Starting a process instance using REST call
04-03-2018 04:45 PM
I am trying to start a process instance using REST API.
It can start the process and pass the variable but I also want to retrieve the data from the database.
According to the variable I pass into the body.
(POST) http://localhost:8080/activiti-app/api/runtime/process-instances?tenantId=tenant_1
"processDefinitionId":"vacationRequest",
"businessKey":"vacationRequest",
"variables": [
"name":"userId",
"value":"user123"
When I open the activiti app Task I can see the process is running and the userId is passed in, but I cannot get the userdata from Mysql database.
If I start the process in the Task App it will work, but not uring REST call.
Brian
Alfresco Process Services
04-04-2018 04:40 AM
I'm not sure if you want to get the user involved by this process. if you want to get this ,you can call
/runtime/process-instances/{processInstanceId}/identitylinks
