SAML 2.0/OAUTH 2.0 Single Sign On integration with Alfresco community edition 5.2
achatterji
Hi All,
I'm pretty new to Alfresco. Can you plese suggest whether Alfresco community edition does support SAML 2.0 (preferably) or OAUTH 2.0 Authorization for Single Sign On. If there is can I have any guidance documentation how to implement the same.
It would be of great help if Ive that insight.
9 REPLIES 9
EddieMay
World-Class Innovator
Hi @achatterji,
Yes, Community 5.2 does support SAML - "SAML Single Sign On can be used for Alfresco Community Edition and Alfresco Office Services".
HTH
Digital Community Manager, Alfresco Software.
cesarista
Mmmm, is this valid for 5.2 CE ?
I remember to use a custom addon for 5.2 only in Enterprise Edition, but not in CE.
https://docs.alfresco.com/5.2/concepts/supported-platforms-ACS.html
Kind regards.
--C.
EddieMay
Hi @cesarista,
You're probably right - apologies for the misdirection.
achatterji
I'm pretty new to Alfresco.  We've got primarily 2 options in Microsoft Authorization landscape.
1.SAML 2.0.
2. OAUTH 2.0.
Can anybody please guide me regarding Single Sign On integration with Alfresco. Is there any clear documentation how to implement either of the above mentioned authorization mechanism with steps. I'm looking for this desparetely. Appreciate your kind help.
Hi @EddieMay / @cesarista ,
In this document I can see SAML is supported for 5.2.0 version. I'm a bit confused. Can you please guide me through this.
cesarista
Hi:
This is the compatibility matrix for Enterprise / Subscription-based Edition of ACS 5.2.
The Enterprise third party integrations such as SAML SSO does not apply to Community Edition. Also it happens with commercial databases (such as Oracle and MS-SQLServer).
Regards.
--C.
achatterji
Hi @cesarista,
Thanks for your valuable input. Is there any direction for supported SSO authorization mechanism for Alfresco 5.2 content services community edition
here's the official documentation starting point: https://docs.alfresco.com/community/concepts/auth-basics.html
It's the docs for the latest version of Alfresco CE, but I don't remember any changes from 5.2.
For SSO we usually use NTLM (old, vulnerable, not recommended) or Kerberos.
Hope this helps.
Leonardo.
@lmattioli1 ,
Thanks for the direction.
