nuxeo-dm-5.4.0_01-jboss/nuxeo-dm-5.4.0.1-jboss/server/default/deploy/nuxeo.ear/bundles/nuxeo-platform-jbpm-facade-5.4.0.1.jar/} 2013-11-09 17:02:36,804 INFO [org.jboss.ejb3.deployers.Ejb3DependenciesDeployer] Encountered deployment AbstractVFSDeploymentContext@396501207{vfszip:/home/epankmi/Desktop/nuxeo-dm-5.4.0_01-jboss/nuxeo-dm-5.4.0.1-jboss/server/default/deploy/nuxeo.ear/bundles/nuxeo-platform-jbpm-facade-5.4.0.1.jar/} 2013-11-09 17:02:36,805 INFO [org.jboss.ejb3.deployers.Ejb3DependenciesDeployer] Encountered deployment AbstractVFSDeploymentContext@1642558066{vfszip:/home/epankmi/Desktop/nuxeo-dm-5.4.0_01-jboss/nuxeo-dm-5.4.0.1-jboss/server/default/deploy/nuxeo.ear/bundles/nuxeo-platform-mimetype-facade-5.4.0.1.jar/} 2013-11-09 17:02:36,805 INFO [org.jboss.ejb3.deployers.Ejb3DependenciesDeployer] Encountered deployment AbstractVFSDeploymentContext@1642558066{vfszip:/home/epankmi/Desktop/nuxeo-dm-5.4.0_01-jboss/nuxeo-dm-5.4.0.1-jboss/server/default/deploy/nuxeo.ear/bundles/nuxeo-platform-mimetype-facade-5.4.0.1.jar/} 2013-11-09 17:02:36,805 INFO [org.jboss.ejb3.deployers.Ejb3DependenciesDeployer] Encountered deployment AbstractVFSDeploymentContext@1929206696{vfszip:/home/epankmi/Desktop/nuxeo-dm-5.4.0_01-jboss/nuxeo-dm-5.4.0.1-jboss/server/default/deploy/nuxeo.ear/bundles/nuxeo-platform-notification-facade-5.4.0.1.jar/} 2013-11-09 17:02:36,805 INFO [org.jboss.ejb3.deployers.Ejb3DependenciesDeployer] Encountered deployment AbstractVFSDeploymentContext@1929206696{vfszip:/home/epankmi/Desktop/nuxeo-dm-5.4.0_01-jboss/nuxeo-dm-5.4.0.1-jboss/server/default/deploy/nuxeo.ear/bundles/nuxeo-platform-notification-facade-5.4.0.1.jar/} 2013-11-09 17:02:36,805 INFO [org.jboss.ejb3.deployers.Ejb3DependenciesDeployer] Encountered deployment AbstractVFSDeploymentContext@240293799{vfszip:/home/epankmi/Desktop/nuxeo-dm-5.4.0_01-jboss/nuxeo-dm-5.4.0.1-jboss/server/default/deploy/nuxeo.ear/bundles/nuxeo-platform-placeful-facade-5.4.0.1.jar/} 2013-11-09 17:02:36,805 INFO [org.jboss.ejb3.deployers.Ejb3DependenciesDeployer] Encountered deployment AbstractVFSDeploymentContext@240293799{vfszip:/home/epankmi/Desktop/nuxeo-dm-5.4.0_01-jboss/nuxeo-dm-5.4.0.1-jboss/server/default/deploy/nuxeo.ear/bundles/nuxeo-platform-placeful-facade-5.4.0.1.jar/} 2013-11-09 17:02:36,805 INFO [org.jboss.ejb3.deployers.Ejb3DependenciesDeployer] Encountered deployment AbstractVFSDeploymentContext@1768125815{vfszip:/home/epankmi/Desktop/nuxeo-dm-5.4.0_01-jboss/nuxeo-dm-5.4.0.1-jboss/server/default/deploy/nuxeo.ear/bundles/nuxeo-platform-relations-facade-5.4.0.1.jar/} 2013-11-09 17:02:36,805 INFO [org.jboss.ejb3.deployers.Ejb3DependenciesDeployer] Encountered deployment AbstractVFSDeploymentContext@1768125815{vfszip:/home/epankmi/Desktop/nuxeo-dm-5.4.0_01-jboss/nuxeo-dm-5.4.0.1-jboss/server/default/deploy/nuxeo.ear/bundles/nuxeo-platform-relations-facade-5.4.0.1.jar/} 2013-11-09 17:02:36,805 INFO [org.jboss.ejb3.deployers.Ejb3DependenciesDeployer] Encountered deployment AbstractVFSDeploymentContext@267212923{vfszip:/home/epankmi/Desktop/nuxeo-dm-5.4.0_01-jboss/nuxeo-dm-5.4.0.1-jboss/server/default/deploy/nuxeo.ear/bundles/nuxeo-platform-search-facade-5.4.0.1.jar/} 2013-11-09 17:02:36,805 INFO [org.jboss.ejb3.deployers.Ejb3DependenciesDeployer] Encountered deployment AbstractVFSDeploymentContext@267212923{vfszip:/home/epankmi/Desktop/nuxeo-dm-5.4.0_01-jboss/nuxeo-dm-5.4.0.1-jboss/server/default/deploy/nuxeo.ear/bundles/nuxeo-platform-search-facade-5.4.0.1.jar/} 2013-11-09 17:02:36,805 INFO [org.jboss.ejb3.deployers.Ejb3DependenciesDeployer] Encountered deployment AbstractVFSDeploymentContext@267212923{vfszip:/home/epankmi/Desktop/nuxeo-dm-5.4.0_01-jboss/nuxeo-dm-5.4.0.1-jboss/server/default/deploy/nuxeo.ear/bundles/nuxeo-platform-search-facade-5.4.0.1.jar/} 2013-11-09 17:02:36,805 INFO [org.jboss.ejb3.deployers.Ejb3DependenciesDeployer] Encountered deployment AbstractVFSDeploymentContext@267212923{vfszip:/home/epankmi/Desktop/nuxeo-dm-5.4.0_01-jboss/nuxeo-dm-5.4.0.1-jboss/server/default/deploy/nuxeo.ear/bundles/nuxeo-platform-search-facade-5.4.0.1.jar/} 2013-11-09 17:02:36,805 INFO [org.jboss.ejb3.deployers.Ejb3DependenciesDeployer] Encountered deployment AbstractVFSDeploymentContext@659290984{vfszip:/home/epankmi/Desktop/nuxeo-dm-5.4.0_01-jboss/nuxeo-dm-5.4.0.1-jboss/server/default/deploy/nuxeo.ear/bundles/nuxeo-platform-tag-facade-5.4.0.1.jar/} 2013-11-09 17:02:36,805 INFO [org.jboss.ejb3.deployers.Ejb3DependenciesDeployer] Encountered deployment AbstractVFSDeploymentContext@659290984{vfszip:/home/epankmi/Desktop/nuxeo-dm-5.4.0_01-jboss/nuxeo-dm-5.4.0.1-jboss/server/default/deploy/nuxeo.ear/bundles/nuxeo-platform-tag-facade-5.4.0.1.jar/} 2013-11-09 17:02:36,889 INFO [org.jboss.ejb3.deployers.Ejb3DependenciesDeployer] Encountered deployment AbstractVFSDeploymentContext@659290984{vfszip:/home/epankmi/Desktop/nuxeo-dm-5.4.0_01-jboss/nuxeo-dm-5.4.0.1-jboss/server/default/deploy/nuxeo.ear/bundles/nuxeo-platform-tag-facade-5.4.0.1.jar/} 2013-11-09 17:02:36,889 INFO [org.jboss.ejb3.deployers.Ejb3DependenciesDeployer] Encountered deployment AbstractVFSDeploymentContext@659290984{vfszip:/home/epankmi/Desktop/nuxeo-dm-5.4.0_01-jboss/nuxeo-dm-5.4.0.1-jboss/server/default/deploy/nuxeo.ear/bundles/nuxeo-platform-tag-facade-5.4.0.1.jar/} 2013-11-09 17:02:36,889 INFO [org.jboss.ejb3.deployers.Ejb3DependenciesDeployer] Encountered deployment AbstractVFSDeploymentContext@1691230760{vfszip:/home/epankmi/Desktop/nuxeo-dm-5.4.0_01-jboss/nuxeo-dm-5.4.0.1-jboss/server/default/deploy/nuxeo.ear/bundles/nuxeo-platform-types-facade-5.4.0.1.jar/} 2013-11-09 17:02:36,889 INFO [org.jboss.ejb3.deployers.Ejb3DependenciesDeployer] Encountered deployment AbstractVFSDeploymentContext@1691230760{vfszip:/home/epankmi/Desktop/nuxeo-dm-5.4.0_01-jboss/nuxeo-dm-5.4.0.1-jboss/server/default/deploy/nuxeo.ear/bundles/nuxeo-platform-types-facade-5.4.0.1.jar/} 2013-11-09 17:02:36,890 INFO [org.jboss.ejb3.deployers.Ejb3DependenciesDeployer] Encountered deployment AbstractVFSDeploymentContext@880653049{vfszip:/home/epankmi/Desktop/nuxeo-dm-5.4.0_01-jboss/nuxeo-dm-5.4.0.1-jboss/server/default/deploy/nuxeo.ear/bundles/nuxeo-platform-uidgen-core-5.4.0.1.jar/} 2013-11-09 17:02:36,890 INFO [org.jboss.ejb3.deployers.Ejb3DependenciesDeployer] Encountered deployment AbstractVFSDeploymentContext@880653049{vfszip:/home/epankmi/Desktop/nuxeo-dm-5.4.0_01-jboss/nuxeo-dm-5.4.0.1-jboss/server/default/deploy/nuxeo.ear/bundles/nuxeo-platform-uidgen-core-5.4.0.1.jar/} 2013-11-09 17:02:36,890 INFO [org.jboss.ejb3.deployers.Ejb3DependenciesDeployer] Encountered deployment AbstractVFSDeploymentContext@401569563{vfszip:/home/epankmi/Desktop/nuxeo-dm-5.4.0_01-jboss/nuxeo-dm-5.4.0.1-jboss/server/default/deploy/nuxeo.ear/bundles/nuxeo-platform-url-facade-5.4.0.1.jar/} 2013-11-09 17:02:36,890 INFO [org.jboss.ejb3.deployers.Ejb3DependenciesDeployer] Encountered deployment AbstractVFSDeploymentContext@401569563{vfszip:/home/epankmi/Desktop/nuxeo-dm-5.4.0_01-jboss/nuxeo-dm-5.4.0.1-jboss/server/default/deploy/nuxeo.ear/bundles/nuxeo-platform-url-facade-5.4.0.1.jar/} 2013-11-09 17:02:36,890 INFO [org.jboss.ejb3.deployers.Ejb3DependenciesDeployer] Encountered deployment AbstractVFSDeploymentContext@1786026467{vfszip:/home/epankmi/Desktop/nuxeo-dm-5.4.0_01-jboss/nuxeo-dm-5.4.0.1-jboss/server/default/deploy/nuxeo.ear/bundles/nuxeo-platform-usermanager-facade-5.4.0.1.jar/} 2013-11-09 17:02:36,890 INFO [org.jboss.ejb3.deployers.Ejb3DependenciesDeployer] Encountered deployment AbstractVFSDeploymentContext@1786026467{vfszip:/home/epankmi/Desktop/nuxeo-dm-5.4.0_01-jboss/nuxeo-dm-5.4.0.1-jboss/server/default/deploy/nuxeo.ear/bundles/nuxeo-platform-usermanager-facade-5.4.0.1.jar/} 2013-11-09 17:02:36,890 INFO [org.jboss.ejb3.deployers.Ejb3DependenciesDeployer] Encountered deployment AbstractVFSDeploymentContext@73731046{vfszip:/home/epankmi/Desktop/nuxeo-dm-5.4.0_01-jboss/nuxeo-dm-5.4.0.1-jboss/server/default/deploy/nuxeo.ear/bundles/nuxeo-platform-userworkspace-facade-5.4.0.1.jar/} 2013-11-09 17:02:36,890 INFO [org.jboss.ejb3.deployers.Ejb3DependenciesDeployer] Encountered deployment AbstractVFSDeploymentContext@73731046{vfszip:/home/epankmi/Desktop/nuxeo-dm-5.4.0_01-jboss/nuxeo-dm-5.4.0.1-jboss/server/default/deploy/nuxeo.ear/bundles/nuxeo-platform-userworkspace-facade-5.4.0.1.jar/} 2013-11-09 17:02:36,890 INFO [org.jboss.ejb3.deployers.Ejb3DependenciesDeployer] Encountered deployment AbstractVFSDeploymentContext@1650570568{vfszip:/home/epankmi/Desktop/nuxeo-dm-5.4.0_01-jboss/nuxeo-dm-5.4.0.1-jboss/server/default/deploy/nuxeo.ear/bundles/nuxeo-platform-versioning-core-5.4.0.1.jar/} 2013-11-09 17:02:36,890 INFO [org.jboss.ejb3.deployers.Ejb3DependenciesDeployer] Encountered deployment AbstractVFSDeploymentContext@1650570568{vfszip:/home/epankmi/Desktop/nuxeo-dm-5.4.0_01-jboss/nuxeo-dm-5.4.0.1-jboss/server/default/deploy/nuxeo.ear/bundles/nuxeo-platform-versioning-core-5.4.0.1.jar/} 2013-11-09 17:02:36,891 INFO [org.jboss.ejb3.deployers.Ejb3DependenciesDeployer] Encountered deployment AbstractVFSDeploymentContext@1479464985{vfszip:/home/epankmi/Desktop/nuxeo-dm-5.4.0_01-jboss/nuxeo-dm-5.4.0.1-jboss/server/default/deploy/nuxeo.ear/bundles/nuxeo-platform-webapp-core-5.4.0.1.jar/} 2013-11-09 17:02:36,891 INFO [org.jboss.ejb3.deployers.Ejb3DependenciesDeployer] Encountered deployment AbstractVFSDeploymentContext@1479464985{vfszip:/home/epankmi/Desktop/nuxeo-dm-5.4.0_01-jboss/nuxeo-dm-5.4.0.1-jboss/server/default/deploy/nuxeo.ear/bundles/nuxeo-platform-webapp-core-5.4.0.1.jar/} 2013-11-09 17:02:36,891 INFO [org.jboss.ejb3.deployers.Ejb3DependenciesDeployer] Encountered deployment AbstractVFSDeploymentContext@1479464985{vfszip:/home/epankmi/Desktop/nuxeo-dm-5.4.0_01-jboss/nuxeo-dm-5.4.0.1-jboss/server/default/deploy/nuxeo.ear/bundles/nuxeo-platform-webapp-core-5.4.0.1.jar/} 2013-11-09 17:02:40,732 ERROR [org.jboss.kernel.plugins.dependency.AbstractKernelController] Error installing to Start: name=jboss:service=invoker,type=http state=Create mode=Manual requiredState=Installed java.net.UnknownHostException: B1H68R1.egi.ericsson.com: B1H68R1.egi.ericsson.com at java.net.InetAddress.getLocalHost(InetAddress.java:1454) at org.jboss.invocation.http.server.HttpInvoker.checkInvokerURL(HttpInvoker.java:204) at org.jboss.invocation.http.server.HttpInvoker.startService(HttpInvoker.java:101) at org.jboss.system.ServiceMBeanSupport.jbossInternalStart(ServiceMBeanSupport.java:376) at org.jboss.system.ServiceMBeanSupport.jbossInternalLifecycle(ServiceMBeanSupport.java:322) at sun.reflect.GeneratedMethodAccessor81.invoke(Unknown Source) at sun.reflect.DelegatingMethodAccessorImpl.invoke(DelegatingMethodAccessorImpl.java:43) at java.lang.reflect.Method.invoke(Method.java:616) at org.jboss.mx.interceptor.ReflectedDispatcher.invoke(ReflectedDispatcher.java:157) at org.jboss.mx.server.Invocation.dispatch(Invocation.java:96) at org.jboss.mx.server.Invocation.invoke(Invocation.java:88) at org.jboss.mx.server.AbstractMBeanInvoker.invoke(AbstractMBeanInvoker.java:264) at org.jboss.mx.server.MBeanServerImpl.invoke(MBeanServerImpl.java:668) at org.jboss.system.microcontainer.ServiceProxy.invoke(ServiceProxy.java:189) at sun.proxy.$Proxy38.start(Unknown Source) at org.jboss.system.microcontainer.StartStopLifecycleAction.installAction(StartStopLifecycleAction.java:42) at org.jboss.system.microcontainer.StartStopLifecycleAction.installAction(StartStopLifecycleAction.java:37) at org.jboss.dependency.plugins.action.SimpleControllerContextAction.simpleInstallAction(SimpleControllerContextAction.java:62) at org.jboss.dependency.plugins.action.AccessControllerContextAction.install(AccessControllerContextAction.java:71) at org.jboss.dependency.plugins.AbstractControllerContextActions.install(AbstractControllerContextActions.java:51) at org.jboss.dependency.plugins.AbstractControllerContext.install(AbstractControllerContext.java:348) at org.jboss.system.microcontainer.ServiceControllerContext.install(ServiceControllerContext.java:286) at org.jboss.dependency.plugins.AbstractController.install(AbstractController.java:1631) at org.jboss.dependency.plugins.AbstractController.incrementState(AbstractController.java:934) at org.jboss.dependency.plugins.AbstractController.resolveContexts(AbstractController.java:1082) at org.jboss.dependency.plugins.AbstractController.resolveContexts(AbstractController.java:984) at org.jboss.dependency.plugins.AbstractController.change(AbstractController.java:822) at org.jboss.dependency.plugins.AbstractController.change(AbstractController.java:553) at org.jboss.system.ServiceController.doChange(ServiceController.java:688) at org.jboss.system.ServiceController.start(ServiceController.java:460) at org.jboss.system.deployers.ServiceDeployer.start(ServiceDeployer.java:163) at org.jboss.system.deployers.ServiceDeployer.deploy(ServiceDeployer.java:99) at org.jboss.system.deployers.ServiceDeployer.deploy(ServiceDeployer.java:46) at org.jboss.deployers.spi.deployer.helpers.AbstractSimpleRealDeployer.internalDeploy(AbstractSimpleRealDeployer.java:62) at org.jboss.deployers.spi.deployer.helpers.AbstractRealDeployer.deploy(AbstractRealDeployer.java:50) at org.jboss.deployers.plugins.deployers.DeployerWrapper.deploy(DeployerWrapper.java:171) at org.jboss.deployers.plugins.deployers.DeployersImpl.doDeploy(DeployersImpl.java:1439) at