Problems with custom models
moez_khedher
i had create two amps ;one repo and other share for my custom model i copy them to amp folder and amp_share in alfresco installation i stop my tomcat; and i run apply_amps after starting my server and when i sign in with admin admin ; my authentification is denied any ideas.?
if not; any ideas for creating a custom model for alfresco
Note: this is the link i used to create the model; Working With Custom Content Types in Alfresco | ECMArchitect | Alfresco Developer Tutorials
but it doesnt work;<!-- HEEEEEEEELP-->
8 REPLIES 8
afaust
Legendary Innovator
Legendary Innovator
First rule in asking for help: Provide log files and extensive information on what you did. When you only say "I created two AMPs and installed them", that is not really helpful. The tutorial in question is a proven one and there are likely not any errors in it, so there must be an error in what you have done in transferring what you read into practice.
ok
1-first i installed alfresco wich i download it from here  https://download.alfresco.com/release/community/201707-build-00028/alfresco-community-installer-2017...
2-i create two projects in an other folder ;content-tutorial-repo and content-tutorial-share  with
mvn archetype:generate -Dfilter=org.alfresco:
3-then i run mvn install for the two projects
4-two amps files are created
then i copied them as i said to alfresco installation and run apply_amps; that would make the model knwoed by the share as mentioned in the tutorial ; but i cant log in to see it; i really make the same work in the tutorial step by step !!!
and those are  my logs files  here
catalina file:
févr. 14, 2018 5:12:34 PM org.apache.catalina.core.AprLifecycleListener lifecycleEvent
INFOS: Loaded APR based Apache Tomcat Native library 1.2.14 using APR version 1.6.2.
INFOS: APR capabilities: IPv6 [true], sendfile [true], accept filters [false], random [true].
févr. 14, 2018 5:12:35 PM org.apache.catalina.core.AprLifecycleListener initializeSSL
INFOS: OpenSSL successfully initialized (OpenSSL 1.0.2l 25 May 2017)
févr. 14, 2018 5:12:36 PM org.apache.coyote.AbstractProtocol init
INFOS: Initializing ProtocolHandler ["http-apr-8080"]
INFOS: Initializing ProtocolHandler ["ajp-apr-8009"]
INFOS: Initializing ProtocolHandler ["http-bio-8443"]
févr. 14, 2018 5:12:39 PM org.apache.catalina.startup.Catalina load
INFOS: Initialization processed in 6336 ms
févr. 14, 2018 5:12:39 PM org.apache.catalina.core.StandardService startInternal
INFOS: Démarrage du service Catalina
févr. 14, 2018 5:12:39 PM org.apache.catalina.core.StandardEngine startInternal
INFOS: Starting Servlet Engine: Apache Tomcat/7.0.x
févr. 14, 2018 5:12:39 PM org.apache.catalina.startup.HostConfig deployDescriptor
INFOS: Déploiement du descripteur de configuration C:\alfresco\tomcat\conf\Catalina\localhost\alfresco.xml
févr. 14, 2018 5:13:53 PM org.apache.catalina.startup.TldConfig execute
INFOS: At least one JAR was scanned for TLDs yet contained no TLDs. Enable debug logging for this logger for a complete list of JARs that were scanned but no TLDs were found in them. Skipping unneeded JARs during scanning can improve startup time and JSP compilation time.
févr. 14, 2018 5:14:33 PM org.apache.catalina.core.StandardContext startInternal
GRAVE: One or more listeners failed to start. Full details will be found in the appropriate container log file
GRAVE: Erreur de démarrage du contexte [/alfresco] suite aux erreurs précédentes
févr. 14, 2018 5:14:34 PM org.apache.catalina.loader.WebappClassLoaderBase clearReferencesThreads
GRAVE: The web application [/alfresco] appears to have started a thread named [QuartzScheduler_Worker-1] but has failed to stop it. This is very likely to create a memory leak.
GRAVE: The web application [/alfresco] appears to have started a thread named [QuartzScheduler_Worker-2] but has failed to stop it. This is very likely to create a memory leak.
GRAVE: The web application [/alfresco] appears to have started a thread named [Timer-1] but has failed to stop it. This is very likely to create a memory leak.
GRAVE: The web application [/alfresco] appears to have started a thread named [QuartzScheduler_QuartzSchedulerThread] but has failed to stop it. This is very likely to create a memory leak.
févr. 14, 2018 5:14:34 PM org.apache.catalina.loader.WebappClassLoaderBase checkThreadLocalMapForLeaks
GRAVE: The web application [/alfresco] created a ThreadLocal with key of type [org.alfresco.repo.template.QNameAwareObjectWrapper$1] (value [org.alfresco.repo.template.QNameAwareObjectWrapper$1@7576c1aa]) and a value of type [org.alfresco.repo.template.QNameAwareObjectWrapper$1$1] (value [org.alfresco.repo.template.QNameAwareObjectWrapper$1$1@7a182a17]) but failed to remove it when the web application was stopped. Threads are going to be renewed over time to try and avoid a probable memory leak.
GRAVE: The web application [/alfresco] created a ThreadLocal with key of type [org.alfresco.repo.template.QNameAwareObjectWrapper$1] (value [org.alfresco.repo.template.QNameAwareObjectWrapper$1@5d869e13]) and a value of type [org.alfresco.repo.template.QNameAwareObjectWrapper$1$1] (value [org.alfresco.repo.template.QNameAwareObjectWrapper$1$1@650a941d]) but failed to remove it when the web application was stopped. Threads are going to be renewed over time to try and avoid a probable memory leak.
GRAVE: The web application [/alfresco] created a ThreadLocal with key of type [java.lang.ThreadLocal] (value [java.lang.ThreadLocal@347eb11a]) and a value of type [org.alfresco.util.CachingDateFormat] (value [yyyy-MM-dd]) but failed to remove it when the web application was stopped. Threads are going to be renewed over time to try and avoid a probable memory leak.
févr. 14, 2018 5:14:34 PM org.apache.catalina.startup.HostConfig deployDescriptor
INFOS: Deployment of configuration descriptor C:\alfresco\tomcat\conf\Catalina\localhost\alfresco.xml has finished in 114 350 ms
INFOS: Déploiement du descripteur de configuration C:\alfresco\tomcat\conf\Catalina\localhost\share.xml
févr. 14, 2018 5:16:12 PM org.apache.catalina.startup.TldConfig execute
févr. 14, 2018 5:16:41 PM org.apache.catalina.startup.HostConfig deployDescriptor
INFOS: Deployment of configuration descriptor C:\alfresco\tomcat\conf\Catalina\localhost\share.xml has finished in 126 809 ms
INFOS: Déploiement du descripteur de configuration C:\alfresco\tomcat\conf\Catalina\localhost\solr4.xml
févr. 14, 2018 5:16:41 PM org.apache.catalina.startup.SetContextPropertiesRule begin
AVERTISSEMENT: [SetContextPropertiesRule]{Context} Setting property 'debug' to '0' did not find a matching property.
févr. 14, 2018 5:17:12 PM org.apache.catalina.startup.TldConfig execute
févr. 14, 2018 5:17:19 PM org.apache.catalina.startup.HostConfig deployDescriptor
INFOS: Deployment of configuration descriptor C:\alfresco\tomcat\conf\Catalina\localhost\solr4.xml has finished in 38 714 ms
févr. 14, 2018 5:17:19 PM org.apache.catalina.startup.HostConfig deployWAR
INFOS: Déploiement de l'archive C:\alfresco\tomcat\webapps\ROOT.war de l'application web
févr. 14, 2018 5:17:19 PM org.apache.catalina.startup.SetContextPropertiesRule begin
AVERTISSEMENT: [SetContextPropertiesRule]{Context} Setting property 'debug' to '100' did not find a matching property.
