Nuxeo Drive work with multi tenant instalation?
Claudio_Viana1
I install a server with 2 repositories, and the action Direct Edit dont work when I try to open file that is on other repository that is not be default repository. Is there any additional configuration to apply to the drive? Bellow the log of drive when a execute the action.
server version 10.2
2019-01-08 17:40:59 4000 140735099588608 DEBUG nxdrive.wui.application Event URL=nxdrive://edit/http/server1:8080/nuxeo/user/Administrator/repo/repo2/nxdocid/5aca2e2e-8410-4246-840c-2d2bd753ac6c/filename/teste1.png/downloadUrl/nxfile/repo2/5aca2e2e-8410-4246-840c-2d2bd753ac6c/blobholder:0/, info={'repo': 'repo2', 'command': 'download_edit', 'user': 'Administrator', 'doc_id': '5aca2e2e-8410-4246-840c-2d2bd753ac6c', 'server_url': 'http://server1:8080/nuxeo', 'download_url': 'nxfile/repo2/5aca2e2e-8410-4246-840c-2d2bd753ac6c/blobholder:0/', 'filename': 'teste1.png'} 2019-01-08 17:40:59 4000 140735099588608 DEBUG nxdrive.direct_edit Editing doc 5aca2e2e-8410-4246-840c-2d2bd753ac6c on http://server1:8080/nuxeo 2019-01-08 17:41:00 4000 140735099588608 DEBUG nxdrive.client.base_automation_client Remote exception message: Failed to invoke operation: Repository.GetDocument, 5aca2e2e-8410-4246-840c-2d2bd753ac6c 2019-01-08 17:41:00 4000 140735099588608 DEBUG nxdrive.client.base_automation_client Remote exception details: '{"entity-type":"exception","status":404,"message":"Failed to invoke operation: Repository.GetDocument, 5aca2e2e-8410-4246-840c-2d2bd753ac6c"}' 2019-01-08 17:41:00 4000 140735099588608 ERROR nxdrive.wui.application Error handling URL event <built-in method url of QFileOpenEvent object at 0x119c58c30> Traceback (most recent call last): File "nxdrive/wui/application.py", line 675, in event File "nxdrive/wui/application.py", line 707, in _handle_macos_event File "nxdrive/direct_edit.py", line 336, in edit File "nxdrive/direct_edit.py", line 275, in _prepare_edit File "nxdrive/direct_edit.py", line 243, in _get_info File "nxdrive/client/remote_document_client.py", line 453, in fetch NotFound: Failed to fetch document '5aca2e2e-8410-4246-840c-2d2bd753ac6c' on server u'http://server1:8080/nuxeo/'
Mickaël_Schoent
It seems you are using a very old version of Nuxeo Drive. Could you retry with an up-to-date version? See https://community.nuxeo.com/static/drive-updates/ to find the latest version.