org.jboss.deployers.plugins.deployers.DeployersImpl.doInstallParentFirst(DeployersImpl.java:1157) at org.jboss.deployers.plugins.deployers.DeployersImpl.doInstallParentFirst(DeployersImpl.java:1178) at org.jboss.deployers.plugins.deployers.DeployersImpl.install(DeployersImpl.java:1098) at org.jboss.dependency.plugins.AbstractControllerContext.install(AbstractControllerContext.java:348) at org.jboss.dependency.plugins.AbstractController.install(AbstractController.java:1631) at org.jboss.dependency.plugins.AbstractController.incrementState(AbstractController.java:934) at org.jboss.dependency.plugins.AbstractController.resolveContexts(AbstractController.java:1082) at org.jboss.dependency.plugins.AbstractController.resolveContexts(AbstractController.java:984) at org.jboss.dependency.plugins.AbstractController.change(AbstractController.java:822) at org.jboss.dependency.plugins.AbstractController.change(AbstractController.java:553) at org.jboss.deployers.plugins.deployers.DeployersImpl.process(DeployersImpl.java:781) at org.jboss.deployers.plugins.main.MainDeployerImpl.process(MainDeployerImpl.java:702) at org.jboss.system.server.profileservice.repository.MainDeployerAdapter.process(MainDeployerAdapter.java:117) at org.jboss.system.server.profileservice.repository.ProfileDeployAction.install(ProfileDeployAction.java:70) at org.jboss.system.server.profileservice.repository.AbstractProfileAction.install(AbstractProfileAction.java:53) at org.jboss.system.server.profileservice.repository.AbstractProfileService.install(AbstractProfileService.java:361) at org.jboss.dependency.plugins.AbstractControllerContext.install(AbstractControllerContext.java:348) at org.jboss.dependency.plugins.AbstractController.install(AbstractController.java:1631) at org.jboss.dependency.plugins.AbstractController.incrementState(AbstractController.java:934) at org.jboss.dependency.plugins.AbstractController.resolveContexts(AbstractController.java:1082) at org.jboss.dependency.plugins.AbstractController.resolveContexts(AbstractController.java:984) at org.jboss.dependency.plugins.AbstractController.change(AbstractController.java:822) at org.jboss.dependency.plugins.AbstractController.change(AbstractController.java:553) at org.jboss.system.server.profileservice.repository.AbstractProfileService.activateProfile(AbstractProfileService.java:306) at org.jboss.system.server.profileservice.ProfileServiceBootstrap.start(ProfileServiceBootstrap.java:271) at org.jboss.bootstrap.AbstractServerImpl.start(AbstractServerImpl.java:461) at org.jboss.Main.boot(Main.java:221) at org.jboss.Main$1.run(Main.java:556) at java.lang.Thread.run(Thread.java:679) 2013-11-09 17:02:40,745 ERROR [org.jboss.kernel.plugins.dependency.AbstractKernelController] Error installing to Real: name=vfsfile:/home/epankmi/Desktop/nuxeo-dm-5.4.0_01-jboss/nuxeo-dm-5.4.0.1-jboss/server/default/deploy/http-invoker.sar/ state=PreReal mode=Manual requiredState=Real org.jboss.deployers.spi.DeploymentException: Error deploying: jboss:service=invoker,type=http at org.jboss.deployers.spi.DeploymentException.rethrowAsDeploymentException(DeploymentException.java:49) at org.jboss.system.deployers.ServiceDeployer.deploy(ServiceDeployer.java:118) at org.jboss.system.deployers.ServiceDeployer.deploy(ServiceDeployer.java:46) at org.jboss.deployers.spi.deployer.helpers.AbstractSimpleRealDeployer.internalDeploy(AbstractSimpleRealDeployer.java:62) at org.jboss.deployers.spi.deployer.helpers.AbstractRealDeployer.deploy(AbstractRealDeployer.java:50) at org.jboss.deployers.plugins.deployers.DeployerWrapper.deploy(DeployerWrapper.java:171) at org.jboss.deployers.plugins.deployers.DeployersImpl.doDeploy(DeployersImpl.java:1439) at org.jboss.deployers.plugins.deployers.DeployersImpl.doInstallParentFirst(DeployersImpl.java:1157) at org.jboss.deployers.plugins.deployers.DeployersImpl.doInstallParentFirst(DeployersImpl.java:1178) at org.jboss.deployers.plugins.deployers.DeployersImpl.install(DeployersImpl.java:1098) at org.jboss.dependency.plugins.AbstractControllerContext.install(AbstractControllerContext.java:348) at org.jboss.dependency.plugins.AbstractController.install(AbstractController.java:1631) at org.jboss.dependency.plugins.AbstractController.incrementState(AbstractController.java:934) at org.jboss.dependency.plugins.AbstractController.resolveContexts(AbstractController.java:1082) at org.jboss.dependency.plugins.AbstractController.resolveContexts(AbstractController.java:984) at org.jboss.dependency.plugins.AbstractController.change(AbstractController.java:822) at org.jboss.dependency.plugins.AbstractController.change(AbstractController.java:553) at org.jboss.deployers.plugins.deployers.DeployersImpl.process(DeployersImpl.java:781) at org.jboss.deployers.plugins.main.MainDeployerImpl.process(MainDeployerImpl.java:702) at org.jboss.system.server.profileservice.repository.MainDeployerAdapter.process(MainDeployerAdapter.java:117) at org.jboss.system.server.profileservice.repository.ProfileDeployAction.install(ProfileDeployAction.java:70) at org.jboss.system.server.profileservice.repository.AbstractProfileAction.install(AbstractProfileAction.java:53) at org.jboss.system.server.profileservice.repository.AbstractProfileService.install(AbstractProfileService.java:361) at org.jboss.dependency.plugins.AbstractControllerContext.install(AbstractControllerContext.java:348) at org.jboss.dependency.plugins.AbstractController.install(AbstractController.java:1631) at org.jboss.dependency.plugins.AbstractController.incrementState(AbstractController.java:934) at org.jboss.dependency.plugins.AbstractController.resolveContexts(AbstractController.java:1082) at org.jboss.dependency.plugins.AbstractController.resolveContexts(AbstractController.java:984) at org.jboss.dependency.plugins.AbstractController.change(AbstractController.java:822) at org.jboss.dependency.plugins.AbstractController.change(AbstractController.java:553) at org.jboss.system.server.profileservice.repository.AbstractProfileService.activateProfile(AbstractProfileService.java:306) at org.jboss.system.server.profileservice.ProfileServiceBootstrap.start(ProfileServiceBootstrap.java:271) at org.jboss.bootstrap.AbstractServerImpl.start(AbstractServerImpl.java:461) at org.jboss.Main.boot(Main.java:221) at org.jboss.Main$1.run(Main.java:556) at java.lang.Thread.run(Thread.java:679) Caused by: java.net.UnknownHostException: B1H68R1.egi.ericsson.com: B1H68R1.egi.ericsson.com at java.net.InetAddress.getLocalHost(InetAddress.java:1454) at org.jboss.invocation.http.server.HttpInvoker.checkInvokerURL(HttpInvoker.java:204) at org.jboss.invocation.http.server.HttpInvoker.startService(HttpInvoker.java:101) at org.jboss.system.ServiceMBeanSupport.jbossInternalStart(ServiceMBeanSupport.java:376) at org.jboss.system.ServiceMBeanSupport.jbossInternalLifecycle(ServiceMBeanSupport.java:322) at sun.reflect.GeneratedMethodAccessor81.invoke(Unknown Source) at sun.reflect.DelegatingMethodAccessorImpl.invoke(DelegatingMethodAccessorImpl.java:43) at java.lang.reflect.Method.invoke(Method.java:616) at org.jboss.mx.interceptor.ReflectedDispatcher.invoke(ReflectedDispatcher.java:157) at org.jboss.mx.server.Invocation.dispatch(Invocation.java:96) at org.jboss.mx.server.Invocation.invoke(Invocation.java:88) at org.jboss.mx.server.AbstractMBeanInvoker.invoke(AbstractMBeanInvoker.java:264) at org.jboss.mx.server.MBeanServerImpl.invoke(MBeanServerImpl.java:668) at org.jboss.system.microcontainer.ServiceProxy.invoke(ServiceProxy.java:189) at sun.proxy.$Proxy38.start(Unknown Source) at org.jboss.system.microcontainer.StartStopLifecycleAction.installAction(StartStopLifecycleAction.java:42) at org.jboss.system.microcontainer.StartStopLifecycleAction.installAction(StartStopLifecycleAction.java:37) at org.jboss.dependency.plugins.action.SimpleControllerContextAction.simpleInstallAction(SimpleControllerContextAction.java:62) at org.jboss.dependency.plugins.action.AccessControllerContextAction.install(AccessControllerContextAction.java:71) at org.jboss.dependency.plugins.AbstractControllerContextActions.install(AbstractControllerContextActions.java:51) at org.jboss.dependency.plugins.AbstractControllerContext.install(AbstractControllerContext.java:348) at org.jboss.system.microcontainer.ServiceControllerContext.install(ServiceControllerContext.java:286) at org.jboss.dependency.plugins.AbstractController.install(AbstractController.java:1631) at org.jboss.dependency.plugins.AbstractController.incrementState(AbstractController.java:934) at org.jboss.dependency.plugins.AbstractController.resolveContexts(AbstractController.java:1082) at org.jboss.dependency.plugins.AbstractController.resolveContexts(AbstractController.java:984) at org.jboss.dependency.plugins.AbstractController.change(AbstractController.java:822) at org.jboss.dependency.plugins.AbstractController.change(AbstractController.java:553) at org.jboss.system.ServiceController.doChange(ServiceController.java:688) at org.jboss.system.ServiceController.start(ServiceController.java:460) at org.jboss.system.deployers.ServiceDeployer.start(ServiceDeployer.java:163) at org.jboss.system.deployers.ServiceDeployer.deploy(ServiceDeployer.java:99) ... 34 more 2013-11-09 17:02:42,354 ERROR [org.jboss.kernel.plugins.dependency.AbstractKernelController] Error installing to Start: name=jboss.remoting:protocol=rmi,service=JMXConnectorServer state=Create mode=Manual requiredState=Installed java.rmi.server.ExportException: Port already in use: 1090; nested exception is: java.net.BindException: Address already in use at sun.rmi.transport.tcp.TCPTransport.listen(TCPTransport.java:328) at sun.rmi.transport.tcp.TCPTransport.exportObject(TCPTransport.java:236) at sun.rmi.transport.tcp.TCPEndpoint.exportObject(TCPEndpoint.java:411) at sun.rmi.transport.LiveRef.exportObject(LiveRef.java:147) at sun.rmi.server.UnicastServerRef.exportObject(UnicastServerRef.java:207) at sun.rmi.registry.RegistryImpl.setup(RegistryImpl.java:122) at sun.rmi.registry.RegistryImpl.(RegistryImpl.java:98) at java.rmi.registry.LocateRegistry.createRegistry(LocateRegistry.java:239) at org.jboss.mx.remoting.service.JMXConnectorServerService.start(JMXConnectorServerService.java:117) at sun.reflect.NativeMethodAccessorImpl.invoke0(Native Method) at sun.reflect.NativeMethodAccessorImpl.invoke(NativeMethodAccessorImpl.java:57) at sun.reflect.DelegatingMethodAccessorImpl.invoke(DelegatingMethodAccessorImpl.java:43) at java.lang.reflect.Method.invoke(Method.java:616) at org.jboss.mx.interceptor.ReflectedDispatcher.invoke(ReflectedDispatcher.java:157) at org.jboss.mx.server.Invocation.dispatch(Invocation.java:96) at org.jboss.mx.server.Invocation.invoke(Invocation.java:88) at org.jboss.mx.server.AbstractMBeanInvoker.invoke(AbstractMBeanInvoker.java:264) at org.jboss.mx.server.MBeanServerImpl.invoke(MBeanServerImpl.java:668) at org.jboss.system.microcontainer.ServiceProxy.invoke(ServiceProxy.java:206) at sun.proxy.$Proxy38.start(Unknown Source) at org.jboss.system.microcontainer.StartStopLifecycleAction.installAction(StartStopLifecycleAction.java:42) at org.jboss.system.microcontainer.StartStopLifecycleAction.installAction(StartStopLifecycleAction.java:37) at org.jboss.dependency.plugins.action.SimpleControllerContextAction.simpleInstallAction(SimpleControllerContextAction.java:62) at org.jboss.dependency.plugins.action.AccessControllerContextAction.install(AccessControllerContextAction.java:71) at org.jboss.dependency.plugins.AbstractControllerContextActions.install(AbstractControllerContextActions.java:51) at org.jboss.dependency.plugins.AbstractControllerContext.install(AbstractControllerContext.java:348) at org.jboss.system.microcontainer.ServiceControllerContext.install(ServiceControllerContext.java:286) at org.jboss.dependency.plugins.AbstractController.install(AbstractController.java:1631) at org.jboss.dependency.plugins.AbstractController.incrementState(AbstractController.java:934) at org.jboss.dependency.plugins.AbstractController.resolveContexts(AbstractController.java:1082) at org.jboss.dependency.plugins.AbstractController.resolveContexts(AbstractController.java:984) at org.jboss.dependency.plugins.AbstractController.change(AbstractController.java:822) at org.jboss.dependency.plugins.AbstractController.change(AbstractController.java:553) at org.jboss.system.ServiceController.doChange(ServiceController.java:688) at org.jboss.system.ServiceController.start(ServiceController.java:460) at org.jboss.system.deployers.ServiceDeployer.start(ServiceDeployer.java:163) at org.jboss.system.deployers.ServiceDeployer.deploy(ServiceDeployer.java:99) at org.jboss.system.deployers.ServiceDeployer.deploy(ServiceDeployer.java:46) at org.jboss.deployers.spi.deployer.helpers.AbstractSimpleRealDeployer.internalDeploy(AbstractSimpleRealDeployer.java:62) at org.jboss.deployers.spi.deployer.helpers.AbstractRealDeployer.deploy(AbstractRealDeployer.java:50) at org.jboss.deployers.plugins.deployers.DeployerWrapper.deploy(DeployerWrapper.java:171) at org.jboss.deployers.plugins.deployers.DeployersImpl.doDeploy(DeployersImpl.java:1439) at org.jboss.deployers.plugins.deployers.DeployersImpl.doInstallParentFirst(DeployersImpl.java:1157) at org.jboss.deployers.plugins.deployers.DeployersImpl.doInstallParentFirst(DeployersImpl.java:1178) at org.jboss.deployers.plugins.deployers.DeployersImpl.install(DeployersImpl.java:1098) at