févr. 14, 2018 5:17:20 PM org.apache.catalina.startup.TldConfig execute
févr. 14, 2018 5:17:20 PM org.apache.catalina.startup.HostConfig deployWAR
INFOS: Deployment of web application archive C:\alfresco\tomcat\webapps\ROOT.war has finished in 386 ms
INFOS: Déploiement de l'archive C:\alfresco\tomcat\webapps\_vti_bin.war de l'application web
INFOS: Deployment of web application archive C:\alfresco\tomcat\webapps\_vti_bin.war has finished in 517 ms
févr. 14, 2018 5:17:20 PM org.apache.catalina.startup.HostConfig deployDirectory
INFOS: Déploiement du répertoire C:\alfresco\tomcat\webapps\host-manager de l'application web
févr. 14, 2018 5:17:21 PM org.apache.catalina.startup.TldConfig execute
févr. 14, 2018 5:17:21 PM org.apache.catalina.startup.HostConfig deployDirectory
INFOS: Deployment of web application directory C:\alfresco\tomcat\webapps\host-manager has finished in 215 ms
INFOS: Déploiement du répertoire C:\alfresco\tomcat\webapps\manager de l'application web
INFOS: Deployment of web application directory C:\alfresco\tomcat\webapps\manager has finished in 185 ms
févr. 14, 2018 5:17:21 PM org.apache.coyote.AbstractProtocol start
INFOS: Starting ProtocolHandler ["http-apr-8080"]
INFOS: Starting ProtocolHandler ["ajp-apr-8009"]
INFOS: Starting ProtocolHandler ["http-bio-8443"]
févr. 14, 2018 5:17:21 PM org.apache.catalina.startup.Catalina start
INFOS: Server startup in 281588 ms
alfrescotomcat-stderr.2018-02-14:
2018-02-14 17:12:31 Commons Daemon procrun stderr initialized
a.util.concurrent.ThreadPoolExecutor$Worker.run(Unknown Source)
févr. 14, 2018 5:14:32 PM org.apache.catalina.core.StandardContext listenerStart
GRAVE: Exception lors de l'envoi de l'évènement contexte initialisé (context initialized) à l'instance de classe d'écoute (listener) org.alfresco.repo.webdav.WebDAVSessionListener
java.util.MissingResourceException: Can't find bundle for base name alfresco/module/content-tutorial-repo/messages/scModel, locale fr_FR
at java.util.ResourceBundle.throwMissingResourceException(Unknown Source)
at java.util.ResourceBundle.getBundleImpl(Unknown Source)
at java.util.ResourceBundle.getBundle(Unknown Source)
at org.springframework.extensions.surf.util.I18NUtil.getLocaleProperties(I18NUtil.java:468)
at org.springframework.extensions.surf.util.I18NUtil.getMessage(I18NUtil.java:352)
at org.springframework.extensions.surf.util.I18NUtil.getMessage(I18NUtil.java:382)
at org.springframework.extensions.surf.util.I18NUtil.getMessage(I18NUtil.java:369)
at org.alfresco.util.LogUtil.error(LogUtil.java:100)
at org.alfresco.repo.domain.schema.SchemaBootstrap.onBootstrap(SchemaBootstrap.java:1833)
at org.alfresco.repo.management.SafeApplicationEventMulticaster.multicastEventInternal(SafeApplicationEventMulticaster.java:214)
at org.alfresco.repo.management.SafeApplicationEventMulticaster.multicastEvent(SafeApplicationEventMulticaster.java:185)
at org.springframework.context.support.AbstractApplicationContext.publishEvent(AbstractApplicationContext.java:334)
at org.springframework.context.support.AbstractApplicationContext.finishRefresh(AbstractApplicationContext.java:954)
at org.springframework.context.support.AbstractApplicationContext.refresh(AbstractApplicationContext.java:482)
at org.springframework.web.context.ContextLoader.configureAndRefreshWebApplicationContext(ContextLoader.java:410)
at org.springframework.web.context.ContextLoader.initWebApplicationContext(ContextLoader.java:306)
at org.springframework.web.context.ContextLoaderListener.contextInitialized(ContextLoaderListener.java:112)
at org.alfresco.web.app.ContextLoaderListener.contextInitialized(ContextLoaderListener.java:70)
at org.apache.catalina.core.StandardContext.listenerStart(StandardContext.java:5110)
at org.apache.catalina.core.StandardContext.startInternal(StandardContext.java:5633)
at org.apache.catalina.util.LifecycleBase.start(LifecycleBase.java:145)
at org.apache.catalina.core.ContainerBase.addChildInternal(ContainerBase.java:1015)
at org.apache.catalina.core.ContainerBase.addChild(ContainerBase.java:991)
at org.apache.catalina.core.StandardHost.addChild(StandardHost.java:652)
at org.apache.catalina.startup.HostConfig.deployDescriptor(HostConfig.java:712)
at org.apache.catalina.startup.HostConfig$DeployDescriptor.run(HostConfig.java:2002)
at java.util.concurrent.Executors$RunnableAdapter.call(Unknown Source)
at java.util.concurrent.FutureTask.run(Unknown Source)
févr. 14, 2018 5:14:33 PM org.apache.catalina.core.ApplicationContext log
INFOS: Closing Spring root WebApplicationContext
févr. 14, 2018 5:14:34 PM org.apache.catalina.core.ApplicationContext log
INFOS: Shutting down log4j
févr. 14, 2018 5:16:12 PM org.apache.catalina.core.ApplicationContext log
INFOS: No Spring WebApplicationInitializer types detected on classpath
févr. 14, 2018 5:16:13 PM org.apache.catalina.core.ApplicationContext log
INFOS: Initializing Spring root WebApplicationContext
févr. 14, 2018 5:16:40 PM org.apache.catalina.core.ApplicationContext log
INFOS: org.tuckey.web.filters.urlrewrite.UrlRewriteFilter INFO: loaded (conf ok)
févr. 14, 2018 5:16:41 PM org.apache.catalina.core.ApplicationContext log
INFOS: Initializing Spring FrameworkServlet 'Spring Surf Dispatcher Servlet'
févr. 14, 2018 5:17:12 PM org.apache.catalina.core.ApplicationContext log
alfrescotomcat-stdout.2018-02-14
2018-02-14 17:12:31 Commons Daemon procrun stdout initialized
2018-02-14 17:14:04,470 INFO [alfresco.repo.admin] [localhost-startStop-1] Using database URL 'jdbcSmiley Tongueostgresql://localhost:5432/alfresco' with user 'alfresco'.
2018-02-14 17:14:04,495 INFO [alfresco.repo.admin] [localhost-startStop-1] Connected to database PostgreSQL version 9.4.12
2018-02-14 17:14:12,180 INFO [domain.schema.SchemaBootstrap] [localhost-startStop-1] Ignoring script patch (post-Hibernate): patch.db-V4.2-metadata-query-indexes
2018-02-14 17:14:12,181 INFO [domain.schema.SchemaBootstrap] [localhost-startStop-1] Ignoring script patch (post-Hibernate): patch.db-V5.1-metadata-query-indexes
2018-02-14 17:14:12,182 INFO [domain.schema.SchemaBootstrap] [localhost-startStop-1] Ignoring script patch (post-Hibernate): patch.db-V5.2-remove-jbpm-tables-from-db
2018-02-14 17:14:23,569 INFO [management.subsystems.ChildApplicationContextFactory] [localhost-startStop-1] Starting 'Authentication' subsystem, ID: [Authentication, managed, alfrescoNtlm1]
2018-02-14 17:14:23,964 INFO [management.subsystems.ChildApplicationContextFactory] [localhost-startStop-1] Startup of 'Authentication' subsystem, ID: [Authentication, managed, alfrescoNtlm1] complete
2018-02-14 17:14:28,768 INFO [extensions.webscripts.TemplateProcessorRegistry] [localhost-startStop-1] Registered template processor Repository Template Processor for extension ftl
2018-02-14 17:14:28,774 INFO [extensions.webscripts.ScriptProcessorRegistry] [localhost-startStop-1] Registered script processor Repository Script Processor for extension js
2018-02-14 17:14:32,617 INFO [management.subsystems.ChildApplicationContextFactory] [localhost-startStop-1] Starting 'ContentStore' subsystem, ID: [ContentStore, managed, unencrypted]
2018-02-14 17:14:32,685 INFO [management.subsystems.ChildApplicationContextFactory] [localhost-startStop-1] Startup of 'ContentStore' subsystem, ID: [ContentStore, managed, unencrypted] complete
2018-02-14 17:14:32,821 ERROR [web.context.ContextLoader] [localhost-startStop-1] Context initialization failed
2018-02-14 17:14:33,428 WARN [context.support.XmlWebApplicationContext] [localhost-startStop-1] Exception thrown from ApplicationListener handling ContextClosedEvent
at org.alfresco.repo.workflow.activiti.ActivitiEngineInitializer.onShutdown(ActivitiEngineInitializer.java:65)
at org.springframework.extensions.surf.util.AbstractLifecycleBean.onApplicationEvent(AbstractLifecycleBean.java:67)
at org.alfresco.repo.management.SafeApplicationEventMulticaster.multicastEvent(SafeApplicationEventMulticaster.java:190)
at org.springframework.context.support.AbstractApplicationContext.doClose(AbstractApplicationContext.java:1055)
at org.springframework.context.support.AbstractApplicationContext.close(AbstractApplicationContext.java:1016)
at org.springframework.web.context.ContextLoader.closeWebApplicationContext(ContextLoader.java:586)
at org.springframework.web.context.ContextLoaderListener.contextDestroyed(ContextLoaderListener.java:143)
at org.apache.catalina.core.StandardContext.listenerStop(StandardContext.java:5157)
at org.apache.catalina.core.StandardContext.stopInternal(StandardContext.java:5830)
at org.apache.catalina.util.LifecycleBase.stop(LifecycleBase.java:221)
at org.apache.catalina.util.LifecycleBase.start(LifecycleBase.java:149)
2018-02-14 17:14:33,744 INFO [management.subsystems.ChildApplicationContextFactory] [localhost-startStop-1] Stopping 'ContentStore' subsystem, ID: [ContentStore, managed, unencrypted]
2018-02-14 17:14:33,744 INFO [management.subsystems.ChildApplicationContextFactory] [localhost-startStop-1] Stopped 'ContentStore' subsystem, ID: [ContentStore, managed, unencrypted]
2018-02-14 17:14:34,143 INFO [management.subsystems.ChildApplicationContextFactory] [localhost-startStop-1] Stopping 'Authentication' subsystem, ID: [Authentication, managed, alfrescoNtlm1]
2018-02-14 17:14:34,143 INFO [management.subsystems.ChildApplicationContextFactory] [localhost-startStop-1] Stopped 'Authentication' subsystem, ID: [Authentication, managed, alfrescoNtlm1]
2018-02-14 17:16:27,340 INFO [config.packaging.ModulePackageManager] [localhost-startStop-1] Found 3 module package(s)
2018-02-14 17:16:27,352 INFO [config.packaging.ModulePackageManager] [localhost-startStop-1] content-tutorial-share Share Jar Module - SDK 3, 1.0-SNAPSHOT, Share JAR Module (to be included in the share.war) - SDK 3
Alfresco / Google Docs Share Module, 3.0.4.2, The Share side artifacts of the Alfresco / Google Docs Integration.
