Problems with solr6 index rebuild and alfresco 6.x
06-09-2020 01:41 AM
Dear support,
My name is Ángel and I am writing to you from Fundación CARTIF. As I indicated in the thread issue, we have problems with the SOLR 6 engine in our Alfresco Community 6.x
Specifically, we saw the following error in the alfresco.log and tried to rebuild the entire solr6 indexing but it didn't work.
2020-06-08 12:10:23,615 ERROR [org.alfresco.repo.site.SiteServiceImpl] [http-nio-8080-exec-23] LuceneQueryParserException with findSites() org.alfresco.repo.search.impl.lucene.LuceneQueryParserException: 05080032 Request failed 500 /solr/alfresco/afts?wt=json&fl=DBID%2Cscore&rows=5&df=TEXT&start=0&locale=es_ES&alternativeDic=DEFAULT_DICTIONARY&fq=%7B%21afts%7DAUTHORITY_FILTER_FROM_JSON&fq=%7B%21afts%7DTENANT_FILTER_FROM_JSON
The symptoms are as follows:
- When accessing a site's repository a popup appears with the previous error.
- We get different results with different users when we do a document search in the whole repository. Add that after trying a rebuild of the index now no user finds anything.
We have followed these links:
https://docs.alfresco.com/5.1/tasks/solr-reindex.html
https://www.zylk.net/en/web-2-0/blog/-/blogs/performing-a-full-reindex-with-solr-for-alfresco-ecm
Any idea what might be happening and how to fix it?
Thank you very much for your attention.
Best regards,
Ángel.
Alfresco Content Services
06-10-2020 03:49 AM
Hi @angelborroy ,
Thanks for your suggestion. With Java SE11 or Java OpenJDK 11 I get this error on Tomcat logs:
Error: Could not create the Java Virtual Machine. Error: A fatal exception has occurred. Program will exit. NOTE: Picked up JDK_JAVA_OPTIONS: --add-opens=java.base/java.lang=ALL-UNNAMED --add-opens=java.base/java.io=ALL-UNNAMED --add-opens=java.rmi/sun.rmi.transport=ALL-UNNAMED -Djava.endorsed.dirs=/opt/alfresco/tomcat/endorsed is not supported. Endorsed standards and standalone APIs in modular form will be supported via the concept of upgradeable modules.
The only way I can run Alfresco 6.x is with Java version 8.
Thank you.
Best regards,
Ángel.
06-10-2020 03:56 AM
Sorry, the upload of the log file "solr.log" has failed. It has now been attached.
2020-06-10 08:50:54.468 INFO (main) [ ] o.e.j.s.Server jetty-9.3.14.v20161028 2020-06-10 08:50:55.969 INFO (main) [ ] o.a.s.s.SolrDispatchFilter ___ _ Welcome to Apache Solr™ version 6.6.5-patched a77dde61f5121c726afb0e50a8e34ebba88534a4 - build - 2018-10-26 16:24:31 2020-06-10 08:50:55.970 INFO (main) [ ] o.a.s.s.SolrDispatchFilter / __| ___| |_ _ Starting in standalone mode on port 8983 2020-06-10 08:50:55.970 INFO (main) [ ] o.a.s.s.SolrDispatchFilter \__ \/ _ \ | '_| Install dir: /opt/alfresco/alfresco-search-services/solr 2020-06-10 08:50:55.997 INFO (main) [ ] o.a.s.s.SolrDispatchFilter |___/\___/_|_| Start time: 2020-06-10T07:50:55.972Z 2020-06-10 08:50:57.150 ERROR (main) [ ] o.a.s.s.SolrDispatchFilter Could not start Solr. Check solr/home property and the logs 2020-06-10 08:50:57.183 ERROR (main) [ ] o.a.s.c.SolrCore null:java.lang.UnsupportedClassVersionError: org/alfresco/error/AlfrescoRuntimeException has been compiled by a more recent version of the Java Runtime (class file version 55.0), this version of the Java Runtime only recognizes class file versions up to 52.0 at java.lang.ClassLoader.defineClass1(Native Method) at java.lang.ClassLoader.defineClass(ClassLoader.java:756) at java.security.SecureClassLoader.defineClass(SecureClassLoader.java:142) at java.net.URLClassLoader.defineClass(URLClassLoader.java:468) at