09-20-2019 03:48 AM
While uploading document to Alfresco Content services using CMIS we are passing Metadata as Alfresco Custom Properties along with it. All Custom propertis are being accepted and document content uploaded, but values for some custom properties are not being set. Their values are shown as none. For example custom properties such as string, DateTime and long are bein set along with their values, but Custom property value for int (integer) is not being set in ACS(value is shown as (None).
09-20-2019 06:36 AM
I have found solution and you can see it in source code I have sent in previous post. I converted C# property to type long instead of int and pass it to Alfresco property which is (in Alfresco Content service model) type of int.
09-20-2019 05:34 AM
Can you share some source code?
The description of your problem doesn't fit with any other issue related with CMIS I've heard of before...
09-20-2019 06:32 AM
public static AlfrescoSearchItem UploadDocument(string fileName, string filePath, string nodeName, SaveVersion version = null)
IDocument remoteDocument = null;
IOperationContext oc = session.CreateOperationContext();
oc.IncludeAcls = true;
IFolder folder = session.GetRootFolder(oc);
folder = (IFolder)session.GetObject(nodeName);
IDictionary<string, object> properties = new Dictionary<string, object>();
properties.Add(alfObjectType, $"D:{alfModelPrefix}:{alfModelType}");
properties.Add(PropertyIds.Name, fileName);
foreach (var prop in version.VersionProperties)
if (!(prop.Name == DMS.pathMetaData))
SetAlfrescoProperty(prop, properties);
ContentStream contentStream = new ContentStream();
contentStream.FileName = fileName;
contentStream.MimeType = System.Web.MimeMapping.GetMimeMapping(fileName);
contentStream.Stream = System.IO.File.OpenRead(filePath);
remoteDocument = folder.CreateDocument(properties, contentStream, null);
private static void SetAlfrescoProperty(VersionProperty prop, IDictionary<string, object> properties)
var alfrescoPropName = mappingProps.Where(x => x.CTXPropName == prop.Name).Select(x => x.AlfrescoPropName).FirstOrDefault();
var alfrescoPropType = mappingProps.Where(x => x.CTXPropName == prop.Name).Select(x => x.PropTypeName).FirstOrDefault();
switch (alfrescoPropType)
case "int":
long intConverted;
if (long.TryParse(prop.Value, out intConverted))
properties.Add(alfrescoPropName, intConverted);
else
var exc = new Exception($"Bad 'int' format in File property: {prop.Name} with value={prop.Value}");
exc.Data.Add(prop.Name.ToString(), prop.Value.ToString());
throw exc;
break;
case "float":
float floatConverted;
if (float.TryParse(prop.Value, out floatConverted))
properties.Add(alfrescoPropName, floatConverted);
else
var exc = new Exception($"Bad 'float' format in File property: {prop.Name} with value={prop.Value}");
throw exc;
break;
case "long":
long longConverted;
if (long.TryParse(prop.Value, out longConverted))
properties.Add(alfrescoPropName, longConverted);
else
var exc = new Exception($"Bad 'long' format in File property: {prop.Name} with value={prop.Value}");
throw exc;
break;
case "double":
double doubleConverted;
if (double.TryParse(prop.Value, out doubleConverted))
properties.Add(alfrescoPropName, doubleConverted);
else
var exc = new Exception($"Bad 'double' format in File property: {prop.Name} with value={prop.Value}");
throw exc;
break;
case "dateTime":
DateTime dateTimeconverted;
if (DateTime.TryParse(prop.Value, out dateTimeconverted))
properties.Add(alfrescoPropName, dateTimeconverted);
else
var exc = new Exception($"Bad 'DateTime' format in File property: {prop.Name} with value={prop.Value}");
throw exc;
break;
case "boolean":
bool boolConverted;
if (bool.TryParse(prop.Value, out boolConverted))
properties.Add(alfrescoPropName, boolConverted);
else
var exc = new Exception($"Bad 'boolean' format in File property: {prop.Name} with value={prop.Value}");
throw exc;
break;
default:
properties.Add(alfrescoPropName, prop.Value);
break;
09-20-2019 06:36 AM