2018-02-14 17:16:28,265 INFO [extensions.webscripts.TemplateProcessorRegistry] [localhost-startStop-1] Registered template processor freemarker for extension ftl
2018-02-14 17:16:28,270 INFO [extensions.webscripts.ScriptProcessorRegistry] [localhost-startStop-1] Registered script processor javascript for extension js
2018-02-14 17:16:28,271 INFO [extensions.webscripts.TemplateProcessorRegistry] [localhost-startStop-1] Registered template processor freemarker for extension ftl
2018-02-14 17:16:28,273 INFO [extensions.webscripts.ScriptProcessorRegistry] [localhost-startStop-1] Registered script processor javascript for extension js
2018-02-14 17:16:40,162 INFO [extensions.webscripts.DeclarativeRegistry] [localhost-startStop-1] Registered 394 Web Scripts (+0 failed), 412 URLs
2018-02-14 17:16:40,163 INFO [extensions.webscripts.DeclarativeRegistry] [localhost-startStop-1] Registered 8 Package Description Documents (+0 failed)
2018-02-14 17:16:40,163 INFO [extensions.webscripts.DeclarativeRegistry] [localhost-startStop-1] Registered 0 Schema Description Documents (+0 failed)
2018-02-14 17:16:40,603 INFO [extensions.webscripts.AbstractRuntimeContainer] [localhost-startStop-1] Initialised Surf Container Web Script Container (in 12305.631ms)
2018-02-14 17:16:40,606 INFO [extensions.webscripts.TemplateProcessorRegistry] [localhost-startStop-1] Registered template processor freemarker for extension ftl
2018-02-14 17:16:40,607 INFO [extensions.webscripts.ScriptProcessorRegistry] [localhost-startStop-1] Registered script processor javascript for extension js
2018-02-14 17:17:19,542 INFO [solr.component.AsyncBuildSuggestComponent] [coreLoadExecutor-5-thread-1] Initializing SuggestComponent
2018-02-14 17:17:19,542 INFO [solr.component.AsyncBuildSuggestComponent] [coreLoadExecutor-5-thread-2] Initializing SuggestComponent
2018-02-14 17:17:19,841 INFO [solr.component.AsyncBuildSuggestComponent] [Suggestor-alfresco-1] Loading suggester index for: shingleBasedSuggestions
2018-02-14 17:17:19,950 INFO [solr.component.AsyncBuildSuggestComponent] [Suggestor-alfresco-1] Loaded suggester shingleBasedSuggestions, took 109 ms
2018-02-14 17:17:22,082 ERROR [solr.tracker.AbstractTracker] [org.alfresco.solr.AlfrescoCoreAdminHandler@32e203d6_Worker-1] Model tracking failed
org.alfresco.error.AlfrescoRuntimeException: 01140000 archive GetModelsDiff return status is 404
at org.alfresco.solr.client.SOLRAPIClient.getModelsDiff(SOLRAPIClient.java:1181)
at org.alfresco.solr.tracker.ModelTracker.trackModelsImpl(ModelTracker.java:248)
at org.alfresco.solr.tracker.ModelTracker.trackModels(ModelTracker.java:206)
at org.alfresco.solr.tracker.ModelTracker.ensureFirstModelSync(ModelTracker.java:228)
at org.alfresco.solr.tracker.CoreWatcherJob.registerForCore(CoreWatcherJob.java:145)
at org.alfresco.solr.tracker.CoreWatcherJob.execute(CoreWatcherJob.java:82)
2018-02-14 17:17:22,154 ERROR [solr.tracker.AbstractTracker] [org.alfresco.solr.AlfrescoCoreAdminHandler@32e203d6_Worker-1] Model tracking failed
org.alfresco.error.AlfrescoRuntimeException: 01140001 archive GetModelsDiff return status is 404
2018-02-14 17:17:30,046 ERROR [solr.tracker.AbstractTracker] [org.alfresco.solr.AlfrescoCoreAdminHandler@32e203d6_Worker-5] Model tracking failed
org.alfresco.error.AlfrescoRuntimeException: 01140004 archive GetModelsDiff return status is 404
at org.alfresco.solr.component.EnsureModelsComponent.prepare(EnsureModelsComponent.java:87)
at org.apache.solr.handler.component.AlfrescoSearchHandler.handleRequestBody(AlfrescoSearchHandler.java:292)
at org.apache.solr.handler.RequestHandlerBase.handleRequest(RequestHandlerBase.java:135)
at org.alfresco.solr.Cloud.getResponse(Cloud.java:165)
at org.alfresco.solr.Cloud.getSolrDocumentList(Cloud.java:149)
at org.alfresco.solr.SolrInformationServer.getDocsWithUncleanContent(SolrInformationServer.java:722)
at org.alfresco.solr.tracker.ContentTracker.doTrack(ContentTracker.java:76)
at org.alfresco.solr.tracker.AbstractTracker.track(AbstractTracker.java:179)
at org.alfresco.solr.tracker.TrackerJob.execute(TrackerJob.java:54)
2018-02-14 17:17:30,055 ERROR [solr.tracker.AbstractTracker] [org.alfresco.solr.AlfrescoCoreAdminHandler@32e203d6_Worker-2] Tracking failed
org.alfresco.error.AlfrescoRuntimeException: 01140002 archive GetModelsDiff return status is 404
at org.alfresco.solr.tracker.ModelTracker.doTrack(ModelTracker.java:166)
2018-02-14 17:17:30,064 ERROR [solr.tracker.AbstractTracker] [org.alfresco.solr.AlfrescoCoreAdminHandler@32e203d6_Worker-6] Model tracking failed
org.alfresco.error.AlfrescoRuntimeException: 01140005 archive GetModelsDiff return status is 404
2018-02-14 17:17:30,066 ERROR [solr.tracker.AbstractTracker] [org.alfresco.solr.AlfrescoCoreAdminHandler@32e203d6_Worker-4] Tracking failed
org.alfresco.error.AlfrescoRuntimeException: 01140003 api/solr/aclchangesets return status:404
at org.alfresco.solr.client.SOLRAPIClient.getAclChangeSets(SOLRAPIClient.java:169)
at org.alfresco.solr.tracker.AclTracker.checkRepoAndIndexConsistency(AclTracker.java:334)
at org.alfresco.solr.tracker.AclTracker.trackRepository(AclTracker.java:312)
at org.alfresco.solr.tracker.AclTracker.doTrack(AclTracker.java:103)
2018-02-14 17:17:30,099 ERROR [solr.tracker.AbstractTracker] [org.alfresco.solr.AlfrescoCoreAdminHandler@32e203d6_Worker-3] Tracking failed
org.alfresco.error.AlfrescoRuntimeException: 01140006 api/solr/aclchangesets return status:404
2018-02-14 17:17:38,264 INFO [web.site.EditionInterceptor] [http-apr-8080-exec-9] Unable to retrieve License information from Alfresco: 404
2018-02-14 17:17:45,065 ERROR [solr.tracker.AbstractTracker] [org.alfresco.solr.AlfrescoCoreAdminHandler@32e203d6_Worker-13] Model tracking failed
org.alfresco.error.AlfrescoRuntimeException: 01140009 archive GetModelsDiff return status is 404
2018-02-14 17:17:45,072 ERROR [solr.tracker.AbstractTracker] [org.alfresco.solr.AlfrescoCoreAdminHandler@32e203d6_Worker-12] Model tracking failed
org.alfresco.error.AlfrescoRuntimeException: 01140010 archive GetModelsDiff return status is 404
2018-02-14 17:17:45,097 ERROR [solr.tracker.AbstractTracker] [org.alfresco.solr.AlfrescoCoreAdminHandler@32e203d6_Worker-11] Tracking failed
org.alfresco.error.AlfrescoRuntimeException: 01140007 api/solr/aclchangesets return status:404
2018-02-14 17:17:45,108 ERROR [solr.tracker.AbstractTracker] [org.alfresco.solr.AlfrescoCoreAdminHandler@32e203d6_Worker-16] Tracking failed
org.alfresco.error.AlfrescoRuntimeException: 01140011 archive GetModelsDiff return status is 404
2018-02-14 17:17:45,117 ERROR [solr.tracker.AbstractTracker] [org.alfresco.solr.AlfrescoCoreAdminHandler@32e203d6_Worker-10] Tracking failed
org.alfresco.error.AlfrescoRuntimeException: 01140008 api/solr/aclchangesets return status:404
2018-02-14 17:18:00,014 ERROR [solr.tracker.AbstractTracker] [org.alfresco.solr.AlfrescoCoreAdminHandler@32e203d6_Worker-19] Model tracking failed
org.alfresco.error.AlfrescoRuntimeException: 01140014 archive GetModelsDiff return status is 404
2018-02-14 17:18:00,036 ERROR [solr.tracker.AbstractTracker] [org.alfresco.solr.AlfrescoCoreAdminHandler@32e203d6_Worker-18] Tracking failed
org.alfresco.error.AlfrescoRuntimeException: 01140012 api/solr/aclchangesets return status:404
2018-02-14 17:18:00,036 ERROR [solr.tracker.AbstractTracker] [org.alfresco.solr.AlfrescoCoreAdminHandler@32e203d6_Worker-17] Tracking failed
org.alfresco.error.AlfrescoRuntimeException: 01140013 api/solr/aclchangesets return status:404
