04-24-2020 04:38 AM
I am using Alfresco Community Edition 201911 GA , and when I edit a plain text file using "Edit in Alfresco Share" the thumbnails are not refreshed. I does update one or two times, but after that document does not update anymore.
If I create a new document, it happens the same, the thumbnails get updated a couple of times but not more.
When this happens I can see in the log the following error:
2020-04-24 07:47:36,551 ERROR [org.springframework.extensions.webscripts.AbstractRuntime] [ajp-nio-127.0.0.1-8009-exec-11] Exception from executeScript: 03240001 Wrapped Exception (with status template): 03240020 Failed to execute script 'classpath*:alfresco/templates/webscripts/org/alfresco/repository/thumbnail/thumbnail.get.js': 03240019 03240018 A rendition of name: {http://www.alfresco.org/model/content/1.0}pdf should have been created for source node: workspace://SpacesStore/f5f4ff84-4749-4b77-8435-fb7cf924d5a3
org.springframework.extensions.webscripts.WebScriptException: 03240001 Wrapped Exception (with status template): 03240020 Failed to execute script 'classpath*:alfresco/templates/webscripts/org/alfresco/repository/thumbnail/thumbnail.get.js': 03240019 03240018 A rendition of name: {http://www.alfresco.org/model/content/1.0}pdf should have been created for source node: workspace://SpacesStore/f5f4ff84-4749-4b77-8435-fb7cf924d5a3
at org.springframework.extensions.webscripts.AbstractWebScript.createStatusException(AbstractWebScript.java:1139)
at org.alfresco.repo.web.scripts.content.StreamContent.execute(StreamContent.java:202)
at org.alfresco.repo.web.scripts.RepositoryContainer$3.execute(RepositoryContainer.java:519)
at org.alfresco.repo.transaction.RetryingTransactionHelper.doInTransaction(RetryingTransactionHelper.java:450)
at org.alfresco.repo.web.scripts.RepositoryContainer.transactionedExecute(RepositoryContainer.java:595)
at org.alfresco.repo.web.scripts.RepositoryContainer.transactionedExecuteAs(RepositoryContainer.java:664)
at org.alfresco.repo.web.scripts.RepositoryContainer.executeScriptInternal(RepositoryContainer.java:435)
at org.alfresco.repo.web.scripts.RepositoryContainer.executeScript(RepositoryContainer.java:315)
at org.springframework.extensions.webscripts.AbstractRuntime.executeScript(AbstractRuntime.java:399)
at org.springframework.extensions.webscripts.AbstractRuntime.executeScript(AbstractRuntime.java:210)
at org.springframework.extensions.webscripts.servlet.WebScriptServlet.service(WebScriptServlet.java:132)
at org.alfresco.repo.web.scripts.AlfrescoWebScriptServlet.service(AlfrescoWebScriptServlet.java:43)
at javax.servlet.http.HttpServlet.service(HttpServlet.java:741)
at org.apache.catalina.core.ApplicationFilterChain.internalDoFilter(ApplicationFilterChain.java:231)
at org.apache.catalina.core.ApplicationFilterChain.doFilter(ApplicationFilterChain.java:166)
at org.apache.tomcat.websocket.server.WsFilter.doFilter(WsFilter.java:52)
at org.apache.catalina.core.ApplicationFilterChain.internalDoFilter(ApplicationFilterChain.java:193)
at org.alfresco.web.app.servlet.GlobalLocalizationFilter.doFilter(GlobalLocalizationFilter.java:68)
at org.alfresco.web.app.servlet.ClearSecurityContextFilter.doFilter(ClearSecurityContextFilter.java:53)
at org.apache.catalina.core.StandardWrapperValve.invoke(StandardWrapperValve.java:199)
at org.apache.catalina.core.StandardContextValve.invoke(StandardContextValve.java:96)
at org.apache.catalina.authenticator.AuthenticatorBase.invoke(AuthenticatorBase.java:543)
at org.apache.catalina.core.StandardHostValve.invoke(StandardHostValve.java:139)
at org.apache.catalina.valves.ErrorReportValve.invoke(ErrorReportValve.java:81)
at org.apache.catalina.valves.AbstractAccessLogValve.invoke(AbstractAccessLogValve.java:690)
at org.apache.catalina.core.StandardEngineValve.invoke(StandardEngineValve.java:87)
at org.apache.catalina.connector.CoyoteAdapter.service(CoyoteAdapter.java:343)
at org.apache.coyote.ajp.AjpProcessor.service(AjpProcessor.java:525)
at org.apache.coyote.AbstractProcessorLight.process(AbstractProcessorLight.java:65)
at org.apache.coyote.AbstractProtocol$ConnectionHandler.process(AbstractProtocol.java:818)
at org.apache.tomcat.util.net.NioEndpoint$SocketProcessor.doRun(NioEndpoint.java:1627)
at org.apache.tomcat.util.net.SocketProcessorBase.run(SocketProcessorBase.java:49)
at java.base/java.util.concurrent.ThreadPoolExecutor.runWorker(ThreadPoolExecutor.java:1128)
