05-22-2017 09:41 AM
Continuing my study to create a simple custom indicators (on my preivous post: How to change default icon folder based on its properties? ), I start to create it with reference from Jeff's post here Colour vs tags .
I create ar:dirFungsi properties applied to a folder which will add a custom indicator.
Following are my steps and codes:
1. Add an evaluator /tomcat/webapps/share/WEB-INF/classes/alfresco/custom-slingshot-application-context.xml
<beans>
<!-- Directory Obyektif Evaluator -->
<bean id="evaluator.doclib.action.dirObyektif" parent="evaluator.doclib.action.value">
<property name="accessor" value="node.properties.ar:dirFungsi" />
<property name="comparator">
<bean class="org.alfresco.web.evaluator.StringEqualsComparator">
<property name="value" value="DirObyektif" />
</bean>
</property>
</bean>
</beans>
2. Add indicator inside condition attribute equals to DocumentLibrary in /tomcat/shared/classes/alfresco/web-extension/share-config-custom.xml
<indicators>
<indicator id="dirobyektif" index="100">
<evaluator>evaluator.doclib.action.dirObyektif</evaluator>
</indicator>
</indicators>
3. Create an image in /tomcat/webapps/share/components/documentlibrary/indicators/dirobyektif-16.png
Then I restarted the server, but the indicator doesn't appear.
What is the problem and how to solve it?
[bayu]
05-27-2017 08:11 AM
don't add your customizations to /share nor /alfresco
check the documentation here:
Evaluators | Alfresco Documentation
re-do your first step, adding evaluator to this file:
tomcat/shared/classes/alfresco/web-extension/custom-slingshot-application-context.xml
05-27-2017 11:01 AM
Hi Markus Joos
I have put the evaluator as suggested, but the indicator still not appear
I also checked share.log & alfresco.log but nothing errors found.
Is there any misconfigure syntax on my files above?
My idea is simple, evaluator will check the folder property ar:dirFungsi value is "DirObyektif", if true, the custom indicator will appear.
06-05-2017 07:51 AM
Anyone can help my problem, pls?
Thank you in advance.