2018-02-14 17:18:00,043 ERROR [solr.tracker.AbstractTracker] [org.alfresco.solr.AlfrescoCoreAdminHandler@32e203d6_Worker-20] Model tracking failed
org.alfresco.error.AlfrescoRuntimeException: 01140015 archive GetModelsDiff return status is 404
2018-02-14 17:18:00,055 ERROR [solr.tracker.AbstractTracker] [org.alfresco.solr.AlfrescoCoreAdminHandler@32e203d6_Worker-24] Tracking failed
org.alfresco.error.AlfrescoRuntimeException: 01140016 archive GetModelsDiff return status is 404
2018-02-14 17:18:15,050 ERROR [solr.tracker.AbstractTracker] [org.alfresco.solr.AlfrescoCoreAdminHandler@32e203d6_Worker-27] Model tracking failed
org.alfresco.error.AlfrescoRuntimeException: 01140018 archive GetModelsDiff return status is 404
2018-02-14 17:18:15,058 ERROR [solr.tracker.AbstractTracker] [org.alfresco.solr.AlfrescoCoreAdminHandler@32e203d6_Worker-25] Tracking failed
org.alfresco.error.AlfrescoRuntimeException: 01140017 api/solr/aclchangesets return status:404
2018-02-14 17:18:15,061 ERROR [solr.tracker.AbstractTracker] [org.alfresco.solr.AlfrescoCoreAdminHandler@32e203d6_Worker-26] Tracking failed
org.alfresco.error.AlfrescoRuntimeException: 01140019 api/solr/aclchangesets return status:404
2018-02-14 17:18:15,071 ERROR [solr.tracker.AbstractTracker] [org.alfresco.solr.AlfrescoCoreAdminHandler@32e203d6_Worker-28] Model tracking failed
org.alfresco.error.AlfrescoRuntimeException: 01140021 archive GetModelsDiff return status is 404
2018-02-14 17:18:15,073 ERROR [solr.tracker.AbstractTracker] [org.alfresco.solr.AlfrescoCoreAdminHandler@32e203d6_Worker-31] Tracking failed
org.alfresco.error.AlfrescoRuntimeException: 01140020 archive GetModelsDiff return status is 404
2018-02-14 17:18:30,007 ERROR [solr.tracker.AbstractTracker] [org.alfresco.solr.AlfrescoCoreAdminHandler@32e203d6_Worker-35] Model tracking failed
org.alfresco.error.AlfrescoRuntimeException: 01140023 archive GetModelsDiff return status is 404
2018-02-14 17:18:30,025 ERROR [solr.tracker.AbstractTracker] [org.alfresco.solr.AlfrescoCoreAdminHandler@32e203d6_Worker-34] Tracking failed
org.alfresco.error.AlfrescoRuntimeException: 01140024 api/solr/aclchangesets return status:404
2018-02-14 17:18:30,030 ERROR [solr.tracker.AbstractTracker] [org.alfresco.solr.AlfrescoCoreAdminHandler@32e203d6_Worker-33] Tracking failed
org.alfresco.error.AlfrescoRuntimeException: 01140022 api/solr/aclchangesets return status:404
2018-02-14 17:18:30,035 ERROR [solr.tracker.AbstractTracker] [org.alfresco.solr.AlfrescoCoreAdminHandler@32e203d6_Worker-36] Model tracking failed
org.alfresco.error.AlfrescoRuntimeException: 01140025 archive GetModelsDiff return status is 404
2018-02-14 17:18:30,054 ERROR [solr.tracker.AbstractTracker] [org.alfresco.solr.AlfrescoCoreAdminHandler@32e203d6_Worker-39] Tracking failed
org.alfresco.error.AlfrescoRuntimeException: 01140026 archive GetModelsDiff return status is 404
2018-02-14 17:18:45,016 ERROR [solr.tracker.AbstractTracker] [org.alfresco.solr.AlfrescoCoreAdminHandler@32e203d6_Worker-7] Model tracking failed
org.alfresco.error.AlfrescoRuntimeException: 01140029 archive GetModelsDiff return status is 404
2018-02-14 17:18:45,027 ERROR [solr.tracker.AbstractTracker] [org.alfresco.solr.AlfrescoCoreAdminHandler@32e203d6_Worker-8] Tracking failed
org.alfresco.error.AlfrescoRuntimeException: 01140027 api/solr/aclchangesets return status:404
2018-02-14 17:18:45,029 ERROR [solr.tracker.AbstractTracker] [org.alfresco.solr.AlfrescoCoreAdminHandler@32e203d6_Worker-1] Tracking failed
org.alfresco.error.AlfrescoRuntimeException: 01140028 api/solr/aclchangesets return status:404
2018-02-14 17:18:45,035 ERROR [solr.tracker.AbstractTracker] [org.alfresco.solr.AlfrescoCoreAdminHandler@32e203d6_Worker-2] Model tracking failed
org.alfresco.error.AlfrescoRuntimeException: 01140030 archive GetModelsDiff return status is 404
2018-02-14 17:18:45,048 ERROR [solr.tracker.AbstractTracker] [org.alfresco.solr.AlfrescoCoreAdminHandler@32e203d6_Worker-5] Tracking failed
org.alfresco.error.AlfrescoRuntimeException: 01140031 archive GetModelsDiff return status is 404
2018-02-14 17:19:00,024 ERROR [solr.tracker.AbstractTracker] [org.alfresco.solr.AlfrescoCoreAdminHandler@32e203d6_Worker-6] Tracking failed
org.alfresco.error.AlfrescoRuntimeException: 01140032 api/solr/aclchangesets return status:404
2018-02-14 17:19:00,033 ERROR [solr.tracker.AbstractTracker] [org.alfresco.solr.AlfrescoCoreAdminHandler@32e203d6_Worker-9] Tracking failed
org.alfresco.error.AlfrescoRuntimeException: 01140033 api/solr/aclchangesets return status:404
2018-02-14 17:19:00,039 ERROR [solr.tracker.AbstractTracker] [org.alfresco.solr.AlfrescoCoreAdminHandler@32e203d6_Worker-15] Model tracking failed
org.alfresco.error.AlfrescoRuntimeException: 01140034 archive GetModelsDiff return status is 404
2018-02-14 17:19:00,046 ERROR [solr.tracker.AbstractTracker] [org.alfresco.solr.AlfrescoCoreAdminHandler@32e203d6_Worker-14] Model tracking failed
org.alfresco.error.AlfrescoRuntimeException: 01140035 archive GetModelsDiff return status is 404
2018-02-14 17:19:00,056 ERROR [solr.tracker.AbstractTracker] [org.alfresco.solr.AlfrescoCoreAdminHandler@32e203d6_Worker-12] Tracking failed
org.alfresco.error.AlfrescoRuntimeException: 01140036 archive GetModelsDiff return status is 404
2018-02-14 17:19:15,016 ERROR [solr.tracker.AbstractTracker] [org.alfresco.solr.AlfrescoCoreAdminHandler@32e203d6_Worker-19] Model tracking failed
org.alfresco.error.AlfrescoRuntimeException: 01140039 archive GetModelsDiff return status is 404
2018-02-14 17:19:15,023 ERROR [solr.tracker.AbstractTracker] [org.alfresco.solr.AlfrescoCoreAdminHandler@32e203d6_Worker-10] Tracking failed
org.alfresco.error.AlfrescoRuntimeException: 01140037 api/solr/aclchangesets return status:404
2018-02-14 17:19:15,025 ERROR [solr.tracker.AbstractTracker] [org.alfresco.solr.AlfrescoCoreAdminHandler@32e203d6_Worker-21] Tracking failed
org.alfresco.error.AlfrescoRuntimeException: 01140038 api/solr/aclchangesets return status:404
2018-02-14 17:19:15,030 ERROR [solr.tracker.AbstractTracker] [org.alfresco.solr.AlfrescoCoreAdminHandler@32e203d6_Worker-18] Model tracking failed
org.alfresco.error.AlfrescoRuntimeException: 01140040 archive GetModelsDiff return status is 404
2018-02-14 17:19:15,045 ERROR [solr.tracker.AbstractTracker] [org.alfresco.solr.AlfrescoCoreAdminHandler@32e203d6_Worker-23] Tracking failed
org.alfresco.error.AlfrescoRuntimeException: 01140041 archive GetModelsDiff return status is 404
2018-02-14 17:19:30,008 ERROR [solr.tracker.AbstractTracker] [org.alfresco.solr.AlfrescoCoreAdminHandler@32e203d6_Worker-29] Model tracking failed
org.alfresco.error.AlfrescoRuntimeException: 01140044 archive GetModelsDiff return status is 404
2018-02-14 17:19:30,017 ERROR [solr.tracker.AbstractTracker] [org.alfresco.solr.AlfrescoCoreAdminHandler@32e203d6_Worker-27] Tracking failed
org.alfresco.error.AlfrescoRuntimeException: 01140043 api/solr/aclchangesets return status:404
2018-02-14 17:19:30,019 ERROR [solr.tracker.AbstractTracker] [org.alfresco.solr.AlfrescoCoreAdminHandler@32e203d6_Worker-24] Tracking failed
org.alfresco.error.AlfrescoRuntimeException: 01140042 api/solr/aclchangesets return status:404
2018-02-14 17:19:30,026 ERROR [solr.tracker.AbstractTracker] [org.alfresco.solr.AlfrescoCoreAdminHandler@32e203d6_Worker-25] Model tracking failed
org.alfresco.error.AlfrescoRuntimeException: 01140046 archive GetModelsDiff return status is 404