java.net.URLClassLoader.access$100(URLClassLoader.java:74) at java.net.URLClassLoader$1.run(URLClassLoader.java:369) at java.net.URLClassLoader$1.run(URLClassLoader.java:363) at java.security.AccessController.doPrivileged(Native Method) at java.net.URLClassLoader.findClass(URLClassLoader.java:362) at org.eclipse.jetty.webapp.WebAppClassLoader.findClass(WebAppClassLoader.java:550) at org.eclipse.jetty.webapp.WebAppClassLoader.loadClass(WebAppClassLoader.java:475) at org.eclipse.jetty.webapp.WebAppClassLoader.loadClass(WebAppClassLoader.java:428) at java.lang.Class.forName0(Native Method) at java.lang.Class.forName(Class.java:348) at org.apache.solr.core.SolrResourceLoader.findClass(SolrResourceLoader.java:539) at org.apache.solr.core.SolrResourceLoader.newInstance(SolrResourceLoader.java:624) at org.apache.solr.core.CoreContainer.createHandler(CoreContainer.java:1413) at org.apache.solr.core.CoreContainer.load(CoreContainer.java:498) at org.apache.solr.servlet.SolrDispatchFilter.createCoreContainer(SolrDispatchFilter.java:244) at org.apache.solr.servlet.SolrDispatchFilter.init(SolrDispatchFilter.java:173) at org.eclipse.jetty.servlet.FilterHolder.initialize(FilterHolder.java:137) at org.eclipse.jetty.servlet.ServletHandler.initialize(ServletHandler.java:873) at org.eclipse.jetty.servlet.ServletContextHandler.startContext(ServletContextHandler.java:349) at org.eclipse.jetty.webapp.WebAppContext.startWebapp(WebAppContext.java:1404) at org.eclipse.jetty.webapp.WebAppContext.startContext(WebAppContext.java:1366) at org.eclipse.jetty.server.handler.ContextHandler.doStart(ContextHandler.java:778) at org.eclipse.jetty.servlet.ServletContextHandler.doStart(ServletContextHandler.java:262) at org.eclipse.jetty.webapp.WebAppContext.doStart(WebAppContext.java:520) at org.eclipse.jetty.util.component.AbstractLifeCycle.start(AbstractLifeCycle.java:68) at org.eclipse.jetty.deploy.bindings.StandardStarter.processBinding(StandardStarter.java:41) at org.eclipse.jetty.deploy.AppLifeCycle.runBindings(AppLifeCycle.java:188) at org.eclipse.jetty.deploy.DeploymentManager.requestAppGoal(DeploymentManager.java:499) at org.eclipse.jetty.deploy.DeploymentManager.addApp(DeploymentManager.java:147) at org.eclipse.jetty.deploy.providers.ScanningAppProvider.fileAdded(ScanningAppProvider.java:180) at org.eclipse.jetty.deploy.providers.WebAppProvider.fileAdded(WebAppProvider.java:458) at org.eclipse.jetty.deploy.providers.ScanningAppProvider$1.fileAdded(ScanningAppProvider.java:64) at org.eclipse.jetty.util.Scanner.reportAddition(Scanner.java:610) at org.eclipse.jetty.util.Scanner.reportDifferences(Scanner.java:529) at org.eclipse.jetty.util.Scanner.scan(Scanner.java:392) at org.eclipse.jetty.util.Scanner.doStart(Scanner.java:313) at org.eclipse.jetty.util.component.AbstractLifeCycle.start(AbstractLifeCycle.java:68) at org.eclipse.jetty.deploy.providers.ScanningAppProvider.doStart(ScanningAppProvider.java:150) at org.eclipse.jetty.util.component.AbstractLifeCycle.start(AbstractLifeCycle.java:68) at org.eclipse.jetty.deploy.DeploymentManager.startAppProvider(DeploymentManager.java:561) at org.eclipse.jetty.deploy.DeploymentManager.doStart(DeploymentManager.java:236) at org.eclipse.jetty.util.component.AbstractLifeCycle.start(AbstractLifeCycle.java:68) at org.eclipse.jetty.util.component.ContainerLifeCycle.start(ContainerLifeCycle.java:131) at org.eclipse.jetty.server.Server.start(Server.java:422) at org.eclipse.jetty.util.component.ContainerLifeCycle.doStart(ContainerLifeCycle.java:113) at