org.jboss.dependency.plugins.AbstractControllerContext.install(AbstractControllerContext.java:348) at org.jboss.dependency.plugins.AbstractController.install(AbstractController.java:1631) at org.jboss.dependency.plugins.AbstractController.incrementState(AbstractController.java:934) at org.jboss.dependency.plugins.AbstractController.resolveContexts(AbstractController.java:1082) at org.jboss.dependency.plugins.AbstractController.resolveContexts(AbstractController.java:984) at org.jboss.dependency.plugins.AbstractController.change(AbstractController.java:822) at org.jboss.dependency.plugins.AbstractController.change(AbstractController.java:553) at org.jboss.deployers.plugins.deployers.DeployersImpl.process(DeployersImpl.java:781) at org.jboss.deployers.plugins.main.MainDeployerImpl.process(MainDeployerImpl.java:702) at org.jboss.system.server.profileservice.repository.MainDeployerAdapter.process(MainDeployerAdapter.java:117) at org.jboss.system.server.profileservice.repository.ProfileDeployAction.install(ProfileDeployAction.java:70) at org.jboss.system.server.profileservice.repository.AbstractProfileAction.install(AbstractProfileAction.java:53) at org.jboss.system.server.profileservice.repository.AbstractProfileService.install(AbstractProfileService.java:361) at org.jboss.dependency.plugins.AbstractControllerContext.install(AbstractControllerContext.java:348) at org.jboss.dependency.plugins.AbstractController.install(AbstractController.java:1631) at org.jboss.dependency.plugins.AbstractController.incrementState(AbstractController.java:934) at org.jboss.dependency.plugins.AbstractController.resolveContexts(AbstractController.java:1082) at org.jboss.dependency.plugins.AbstractController.resolveContexts(AbstractController.java:984) at org.jboss.dependency.plugins.AbstractController.change(AbstractController.java:822) at org.jboss.dependency.plugins.AbstractController.change(AbstractController.java:553) at org.jboss.system.server.profileservice.repository.AbstractProfileService.activateProfile(AbstractProfileService.java:306) at org.jboss.system.server.profileservice.ProfileServiceBootstrap.start(ProfileServiceBootstrap.java:271) at org.jboss.bootstrap.AbstractServerImpl.start(AbstractServerImpl.java:461) at org.jboss.Main.boot(Main.java:221) at org.jboss.Main$1.run(Main.java:556) at java.lang.Thread.run(Thread.java:679) Caused by: java.net.BindException: Address already in use at java.net.PlainSocketImpl.socketBind(Native Method) at java.net.AbstractPlainSocketImpl.bind(AbstractPlainSocketImpl.java:353) at java.net.ServerSocket.bind(ServerSocket.java:336) at java.net.ServerSocket.(ServerSocket.java:202) at org.jboss.net.sockets.DefaultSocketFactory.createServerSocket(DefaultSocketFactory.java:124) at org.jboss.net.sockets.DefaultSocketFactory.createServerSocket(DefaultSocketFactory.java:99) at sun.rmi.transport.tcp.TCPEndpoint.newServerSocket(TCPEndpoint.java:667) at sun.rmi.transport.tcp.TCPTransport.listen(TCPTransport.java:317) ... 70 more 2013-11-09 17:02:42,358 ERROR [org.jboss.kernel.plugins.dependency.AbstractKernelController] Error installing to Real: name=vfsfile:/home/epankmi/Desktop/nuxeo-dm-5.4.0_01-jboss/nuxeo-dm-5.4.0.1-jboss/server/default/deploy/jmx-remoting.sar/ state=PreReal mode=Manual requiredState=Real org.jboss.deployers.spi.DeploymentException: Error deploying: jboss.remoting:service=JMXConnectorServer,protocol=rmi at org.jboss.deployers.spi.DeploymentException.rethrowAsDeploymentException(DeploymentException.java:49) at org.jboss.system.deployers.ServiceDeployer.deploy(ServiceDeployer.java:118) at org.jboss.system.deployers.ServiceDeployer.deploy(ServiceDeployer.java:46) at org.jboss.deployers.spi.deployer.helpers.AbstractSimpleRealDeployer.internalDeploy(AbstractSimpleRealDeployer.java:62) at org.jboss.deployers.spi.deployer.helpers.AbstractRealDeployer.deploy(AbstractRealDeployer.java:50) at org.jboss.deployers.plugins.deployers.DeployerWrapper.deploy(DeployerWrapper.java:171) at org.jboss.deployers.plugins.deployers.DeployersImpl.doDeploy(DeployersImpl.java:1439) at org.jboss.deployers.plugins.deployers.DeployersImpl.doInstallParentFirst(DeployersImpl.java:1157) at org.jboss.deployers.plugins.deployers.DeployersImpl.doInstallParentFirst(DeployersImpl.java:1178) at org.jboss.deployers.plugins.deployers.DeployersImpl.install(DeployersImpl.java:1098) at org.jboss.dependency.plugins.AbstractControllerContext.install(AbstractControllerContext.java:348) at org.jboss.dependency.plugins.AbstractController.install(AbstractController.java:1631) at org.jboss.dependency.plugins.AbstractController.incrementState(AbstractController.java:934) at org.jboss.dependency.plugins.AbstractController.resolveContexts(AbstractController.java:1082) at org.jboss.dependency.plugins.AbstractController.resolveContexts(AbstractController.java:984) at org.jboss.dependency.plugins.AbstractController.change(AbstractController.java:822) at org.jboss.dependency.plugins.AbstractController.change(AbstractController.java:553) at org.jboss.deployers.plugins.deployers.DeployersImpl.process(DeployersImpl.java:781) at org.jboss.deployers.plugins.main.MainDeployerImpl.process(MainDeployerImpl.java:702) at org.jboss.system.server.profileservice.repository.MainDeployerAdapter.process(MainDeployerAdapter.java:117) at org.jboss.system.server.profileservice.repository.ProfileDeployAction.install(ProfileDeployAction.java:70) at org.jboss.system.server.profileservice.repository.AbstractProfileAction.install(AbstractProfileAction.java:53) at org.jboss.system.server.profileservice.repository.AbstractProfileService.install(AbstractProfileService.java:361) at org.jboss.dependency.plugins.AbstractControllerContext.install(AbstractControllerContext.java:348) at org.jboss.dependency.plugins.AbstractController.install(AbstractController.java:1631) at org.jboss.dependency.plugins.AbstractController.incrementState(AbstractController.java:934) at org.jboss.dependency.plugins.AbstractController.resolveContexts(AbstractController.java:1082) at org.jboss.dependency.plugins.AbstractController.resolveContexts(AbstractController.java:984) at org.jboss.dependency.plugins.AbstractController.change(AbstractController.java:822) at org.jboss.dependency.plugins.AbstractController.change(AbstractController.java:553) at org.jboss.system.server.profileservice.repository.AbstractProfileService.activateProfile(AbstractProfileService.java:306) at org.jboss.system.server.profileservice.ProfileServiceBootstrap.start(ProfileServiceBootstrap.java:271) at org.jboss.bootstrap.AbstractServerImpl.start(AbstractServerImpl.java:461) at org.jboss.Main.boot(Main.java:221) at org.jboss.Main$1.run(Main.java:556) at java.lang.Thread.run(Thread.java:679) Caused by: java.rmi.server.ExportException: Port already in use: 1090; nested exception is: java.net.BindException: Address already in use at sun.rmi.transport.tcp.TCPTransport.listen(TCPTransport.java:328) at sun.rmi.transport.tcp.TCPTransport.exportObject(TCPTransport.java:236) at sun.rmi.transport.tcp.TCPEndpoint.exportObject(TCPEndpoint.java:411) at sun.rmi.transport.LiveRef.exportObject(LiveRef.java:147) at sun.rmi.server.UnicastServerRef.exportObject(UnicastServerRef.java:207) at sun.rmi.registry.RegistryImpl.setup(RegistryImpl.java:122) at sun.rmi.registry.RegistryImpl.(RegistryImpl.java:98) at java.rmi.registry.LocateRegistry.createRegistry(LocateRegistry.java:239) at org.jboss.mx.remoting.service.JMXConnectorServerService.start(JMXConnectorServerService.java:117) at sun.reflect.NativeMethodAccessorImpl.invoke0(Native Method) at sun.reflect.NativeMethodAccessorImpl.invoke(NativeMethodAccessorImpl.java:57) at sun.reflect.DelegatingMethodAccessorImpl.invoke(DelegatingMethodAccessorImpl.java:43) at java.lang.reflect.Method.invoke(Method.java:616) at org.jboss.mx.interceptor.ReflectedDispatcher.invoke(ReflectedDispatcher.java:157) at org.jboss.mx.server.Invocation.dispatch(Invocation.java:96) at org.jboss.mx.server.Invocation.invoke(Invocation.java:88) at org.jboss.mx.server.AbstractMBeanInvoker.invoke(AbstractMBeanInvoker.java:264) at org.jboss.mx.server.MBeanServerImpl.invoke(MBeanServerImpl.java:668) at org.jboss.system.microcontainer.ServiceProxy.invoke(ServiceProxy.java:206) at sun.proxy.$Proxy38.start(Unknown Source) at org.jboss.system.microcontainer.StartStopLifecycleAction.installAction(StartStopLifecycleAction.java:42) at org.jboss.system.microcontainer.StartStopLifecycleAction.installAction(StartStopLifecycleAction.java:37) at org.jboss.dependency.plugins.action.SimpleControllerContextAction.simpleInstallAction(SimpleControllerContextAction.java:62) at org.jboss.dependency.plugins.action.AccessControllerContextAction.install(AccessControllerContextAction.java:71) at org.jboss.dependency.plugins.AbstractControllerContextActions.install(AbstractControllerContextActions.java:51) at org.jboss.dependency.plugins.AbstractControllerContext.install(AbstractControllerContext.java:348) at org.jboss.system.microcontainer.ServiceControllerContext.install(ServiceControllerContext.java:286) at org.jboss.dependency.plugins.AbstractController.install(AbstractController.java:1631) at org.jboss.dependency.plugins.AbstractController.incrementState(AbstractController.java:934) at org.jboss.dependency.plugins.AbstractController.resolveContexts(AbstractController.java:1082) at org.jboss.dependency.plugins.AbstractController.resolveContexts(AbstractController.java:984) at org.jboss.dependency.plugins.AbstractController.change(AbstractController.java:822) at org.jboss.dependency.plugins.AbstractController.change(AbstractController.java:553) at org.jboss.system.ServiceController.doChange(ServiceController.java:688) at org.jboss.system.ServiceController.start(ServiceController.java:460) at org.jboss.system.deployers.ServiceDeployer.start(ServiceDeployer.java:163) at org.jboss.system.deployers.ServiceDeployer.deploy(ServiceDeployer.java:99) ... 34 more Caused by: java.net.BindException: Address already in use at java.net.PlainSocketImpl.socketBind(Native Method) at java.net.AbstractPlainSocketImpl.bind(AbstractPlainSocketImpl.java:353) at java.net.ServerSocket.bind(ServerSocket.java:336) at java.net.ServerSocket.(ServerSocket.java:202) at org.jboss.net.sockets.DefaultSocketFactory.createServerSocket(DefaultSocketFactory.java:124) at org.jboss.net.sockets.DefaultSocketFactory.createServerSocket(DefaultSocketFactory.java:99) at sun.rmi.transport.tcp.TCPEndpoint.newServerSocket(TCPEndpoint.java:667) at sun.rmi.transport.tcp.TCPTransport.listen(TCPTransport.java:317) ... 70 more 2013-11-09 17:02:45,136 ERROR [org.jboss.kernel.plugins.dependency.AbstractKernelController] Error installing to Create: name=jboss.messaging:service=Connector,transport=bisocket state=Configured mode=Manual requiredState=Create java.lang.RuntimeException: Error setting up server invoker SocketServerInvoker[0.0.0.0:4457] at org.jboss.remoting.ServerInvoker.create(ServerInvoker.java:936) at org.jboss.remoting.transport.Connector.init(Connector.java:436) at org.jboss.remoting.transport.Connector.create(Connector.java:1143) at sun.reflect.NativeMethodAccessorImpl.invoke0(Native Method) at sun.reflect.NativeMethodAccessorImpl.invoke(NativeMethodAccessorImpl.java:57) at sun.reflect.DelegatingMethodAccessorImpl.invoke(DelegatingMethodAccessorImpl.java:43) at java.lang.reflect.Method.invoke(Method.java:616) at org.jboss.mx.interceptor.ReflectedDispatcher.invoke(ReflectedDispatcher.java:157) at org.jboss.mx.server.Invocation.dispatch(Invocation.java:96) at org.jboss.mx.server.Invocation.invoke(Invocation.java:88) at org.jboss.mx.server.AbstractMBeanInvoker.invoke(AbstractMBeanInvoker.java:264) at org.jboss.mx.server.MBeanServerImpl.invoke(MBeanServerImpl.java:668) at org.jboss.system.microcontainer.ServiceProxy.invoke(ServiceProxy.java:206) at sun.proxy.