2018-02-14 17:19:30,029 ERROR [solr.tracker.AbstractTracker] [org.alfresco.solr.AlfrescoCoreAdminHandler@32e203d6_Worker-28] Tracking failed
org.alfresco.error.AlfrescoRuntimeException: 01140045 archive GetModelsDiff return status is 404
2018-02-14 17:19:45,023 ERROR [solr.tracker.AbstractTracker] [org.alfresco.solr.AlfrescoCoreAdminHandler@32e203d6_Worker-35] Tracking failed
org.alfresco.error.AlfrescoRuntimeException: 01140047 api/solr/aclchangesets return status:404
2018-02-14 17:19:45,025 ERROR [solr.tracker.AbstractTracker] [org.alfresco.solr.AlfrescoCoreAdminHandler@32e203d6_Worker-37] Model tracking failed
org.alfresco.error.AlfrescoRuntimeException: 01140049 archive GetModelsDiff return status is 404
2018-02-14 17:19:45,027 ERROR [solr.tracker.AbstractTracker] [org.alfresco.solr.AlfrescoCoreAdminHandler@32e203d6_Worker-32] Tracking failed
org.alfresco.error.AlfrescoRuntimeException: 01140048 api/solr/aclchangesets return status:404
2018-02-14 17:19:45,033 ERROR [solr.tracker.AbstractTracker] [org.alfresco.solr.AlfrescoCoreAdminHandler@32e203d6_Worker-36] Model tracking failed
org.alfresco.error.AlfrescoRuntimeException: 01140050 archive GetModelsDiff return status is 404
2018-02-14 17:19:45,046 ERROR [solr.tracker.AbstractTracker] [org.alfresco.solr.AlfrescoCoreAdminHandler@32e203d6_Worker-38] Tracking failed
org.alfresco.error.AlfrescoRuntimeException: 01140051 archive GetModelsDiff return status is 404
2018-02-14 17:20:00,018 ERROR [solr.tracker.AbstractTracker] [org.alfresco.solr.AlfrescoCoreAdminHandler@32e203d6_Worker-39] Tracking failed
org.alfresco.error.AlfrescoRuntimeException: 01140052 api/solr/aclchangesets return status:404
2018-02-14 17:20:00,029 ERROR [solr.tracker.AbstractTracker] [org.alfresco.solr.AlfrescoCoreAdminHandler@32e203d6_Worker-1] Model tracking failed
org.alfresco.error.AlfrescoRuntimeException: 01140055 archive GetModelsDiff return status is 404
2018-02-14 17:20:00,033 ERROR [solr.tracker.AbstractTracker] [org.alfresco.solr.AlfrescoCoreAdminHandler@32e203d6_Worker-8] Model tracking failed
org.alfresco.error.AlfrescoRuntimeException: 01140056 archive GetModelsDiff return status is 404
2018-02-14 17:20:00,037 ERROR [solr.tracker.AbstractTracker] [org.alfresco.solr.AlfrescoCoreAdminHandler@32e203d6_Worker-40] Tracking failed
org.alfresco.error.AlfrescoRuntimeException: 01140053 api/solr/aclchangesets return status:404
2018-02-14 17:20:00,045 ERROR [solr.tracker.AbstractTracker] [org.alfresco.solr.AlfrescoCoreAdminHandler@32e203d6_Worker-2] Tracking failed
org.alfresco.error.AlfrescoRuntimeException: 01140054 archive GetModelsDiff return status is 404
2018-02-14 17:20:15,011 ERROR [solr.tracker.AbstractTracker] [org.alfresco.solr.AlfrescoCoreAdminHandler@32e203d6_Worker-13] Model tracking failed
org.alfresco.error.AlfrescoRuntimeException: 01140059 archive GetModelsDiff return status is 404
2018-02-14 17:20:15,025 ERROR [solr.tracker.AbstractTracker] [org.alfresco.solr.AlfrescoCoreAdminHandler@32e203d6_Worker-6] Tracking failed
org.alfresco.error.AlfrescoRuntimeException: 01140058 api/solr/aclchangesets return status:404
2018-02-14 17:20:15,030 ERROR [solr.tracker.AbstractTracker] [org.alfresco.solr.AlfrescoCoreAdminHandler@32e203d6_Worker-5] Tracking failed
org.alfresco.error.AlfrescoRuntimeException: 01140057 api/solr/aclchangesets return status:404
2018-02-14 17:20:15,034 ERROR [solr.tracker.AbstractTracker] [org.alfresco.solr.AlfrescoCoreAdminHandler@32e203d6_Worker-11] Model tracking failed
org.alfresco.error.AlfrescoRuntimeException: 01140060 archive GetModelsDiff return status is 404
2018-02-14 17:20:15,049 ERROR [solr.tracker.AbstractTracker] [org.alfresco.solr.AlfrescoCoreAdminHandler@32e203d6_Worker-15] Tracking failed
org.alfresco.error.AlfrescoRuntimeException: 01140061 archive GetModelsDiff return status is 404
2018-02-14 17:20:30,013 ERROR [solr.tracker.AbstractTracker] [org.alfresco.solr.AlfrescoCoreAdminHandler@32e203d6_Worker-10] Model tracking failed
org.alfresco.error.AlfrescoRuntimeException: 01140063 archive GetModelsDiff return status is 404
2018-02-14 17:20:30,027 ERROR [solr.tracker.AbstractTracker] [org.alfresco.solr.AlfrescoCoreAdminHandler@32e203d6_Worker-12] Tracking failed
org.alfresco.error.AlfrescoRuntimeException: 01140062 api/solr/aclchangesets return status:404
2018-02-14 17:20:30,029 ERROR [solr.tracker.AbstractTracker] [org.alfresco.solr.AlfrescoCoreAdminHandler@32e203d6_Worker-19] Tracking failed
org.alfresco.error.AlfrescoRuntimeException: 01140064 api/solr/aclchangesets return status:404
2018-02-14 17:20:30,033 ERROR [solr.tracker.AbstractTracker] [org.alfresco.solr.AlfrescoCoreAdminHandler@32e203d6_Worker-17] Model tracking failed
org.alfresco.error.AlfrescoRuntimeException: 01140065 archive GetModelsDiff return status is 404
2018-02-14 17:20:30,047 ERROR [solr.tracker.AbstractTracker] [org.alfresco.solr.AlfrescoCoreAdminHandler@32e203d6_Worker-18] Tracking failed
org.alfresco.error.AlfrescoRuntimeException: 01140066 archive GetModelsDiff return status is 404
2018-02-14 17:20:45,006 ERROR [solr.tracker.AbstractTracker] [org.alfresco.solr.AlfrescoCoreAdminHandler@32e203d6_Worker-27] Model tracking failed
org.alfresco.error.AlfrescoRuntimeException: 01140069 archive GetModelsDiff return status is 404
2018-02-14 17:20:45,028 ERROR [solr.tracker.AbstractTracker] [org.alfresco.solr.AlfrescoCoreAdminHandler@32e203d6_Worker-20] Tracking failed
org.alfresco.error.AlfrescoRuntimeException: 01140067 api/solr/aclchangesets return status:404
2018-02-14 17:20:45,040 ERROR [solr.tracker.AbstractTracker] [org.alfresco.solr.AlfrescoCoreAdminHandler@32e203d6_Worker-26] Tracking failed
org.alfresco.error.AlfrescoRuntimeException: 01140068 api/solr/aclchangesets return status:404
2018-02-14 17:20:45,046 ERROR [solr.tracker.AbstractTracker] [org.alfresco.solr.AlfrescoCoreAdminHandler@32e203d6_Worker-30] Model tracking failed
org.alfresco.error.AlfrescoRuntimeException: 01140070 archive GetModelsDiff return status is 404
2018-02-14 17:20:45,058 ERROR [solr.tracker.AbstractTracker] [org.alfresco.solr.AlfrescoCoreAdminHandler@32e203d6_Worker-25] Tracking failed
org.alfresco.error.AlfrescoRuntimeException: 01140071 archive GetModelsDiff return status is 404
2018-02-14 17:21:00,022 ERROR [solr.tracker.AbstractTracker] [org.alfresco.solr.AlfrescoCoreAdminHandler@32e203d6_Worker-35] Model tracking failed
org.alfresco.error.AlfrescoRuntimeException: 01140074 archive GetModelsDiff return status is 404
2018-02-14 17:21:00,031 ERROR [solr.tracker.AbstractTracker] [org.alfresco.solr.AlfrescoCoreAdminHandler@32e203d6_Worker-28] Tracking failed
org.alfresco.error.AlfrescoRuntimeException: 01140072 api/solr/aclchangesets return status:404
2018-02-14 17:21:00,034 ERROR [solr.tracker.AbstractTracker] [org.alfresco.solr.AlfrescoCoreAdminHandler@32e203d6_Worker-31] Tracking failed
org.alfresco.error.AlfrescoRuntimeException: 01140073 api/solr/aclchangesets return status:404
2018-02-14 17:21:00,042 ERROR [solr.tracker.AbstractTracker] [org.alfresco.solr.AlfrescoCoreAdminHandler@32e203d6_Worker-37] Model tracking failed
org.alfresco.error.AlfrescoRuntimeException: 01140075 archive GetModelsDiff return status is 404
2018-02-14 17:21:00,056 ERROR [solr.tracker.AbstractTracker] [org.alfresco.solr.AlfrescoCoreAdminHandler@32e203d6_Worker-36] Tracking failed
org.alfresco.error.AlfrescoRuntimeException: 01140076 archive GetModelsDiff return status is 404
2018-02-14 17:21:15,014 ERROR [solr.tracker.AbstractTracker] [org.alfresco.solr.AlfrescoCoreAdminHandler@32e203d6_Worker-3] Model tracking failed
