UTF-8 character problem
taskinbinbir
I'm using alfresco 5.2. I have got o problem. Turkish characters look like ? in the footer of the index page.
There is a UTF-8 problem in this section. how can i solve this problem ?
5 REPLIES 5
cesarista
World-Class Innovator
Hi:
This label is extended in some properties file.
One thing you can do is to write your label with your non UTF8 characters in one file, and then to apply native2ascii program to this property file.
Regards.
--C.
I did it like you said but unchanged.
cesarista
native2ascii should convert your original file. Replace the original file with the resulting file and then restart Alfresco.
I did it like you said.
cesarista
In that case, you can try to start Alfresco with -Dfile.encoding=UTF8
Regards.
--C.