org.eclipse.jetty.server.handler.AbstractHandler.doStart(AbstractHandler.java:61) at org.eclipse.jetty.server.Server.doStart(Server.java:389) at org.eclipse.jetty.util.component.AbstractLifeCycle.start(AbstractLifeCycle.java:68) at org.eclipse.jetty.xml.XmlConfiguration$1.run(XmlConfiguration.java:1516) at java.security.AccessController.doPrivileged(Native Method) at org.eclipse.jetty.xml.XmlConfiguration.main(XmlConfiguration.java:1441) at sun.reflect.NativeMethodAccessorImpl.invoke0(Native Method) at sun.reflect.NativeMethodAccessorImpl.invoke(NativeMethodAccessorImpl.java:62) at sun.reflect.DelegatingMethodAccessorImpl.invoke(DelegatingMethodAccessorImpl.java:43) at java.lang.reflect.Method.invoke(Method.java:498) at org.eclipse.jetty.start.Main.invokeMain(Main.java:214) at org.eclipse.jetty.start.Main.start(Main.java:457) at org.eclipse.jetty.start.Main.main(Main.java:75) 2020-06-10 08:50:57.185 WARN (main) [ ] o.e.j.d.DeploymentManager Unable to reach node goal: started java.lang.UnsupportedClassVersionError: org/alfresco/error/AlfrescoRuntimeException has been compiled by a more recent version of the Java Runtime (class file version 55.0), this version of the Java Runtime only recognizes class file versions up to 52.0 at java.lang.ClassLoader.defineClass1(Native Method) at java.lang.ClassLoader.defineClass(ClassLoader.java:756) at java.security.SecureClassLoader.defineClass(SecureClassLoader.java:142) at java.net.URLClassLoader.defineClass(URLClassLoader.java:468) at java.net.URLClassLoader.access$100(URLClassLoader.java:74) at java.net.URLClassLoader$1.run(URLClassLoader.java:369) at java.net.URLClassLoader$1.run(URLClassLoader.java:363) at java.security.AccessController.doPrivileged(Native Method) at java.net.URLClassLoader.findClass(URLClassLoader.java:362) at org.eclipse.jetty.webapp.WebAppClassLoader.findClass(WebAppClassLoader.java:550) at org.eclipse.jetty.webapp.WebAppClassLoader.loadClass(WebAppClassLoader.java:475) at org.eclipse.jetty.webapp.WebAppClassLoader.loadClass(WebAppClassLoader.java:428) at java.lang.Class.forName0(Native Method) at java.lang.Class.forName(Class.java:348) at org.apache.solr.core.SolrResourceLoader.findClass(SolrResourceLoader.java:539) at org.apache.solr.core.SolrResourceLoader.newInstance(SolrResourceLoader.java:624) at org.apache.solr.core.CoreContainer.createHandler(CoreContainer.java:1413) at org.apache.solr.core.CoreContainer.load(CoreContainer.java:498) at org.apache.solr.servlet.SolrDispatchFilter.createCoreContainer(SolrDispatchFilter.java:244) at org.apache.solr.servlet.SolrDispatchFilter.init(SolrDispatchFilter.java:173) at org.eclipse.jetty.servlet.FilterHolder.initialize(FilterHolder.java:137) at org.eclipse.jetty.servlet.ServletHandler.initialize(ServletHandler.java:873) at org.eclipse.jetty.servlet.ServletContextHandler.startContext(ServletContextHandler.java:349) at org.eclipse.jetty.webapp.WebAppContext.startWebapp(WebAppContext.java:1404) at org.eclipse.jetty.webapp.WebAppContext.startContext(WebAppContext.java:1366) at org.eclipse.jetty.server.handler.ContextHandler.doStart(ContextHandler.java:778) at org.eclipse.jetty.servlet.ServletContextHandler.doStart(ServletContextHandler.java:262) at org.eclipse.jetty.webapp.WebAppContext.doStart(WebAppContext.java:520) at org.eclipse.jetty.util.component.AbstractLifeCycle.start(AbstractLifeCycle.java:68) at org.eclipse.jetty.deploy.bindings.StandardStarter.processBinding(StandardStarter.java:41) at org.eclipse.jetty.deploy.AppLifeCycle.runBindings(AppLifeCycle.java:188) at