org.alfresco.error.AlfrescoRuntimeException: 01140079 archive GetModelsDiff return status is 404
2018-02-14 17:21:15,031 ERROR [solr.tracker.AbstractTracker] [org.alfresco.solr.AlfrescoCoreAdminHandler@32e203d6_Worker-38] Tracking failed
org.alfresco.error.AlfrescoRuntimeException: 01140078 api/solr/aclchangesets return status:404
2018-02-14 17:21:15,035 ERROR [solr.tracker.AbstractTracker] [org.alfresco.solr.AlfrescoCoreAdminHandler@32e203d6_Worker-7] Tracking failed
org.alfresco.error.AlfrescoRuntimeException: 01140077 api/solr/aclchangesets return status:404
2018-02-14 17:21:15,046 ERROR [solr.tracker.AbstractTracker] [org.alfresco.solr.AlfrescoCoreAdminHandler@32e203d6_Worker-4] Model tracking failed
org.alfresco.error.AlfrescoRuntimeException: 01140081 archive GetModelsDiff return status is 404
2018-02-14 17:21:15,048 ERROR [solr.tracker.AbstractTracker] [org.alfresco.solr.AlfrescoCoreAdminHandler@32e203d6_Worker-1] Tracking failed
org.alfresco.error.AlfrescoRuntimeException: 01140080 archive GetModelsDiff return status is 404
2018-02-14 17:21:30,005 ERROR [solr.tracker.AbstractTracker] [org.alfresco.solr.AlfrescoCoreAdminHandler@32e203d6_Worker-6] Model tracking failed
org.alfresco.error.AlfrescoRuntimeException: 01140083 archive GetModelsDiff return status is 404
2018-02-14 17:21:30,012 ERROR [solr.tracker.AbstractTracker] [org.alfresco.solr.AlfrescoCoreAdminHandler@32e203d6_Worker-5] Model tracking failed
org.alfresco.error.AlfrescoRuntimeException: 01140085 archive GetModelsDiff return status is 404
2018-02-14 17:21:30,014 ERROR [solr.tracker.AbstractTracker] [org.alfresco.solr.AlfrescoCoreAdminHandler@32e203d6_Worker-16] Tracking failed
org.alfresco.error.AlfrescoRuntimeException: 01140084 api/solr/aclchangesets return status:404
2018-02-14 17:21:30,013 ERROR [solr.tracker.AbstractTracker] [org.alfresco.solr.AlfrescoCoreAdminHandler@32e203d6_Worker-2] Tracking failed
org.alfresco.error.AlfrescoRuntimeException: 01140082 api/solr/aclchangesets return status:404
2018-02-14 17:21:30,026 ERROR [solr.tracker.AbstractTracker] [org.alfresco.solr.AlfrescoCoreAdminHandler@32e203d6_Worker-9] Tracking failed
org.alfresco.error.AlfrescoRuntimeException: 01140086 archive GetModelsDiff return status is 404
2018-02-14 17:21:45,020 ERROR [solr.tracker.AbstractTracker] [org.alfresco.solr.AlfrescoCoreAdminHandler@32e203d6_Worker-10] Model tracking failed
org.alfresco.error.AlfrescoRuntimeException: 01140089 archive GetModelsDiff return status is 404
2018-02-14 17:21:45,028 ERROR [solr.tracker.AbstractTracker] [org.alfresco.solr.AlfrescoCoreAdminHandler@32e203d6_Worker-14] Tracking failed
org.alfresco.error.AlfrescoRuntimeException: 01140088 api/solr/aclchangesets return status:404
2018-02-14 17:21:45,030 ERROR [solr.tracker.AbstractTracker] [org.alfresco.solr.AlfrescoCoreAdminHandler@32e203d6_Worker-12] Tracking failed
org.alfresco.error.AlfrescoRuntimeException: 01140087 api/solr/aclchangesets return status:404
2018-02-14 17:21:45,046 ERROR [solr.tracker.AbstractTracker] [org.alfresco.solr.AlfrescoCoreAdminHandler@32e203d6_Worker-17] Tracking failed
org.alfresco.error.AlfrescoRuntimeException: 01140090 archive GetModelsDiff return status is 404
2018-02-14 17:21:45,047 ERROR [solr.tracker.AbstractTracker] [org.alfresco.solr.AlfrescoCoreAdminHandler@32e203d6_Worker-22] Model tracking failed
org.alfresco.error.AlfrescoRuntimeException: 01140091 archive GetModelsDiff return status is 404
2018-02-14 17:22:00,008 ERROR [solr.tracker.AbstractTracker] [org.alfresco.solr.AlfrescoCoreAdminHandler@32e203d6_Worker-26] Model tracking failed
org.alfresco.error.AlfrescoRuntimeException: 01140093 archive GetModelsDiff return status is 404
2018-02-14 17:22:00,020 ERROR [solr.tracker.AbstractTracker] [org.alfresco.solr.AlfrescoCoreAdminHandler@32e203d6_Worker-23] Tracking failed
org.alfresco.error.AlfrescoRuntimeException: 01140092 api/solr/aclchangesets return status:404
2018-02-14 17:22:00,025 ERROR [solr.tracker.AbstractTracker] [org.alfresco.solr.AlfrescoCoreAdminHandler@32e203d6_Worker-27] Model tracking failed
org.alfresco.error.AlfrescoRuntimeException: 01140095 archive GetModelsDiff return status is 404
2018-02-14 17:22:00,034 ERROR [solr.tracker.AbstractTracker] [org.alfresco.solr.AlfrescoCoreAdminHandler@32e203d6_Worker-18] Tracking failed
org.alfresco.error.AlfrescoRuntimeException: 01140094 api/solr/aclchangesets return status:404
2018-02-14 17:22:00,044 ERROR [solr.tracker.AbstractTracker] [org.alfresco.solr.AlfrescoCoreAdminHandler@32e203d6_Worker-24] Tracking failed
org.alfresco.error.AlfrescoRuntimeException: 01140096 archive GetModelsDiff return status is 404
2018-02-14 17:22:15,008 ERROR [solr.tracker.AbstractTracker] [org.alfresco.solr.AlfrescoCoreAdminHandler@32e203d6_Worker-28] Model tracking failed
org.alfresco.error.AlfrescoRuntimeException: 01140099 archive GetModelsDiff return status is 404
2018-02-14 17:22:15,022 ERROR [solr.tracker.AbstractTracker] [org.alfresco.solr.AlfrescoCoreAdminHandler@32e203d6_Worker-25] Tracking failed
org.alfresco.error.AlfrescoRuntimeException: 01140098 api/solr/aclchangesets return status:404
2018-02-14 17:22:15,022 ERROR [solr.tracker.AbstractTracker] [org.alfresco.solr.AlfrescoCoreAdminHandler@32e203d6_Worker-31] Model tracking failed
org.alfresco.error.AlfrescoRuntimeException: 01140100 archive GetModelsDiff return status is 404
2018-02-14 17:22:15,034 ERROR [solr.tracker.AbstractTracker] [org.alfresco.solr.AlfrescoCoreAdminHandler@32e203d6_Worker-35] Tracking failed
org.alfresco.error.AlfrescoRuntimeException: 01140097 api/solr/aclchangesets return status:404
2018-02-14 17:22:15,046 ERROR [solr.tracker.AbstractTracker] [org.alfresco.solr.AlfrescoCoreAdminHandler@32e203d6_Worker-32] Tracking failed
org.alfresco.error.AlfrescoRuntimeException: 01140101 archive GetModelsDiff return status is 404
2018-02-14 17:22:30,008 ERROR [solr.tracker.AbstractTracker] [org.alfresco.solr.AlfrescoCoreAdminHandler@32e203d6_Worker-38] Model tracking failed
org.alfresco.error.AlfrescoRuntimeException: 01140103 archive GetModelsDiff return status is 404
2018-02-14 17:22:30,023 ERROR [solr.tracker.AbstractTracker] [org.alfresco.solr.AlfrescoCoreAdminHandler@32e203d6_Worker-36] Tracking failed
org.alfresco.error.AlfrescoRuntimeException: 01140102 api/solr/aclchangesets return status:404
2018-02-14 17:22:30,024 ERROR [solr.tracker.AbstractTracker] [org.alfresco.solr.AlfrescoCoreAdminHandler@32e203d6_Worker-3] Tracking failed
org.alfresco.error.AlfrescoRuntimeException: 01140104 api/solr/aclchangesets return status:404
2018-02-14 17:22:30,030 ERROR [solr.tracker.AbstractTracker] [org.alfresco.solr.AlfrescoCoreAdminHandler@32e203d6_Worker-39] Model tracking failed
org.alfresco.error.AlfrescoRuntimeException: 01140105 archive GetModelsDiff return status is 404
2018-02-14 17:22:30,044 ERROR [solr.tracker.AbstractTracker] [org.alfresco.solr.AlfrescoCoreAdminHandler@32e203d6_Worker-4] Tracking failed
org.alfresco.error.AlfrescoRuntimeException: 01140106 archive GetModelsDiff return status is 404
2018-02-14 17:22:45,018 ERROR [solr.tracker.AbstractTracker] [org.alfresco.solr.AlfrescoCoreAdminHandler@32e203d6_Worker-16] Model tracking failed
org.alfresco.error.AlfrescoRuntimeException: 01140108 archive GetModelsDiff return status is 404
2018-02-14 17:22:45,022 ERROR [solr.tracker.AbstractTracker] [org.alfresco.solr.AlfrescoCoreAdminHandler@32e203d6_Worker-13] Tracking failed
