10-01-2014 06:33 AM
Hi! I want to programmatically run the "SerialDocumentReview" workflow on a document through REST API. I was able to start the workflow but now I need to select the particiants. Can someone help me please? Thank you in advance, Rado Andriamahady
10-01-2014 05:46 PM
I do not have editing ability, but you should change your title to "Help with Workflow Automation" (notice wit -> with), along with ... "I need to select the participants." (particiants -> participants).
02-15-2016 07:05 AM
Hi, Please refer the link https://doc.nuxeo.com/display/NXDOC/Workflow+APIs for Serial as well as parallel workflow api's. Revert for clarifications.