org.eclipse.jetty.deploy.DeploymentManager.requestAppGoal(DeploymentManager.java:499) at org.eclipse.jetty.deploy.DeploymentManager.addApp(DeploymentManager.java:147) at org.eclipse.jetty.deploy.providers.ScanningAppProvider.fileAdded(ScanningAppProvider.java:180) at org.eclipse.jetty.deploy.providers.WebAppProvider.fileAdded(WebAppProvider.java:458) at org.eclipse.jetty.deploy.providers.ScanningAppProvider$1.fileAdded(ScanningAppProvider.java:64) at org.eclipse.jetty.util.Scanner.reportAddition(Scanner.java:610) at org.eclipse.jetty.util.Scanner.reportDifferences(Scanner.java:529) at org.eclipse.jetty.util.Scanner.scan(Scanner.java:392) at org.eclipse.jetty.util.Scanner.doStart(Scanner.java:313) at org.eclipse.jetty.util.component.AbstractLifeCycle.start(AbstractLifeCycle.java:68) at org.eclipse.jetty.deploy.providers.ScanningAppProvider.doStart(ScanningAppProvider.java:150) at org.eclipse.jetty.util.component.AbstractLifeCycle.start(AbstractLifeCycle.java:68) at org.eclipse.jetty.deploy.DeploymentManager.startAppProvider(DeploymentManager.java:561) at org.eclipse.jetty.deploy.DeploymentManager.doStart(DeploymentManager.java:236) at org.eclipse.jetty.util.component.AbstractLifeCycle.start(AbstractLifeCycle.java:68) at org.eclipse.jetty.util.component.ContainerLifeCycle.start(ContainerLifeCycle.java:131) at org.eclipse.jetty.server.Server.start(Server.java:422) at org.eclipse.jetty.util.component.ContainerLifeCycle.doStart(ContainerLifeCycle.java:113) at org.eclipse.jetty.server.handler.AbstractHandler.doStart(AbstractHandler.java:61) at org.eclipse.jetty.server.Server.doStart(Server.java:389) at org.eclipse.jetty.util.component.AbstractLifeCycle.start(AbstractLifeCycle.java:68) at org.eclipse.jetty.xml.XmlConfiguration$1.run(XmlConfiguration.java:1516) at java.security.AccessController.doPrivileged(Native Method) at org.eclipse.jetty.xml.XmlConfiguration.main(XmlConfiguration.java:1441) at sun.reflect.NativeMethodAccessorImpl.invoke0(Native Method) at sun.reflect.NativeMethodAccessorImpl.invoke(NativeMethodAccessorImpl.java:62) at sun.reflect.DelegatingMethodAccessorImpl.invoke(DelegatingMethodAccessorImpl.java:43) at java.lang.reflect.Method.invoke(Method.java:498) at org.eclipse.jetty.start.Main.invokeMain(Main.java:214) at org.eclipse.jetty.start.Main.start(Main.java:457) at org.eclipse.jetty.start.Main.main(Main.java:75) 2020-06-10 08:50:57.209 INFO (main) [ ] o.e.j.s.Server Started @4055ms 2020-06-10 08:51:09.703 ERROR (Finalizer) [ ] o.a.s.c.CoreContainer CoreContainer was not close prior to finalize(), indicates a bug -- POSSIBLE RESOURCE LEAK!!! instance=2044366277
06-10-2020 05:35 AM
You are not using Java 11.
06-10-2020 08:43 AM
As I said here, the problem when I use Java 11 is the "endorsed" module. I don't know how to solve that.
Best regards,
Ángel.
06-10-2020 09:03 AM
You could use Java 11 for SOLR and Java 8 for Alfresco Repository.
But Alfresco Repository should be working also with Java 11.
06-09-2020 04:13 AM
Hi @cartif & welcome to Alfresco!
You may find this coming Tech Talk Live useful - (Re)indexing Large Repositories, Wednesday, June 10th, 10:00 AM EDT | 3:00 PM BST | 4:00 PM CEST. Register at: https://www.alfresco.com/events/webinars/tech-talk-live-reindexing-large-repositories.The speakers are Angel Borry and Tom Page, search engineers at Alfresco.
06-09-2020 04:23 AM
Hi @EddieMay
Thank you very much for the link! Obviously I just registered for the webinar as it is directly related to this thread.
Best regards,
Ángel.