org.alfresco.error.AlfrescoRuntimeException: 01140107 api/solr/aclchangesets return status:404
2018-02-14 17:22:45,041 ERROR [solr.tracker.AbstractTracker] [org.alfresco.solr.AlfrescoCoreAdminHandler@32e203d6_Worker-6] Model tracking failed
org.alfresco.error.AlfrescoRuntimeException: 01140111 archive GetModelsDiff return status is 404
2018-02-14 17:22:45,044 ERROR [solr.tracker.AbstractTracker] [org.alfresco.solr.AlfrescoCoreAdminHandler@32e203d6_Worker-40] Tracking failed
org.alfresco.error.AlfrescoRuntimeException: 01140109 api/solr/aclchangesets return status:404
2018-02-14 17:22:45,046 ERROR [solr.tracker.AbstractTracker] [org.alfresco.solr.AlfrescoCoreAdminHandler@32e203d6_Worker-11] Tracking failed
org.alfresco.error.AlfrescoRuntimeException: 01140110 archive GetModelsDiff return status is 404
2018-02-14 17:23:00,008 ERROR [solr.tracker.AbstractTracker] [org.alfresco.solr.AlfrescoCoreAdminHandler@32e203d6_Worker-10] Model tracking failed
org.alfresco.error.AlfrescoRuntimeException: 01140114 archive GetModelsDiff return status is 404
2018-02-14 17:23:00,022 ERROR [solr.tracker.AbstractTracker] [org.alfresco.solr.AlfrescoCoreAdminHandler@32e203d6_Worker-15] Tracking failed
org.alfresco.error.AlfrescoRuntimeException: 01140113 api/solr/aclchangesets return status:404
2018-02-14 17:23:00,024 ERROR [solr.tracker.AbstractTracker] [org.alfresco.solr.AlfrescoCoreAdminHandler@32e203d6_Worker-9] Tracking failed
org.alfresco.error.AlfrescoRuntimeException: 01140112 api/solr/aclchangesets return status:404
2018-02-14 17:23:00,029 ERROR [solr.tracker.AbstractTracker] [org.alfresco.solr.AlfrescoCoreAdminHandler@32e203d6_Worker-19] Model tracking failed
org.alfresco.error.AlfrescoRuntimeException: 01140115 archive GetModelsDiff return status is 404
2018-02-14 17:23:00,045 ERROR [solr.tracker.AbstractTracker] [org.alfresco.solr.AlfrescoCoreAdminHandler@32e203d6_Worker-17] Tracking failed
org.alfresco.error.AlfrescoRuntimeException: 01140116 archive GetModelsDiff return status is 404
2018-02-14 17:23:15,010 ERROR [solr.tracker.AbstractTracker] [org.alfresco.solr.AlfrescoCoreAdminHandler@32e203d6_Worker-23] Model tracking failed
org.alfresco.error.AlfrescoRuntimeException: 01140119 archive GetModelsDiff return status is 404
2018-02-14 17:23:15,019 ERROR [solr.tracker.AbstractTracker] [org.alfresco.solr.AlfrescoCoreAdminHandler@32e203d6_Worker-30] Model tracking failed
org.alfresco.error.AlfrescoRuntimeException: 01140120 archive GetModelsDiff return status is 404
2018-02-14 17:23:15,020 ERROR [solr.tracker.AbstractTracker] [org.alfresco.solr.AlfrescoCoreAdminHandler@32e203d6_Worker-20] Tracking failed
org.alfresco.error.AlfrescoRuntimeException: 01140118 api/solr/aclchangesets return status:404
2018-02-14 17:23:15,022 ERROR [solr.tracker.AbstractTracker] [org.alfresco.solr.AlfrescoCoreAdminHandler@32e203d6_Worker-22] Tracking failed
org.alfresco.error.AlfrescoRuntimeException: 01140117 api/solr/aclchangesets return status:404
2018-02-14 17:23:15,037 ERROR [solr.tracker.AbstractTracker] [org.alfresco.solr.AlfrescoCoreAdminHandler@32e203d6_Worker-18] Tracking failed
org.alfresco.error.AlfrescoRuntimeException: 01140121 archive GetModelsDiff return status is 404
2018-02-14 17:23:30,005 ERROR [solr.tracker.AbstractTracker] [org.alfresco.solr.AlfrescoCoreAdminHandler@32e203d6_Worker-28] Model tracking failed
org.alfresco.error.AlfrescoRuntimeException: 01140122 archive GetModelsDiff return status is 404
2018-02-14 17:23:30,022 ERROR [solr.tracker.AbstractTracker] [org.alfresco.solr.AlfrescoCoreAdminHandler@32e203d6_Worker-25] Tracking failed
org.alfresco.error.AlfrescoRuntimeException: 01140123 api/solr/aclchangesets return status:404
2018-02-14 17:23:30,026 ERROR [solr.tracker.AbstractTracker] [org.alfresco.solr.AlfrescoCoreAdminHandler@32e203d6_Worker-34] Model tracking failed
org.alfresco.error.AlfrescoRuntimeException: 01140125 archive GetModelsDiff return status is 404
2018-02-14 17:23:30,027 ERROR [solr.tracker.AbstractTracker] [org.alfresco.solr.AlfrescoCoreAdminHandler@32e203d6_Worker-24] Tracking failed
org.alfresco.error.AlfrescoRuntimeException: 01140124 api/solr/aclchangesets return status:404
2018-02-14 17:23:30,044 ERROR [solr.tracker.AbstractTracker] [org.alfresco.solr.AlfrescoCoreAdminHandler@32e203d6_Worker-35] Tracking failed
org.alfresco.error.AlfrescoRuntimeException: 01140126 archive GetModelsDiff return status is 404
2018-02-14 17:23:45,008 ERROR [solr.tracker.AbstractTracker] [org.alfresco.solr.AlfrescoCoreAdminHandler@32e203d6_Worker-36] Model tracking failed
org.alfresco.error.AlfrescoRuntimeException: 01140128 archive GetModelsDiff return status is 404
2018-02-14 17:23:45,044 ERROR [solr.tracker.AbstractTracker] [org.alfresco.solr.AlfrescoCoreAdminHandler@32e203d6_Worker-38] Tracking failed
org.alfresco.error.AlfrescoRuntimeException: 01140129 api/solr/aclchangesets return status:404
2018-02-14 17:23:45,044 ERROR [solr.tracker.AbstractTracker] [org.alfresco.solr.AlfrescoCoreAdminHandler@32e203d6_Worker-33] Tracking failed
org.alfresco.error.AlfrescoRuntimeException: 01140127 api/solr/aclchangesets return status:404
2018-02-14 17:23:45,049 ERROR [solr.tracker.AbstractTracker] [org.alfresco.solr.AlfrescoCoreAdminHandler@32e203d6_Worker-3] Model tracking failed
org.alfresco.error.AlfrescoRuntimeException: 01140130 archive GetModelsDiff return status is 404
2018-02-14 17:23:45,061 ERROR [solr.tracker.AbstractTracker] [org.alfresco.solr.AlfrescoCoreAdminHandler@32e203d6_Worker-39] Tracking failed
org.alfresco.error.AlfrescoRuntimeException: 01140131 archive GetModelsDiff return status is 404
2018-02-14 17:24:00,018 ERROR [solr.tracker.AbstractTracker] [org.alfresco.solr.AlfrescoCoreAdminHandler@32e203d6_Worker-16] Model tracking failed
org.alfresco.error.AlfrescoRuntimeException: 01140134 archive GetModelsDiff return status is 404
2018-02-14 17:24:00,019 ERROR [solr.tracker.AbstractTracker] [org.alfresco.solr.AlfrescoCoreAdminHandler@32e203d6_Worker-4] Tracking failed
org.alfresco.error.AlfrescoRuntimeException: 01140132 api/solr/aclchangesets return status:404
2018-02-14 17:24:00,021 ERROR [solr.tracker.AbstractTracker] [org.alfresco.solr.AlfrescoCoreAdminHandler@32e203d6_Worker-1] Tracking failed
org.alfresco.error.AlfrescoRuntimeException: 01140133 api/solr/aclchangesets return status:404
2018-02-14 17:24:00,026 ERROR [solr.tracker.AbstractTracker] [org.alfresco.solr.AlfrescoCoreAdminHandler@32e203d6_Worker-5] Model tracking failed
org.alfresco.error.AlfrescoRuntimeException: 01140135 archive GetModelsDiff return status is 404
2018-02-14 17:24:00,044 ERROR [solr.tracker.AbstractTracker] [org.alfresco.solr.AlfrescoCoreAdminHandler@32e203d6_Worker-6] Tracking failed
org.alfresco.error.AlfrescoRuntimeException: 01140136 archive GetModelsDiff return status is 404
2018-02-14 17:24:15,006 ERROR [solr.tracker.AbstractTracker] [org.alfresco.solr.AlfrescoCoreAdminHandler@32e203d6_Worker-21] Model tracking failed
org.alfresco.error.AlfrescoRuntimeException: 01140138 archive GetModelsDiff return status is 404
2018-02-14 17:24:15,016 ERROR [solr.tracker.AbstractTracker] [org.alfresco.solr.AlfrescoCoreAdminHandler@32e203d6_Worker-9] Model tracking failed
org.alfresco.error.AlfrescoRuntimeException: 01140140 archive GetModelsDiff return status is 404
2018-02-14 17:24:15,022 ERROR [solr.tracker.AbstractTracker] [org.alfresco.solr.AlfrescoCoreAdminHandler@32e203d6_Worker-15] Tracking failed
org.alfresco.error.AlfrescoRuntimeException: 01140137 api/solr/aclchangesets return status:404