$Proxy38.create(Unknown Source) at org.jboss.system.microcontainer.CreateDestroyLifecycleAction.installAction(CreateDestroyLifecycleAction.java:42) at org.jboss.system.microcontainer.CreateDestroyLifecycleAction.installAction(CreateDestroyLifecycleAction.java:37) at org.jboss.dependency.plugins.action.SimpleControllerContextAction.simpleInstallAction(SimpleControllerContextAction.java:62) at org.jboss.dependency.plugins.action.AccessControllerContextAction.install(AccessControllerContextAction.java:71) at org.jboss.dependency.plugins.AbstractControllerContextActions.install(AbstractControllerContextActions.java:51) at org.jboss.dependency.plugins.AbstractControllerContext.install(AbstractControllerContext.java:348) at org.jboss.system.microcontainer.ServiceControllerContext.install(ServiceControllerContext.java:286) at org.jboss.dependency.plugins.AbstractController.install(AbstractController.java:1631) at org.jboss.dependency.plugins.AbstractController.incrementState(AbstractController.java:934) at org.jboss.dependency.plugins.AbstractController.resolveContexts(AbstractController.java:1082) at org.jboss.dependency.plugins.AbstractController.resolveContexts(AbstractController.java:984) at org.jboss.dependency.plugins.AbstractController.change(AbstractController.java:822) at org.jboss.dependency.plugins.AbstractController.change(AbstractController.java:553) at org.jboss.system.ServiceController.doChange(ServiceController.java:688) at org.jboss.system.ServiceController.create(ServiceController.java:422) at org.jboss.system.ServiceController.create(ServiceController.java:387) at org.jboss.system.deployers.ServiceDeployer.create(ServiceDeployer.java:158) at org.jboss.system.deployers.ServiceDeployer.deploy(ServiceDeployer.java:96) at org.jboss.system.deployers.ServiceDeployer.deploy(ServiceDeployer.java:46) at org.jboss.deployers.spi.deployer.helpers.AbstractSimpleRealDeployer.internalDeploy(AbstractSimpleRealDeployer.java:62) at org.jboss.deployers.spi.deployer.helpers.AbstractRealDeployer.deploy(AbstractRealDeployer.java:50) at org.jboss.deployers.plugins.deployers.DeployerWrapper.deploy(DeployerWrapper.java:171) at org.jboss.deployers.plugins.deployers.DeployersImpl.doDeploy(DeployersImpl.java:1439) at org.jboss.deployers.plugins.deployers.DeployersImpl.doInstallParentFirst(DeployersImpl.java:1157) at org.jboss.deployers.plugins.deployers.DeployersImpl.doInstallParentFirst(DeployersImpl.java:1178) at org.jboss.deployers.plugins.deployers.DeployersImpl.install(DeployersImpl.java:1098) at org.jboss.dependency.plugins.AbstractControllerContext.install(AbstractControllerContext.java:348) at org.jboss.dependency.plugins.AbstractController.install(AbstractController.java:1631) at org.jboss.dependency.plugins.AbstractController.incrementState(AbstractController.java:934) at org.jboss.dependency.plugins.AbstractController.resolveContexts(AbstractController.java:1082) at org.jboss.dependency.plugins.AbstractController.resolveContexts(AbstractController.java:984) at org.jboss.dependency.plugins.AbstractController.change(AbstractController.java:822) at org.jboss.dependency.plugins.AbstractController.change(AbstractController.java:553) at org.jboss.deployers.plugins.deployers.DeployersImpl.process(DeployersImpl.java:781) at org.jboss.deployers.plugins.main.MainDeployerImpl.process(MainDeployerImpl.java:702) at org.jboss.system.server.profileservice.repository.MainDeployerAdapter.process(MainDeployerAdapter.java:117) at org.jboss.system.server.profileservice.repository.ProfileDeployAction.install(ProfileDeployAction.java:70) at org.jboss.system.server.profileservice.repository.AbstractProfileAction.install(AbstractProfileAction.java:53) at org.jboss.system.server.profileservice.repository.AbstractProfileService.install(AbstractProfileService.java:361) at org.jboss.dependency.plugins.AbstractControllerContext.install(AbstractControllerContext.java:348) at org.jboss.dependency.plugins.AbstractController.install(AbstractController.java:1631) at org.jboss.dependency.plugins.AbstractController.incrementState(AbstractController.java:934) at org.jboss.dependency.plugins.AbstractController.resolveContexts(AbstractController.java:1082) at org.jboss.dependency.plugins.AbstractController.resolveContexts(AbstractController.java:984) at org.jboss.dependency.plugins.AbstractController.change(AbstractController.java:822) at org.jboss.dependency.plugins.AbstractController.change(AbstractController.java:553) at org.jboss.system.server.profileservice.repository.AbstractProfileService.activateProfile(AbstractProfileService.java:306) at org.jboss.system.server.profileservice.ProfileServiceBootstrap.start(ProfileServiceBootstrap.java:271) at org.jboss.bootstrap.AbstractServerImpl.start(AbstractServerImpl.java:461) at org.jboss.Main.boot(Main.java:221) at org.jboss.Main$1.run(Main.java:556) at java.lang.Thread.run(Thread.java:679) Caused by: java.lang.RuntimeException: Can not determine bindable address for locator (InvokerLocator [bisocket://0.0.0.0:4457/?JBM_clientMaxPoolSize=200&clientLeasePeriod=10000&clientSocketClass=org.jboss.jms.client.remoting.ClientSocketWrapper&connectionWait=10&dataType=jms&marshaller=org.jboss.jms.wireformat.JMSWireFormat&numberOfCallRetries=1&pingFrequency=214748364&pingWindowFactor=10&socket.check_connection=false&stopLeaseOnFailure=true&timeout=0&unmarshaller=org.jboss.jms.wireformat.JMSWireFormat&validatorPingPeriod=10000&validatorPingTimeout=5000]) at org.jboss.remoting.InvokerLocator.validateLocator(InvokerLocator.java:270) at org.jboss.remoting.ServerInvoker.setup(ServerInvoker.java:1148) at org.jboss.remoting.transport.socket.SocketServerInvoker.setup(SocketServerInvoker.java:212) at org.jboss.remoting.transport.bisocket.BisocketServerInvoker.setup(BisocketServerInvoker.java:651) at org.jboss.remoting.ServerInvoker.create(ServerInvoker.java:932) ... 65 more 2013-11-09 17:02:45,147 ERROR [org.jboss.kernel.plugins.dependency.AbstractKernelController] Error installing to Real: name=vfsfile:/home/epankmi/Desktop/nuxeo-dm-5.4.0_01-jboss/nuxeo-dm-5.4.0.1-jboss/server/default/deploy/messaging/remoting-bisocket-service.xml state=PreReal mode=Manual requiredState=Real org.jboss.deployers.spi.DeploymentException: Error deploying: jboss.messaging:service=Connector,transport=bisocket at org.jboss.deployers.spi.DeploymentException.rethrowAsDeploymentException(DeploymentException.java:49) at org.jboss.system.deployers.ServiceDeployer.deploy(ServiceDeployer.java:118) at org.jboss.system.deployers.ServiceDeployer.deploy(ServiceDeployer.java:46) at org.jboss.deployers.spi.deployer.helpers.AbstractSimpleRealDeployer.internalDeploy(AbstractSimpleRealDeployer.java:62) at org.jboss.deployers.spi.deployer.helpers.AbstractRealDeployer.deploy(AbstractRealDeployer.java:50) at org.jboss.deployers.plugins.deployers.DeployerWrapper.deploy(DeployerWrapper.java:171) at org.jboss.deployers.plugins.deployers.DeployersImpl.doDeploy(DeployersImpl.java:1439) at org.jboss.deployers.plugins.deployers.DeployersImpl.doInstallParentFirst(DeployersImpl.java:1157) at org.jboss.deployers.plugins.deployers.DeployersImpl.doInstallParentFirst(DeployersImpl.java:1178) at org.jboss.deployers.plugins.deployers.DeployersImpl.install(DeployersImpl.java:1098) at org.jboss.dependency.plugins.AbstractControllerContext.install(AbstractControllerContext.java:348) at org.jboss.dependency.plugins.AbstractController.install(AbstractController.java:1631) at org.jboss.dependency.plugins.AbstractController.incrementState(AbstractController.java:934) at org.jboss.dependency.plugins.AbstractController.resolveContexts(AbstractController.java:1082) at org.jboss.dependency.plugins.AbstractController.resolveContexts(AbstractController.java:984) at org.jboss.dependency.plugins.AbstractController.change(AbstractController.java:822) at org.jboss.dependency.plugins.AbstractController.change(AbstractController.java:553) at org.jboss.deployers.plugins.deployers.DeployersImpl.process(DeployersImpl.java:781) at org.jboss.deployers.plugins.main.MainDeployerImpl.process(MainDeployerImpl.java:702) at org.jboss.system.server.profileservice.repository.MainDeployerAdapter.process(MainDeployerAdapter.java:117) at org.jboss.system.server.profileservice.repository.ProfileDeployAction.install(ProfileDeployAction.java:70) at org.jboss.system.server.profileservice.repository.AbstractProfileAction.install(AbstractProfileAction.java:53) at org.jboss.system.server.profileservice.repository.AbstractProfileService.install(AbstractProfileService.java:361) at org.jboss.dependency.plugins.AbstractControllerContext.install(AbstractControllerContext.java:348) at org.jboss.dependency.plugins.AbstractController.install(AbstractController.java:1631) at org.jboss.dependency.plugins.AbstractController.incrementState(AbstractController.java:934) at org.jboss.dependency.plugins.AbstractController.resolveContexts(AbstractController.java:1082) at org.jboss.dependency.plugins.AbstractController.resolveContexts(AbstractController.java:984) at org.jboss.dependency.plugins.AbstractController.change(AbstractController.java:822) at org.jboss.dependency.plugins.AbstractController.change(AbstractController.java:553) at org.jboss.system.server.profileservice.repository.AbstractProfileService.activateProfile(AbstractProfileService.java:306) at org.jboss.system.server.profileservice.ProfileServiceBootstrap.start(ProfileServiceBootstrap.java:271) at org.jboss.bootstrap.AbstractServerImpl.start(AbstractServerImpl.java:461) at org.jboss.Main.boot(Main.java:221) at org.jboss.Main$1.run(Main.java:556) at java.lang.Thread.run(Thread.java:679) Caused by: java.lang.RuntimeException: Error setting up server invoker SocketServerInvoker[0.0.0.0:4457] at org.jboss.remoting.ServerInvoker.create(ServerInvoker.java:936) at org.jboss.remoting.transport.Connector.init(Connector.java:436) at org.jboss.remoting.transport.Connector.create(Connector.java:1143) at sun.reflect.NativeMethodAccessorImpl.invoke0(Native Method) at sun.reflect.NativeMethodAccessorImpl.invoke(NativeMethodAccessorImpl.java:57) at sun.reflect.DelegatingMethodAccessorImpl.invoke(DelegatingMethodAccessorImpl.java:43) at java.lang.reflect.Method.invoke(Method.java:616) at org.jboss.mx.interceptor.ReflectedDispatcher.invoke(ReflectedDispatcher.java:157) at org.jboss.mx.server.Invocation.dispatch(Invocation.java:96) at org.jboss.mx.server.Invocation.invoke(Invocation.java:88) at org.jboss.mx.server.AbstractMBeanInvoker.invoke(AbstractMBeanInvoker.java:264) at org.jboss.mx.server.MBeanServerImpl.invoke(MBeanServerImpl.java:668) at org.jboss.system.microcontainer.ServiceProxy.invoke(ServiceProxy.java:206) at sun.proxy.$Proxy38.create(Unknown Source) at org.jboss.system.microcontainer.CreateDestroyLifecycleAction.installAction(CreateDestroyLifecycleAction.java:42) at org.jboss.system.microcontainer.CreateDestroyLifecycleAction.installAction(CreateDestroyLifecycleAction.java:37) at org.jboss.dependency.plugins.action.SimpleControllerContextAction.simpleInstallAction(SimpleControllerContextAction.java:62) at org.jboss.dependency.plugins.action.AccessControllerContextAction.install(AccessControllerContextAction.java:71) at org.jboss.dependency.plugins.AbstractControllerContextActions.install(AbstractControllerContextActions.java:51) at org.jboss.dependency.plugins.AbstractControllerContext.install(AbstractControllerContext.java:348) at org.jboss.system.microcontainer.ServiceControllerContext.install(ServiceControllerContext.java:286) at org.jboss.dependency.plugins.AbstractController.install(AbstractController.java:1631) at org.jboss.dependency.plugins.AbstractController.incrementState(AbstractController.java:934) at org.jboss.dependency.plugins.AbstractController.resolveContexts(AbstractController.java:1082) at org.jboss.dependency.plugins.AbstractController.resolveContexts(AbstractController.java:984) at org.jboss.dependency.plugins.AbstractController.change(AbstractController.java:822) at org.jboss.dependency.plugins.AbstractController.change(AbstractController.java:553) at org.jboss.system.ServiceController.doChange(ServiceController.java:688) at org.jboss.system.ServiceController.create(ServiceController.java:422) at org.jboss.system.ServiceController.create(ServiceController.java:387) at org.jboss.system.deployers.ServiceDeployer.create(ServiceDeployer.java:158) at org.jboss.system.deployers.ServiceDeployer.deploy(ServiceDeployer.java:96) ... 34 more Caused by: java.lang.RuntimeException: Can not determine bindable address for locator (InvokerLocator [bisocket://0.0.0.0:4457/?JBM_clientMaxPoolSize=200&clientLeasePeriod=10000&clientSocketClass=org.jboss.jms.client.remoting.ClientSocketWrapper&connectionWait=10&dataType=jms&marshaller=org.jboss.jms.wireformat.JMSWireFormat&numberOfCallRetries=1&pingFrequency=214748364&pingWindowFactor=10&socket.check_connection=false&stopLeaseOnFailure=true&timeout=0&unmarshaller=org.jboss.jms.wireformat.JMSWireFormat&validatorPingPeriod=10000&validatorPingTimeout=5000]) at org.jboss.remoting.InvokerLocator.validateLocator(InvokerLocator.java:270) at org.jboss.remoting.ServerInvoker.setup(ServerInvoker.java:1148) at org.jboss.remoting.transport.socket.SocketServerInvoker.setup(SocketServerInvoker.java:212) at org.jboss.remoting.transport.bisocket.BisocketServerInvoker.setup(BisocketServerInvoker.java:651) at org.jboss.remoting.ServerInvoker.create(ServerInvoker.java:932) ... 