at java.base/java.util.concurrent.ThreadPoolExecutor$Worker.run(ThreadPoolExecutor.java:628)
at java.base/java.lang.Thread.run(Thread.java:834)
Caused by: org.alfresco.scripts.ScriptException: 03240020 Failed to execute script 'classpath*:alfresco/templates/webscripts/org/alfresco/repository/thumbnail/thumbnail.get.js': 03240019 03240018 A rendition of name: {http://www.alfresco.org/model/content/1.0}pdf should have been created for source node: workspace://SpacesStore/f5f4ff84-4749-4b77-8435-fb7cf924d5a3
at org.alfresco.repo.jscript.RhinoScriptProcessor.execute(RhinoScriptProcessor.java:211)
at org.alfresco.repo.processor.ScriptServiceImpl.execute(ScriptServiceImpl.java:219)
at org.alfresco.repo.processor.ScriptServiceImpl.executeScript(ScriptServiceImpl.java:181)
at org.alfresco.repo.web.scripts.RepositoryScriptProcessor.executeScript(RepositoryScriptProcessor.java:109)
at org.springframework.extensions.webscripts.AbstractWebScript.executeScript(AbstractWebScript.java:1376)
at org.alfresco.repo.web.scripts.content.StreamContent.execute(StreamContent.java:146)
... 39 moreHere is a video on showing the issue:
https://drive.google.com/open?id=1jIKjvFDQVyKDmoqaSP4FdklzSafQGTU2
Thanks forehand
06-25-2021 10:11 AM
Pdf preview stop working after document edited using offline option.
Could not load pdf content
06-25-2021 10:33 AM
11-16-2021 08:18 AM
Hi Everyone,
Im face the same issue with Alfresco 6.1 GA, the same issue was metioned at https://hub.alfresco.com/t5/alfresco-content-services-forum/document-preview-isn-t-working-on-edited...
Logs: (The complete logs are showen on link above)
ERROR [extensions.webscripts.AbstractRuntime] [http-nio-8080-exec-7] Exception from executeScript: 10160020 Wrapped Exception (with status template): 10160218 Failed to execute script 'classpath*:alfresco/templates/webscripts/org/alfresco/repository/thumbnail/thumbnail.get.js': 10160217 10160216 A rendition of name: {http://www.alfresco.org/model/content/1.0}pdf should have been created for source node: workspace://SpacesStore/88eb6f27-6b6e-4656-8c3e-705450082e95
org.springframework.extensions.webscripts.WebScriptException: 10160020 Wrapped Exception (with status template): 10160218 Failed to execute script 'classpath*:alfresco/templates/webscripts/org/alfresco/repository/thumbnail/thumbnail.get.js': 10160217 10160216 A rendition of name: {http://www.alfresco.org/model/content/1.0}pdf should have been created for source node: workspace://SpacesStore/88eb6f27-6b6e-4656-8c3e-705450082e95
Caused by: org.alfresco.scripts.ScriptException: 10160218 Failed to execute script 'classpath*:alfresco/templates/webscripts/org/alfresco/repository/thumbnail/thumbnail.get.js': 10160217 10160216 A rendition of name: {http://www.alfresco.org/model/content/1.0}pdf should have been created for source node: workspace://SpacesStore/88eb6f27-6b6e-4656-8c3e-705450082e95There is any solution for this? Note that this error was detected more than (2)two years ago and there is still no solution.
the current versions of Alfresco have this improvement? if yes, how can we migrate it ??
How can we track this issue ?? There is another forum to do that ???
Thanks ...
11-19-2021 04:24 AM
Hi Everyone,
I manage to solve this problem by using Alfresco Transform service AIO with Alfresco Content Services 7.1 GA , i follow the Link Props to @abhinavmishra14 For the excelent and detailed work.
I hope this is useful.
09-10-2024 01:51 PM
I hit same issue with alfresco 7.4 and transform engine 5.1.0. Only working solution for me was create beahvior, delete existing thumbnails and create new one. Here is my code:
@Override
public void onContentUpdate(NodeRef nodeRef, boolean newContent) {
NodeService nodeService = serviceRegistry.getNodeService();
RenditionService2 renditionService2 = serviceRegistry.getRenditionService2();
if(nodeService.exists(nodeRef))
if(ContentModel.TYPE_THUMBNAIL.equals(nodeService.getType(nodeRef))==false)
Set<QName> types = new HashSet<QName>();
types.add(ContentModel.TYPE_THUMBNAIL);
List<ChildAssociationRef> thumbnail_assocs = nodeService.getChildAssocs(nodeRef, types);
for (ChildAssociationRef thumbnail_assoc : thumbnail_assocs) {
NodeRef thumbnail = thumbnail_assoc.getChildRef();
nodeService.deleteNode(thumbnail);
renditionService2.render(nodeRef, "pdf");
}If someone found better solution i will be glad. This is ugly ![]()