2018-02-14 17:24:15,022 ERROR [solr.tracker.AbstractTracker] [org.alfresco.solr.AlfrescoCoreAdminHandler@32e203d6_Worker-11] Tracking failed
org.alfresco.error.AlfrescoRuntimeException: 01140139 api/solr/aclchangesets return status:404
2018-02-14 17:24:15,036 ERROR [solr.tracker.AbstractTracker] [org.alfresco.solr.AlfrescoCoreAdminHandler@32e203d6_Worker-12] Tracking failed
org.alfresco.error.AlfrescoRuntimeException: 01140141 archive GetModelsDiff return status is 404
2018-02-14 17:24:30,012 ERROR [solr.tracker.AbstractTracker] [org.alfresco.solr.AlfrescoCoreAdminHandler@32e203d6_Worker-20] Model tracking failed
org.alfresco.error.AlfrescoRuntimeException: 01140144 archive GetModelsDiff return status is 404
2018-02-14 17:24:30,018 ERROR [solr.tracker.AbstractTracker] [org.alfresco.solr.AlfrescoCoreAdminHandler@32e203d6_Worker-17] Tracking failed
org.alfresco.error.AlfrescoRuntimeException: 01140142 api/solr/aclchangesets return status:404
2018-02-14 17:24:30,019 ERROR [solr.tracker.AbstractTracker] [org.alfresco.solr.AlfrescoCoreAdminHandler@32e203d6_Worker-30] Model tracking failed
org.alfresco.error.AlfrescoRuntimeException: 01140145 archive GetModelsDiff return status is 404
2018-02-14 17:24:30,021 ERROR [solr.tracker.AbstractTracker] [org.alfresco.solr.AlfrescoCoreAdminHandler@32e203d6_Worker-27] Tracking failed
org.alfresco.error.AlfrescoRuntimeException: 01140143 api/solr/aclchangesets return status:404
2018-02-14 17:24:30,036 ERROR [solr.tracker.AbstractTracker] [org.alfresco.solr.AlfrescoCoreAdminHandler@32e203d6_Worker-26] Tracking failed
org.alfresco.error.AlfrescoRuntimeException: 01140146 archive GetModelsDiff return status is 404
2018-02-14 17:24:45,007 ERROR [solr.tracker.AbstractTracker] [org.alfresco.solr.AlfrescoCoreAdminHandler@32e203d6_Worker-31] Model tracking failed
org.alfresco.error.AlfrescoRuntimeException: 01140148 archive GetModelsDiff return status is 404
2018-02-14 17:24:45,021 ERROR [solr.tracker.AbstractTracker] [org.alfresco.solr.AlfrescoCoreAdminHandler@32e203d6_Worker-25] Model tracking failed
org.alfresco.error.AlfrescoRuntimeException: 01140150 archive GetModelsDiff return status is 404
2018-02-14 17:24:45,026 ERROR [solr.tracker.AbstractTracker] [org.alfresco.solr.AlfrescoCoreAdminHandler@32e203d6_Worker-29] Tracking failed
org.alfresco.error.AlfrescoRuntimeException: 01140147 api/solr/aclchangesets return status:404
2018-02-14 17:24:45,026 ERROR [solr.tracker.AbstractTracker] [org.alfresco.solr.AlfrescoCoreAdminHandler@32e203d6_Worker-28] Tracking failed
org.alfresco.error.AlfrescoRuntimeException: 01140149 api/solr/aclchangesets return status:404
2018-02-14 17:24:45,041 ERROR [solr.tracker.AbstractTracker] [org.alfresco.solr.AlfrescoCoreAdminHandler@32e203d6_Worker-37] Tracking failed
org.alfresco.error.AlfrescoRuntimeException: 01140151 archive GetModelsDiff return status is 404
2018-02-14 17:25:00,021 ERROR [solr.tracker.AbstractTracker] [org.alfresco.solr.AlfrescoCoreAdminHandler@32e203d6_Worker-35] Tracking failed
org.alfresco.error.AlfrescoRuntimeException: 01140153 api/solr/aclchangesets return status:404
2018-02-14 17:25:00,023 ERROR [solr.tracker.AbstractTracker] [org.alfresco.solr.AlfrescoCoreAdminHandler@32e203d6_Worker-32] Tracking failed
org.alfresco.error.AlfrescoRuntimeException: 01140152 api/solr/aclchangesets return status:404
2018-02-14 17:25:00,027 ERROR [solr.tracker.AbstractTracker] [org.alfresco.solr.AlfrescoCoreAdminHandler@32e203d6_Worker-7] Model tracking failed
org.alfresco.error.AlfrescoRuntimeException: 01140154 archive GetModelsDiff return status is 404
2018-02-14 17:25:00,030 ERROR [solr.tracker.AbstractTracker] [org.alfresco.solr.AlfrescoCoreAdminHandler@32e203d6_Worker-38] Model tracking failed
org.alfresco.error.AlfrescoRuntimeException: 01140155 archive GetModelsDiff return status is 404
2018-02-14 17:25:00,043 ERROR [solr.tracker.AbstractTracker] [org.alfresco.solr.AlfrescoCoreAdminHandler@32e203d6_Worker-3] Tracking failed
org.alfresco.error.AlfrescoRuntimeException: 01140156 archive GetModelsDiff return status is 404
2018-02-14 17:25:15,010 ERROR [solr.tracker.AbstractTracker] [org.alfresco.solr.AlfrescoCoreAdminHandler@32e203d6_Worker-4] Model tracking failed
org.alfresco.error.AlfrescoRuntimeException: 01140157 archive GetModelsDiff return status is 404
2018-02-14 17:25:15,023 ERROR [solr.tracker.AbstractTracker] [org.alfresco.solr.AlfrescoCoreAdminHandler@32e203d6_Worker-16] Tracking failed
org.alfresco.error.AlfrescoRuntimeException: 01140158 api/solr/aclchangesets return status:404
2018-02-14 17:25:15,028 ERROR [solr.tracker.AbstractTracker] [org.alfresco.solr.AlfrescoCoreAdminHandler@32e203d6_Worker-1] Model tracking failed
org.alfresco.error.AlfrescoRuntimeException: 01140160 archive GetModelsDiff return status is 404
2018-02-14 17:25:15,029 ERROR [solr.tracker.AbstractTracker] [org.alfresco.solr.AlfrescoCoreAdminHandler@32e203d6_Worker-39] Tracking failed
org.alfresco.error.AlfrescoRuntimeException: 01140159 api/solr/aclchangesets return status:404
2018-02-14 17:25:15,044 ERROR [solr.tracker.AbstractTracker] [org.alfresco.solr.AlfrescoCoreAdminHandler@32e203d6_Worker-40] Tracking failed
org.alfresco.error.AlfrescoRuntimeException: 01140161 archive GetModelsDiff return status is 404
thanks
jpotts
World-Class Innovator
Thanks for reading the tutorial. I see this error message:
It is looking for a French properties bundle. Try copying scModel.properties to scModel_fr_FR.properties.
hi Jeff; it's an honor to be anwnsered by you
Try copying scModel.properties to scModel_fr_FR.properties : you mean to modify the name of the file from scModel.properties to scModel_fr_FR.properties???  this file :C:\Users\yahya\Desktop\p\content-tutorial-repo\src\main\resources\alfresco\module\content-tutorial-repo\messages  ???
afaust
Legendary Innovator
Legendary Innovator
No, not modifying it - he means copying the file into a 2nd one with the _fr suffix (the _fr_FR suffix is not really required). The reason for this issue is typically related to your server running in the French / a non-English locale, and due to some logic in the bootstrap, the initialisation tries to lookup the bundle for the default server locale.
I personally prefer running Alfresco servers in English locale which often avoids this kind of issue (locale-specific bundles should be optional after all) - this also provides error messages / log output that more people can work with,
Note that you can also attach log output as separate files on this platform, so your replies / messages remain short and easy to handle.
moez_khedher
thanks very much Axel and Jeff; that's work correctly now
-i have an other issue; when i generate the two projects repo and share with the console (with run.bat) it works fine and i connect to localhost:8081/share but when i close the console windows i cant connect again; how can i connect to alfresco share without regenerating again the two projects.
douglascrp
When you close the console, you are actually killing the maven process, that is why you can't connect anymore.
jpotts
Glad you got the locale problem straightened out.
Keep the two windows open long enough to do your testing/validation. Once that is done, if you want to everything to stay up you can build the artifacts and deploy them to an actual Tomcat server. Then you start up the Tomcat server and you can hit it from your clients.
If you are running on Windows you'll want to install Tomcat as a service.