65 more 2013-11-09 17:02:46,155 ERROR [org.jboss.kernel.plugins.dependency.AbstractKernelController] Error installing to Create: name=org.jboss.ejb3.RemotingConnector state=Configured java.lang.RuntimeException: Error setting up server invoker SocketServerInvoker[0.0.0.0:3873] at org.jboss.remoting.ServerInvoker.create(ServerInvoker.java:936) at org.jboss.remoting.transport.Connector.init(Connector.java:436) at org.jboss.remoting.transport.Connector.create(Connector.java:1143) at sun.reflect.NativeMethodAccessorImpl.invoke0(Native Method) at sun.reflect.NativeMethodAccessorImpl.invoke(NativeMethodAccessorImpl.java:57) at sun.reflect.DelegatingMethodAccessorImpl.invoke(DelegatingMethodAccessorImpl.java:43) at java.lang.reflect.Method.invoke(Method.java:616) at org.jboss.reflect.plugins.introspection.ReflectionUtils.invoke(ReflectionUtils.java:59) at org.jboss.reflect.plugins.introspection.ReflectMethodInfoImpl.invoke(ReflectMethodInfoImpl.java:150) at org.jboss.joinpoint.plugins.BasicMethodJoinPoint.dispatch(BasicMethodJoinPoint.java:66) at org.jboss.kernel.plugins.dependency.KernelControllerContextAction$JoinpointDispatchWrapper.execute(KernelControllerContextAction.java:241) at org.jboss.kernel.plugins.dependency.ExecutionWrapper.execute(ExecutionWrapper.java:47) at org.jboss.kernel.plugins.dependency.KernelControllerContextAction.dispatchExecutionWrapper(KernelControllerContextAction.java:109) at org.jboss.kernel.plugins.dependency.KernelControllerContextAction.dispatchJoinPoint(KernelControllerContextAction.java:70) at org.jboss.kernel.plugins.dependency.LifecycleAction.installActionInternal(LifecycleAction.java:221) at org.jboss.kernel.plugins.dependency.InstallsAwareAction.installAction(InstallsAwareAction.java:54) at org.jboss.kernel.plugins.dependency.InstallsAwareAction.installAction(InstallsAwareAction.java:42) at org.jboss.dependency.plugins.action.SimpleControllerContextAction.simpleInstallAction(SimpleControllerContextAction.java:62) at org.jboss.dependency.plugins.action.AccessControllerContextAction.install(AccessControllerContextAction.java:71) at org.jboss.dependency.plugins.AbstractControllerContextActions.install(AbstractControllerContextActions.java:51) at org.jboss.dependency.plugins.AbstractControllerContext.install(AbstractControllerContext.java:348) at org.jboss.dependency.plugins.AbstractController.install(AbstractController.java:1631) at org.jboss.dependency.plugins.AbstractController.incrementState(AbstractController.java:934) at org.jboss.dependency.plugins.AbstractController.resolveContexts(AbstractController.java:1082) at org.jboss.dependency.plugins.AbstractController.resolveContexts(AbstractController.java:984) at org.jboss.dependency.plugins.AbstractController.install(AbstractController.java:774) at org.jboss.dependency.plugins.AbstractController.install(AbstractController.java:540) at org.jboss.deployers.vfs.deployer.kernel.BeanMetaDataDeployer.deploy(BeanMetaDataDeployer.java:121) at org.jboss.deployers.vfs.deployer.kernel.BeanMetaDataDeployer.deploy(BeanMetaDataDeployer.java:51) at org.jboss.deployers.spi.deployer.helpers.AbstractSimpleRealDeployer.internalDeploy(AbstractSimpleRealDeployer.java:62) at org.jboss.deployers.spi.deployer.helpers.AbstractRealDeployer.deploy(AbstractRealDeployer.java:50) at org.jboss.deployers.plugins.deployers.DeployerWrapper.deploy(DeployerWrapper.java:171) at org.jboss.deployers.plugins.deployers.DeployersImpl.doDeploy(DeployersImpl.java:1439) at org.jboss.deployers.plugins.deployers.DeployersImpl.doInstallParentFirst(DeployersImpl.java:1157) at org.jboss.deployers.plugins.deployers.DeployersImpl.doInstallParentFirst(DeployersImpl.java:1178) at org.jboss.deployers.plugins.deployers.DeployersImpl.install(DeployersImpl.java:1098) at org.jboss.dependency.plugins.AbstractControllerContext.install(AbstractControllerContext.java:348) at org.jboss.dependency.plugins.AbstractController.install(AbstractController.java:1631) at org.jboss.dependency.plugins.AbstractController.incrementState(AbstractController.java:934) at org.jboss.dependency.plugins.AbstractController.resolveContexts(AbstractController.java:1082) at org.jboss.dependency.plugins.AbstractController.resolveContexts(AbstractController.java:984) at org.jboss.dependency.plugins.AbstractController.change(AbstractController.java:822) at org.jboss.dependency.plugins.AbstractController.change(AbstractController.java:553) at org.jboss.deployers.plugins.deployers.DeployersImpl.process(DeployersImpl.java:781) at org.jboss.deployers.plugins.main.MainDeployerImpl.process(MainDeployerImpl.java:702) at org.jboss.system.server.profileservice.repository.MainDeployerAdapter.process(MainDeployerAdapter.java:117) at org.jboss.system.server.profileservice.repository.ProfileDeployAction.install(ProfileDeployAction.java:70) at org.jboss.system.server.profileservice.repository.AbstractProfileAction.install(AbstractProfileAction.java:53) at org.jboss.system.server.profileservice.repository.AbstractProfileService.install(AbstractProfileService.java:361) at org.jboss.dependency.plugins.AbstractControllerContext.install(AbstractControllerContext.java:348) at org.jboss.dependency.plugins.AbstractController.install(AbstractController.java:1631) at org.jboss.dependency.plugins.AbstractController.incrementState(AbstractController.java:934) at org.jboss.dependency.plugins.AbstractController.resolveContexts(AbstractController.java:1082) at org.jboss.dependency.plugins.AbstractController.resolveContexts(AbstractController.java:984) at org.jboss.dependency.plugins.AbstractController.change(AbstractController.java:822) at org.jboss.dependency.plugins.AbstractController.change(AbstractController.java:553) at org.jboss.system.server.profileservice.repository.AbstractProfileService.activateProfile(AbstractProfileService.java:306) at org.jboss.system.server.profileservice.ProfileServiceBootstrap.start(ProfileServiceBootstrap.java:271) at org.jboss.bootstrap.AbstractServerImpl.start(AbstractServerImpl.java:461) at org.jboss.Main.boot(Main.java:221) at org.jboss.Main$1.run(Main.java:556) at java.lang.Thread.run(Thread.java:679) Caused by: java.lang.RuntimeException: Can not determine bindable address for locator (InvokerLocator [socket://0.0.0.0:3873/]) at org.jboss.remoting.InvokerLocator.validateLocator(InvokerLocator.java:270) at org.jboss.remoting.ServerInvoker.setup(ServerInvoker.java:1148) at org.jboss.remoting.transport.socket.SocketServerInvoker.setup(SocketServerInvoker.java:212) at org.jboss.remoting.ServerInvoker.create(ServerInvoker.java:932) ... 61 more 2013-11-09 17:02:50,392 ERROR [org.jboss.kernel.plugins.dependency.AbstractKernelController] Error installing to Create: name=UnifiedInvokerConnector state=Configured java.lang.RuntimeException: Error setting up server invoker SocketServerInvoker[0.0.0.0:4446] at org.jboss.remoting.ServerInvoker.create(ServerInvoker.java:936) at org.jboss.remoting.transport.Connector.init(Connector.java:436) at org.jboss.remoting.transport.Connector.create(Connector.java:1143) at sun.reflect.NativeMethodAccessorImpl.invoke0(Native Method) at sun.reflect.NativeMethodAccessorImpl.invoke(NativeMethodAccessorImpl.java:57) at sun.reflect.DelegatingMethodAccessorImpl.invoke(DelegatingMethodAccessorImpl.java:43) at java.lang.reflect.Method.invoke(Method.java:616) at org.jboss.reflect.plugins.introspection.ReflectionUtils.invoke(ReflectionUtils.java:59) at org.jboss.reflect.plugins.introspection.ReflectMethodInfoImpl.invoke(ReflectMethodInfoImpl.java:150) at org.jboss.joinpoint.plugins.BasicMethodJoinPoint.dispatch(BasicMethodJoinPoint.java:66) at org.jboss.kernel.plugins.dependency.KernelControllerContextAction$JoinpointDispatchWrapper.execute(KernelControllerContextAction.java:241) at org.jboss.kernel.plugins.dependency.ExecutionWrapper.execute(ExecutionWrapper.java:47) at org.jboss.kernel.plugins.dependency.KernelControllerContextAction.dispatchExecutionWrapper(KernelControllerContextAction.java:109) at org.jboss.kernel.plugins.dependency.KernelControllerContextAction.dispatchJoinPoint(KernelControllerContextAction.java:70) at org.jboss.kernel.plugins.dependency.LifecycleAction.installActionInternal(LifecycleAction.java:221) at org.jboss.kernel.plugins.dependency.InstallsAwareAction.installAction(InstallsAwareAction.java:54) at org.jboss.kernel.plugins.dependency.InstallsAwareAction.installAction(InstallsAwareAction.java:42) at org.jboss.dependency.plugins.action.SimpleControllerContextAction.simpleInstallAction(SimpleControllerContextAction.java:62) at org.jboss.dependency.plugins.action.AccessControllerContextAction.install(AccessControllerContextAction.java:71) at org.jboss.dependency.plugins.AbstractControllerContextActions.install(AbstractControllerContextActions.java:51) at org.jboss.dependency.plugins.AbstractControllerContext.install(AbstractControllerContext.java:348) at org.jboss.dependency.plugins.AbstractController.install(AbstractController.java:1631) at org.jboss.dependency.plugins.AbstractController.incrementState(AbstractController.java:934) at org.jboss.dependency.plugins.AbstractController.resolveContexts(AbstractController.java:1082) at org.jboss.dependency.plugins.AbstractController.resolveContexts(AbstractController.java:984) at org.jboss.dependency.plugins.AbstractController.install(AbstractController.java:774) at org.jboss.dependency.plugins.AbstractController.install(AbstractController.java:540) at org.jboss.deployers.vfs.deployer.kernel.BeanMetaDataDeployer.deploy(BeanMetaDataDeployer.java:121) at org.jboss.deployers.vfs.deployer.kernel.BeanMetaDataDeployer.deploy(BeanMetaDataDeployer.java:51) at org.jboss.deployers.spi.deployer.helpers.AbstractSimpleRealDeployer.internalDeploy(AbstractSimpleRealDeployer.java:62) at org.jboss.deployers.spi.deployer.helpers.AbstractRealDeployer.deploy(AbstractRealDeployer.java:50) at org.jboss.deployers.plugins.deployers.DeployerWrapper.deploy(DeployerWrapper.java:171) at org.jboss.deployers.plugins.deployers.DeployersImpl.doDeploy(DeployersImpl.java:1439) at org.jboss.deployers.plugins.deployers.DeployersImpl.doInstallParentFirst(DeployersImpl.java:1157) at org.jboss.deployers.plugins.deployers.DeployersImpl.doInstallParentFirst(DeployersImpl.java:1178) at org.jboss.deployers.plugins.deployers.DeployersImpl.install(DeployersImpl.java:1098) at org.jboss.dependency.plugins.AbstractControllerContext.install(AbstractControllerContext.java:348) at org.jboss.dependency.plugins.AbstractController.install(AbstractController.java:1631) at org.jboss.dependency.plugins.AbstractController.incrementState(AbstractController.java:934) at org.jboss.dependency.plugins.AbstractController.resolveContexts(AbstractController.java:1082) at org.jboss.dependency.plugins.AbstractController.resolveContexts(AbstractController.java:984) at org.jboss.dependency.plugins.AbstractController.change(AbstractController.java:822) at org.jboss.dependency.plugins.AbstractController.change(AbstractController.java:553) at org.jboss.deployers.plugins.deployers.DeployersImpl.process(DeployersImpl.java:781) at org.jboss.deployers.plugins.main.MainDeployerImpl.process(MainDeployerImpl.java:702) at org.jboss.system.server.profileservice.repository.MainDeployerAdapter.process(MainDeployerAdapter.java:117) at org.jboss.system.server.profileservice.repository.ProfileDeployAction.install(ProfileDeployAction.java:70) at org.jboss.system.server.profileservice.repository.AbstractProfileAction.install(AbstractProfileAction.java:53) at org.jboss.system.server.profileservice.repository.AbstractProfileService.install(AbstractProfileService.java:361) at org.jboss.dependency.plugins.AbstractControllerContext.install(AbstractControllerContext.java:348) at org.jboss.dependency.plugins.AbstractController.install(AbstractController.java:1631) at org.jboss.dependency.plugins.AbstractController.incrementState(AbstractController.java:934) at org.jboss.dependency.plugins.AbstractController.resolveContexts(AbstractController.java:1082) at org.jboss.dependency.plugins.AbstractController.resolveContexts(AbstractController.java:984) at org.jboss.dependency.plugins.AbstractController.change(AbstractController.java:822) at org.jboss.dependency.plugins.AbstractController.change(AbstractController.java:553) at org.jboss.system.server.profileservice.repository.AbstractProfileService.activateProfile(AbstractProfileService.java:306) at org.jboss.system.server.profileservice.ProfileServiceBootstrap.start(ProfileServiceBootstrap.java:271) at org.jboss.bootstrap.AbstractServerImpl.start(AbstractServerImpl.java:461) at org.jboss.Main.boot(Main.java:221) at org.jboss.Main$1.run(Main.java:556) at java.lang.Thread.run(Thread.java:679) Caused by: java.lang.RuntimeException: Can not determine bindable address for locator (InvokerLocator [socket://0.0.0.0:4446/?dataType=invocation&enableTcpNoDelay=true&marshaller=org.jboss.invocation.unified.marshall.InvocationMarshaller&unmarshaller=org.jboss.invocation.unified.marshall.InvocationUnMarshaller]) at org.jboss.remoting.InvokerLocator.validateLocator(InvokerLocator.java:270) at org.jboss.remoting.ServerInvoker.setup(ServerInvoker.java:1148) at org.jboss.remoting.transport.socket.SocketServerInvoker.setup(SocketServerInvoker.java:212) at org.jboss.remoting.ServerInvoker.create(ServerInvoker.java:932) ... 61 more 2013-11-09 17:02:50,546 WARN [org.jboss.jms.server.jbosssx.JBossASSecurityMetadataStore] WARNING! POTENTIAL SECURITY RISK. It has been detected that the MessageSucker component which sucks messages from one node to another has not had its password changed from the installation default. Please see the JBoss Messaging user guide for instructions on how to do this. 2013-11-09 17:02:50,595 WARN [org.jboss.annotation.factory.AnnotationCreator] No ClassLoader provided, using TCCL: org.jboss.managed.api.annotation.ManagementComponent 2013-11-09 17:02:50,641 WARN [org.jboss.annotation.factory.AnnotationCreator] No ClassLoader provided, using TCCL: org.jboss.managed.api.annotation.ManagementComponent 2013-11-09 17:02:51,772 WARN [com.arjuna.ats.arjuna.logging.arjLoggerI18N] [com.arjuna.ats.arjuna.common.Uid_1] - cannot get local host. 2013-11-09 17:02:52,833 WARN [com.arjuna.ats.arjuna.logging.arjLoggerI18N] [com.arjuna.ats.arjuna.common.Uid_1] - cannot get local host. 2013-11-09 17:02:52,834 WARN [com.arjuna.ats.arjuna.logging.arjLoggerI18N] [com.arjuna.ats.internal.arjuna.recovery.TransactionStatusManagerItem_2] - Problem with storing host/port java.io.IOException: com.arjuna.ats.arjuna.state.OutputBuffer_10 - Invalid input buffer: string. 2013-11-09 17:02:52,879 FATAL [com.arjuna.ats.arjuna.logging.arjLoggerI18N] [com.arjuna.ats.internal.arjuna.recovery.fail] RecoveryManagerImple: cannot bind to socket on address /0.0.0.0 and port 4,712 2013-11-09 17:02:52,879 ERROR [org.jboss.kernel.plugins.dependency.AbstractKernelController] Error installing to Create: name=TransactionManager state=Configured com.arjuna.ats.arjuna.exceptions.FatalError: Recovery manager already active (or recovery port and address are in use)! at com.arjuna.ats.internal.arjuna.recovery.RecoveryManagerImple.(RecoveryManagerImple.java:164) at com.arjuna.ats.arjuna.recovery.RecoveryManager.(RecoveryManager.java:533) at com.arjuna.ats.arjuna.recovery.RecoveryManager.manager(RecoveryManager.java:136) at com.arjuna.ats.arjuna.recovery.RecoveryManager.manager(RecoveryManager.java:117) at com.arjuna.ats.jbossatx.jta.TransactionManagerService.create(TransactionManagerService.java:214) at sun.reflect.NativeMethodAccessorImpl.invoke0(Native Method) at sun.reflect.NativeMethodAccessorImpl.invoke(NativeMethodAccessorImpl.java:57) at sun.reflect.DelegatingMethodAccessorImpl.invoke(DelegatingMethodAccessorImpl.java:43) at java.lang.reflect.Method.invoke(Method.java:616) at org.jboss.reflect.plugins.introspection.ReflectionUtils.invoke(ReflectionUtils.java:59) at org.jboss.reflect.plugins.introspection.ReflectMethodInfoImpl.invoke(ReflectMethodInfoImpl.java:150) at org.jboss.joinpoint.plugins.BasicMethodJoinPoint.dispatch(BasicMethodJoinPoint.java:66) at org.jboss.kernel.plugins.dependency.KernelControllerContextAction$JoinpointDispatchWrapper.execute(KernelControllerContextAction.java:241) at org.jboss.kernel.plugins.dependency.ExecutionWrapper.execute(ExecutionWrapper.java:47) at org.jboss.kernel.plugins.dependency.KernelControllerContextAction.dispatchExecutionWrapper(KernelControllerContextAction.java:109) at org.jboss.kernel.plugins.dependency.KernelControllerContextAction.dispatchJoinPoint(KernelControllerContextAction.java:70) at org.jboss.kernel.plugins.dependency.LifecycleAction.installActionInternal(LifecycleAction.java:221) at org.jboss.kernel.plugins.dependency.InstallsAwareAction.installAction(InstallsAwareAction.java:54) at org.jboss.kernel.plugins.dependency.InstallsAwareAction.installAction(InstallsAwareAction.java:42) at org.jboss.dependency.plugins.action.SimpleControllerContextAction.simpleInstallAction(SimpleControllerContextAction.java:62) at org.jboss.dependency.plugins.action.AccessControllerContextAction.install(AccessControllerContextAction.java:71) at org.jboss.dependency.plugins.AbstractControllerContextActions.install(AbstractControllerContextActions.java:51) at org.jboss.dependency.plugins.AbstractControllerContext.install(AbstractControllerContext.java:348) at org.jboss.dependency.plugins.AbstractController.install(AbstractController.java:1631) at org.jboss.dependency.plugins.AbstractController.incrementState(AbstractController.java:934) at org.jboss.dependency.plugins.AbstractController.resolveContexts(AbstractController.java:1082) at org.jboss.dependency.plugins.AbstractController.resolveContexts(AbstractController.java:984) at org.jboss.dependency.plugins.AbstractController.install(AbstractController.java:774) at org.jboss.dependency.plugins.AbstractController.install(AbstractController.java:540) at org.jboss.deployers.vfs.deployer.kernel.BeanMetaDataDeployer.deploy(BeanMetaDataDeployer.java:121) at org.jboss.deployers.vfs.deployer.kernel.BeanMetaDataDeployer.deploy(BeanMetaDataDeployer.java:51) at org.jboss.deployers.spi.deployer.helpers.AbstractSimpleRealDeployer.internalDeploy(AbstractSimpleRealDeployer.java:62) at org.jboss.deployers.spi.deployer.helpers.AbstractRealDeployer.deploy(AbstractRealDeployer.java:50) at org.jboss.deployers.plugins.deployers.DeployerWrapper.deploy(DeployerWrapper.java:171) at org.jboss.deployers.plugins.deployers.DeployersImpl.doDeploy(DeployersImpl.java:1439) at org.jboss.deployers.plugins.deployers.DeployersImpl.doInstallParentFirst(DeployersImpl.java:1157) at org.jboss.deployers.plugins.deployers.DeployersImpl.doInstallParentFirst(DeployersImpl.java:1178) at org.jboss.deployers.plugins.deployers.DeployersImpl.install(DeployersImpl.java:1098) at org.jboss.dependency.plugins.AbstractControllerContext.install(AbstractControllerContext.java:348) at org.jboss.dependency.plugins.AbstractController.install(AbstractController.java:1631) at org.jboss.dependency.plugins.AbstractController.incrementState(AbstractController.java:934) at org.jboss.dependency.plugins.AbstractController.resolveContexts(AbstractController.java:1082) at org.jboss.dependency.plugins.AbstractController.resolveContexts(AbstractController.java:984) at org.jboss.dependency.plugins.AbstractController.change(AbstractController.java:822) at org.jboss.dependency.plugins.AbstractController.change(AbstractController.java:553) at org.jboss.deployers.plugins.deployers.DeployersImpl.process(DeployersImpl.java:781) at org.jboss.deployers.plugins.main.MainDeployerImpl.process(MainDeployerImpl.java:702) at org.jboss.system.server.profileservice.repository.MainDeployerAdapter.process(MainDeployerAdapter.java:117) at org.jboss.system.server.profileservice.repository.ProfileDeployAction.install(ProfileDeployAction.java:70) at org.jboss.system.server.profileservice.repository.AbstractProfileAction.install(AbstractProfileAction.java:53) at org.jboss.system.server.profileservice.repository.AbstractProfileService.install(AbstractProfileService.java:361) at org.jboss.dependency.plugins.AbstractControllerContext.install(AbstractControllerContext.java:348) at org.jboss.dependency.plugins.AbstractController.install(AbstractController.java:1631) at org.jboss.dependency.plugins.AbstractController.incrementState(AbstractController.java:934) at org.jboss.dependency.plugins.AbstractController.resolveContexts(AbstractController.java:1082) at org.jboss.dependency.plugins.AbstractController.resolveContexts(AbstractController.java:984) at org.jboss.dependency.plugins.AbstractController.change(AbstractController.java:822) at org.jboss.dependency.plugins.AbstractController.change(AbstractController.java:553) at org.jboss.system.server.profileservice.repository.AbstractProfileService.activateProfile(AbstractProfileService.java:306) at org.jboss.system.server.profileservice.ProfileServiceBootstrap.start(ProfileServiceBootstrap.java:271) at org.jboss.bootstrap.AbstractServerImpl.start(AbstractServerImpl.java:461) at org.jboss.Main.boot(Main.java:221) at org.jboss.Main$1.run(Main.java:556) at java.lang.Thread.run(Thread.java:679) 2013-11-09 17:02:53,718 ERROR [org.jboss.system.server.profileservice.ProfileServiceBootstrap] Failed to load profile: Summary of incomplete deployments (SEE PREVIOUS ERRORS FOR DETAILS):
DEPLOYMENTS MISSING DEPENDENCIES: Deployment "CachedConnectionManager" is missing the following dependencies: Dependency "TransactionManager" (should be in state "Configured", but is actually in state "ERROR") Deployment "ConnectorMBean" is missing the following dependencies: Dependency "jboss.remoting:service=Connector,transport=socket" (should be in state "Create", but is actually in state "** NOT FOUND Depends on 'jboss.remoting:service=Connector,transport=socket' ") Deployment "DefaultUserTransactionprovider" is missing the following dependencies: Dependency "" (should be in state "Described", but is actually in state " UNRESOLVED Demands 'TransactionManager' ") Deployment "DeploymentInvocationHandler" is missing the following dependencies: Dependency "ConnectorMBean" (should be in state "Installed", but is actually in state "Configured") Dependency "ConnectorMBean" (should be in state "Installed", but is actually in state "Configured") Deployment "DeploymentManager" is missing the following dependencies: Deployment "JBossTimerServiceFactory" is missing the following dependencies: Dependency "jboss.ejb:service=EJBTimerService" (should be in state "Create", but is actually in state "Configured") Deployment "MBeanManagedOperationProxyFactory" is missing the following dependencies: Deployment "ManagedOperationProxyFactory" is missing the following dependencies: Deployment "ManagementView" is missing the following dependencies: Dependency "ManagedOperationProxyFactory" (should be in state "Configured", but is actually in state "Instantiated") Dependency "DeploymentManager" (should be in state "Configured", but is actually in state "Instantiated") Dependency "MBeanManagedOperationProxyFactory" (should be in state "Configured", but is actually in state "Instantiated") Deployment "ProfileServiceInvocationHandler" is missing the following dependencies: Dependency "ProfileServiceProxyFactory" (should be in state "Configured", but is actually in state "Instantiated") Dependency "ProfileServiceProxyFactory" (should be in state "Configured", but is actually in state "Instantiated") Deployment "ProfileServiceProxyFactory" is missing the following dependencies: Dependency "DeploymentManager" (should be in state "Configured", but is actually in state "Instantiated") Dependency "ManagementView" (should be in state "Configured", but is actually in state "Instantiated") Deployment "RealTransactionManager" is missing the following dependencies: Dependency "TransactionManager" (should be in state "Instantiated", but is actually in state "ERROR") Deployment "UnifiedInvoker" is missing the following dependencies: Dependency "UnifiedInvokerConnector" (should be in state "Configured", but is actually in state "ERROR") Deployment "WebServer" is missing the following dependencies: Dependency "jboss.jca:service=CachedConnectionManager" (should be in state "Create", but is actually in state " NOT FOUND Depends on 'jboss.jca:service=CachedConnectionManager' ") Dependency "jboss:service=TransactionManager" (should be in state "Create", but is actually in state " NOT FOUND Depends on 'jboss:service=TransactionManager' ") Deployment "WorkManager" is missing the following dependencies: Dependency "TransactionManager" (should be in state "Configured", but is actually in state "ERROR") Deployment "jboss.admin:service=PluginManager" is missing the following dependencies: Dependency "jboss.jmx:name=Invoker,protocol=jrmp,service=proxyFactory,type=adaptor" (should be in state "Create", but is actually in state "Configured") Deployment "jboss.ejb:persistencePolicy=database,service=EJBTimerService" is missing the following dependencies: Dependency "jboss.jca:name=DefaultDS,service=DataSourceBinding" (should be in state "Create", but is actually in state "Configured") Deployment "jboss.ejb:service=EJBTimerService" is missing the following dependencies: Dependency "jboss.ejb:persistencePolicy=database,service=EJBTimerService" (should be in state "Create", but is actually in state "Configured") Dependency "jboss:service=TransactionManager" (should be in state "Create", but is actually in state " NOT FOUND Depends on 'jboss:service=TransactionManager' ") Deployment "jboss.jca:name='jboss-local-jdbc.rar',service=RARDeployment" is missing the following dependencies: Dependency "jboss.jca:service=WorkManager" (should be in state "Configured", but is actually in state " NOT FOUND Depends on 'jboss.jca:service=WorkManager' ") Dependency "jboss:service=TransactionManager" (should be in state "Configured", but is actually in state " NOT FOUND Depends on 'jboss:service=TransactionManager' ") Deployment "jboss.jca:name='jboss-xa-jdbc.rar',service=RARDeployment" is missing the following dependencies: Dependency "jboss.jca:service=WorkManager" (should be in state "Configured", but is actually in state " NOT FOUND Depends on 'jboss.jca:service=WorkManager' ") Dependency "jboss:service=TransactionManager" (should be in state "Configured", but is actually in state " NOT FOUND Depends on 'jboss:service=TransactionManager' ") Deployment "jboss.jca:name='jms-ra.rar',service=RARDeployment" is missing the following dependencies: Dependency "jboss.jca:service=WorkManager" (should be in state "Configured", but is actually in state " NOT FOUND Depends on 'jboss.jca:service=WorkManager' ") Dependency "jboss:service=TransactionManager" (should be in state "Configured", but is actually in state " NOT FOUND Depends on 'jboss:service=TransactionManager' ") Deployment "jboss.jca:name='mail-ra.rar',service=RARDeployment" is missing the following dependencies: Dependency "jboss:service=TransactionManager" (should be in state "Configured", but is actually in state " NOT FOUND Depends on 'jboss:service=TransactionManager' ") Dependency "jboss.jca:service=WorkManager" (should be in state "Configured", but is actually in state " NOT FOUND Depends on 'jboss.jca:service=WorkManager' ") Deployment "jboss.jca:name='quartz-ra.rar',service=RARDeployment" is missing the following dependencies: Dependency "jboss.jca:service=WorkManager" (should be in state "Configured", but is actually in state " NOT FOUND Depends on 'jboss.jca:service=WorkManager' ") Dependency "jboss:service=TransactionManager" (should be in state "Configured", but is actually in state " NOT FOUND Depends on 'jboss:service=TransactionManager' ") Deployment "jboss.jca:name=DefaultDS,service=DataSourceBinding" is missing the following dependencies: Dependency "jboss.jca:name=DefaultDS,service=LocalTxCM" (should be in state "Create", but is actually in state "Configured") Deployment "jboss.jca:name=DefaultDS,service=LocalTxCM" is missing the following dependencies: Dependency "jboss.jca:name=DefaultDS,service=ManagedConnectionPool" (should be in state "Create", but is actually in state "Configured") Dependency "jboss:service=TransactionManager" (should be in state "Create", but is actually in state " NOT FOUND Depends on 'jboss:service=TransactionManager' ") Dependency "jboss.jca:service=CachedConnectionManager" (should be in state "Create", but is actually in state " NOT FOUND Depends on 'jboss.jca:service=CachedConnectionManager' ") Deployment "jboss.jca:name=DefaultDS,service=ManagedConnectionFactory" is missing the following dependencies: Dependency "jboss.jca:name='jboss-local-jdbc.rar',service=RARDeployment" (should be in state "Create", but is actually in state "Instantiated") Deployment "jboss.jca:name=DefaultDS,service=ManagedConnectionPool" is missing the following dependencies: Dependency "jboss.jca:name=DefaultDS,service=ManagedConnectionFactory" (should be in state "Create", but is actually in state "Configured") Deployment "jboss.jca:name=JmsXA,service=ConnectionFactoryBinding" is missing the following dependencies: Dependency "jboss.jca:name=JmsXA,service=TxCM" (should be in state "Create", but is actually in state "Configured") Deployment "jboss.jca:name=JmsXA,service=ManagedConnectionFactory" is missing the following dependencies: Dependency "jboss.jca:name='jms-ra.rar',service=RARDeployment" (should be in state "Create", but is actually in state "Instantiated") Dependency "jboss.messaging:service=ServerPeer" (should be in state "Create", but is actually in state "Configured") Deployment "jboss.jca:name=JmsXA,service=ManagedConnectionPool" is missing the following dependencies: Dependency "jboss.jca:name=JmsXA,service=ManagedConnectionFactory" (should be in state "Create", but is actually in state "Configured") Deployment "jboss.jca:name=JmsXA,service=TxCM" is missing the following dependencies: Dependency "jboss.jca:name=JmsXA,service=ManagedConnectionPool" (should be in state "Create", but is actually in state "Configured") Dependency "jboss:service=TransactionManager" (should be in state "Create", but is actually in state " NOT FOUND Depends on 'jboss:service=TransactionManager' ") Dependency "jboss.jca:service=CachedConnectionManager" (should be in state "Create", but is actually in state " NOT FOUND Depends on 'jboss.jca:service=CachedConnectionManager' ") Deployment "jboss.jca:name=NuxeoDS,service=DataSourceBinding" is missing the following dependencies: Dependency "jboss.jca:name=NuxeoDS,service=LocalTxCM" (should be in state "Create", but is actually in state "Configured") Deployment "jboss.jca:name=NuxeoDS,service=LocalTxCM" is missing the following dependencies: Dependency "jboss:service=TransactionManager" (should be in state "Create", but is actually in state " NOT FOUND Depends on 'jboss:service=TransactionManager' ") Dependency "jboss.jca:name=NuxeoDS,service=ManagedConnectionPool" (should be in state "Create", but is actually in state "Configured") Dependency "jboss.jca:service=CachedConnectionManager" (should be in state "Create", but is actually in state " NOT FOUND Depends on 'jboss.jca:service=CachedConnectionManager' ") Deployment "jboss.jca:name=NuxeoDS,service=ManagedConnectionFactory" is missing the following dependencies: Dependency "jboss.jca:name='jboss-local-jdbc.rar',service=RARDeployment" (should be in state "Create", but is actually in state "Instantiated") Deployment "jboss.jca:name=NuxeoDS,service=ManagedConnectionPool" is missing the following dependencies: Dependency "jboss.jca:name=NuxeoDS,service=ManagedConnectionFactory" (should be in state "Create", but is actually in state "Configured") Deployment "jboss.jmx:name=Invoker,protocol=jrmp,service=proxyFactory,type=adaptor" is missing the following dependencies: Dependency "jboss:service=invoker,type=jrmp" (should be in state "Create", but is actually in state "Configured") Deployment "jboss.jmx:name=MBeanProxyRemote,protocol=jrmp,type=adaptor" is missing the following dependencies: Dependency "jboss.jmx:name=Invoker,protocol=jrmp,service=proxyFactory,type=adaptor" (should be in state "Create", but is actually in state "Configured") Deployment "jboss.messaging.connectionfactory:service=ClusterPullConnectionFactory" is missing the following dependencies: Dependency "jboss.messaging:service=Connector,transport=bisocket" (should be in state "Create", but is actually in state " NOT FOUND Depends on 'jboss.messaging:service=Connector,transport=bisocket' ") Dependency "jboss.messaging:service=PostOffice" (should be in state "Create", but is actually in state "Configured") Dependency "jboss.messaging:service=ServerPeer" (should be in state "Create", but is actually in state "Configured") Deployment "jboss.messaging.connectionfactory:service=ClusteredConnectionFactory" is missing the following dependencies: Dependency "jboss.messaging:service=Connector,transport=bisocket" (should be in state "Create", but is actually in state " NOT FOUND Depends on 'jboss.messaging:service=Connector,transport=bisocket' ") Dependency "jboss.messaging:service=ServerPeer" (should be in state "Create", but is actually in state "Configured") Dependency "jboss.messaging:service=PostOffice" (should be in state "Create", but is actually in state "Configured") Deployment "jboss.messaging.connectionfactory:service=ConnectionFactory" is missing the following dependencies: Dependency "jboss.messaging:service=ServerPeer" (should be in state "Create", but is actually in state "Configured") Dependency "jboss.messaging:service=PostOffice" (should be in state "Create", but is actually in state "Configured") Dependency "jboss.messaging:service=Connector,transport=bisocket" (should be in state "Create", but is actually in state " NOT FOUND Depends on 'jboss.messaging:service=Connector,transport=bisocket' ") Deployment "jboss.messaging.destination:name=DLQ,service=Queue" is missing the following dependencies: Dependency "jboss.messaging:service=ServerPeer" (should be in state "Create", but is actually in state "Configured") Dependency "jboss.messaging:service=PostOffice" (should be in state "Create", but is actually in state "Configured") Deployment "jboss.messaging.destination:name=ExpiryQueue,service=Queue" is missing the following dependencies: Dependency "jboss.messaging:service=ServerPeer" (should be in state "Create", but is actually in state "Configured") Dependency "jboss.messaging:service=PostOffice" (should be in state "Create", but is actually in state "Configured") Deployment "jboss.messaging:service=JMSUserManager" is missing the following dependencies: Dependency "jboss:service=TransactionManager" (should be in state "Create", but is actually in state " NOT FOUND Depends on 'jboss:service=TransactionManager' ") Dependency "jboss.jca:name=DefaultDS,service=DataSourceBinding" (should be in state "Create", but is actually in state "Configured") Deployment "jboss.messaging:service=PersistenceManager" is missing the following dependencies: Dependency "jboss.jca:name=DefaultDS,service=DataSourceBinding" (should be in state "Create", but is actually in state "Configured") Dependency "jboss:service=TransactionManager" (should be in state "Create", but is actually in state " NOT FOUND Depends on 'jboss:service=TransactionManager' ") Deployment "jboss.messaging:service=PostOffice" is missing the following dependencies: Dependency "jboss.messaging:service=ServerPeer" (should be in state "Create", but is actually in state "Configured") Dependency "jboss.jca:name=DefaultDS,service=DataSourceBinding" (should be in state "Create", but is actually in state "Configured") Dependency "jboss:service=TransactionManager" (should be in state "Create", but is actually in state " NOT FOUND Depends on 'jboss:service=TransactionManager' ") Deployment "jboss.messaging:service=ServerPeer" is missing the following dependencies: Dependency "jboss.messaging:service=JMSUserManager" (should be in state "Create", but is actually in state "Configured") Dependency "jboss.messaging:service=PersistenceManager" (should be in state "Create", but is actually in state "Configured") Dependency "jboss.messaging:service=Connector,transport=bisocket" (should be in state "Create", but is actually in state " NOT FOUND Depends on 'jboss.messaging:service=Connector,transport=bisocket' ") Deployment "jboss.mq:service=DestinationManager" is missing the following dependencies: Dependency "jboss.messaging:service=ServerPeer" (should be in state "Create", but is actually in state "Configured") Deployment "jboss.web.deployment:war=/ROOT" is missing the following dependencies: Dependency "jboss.web:service=WebServer" (should be in state "Create", but is actually in state "Configured") Deployment "jboss.web.deployment:war=/admin-console" is missing the following dependencies: Dependency "jboss.web:service=WebServer" (should be in state "Create", but is actually in state "Configured") Deployment "jboss.web.deployment:war=/jbossws" is missing the following dependencies: Dependency "jboss.web:service=WebServer" (should be in state "Create", but is actually in state "Configured") Deployment "jboss.web.deployment:war=/jmx-console" is missing the following dependencies: Dependency "jboss.web:service=WebServer" (should be in state "Create", but is actually in state "Configured") Deployment "jboss.web.deployment:war=/web-console" is missing the following dependencies: Dependency "jboss.web:service=WebServer" (should be in state "Create", but is actually in state "Configured") Dependency "jboss.admin:service=PluginManager" (should be in state "Create", but is actually in state "Configured") Deployment "jboss:service=ClientUserTransaction" is missing the following dependencies: Dependency "jboss:service=proxyFactory,target=ClientUserTransactionFactory" (should be in state "Create", but is actually in state "Configured") Dependency "jboss:service=proxyFactory,target=ClientUserTransaction" (should be in state "Create", but is actually in state "Configured") Deployment "jboss:service=KeyGeneratorFactory,type=HiLo" is missing the following dependencies: Dependency "jboss.jca:name=DefaultDS,service=DataSourceBinding" (should be in state "Create", but is actually in state "Configured") Dependency "jboss:service=TransactionManager" (should be in state "Create", but is actually in state " NOT FOUND Depends on 'jboss:service=TransactionManager' ") Deployment "jboss:service=invoker,type=jrmp" is missing the following dependencies: Dependency "jboss:service=TransactionManager" (should be in state "Create", but is actually in state " NOT FOUND Depends on 'jboss:service=TransactionManager' ") Deployment "jboss:service=invoker,type=local" is missing the following dependencies: Dependency "jboss:service=TransactionManager" (should be in state "Create", but is actually in state " NOT FOUND Depends on 'jboss:service=TransactionManager' ") Deployment "jboss:service=invoker,type=pooled" is missing the following dependencies: Dependency "jboss:service=TransactionManager" (should be in state "Create", but is actually in state " NOT FOUND Depends on 'jboss:service=TransactionManager' ") Deployment "jboss:service=proxyFactory,target=ClientUserTransaction" is missing the following dependencies: Dependency "jboss:service=invoker,type=unified" (should be in state "Create", but is actually in state " NOT FOUND Depends on 'jboss:service=invoker,type=unified' ") Deployment "jboss:service=proxyFactory,target=ClientUserTransactionFactory" is missing the following dependencies: Dependency "jboss:service=invoker,type=unified" (should be in state "Create", but is actually in state " NOT FOUND Depends on 'jboss:service=invoker,type=unified' ") Deployment "vfsfile:/home/epankmi/Desktop/nuxeo-dm-5.4.0_01-jboss/nuxeo-dm-5.4.0.1-jboss/server/default/deploy/nuxeo.ear/" is missing the following dependencies: Dependency "interface javax.transaction.TransactionManager" (should be in state "Real", but is actually in state " NOT FOUND Depends on 'interface javax.transaction.TransactionManager' ") Dependency "interface javax.transaction.TransactionManager" (should be in state "Real", but is actually in state " NOT FOUND Depends on 'interface javax.transaction.TransactionManager' ") Dependency "interface javax.transaction.TransactionManager" (should be in state "Real", but is actually in state " NOT FOUND Depends on 'interface javax.transaction.TransactionManager' ") Dependency "interface javax.transaction.TransactionManager" (should be in state "Real", but is actually in state " NOT FOUND Depends on 'interface javax.transaction.TransactionManager' ") Dependency "interface javax.transaction.TransactionManager" (should be in state "Real", but is actually in state " NOT FOUND Depends on 'interface javax.transaction.TransactionManager' ") Dependency "interface javax.transaction.TransactionManager" (should be in state "Real", but is actually in state " NOT FOUND Depends on 'interface javax.transaction.TransactionManager' ") Dependency "interface javax.transaction.TransactionManager" (should be in state "Real", but is actually in state " NOT FOUND Depends on 'interface javax.transaction.TransactionManager' ") Dependency "interface javax.transaction.TransactionManager" (should be in state "Real", but is actually in state " NOT FOUND Depends on 'interface javax.transaction.TransactionManager' ") Dependency "interface javax.transaction.TransactionManager" (should be in state "Real", but is actually in state " NOT FOUND Depends on 'interface javax.transaction.TransactionManager' ") Dependency "interface javax.transaction.TransactionManager" (should be in state "Real", but is actually in state " NOT FOUND Depends on 'interface javax.transaction.TransactionManager' ") Dependency "interface javax.transaction.TransactionManager" (should be in state "Real", but is actually in state " NOT FOUND Depends on 'interface javax.transaction.TransactionManager' ") Dependency "interface javax.transaction.TransactionManager" (should be in state "Real", but is actually in state " NOT FOUND Depends on 'interface javax.transaction.TransactionManager' ") Dependency "interface javax.transaction.TransactionManager" (should be in state "Real", but is actually in state " NOT FOUND Depends on 'interface javax.transaction.TransactionManager' ") Dependency "interface javax.transaction.TransactionManager" (should be in state "Real", but is actually in state " NOT FOUND Depends on 'interface javax.transaction.TransactionManager' ") Dependency "interface javax.transaction.TransactionManager" (should be in state "Real", but is actually in state " NOT FOUND Depends on 'interface javax.transaction.TransactionManager' ") Dependency "interface javax.transaction.TransactionManager" (should be in state "Real", but is actually in state " NOT FOUND Depends on 'interface javax.transaction.TransactionManager' ") Dependency "interface javax.transaction.TransactionManager" (should be in state "Real", but is actually in state " NOT FOUND Depends on 'interface javax.transaction.TransactionManager' ") Dependency "interface javax.transaction.TransactionManager" (should be in state "Real", but is actually in state " NOT FOUND Depends on 'interface javax.transaction.TransactionManager' ") Dependency "interface javax.transaction.TransactionManager" (should be in state "Real", but is actually in state " NOT FOUND Depends on 'interface javax.transaction.TransactionManager' ") Dependency "interface javax.transaction.TransactionManager" (should be in state "Real", but is actually in state " NOT FOUND Depends on 'interface javax.transaction.TransactionManager' ") Dependency "interface javax.transaction.TransactionManager" (should be in state "Real", but is actually in state " NOT FOUND Depends on 'interface javax.transaction.TransactionManager' ") Dependency "interface javax.transaction.TransactionManager" (should be in state "Real", but is actually in state " NOT FOUND Depends on 'interface javax.transaction.TransactionManager' ") Dependency "interface javax.transaction.TransactionManager" (should be in state "Real", but is actually in state " NOT FOUND Depends on 'interface javax.transaction.TransactionManager' ") Dependency "interface javax.transaction.TransactionManager" (should be in state "Real", but is actually in state " NOT FOUND Depends on 'interface javax.transaction.TransactionManager' ") Dependency "interface javax.transaction.TransactionManager" (should be in state "Real", but is actually in state " NOT FOUND Depends on 'interface javax.transaction.TransactionManager' ") Dependency "interface javax.transaction.TransactionManager" (should be in state "Real", but is actually in state " NOT FOUND Depends on 'interface javax.transaction.TransactionManager' ") Dependency "interface javax.transaction.TransactionManager" (should be in state "Real", but is actually in state " NOT FOUND Depends on 'interface javax.transaction.TransactionManager' ") Dependency "interface javax.transaction.TransactionManager" (should be in state "Real", but is actually in state " NOT FOUND Depends on 'interface javax.transaction.TransactionManager' ") Dependency "interface javax.transaction.TransactionManager" (should be in state "Real", but is actually in state " NOT FOUND Depends on 'interface javax.transaction.TransactionManager' ") Dependency "interface javax.transaction.TransactionManager" (should be in state "Real", but is actually in state " NOT FOUND Depends on 'interface javax.transaction.TransactionManager' ") Dependency "interface javax.transaction.TransactionManager" (should be in state "Real", but is actually in state " NOT FOUND Depends on 'interface javax.transaction.TransactionManager' ") Dependency "interface javax.transaction.TransactionManager" (should be in state "Real", but is actually in state " NOT FOUND Depends on 'interface javax.transaction.TransactionManager' ") Dependency "interface javax.transaction.TransactionManager" (should be in state "Real", but is actually in state " NOT FOUND Depends on 'interface javax.transaction.TransactionManager' ") Dependency "interface javax.transaction.TransactionManager" (should be in state "Real", but is actually in state " NOT FOUND Depends on 'interface javax.transaction.TransactionManager' ") Dependency "interface javax.transaction.TransactionManager" (should be in state "Real", but is actually in state " NOT FOUND Depends on 'interface javax.transaction.TransactionManager' ") Dependency "interface javax.transaction.TransactionManager" (should be in state "Real", but is actually in state " NOT FOUND Depends on 'interface javax.transaction.TransactionManager' ") Dependency "interface javax.transaction.TransactionManager" (should be in state "Real", but is actually in state " NOT FOUND Depends on 'interface javax.transaction.TransactionManager' ") Dependency "interface javax.transaction.TransactionManager" (should be in state "Real", but is actually in state " NOT FOUND Depends on 'interface javax.transaction.TransactionManager' ") Dependency "interface javax.transaction.TransactionManager" (should be in state "Real", but is actually in state " NOT FOUND Depends on 'interface javax.transaction.TransactionManager' ") Dependency "interface javax.transaction.TransactionManager" (should be in state "Real", but is actually in state " NOT FOUND Depends on 'interface javax.transaction.TransactionManager' ") Dependency "interface javax.transaction.TransactionManager" (should be in state "Real", but is actually in state " NOT FOUND Depends on 'interface javax.transaction.TransactionManager' ") Dependency "interface javax.transaction.TransactionManager" (should be in state "Real", but is actually in state " NOT FOUND Depends on 'interface javax.transaction.TransactionManager' ") Dependency "interface javax.transaction.TransactionManager" (should be in state "Real", but is actually in state " NOT FOUND Depends on 'interface javax.transaction.TransactionManager' ") Dependency "interface javax.transaction.TransactionManager" (should be in state "Real", but is actually in state " NOT FOUND Depends on 'interface javax.transaction.TransactionManager' ") Dependency "interface javax.transaction.TransactionManager" (should be in state "Real", but is actually in state " NOT FOUND Depends on 'interface javax.transaction.TransactionManager' ") Dependency "interface javax.transaction.TransactionManager" (should be in state "Real", but is actually in state " NOT FOUND Depends on 'interface javax.transaction.TransactionManager' ") Dependency "interface javax.transaction.TransactionManager" (should be in state "Real", but is actually in state " NOT FOUND Depends on 'interface javax.transaction.TransactionManager' ") Dependency "interface javax.transaction.TransactionManager" (should be in state "Real", but is actually in state " NOT FOUND Depends on 'interface javax.transaction.TransactionManager' ") Dependency "interface javax.transaction.TransactionManager" (should be in state "Real", but is actually in state " NOT FOUND Depends on 'interface javax.transaction.TransactionManager' ") Dependency "interface javax.transaction.TransactionManager" (should be in state "Real", but is actually in state " NOT FOUND Depends on 'interface javax.transaction.TransactionManager' ") Dependency "interface javax.transaction.TransactionManager" (should be in state "Real", but is actually in state " NOT FOUND Depends on 'interface javax.transaction.TransactionManager' ") Dependency "interface javax.transaction.TransactionManager" (should be in state "Real", but is actually in state " NOT FOUND Depends on 'interface javax.transaction.TransactionManager' ") Dependency "interface javax.transaction.TransactionManager" (should be in state "Real", but is actually in state " NOT FOUND Depends on 'interface javax.transaction.TransactionManager' ") Deployment "vfsfile:/home/epankmi/Desktop/nuxeo-dm-5.4.0_01-jboss/nuxeo-dm-5.4.0.1-jboss/server/default/deploy/nuxeo.ear/nuxeo.war/_Alias_AbstractKernelController[813888402]" is missing the following dependencies: Dependency "vfsfile:/home/epankmi/Desktop/nuxeo-dm-5.4.0_01-jboss/nuxeo-dm-5.4.0.1-jboss/server/default/deploy/nuxeo.ear/" (should be in state "Installed", but is actually in state "PreReal") Deployment "vfsfile:/home/epankmi/Desktop/nuxeo-dm-5.4.0_01-jboss/nuxeo-dm-5.4.0.1-jboss/server/default/deploy/profileservice-secured.jar/" is missing the following dependencies: Dependency "interface javax.transaction.TransactionManager" (should be in state "Real", but is actually in state " NOT FOUND Depends on 'interface javax.transaction.TransactionManager' ") Dependency "interface javax.transaction.TransactionManager" (should be in state "Real", but is actually in state " NOT FOUND Depends on 'interface javax.transaction.TransactionManager' ") Dependency "interface javax.transaction.TransactionManager" (should be in state "Real", but is actually in state " NOT FOUND Depends on 'interface javax.transaction.TransactionManager' **")
DEPLOYMENTS IN ERROR: Deployment "interface javax.transaction.TransactionManager" is in error due to the following reason(s): ** NOT FOUND Depends on 'interface javax.transaction.TransactionManager' ** Deployment "TransactionManager" is in error due to the following reason(s): com.arjuna.ats.arjuna.exceptions.FatalError: Recovery manager already active (or recovery port and address are in use)!, ERROR Deployment "jboss.jca:service=WorkManager" is in error due to the following reason(s): ** NOT FOUND Depends on 'jboss.jca:service=WorkManager' ** Deployment "vfsfile:/home/epankmi/Desktop/nuxeo-dm-5.4.0_01-jboss/nuxeo-dm-5.4.0.1-jboss/server/default/deploy/messaging/remoting-bisocket-service.xml" is in error due to the following reason(s): java.lang.RuntimeException: Can not determine bindable address for locator (InvokerLocator [bisocket://0.0.0.0:4457/?JBM_clientMaxPoolSize=200&clientLeasePeriod=10000&clientSocketClass=org.jboss.jms.client.remoting.ClientSocketWrapper&connectionWait=10&dataType=jms&marshaller=org.jboss.jms.wireformat.JMSWireFormat&numberOfCallRetries=1&pingFrequency=214748364&pingWindowFactor=10&socket.check_connection=false&stopLeaseOnFailure=true&timeout=0&unmarshaller=org.jboss.jms.wireformat.JMSWireFormat&validatorPingPeriod=10000&validatorPingTimeout=5000]) Deployment "WSServerConfig" is in error due to the following reason(s): java.net.UnknownHostException: B1H68R1.egi.ericsson.com: B1H68R1.egi.ericsson.com Deployment "jboss.messaging:service=Connector,transport=bisocket" is in error due to the following reason(s): ** NOT FOUND Depends on 'jboss.messaging:service=Connector,transport=bisocket' ** Deployment "vfsfile:/home/epankmi/Desktop/nuxeo-dm-5.4.0_01-jboss/nuxeo-dm-5.4.0.1-jboss/server/default/deploy/jmx-remoting.sar/" is in error due to the following reason(s): java.net.BindException: Address already in use Deployment "jboss:service=invoker,type=unified" is in error due to the following reason(s): ** NOT FOUND Depends on 'jboss:service=invoker,type=unified' ** Deployment "vfsfile:/home/epankmi/Desktop/nuxeo-dm-5.4.0_01-jboss/nuxeo-dm-5.4.0.1-jboss/server/default/deploy/http-invoker.sar/" is in error due to the following reason(s): java.net.UnknownHostException: B1H68R1.egi.ericsson.com: B1H68R1.egi.ericsson.com Deployment "jboss.remoting:service=Connector,transport=socket" is in error due to the following reason(s): ** NOT FOUND Depends on 'jboss.remoting:service=Connector,transport=socket' ** Deployment "org.jboss.ejb3.RemotingConnector" is in error due to the following reason(s): java.lang.RuntimeException: Can not determine bindable address for locator (InvokerLocator [socket://0.0.0.0:3873/]) Deployment "" is in error due to the following reason(s): ** UNRESOLVED Demands 'TransactionManager' ** Deployment "jboss:service=TransactionManager" is in error due to the following reason(s): ** NOT FOUND Depends on 'jboss:service=TransactionManager' ** Deployment "UnifiedInvokerConnector" is in error due to the following reason(s): java.lang.RuntimeException: Can not determine bindable address for locator (InvokerLocator [socket://0.0.0.0:4446/?dataType=invocation&enableTcpNoDelay=true&marshaller=org.jboss.invocation.unified.marshall.InvocationMarshaller&unmarshaller=org.jboss.invocation.unified.marshall.InvocationUnMarshaller]), ERROR Deployment "jboss.jca:service=CachedConnectionManager" is in error due to the following reason(s): ** NOT FOUND Depends on 'jboss.jca:service=CachedConnectionManager' ** Deployment "jboss.web:service=WebServer" is in error due to the following reason(s): Configured
Please help me to solve this problem.
Damien_Metzler
seems like JBoss tries to bind on an address and needs a hostname. He found the name, B1H68R1.egi.ericsson.com somewhere (perhaps in a host file on the system) but then try to resolve it and fails.
